2R-8*6 SERIES
Gas Discharge Tube (GDT) Data Sheet
Features
■ Provide ultra-fast response to surge voltage from slow-rising
surge of 100V/s to rapid-rising surge of 1KV/μs
Stable breakdown voltage
High insulation resistance
Low capacitance (≤1.5pF)
High holdover voltage
Large absorbing transient current capability
Micro-Gap Design
Storage and operating temperature: -40℃ ~ +85℃
Meets MSL level 1, per J-STD-020
Safety certification: UL E244458
Applications
Repeaters, Modems
Telephone Interface, Line cards
Data communication equipment
Line test equipment
Part Number Code
2
8
R
Electrical
Characteristics
M: 10KA
P: 20KA
Electrode Numbers
2R: 2 Electrodes
Lead Type
L: Lead
M: SMD
DC
Spark-over
Voltage
Packing Code
B : Box package
TR: Tape & Reel package
Dimensions
8: 8.0mm×6.0mm
Ordering Code for different package in 2RMxxxL-8 and 2RPxxxL-8 series
Box package: Add suffix“/B”at the end of the part number, such as 2RM075L-8/B or 2RP075L-8/B
Tape & Reel package: Add suffix“/TR”at the end of the part number, such as 2RM075L-8/TR or
2RP075L-8/TR
Revision: GDT-2R-8*6 SERIES-001(A3)
2/7
http://brightking.pulseelectronics.com
2R-8*6 SERIES
Marking
: BritghtKing Logo
2RM090-8 : Device Marking Code
XXXX
: Internal Control Code
Dimensions
L Type
Dimension (mm)
Symbol
D
d
L
D
T
M Type
Spec.
Tolerance
D
8.0
+0.3, -0.5
T
6.0
+0.3, -0.5
d
0.8
±0.1
L
30.0
Max.
D
8.0
+0.3, -0.5
T
6.0
+0.3, -0.5
B
0.5
±0.1
6.0
8.0
B
D
T
1.5
Recommended Pad Size
Electrical Characteristics
Part
Number
DC
Spark-over
Voltage
Maximum
Impulse
Spark-over
Voltage
Nominal
Impulse
Discharge
Current
Alternating
Discharge
Current
Impulse
Life
100V/s
1000V/μs
8/20μs
10times
50Hz,1sec
10/1000μs
100A
Test
Voltage
(V)
(V)
(KA)
(A)
(times)
DC(V)
Minimum
Insulation
Resistance
(GΩ)
Maximum
Capacitance
1MHz
Device
Marking
Code
(pF)
2RM075L-8
2RM075M-8
75±20%
600
10
10
500
25
1.0
1.5
2RM075-8
2RM090L-8
2RM090M-8
90±20%
600
10
10
500
50
1.0
1.5
2RM090-8
2RM120L-8
2RM120M-8
120±20%
600
10
10
500
50
1.0
1.5
2RM120-8
2RM145L-8
2RM145M-8
145±20%
700
10
10
500
100
1.0
1.5
2RM145-8
2RM150L-8
2RM150M-8
150±20%
700
10
10
500
100
1.0
1.5
2RM150-8
2RM230L-8
2RM230M-8
230±20%
700
10
10
500
100
1.0
1.5
2RM230-8
2RM250L-8
2RM250M-8
250±20%
800
10
10
500
100
1.0
1.5
2RM250-8
2RM300L-8
2RM300M-8
300±20%
900
10
10
500
100
1.0
1.5
2RM300-8
2RM350L-8
2RM350M-8
350±20%
900
10
10
500
100
1.0
1.5
2RM350-8
2RM400L-8
2RM400M-8
400±20%
1000
10
10
500
100
1.0
1.5
2RM400-8
2RM470L-8
2RM470M-8
470±20%
1100
10
10
500
250
1.0
1.5
2RM470-8
2RM600L-8
2RM600M-8
600±20%
1300
10
10
500
250
1.0
1.5
2RM600-8
2RM800L-8
2RM800M-8
800±20%
1500
10
10
500
250
1.0
1.5
2RM800-8
3/7
2R-8*6 SERIES
Part
Number
DC
Spark-over
Voltage
Maximum
Impulse
Spark-over
Voltage
Nominal
Impulse
Discharge
Current
Alternating
Discharge
Current
Impulse
Life
100V/s
1000V/μs
8/20μs
10times
50Hz,1sec
10/1000μs
100A
Test
Voltage
(V)
(V)
(KA)
(A)
(times)
DC(V)
75±20%
600
25
1.0
1.5
2RP075-8
Minimum
Insulation
Resistance
Maximum
Capacitance
(GΩ)
1MHz
Device
Marking
Code
(pF)
2RP075L-8
2RP075M-8
2RP090L-8
2RP090M-8
90±20%
600
50
1.0
1.5
2RP090-8
2RP120L-8
2RP120M-8
120±20%
600
50
1.0
1.5
2RP120-8
2RP145L-8
2RP145M-8
145±20%
700
100
1.0
1.5
2RP145-8
2RP150L-8
2RP150M-8
150±20%
700
100
1.0
1.5
2RP150-8
2RP230L-8
2RP230M-8
230±20%
700
100
1.0
1.5
2RP230-8
2RP250L-8
2RP250M-8
250±20%
800
100
1.0
1.5
2RP250-8
2RP300L-8
2RP300M-8
300±20%
900
100
1.0
1.5
2RP300-8
2RP350L-8
2RP350M-8
350±20%
900
100
1.0
1.5
2RP350-8
2RP400L-8
2RP400M-8
400±20%
1000
100
1.0
1.5
2RP400-8
2RP470L-8
2RP470M-8
470±20%
1100
250
1.0
1.5
2RP470-8
2RP600L-8
2RP600M-8
600±20%
1300
250
1.0
1.5
2RP600-8
2RP800L-8
2RP800M-8
800±20%
1500
250
1.0
1.5
2RP800-8
Electrical Ratings
Items
DC Spark-over
Voltage
Maximum Impulse
Spark-over Voltage
Test Condition/Description
Requirement
The voltage is measured with voltage ramp dv/dt=100V/s.
The maximum impulse spark-over voltage is measured with voltage
ramp dv/dt=1000V/μs.
Maximum 8/20μs surge current that can be applied between two
electrodes, 5 positive and 5 negative surges, with 3 minutes interval
time.
Crest value
100
90
Current (%)
Impulse
Discharge Current
To meet
the specified
value
50
20µs
10
8µs
Time
Impulse Width
Alternating
Discharge Current
Insulation
Resistance
Capacitance
Rated RMS value of AC current at 50Hz, 1 sec. for 10 times with
interval time 3 min.
The resistance of gas tube shall be measured between two
electrodes.
The capacitance of gas tube shall be measured between two
electrodes. Test frequency: 1MHz
4/7
2R-8*6 SERIES
Recommended Soldering Conditions
Wave Soldering
300
Preheating
Maximum Wave 265℃
Soldering
Cooling
Temperature (℃)
250
200
150
100
50
1
1.5
2
2.5
Time (minutes)
3
3.5
Item
Conditions
Peak Temperature
265℃
Dipping Time
10 seconds
Soldering
1 time
4
Reflow Soldering
Critical Zone
TL to TP
tP
TP
Ramp-up
TL
tL
Temperature
TS max
TS min
Ramp-down
tS
Preheat
25
t 25℃ to Peak
Time
Profile Feature
Pb-Free Assembly
Average ramp-up rate (TL to TP)
Preheat
-Temperature Min (TS min)
-Temperature Max (TS max)
-Time (min to max) (ts)
TS max to TL
-Ramp-up Rate
Time maintained above:
-Temperature (TL)
-Time (tL)
3℃/second max.
150℃
200℃
60-180 seconds
3℃/second max.
217℃
60-150 seconds
Peak Temperature (TP)
260℃
Time within 5℃ of actual Peak Temperature (tP)
Ramp-down Rate
6℃/second max.
Time 25℃ to Peak Temperature
20-40 seconds
8 minutes max.
5/7
2R-8*6 SERIES
Packaging
Axial Packing (Box)
Skin packing
Dimension (mm)
Symbol
Spec.
Tolerance
A
265.0
±5.0
B
146.0
±5.0
H
8.5
±0.5
Quantity: 100pcs
Inner box
A0
270.0
±2.0
B0
150.0
±2.0
H0
50.0
±2.0
Quantity: 500pcs
Axial Packing (Tape & Reel)
Tape
Dimension (mm)
Symbol
Reel
Spec.
Tolerance
P
10.0
±0.5
W
65.0
±1.0
E
6.0
±0.5
F
26.5
±0.5
d
0.8
±0.1
A1
330.0
±2.0
B1
70.0
±2.0
C1
82.0
±2.0
D
25.0
±0.5
t
2.0
±0.2
Quantity: 500pcs
6/7
2R-8*6 SERIES
SMD Packing (Tape & Reel)
Tape
Dimension (mm)
Symbol
Reel
Spec.
Tolerance
W
16.00
±0.20
P0
4.00
±0.10
P1
12.00
±0.20
P2
2.00
±0.10
D0
1.55
±0.05
E
1.75
±0.10
F
7.50
±0.10
A0
8.20
±0.10
K0
8.50
±0.10
B0
7.50
±0.10
t0
0.50
±0.10
D
330.00
±2.00
d
13.00
±0.50
L
20.00
±2.00
t
2.00
±0.20
t
D
d
Quantity: 500pcs
L
7/7
很抱歉,暂时无法提供与“2RM150L-8”相匹配的价格&库存,您可以联系我们找货
