MM3Z3V0W
MM3Z3V0W
    JSMSEMI(杰盛微)
    SOD-323W
    硅平面齐纳二极管
MM3Z3V0W 数据手册
MM3Z2V0W THRU MM3Z75W Silicon Planar Zener Diodes SOD-323W FEATURES Total power dissipation: Max . 300mW . Wide zener reverse voltage range 2 .0V to 75V. Small plastic package suitable for surface mounted design . Tolerance approximately±5% MECHANICAL DATA Case: SOD-323W Weight: 5 .48mg Absolute Maximum Ratings And Characteristics (Ta = 25 °C) Symbol Value Unit Power Dissipation Ptot 300 mW Forward Voltage at IF = 10 mA VF 0.9 V RθJA 417 Tj , Tstg -55 ~ +150 °C/W Parameter Typical thermal resistance juncting to ambient Operating and Storage Temperature Range Fig. 1 Maximum Continuous Power Derating °C Fig .2 Typical Transient Thermal Impedance 2000 0.6 1000 0.5 0.4 0.3 100 0.2 0.1 0.0 25 50 75 100 125 150 175 Tc ,Case Temperature (°C) 10 0.01 0.1 1 10 100 t, Pulse Duration(sec) www.jsmsemi.com 第1/2页 MM3Z2V0W THRU MM3Z75W Silicon Planar Zener Diodes Characteristics at Ta = 25°C Dynamic Impedance Zener Voltage Range (20ms) Type VZT(at IZT) Marking Reverse Current IZT ZZT(at IZT) IR at VR Max (Ω) Max(μA) (V) Min(V) Nom(V) Max(V) (mA) 1.8 2.0 2.15 5 100 120 0.5 MM3Z2V0W B0 MM3Z2V2W C0 2.08 2.2 2.33 5 100 120 0.7 MM3Z2V4W 1C 2.28 2.4 2.56 5 100 120 1 MM3Z2V7W 1D 2.5 2.7 2.9 5 110 120 1 MM3Z3V0W 1E 2.8 3.0 3.2 5 120 50 1 MM3Z3V3W 1F 3.1 3.3 3.5 5 130 20 1 MM3Z3V6W 1H 3.4 3.6 3.8 5 130 10 1 MM3Z3V9W 1J 3.7 3.9 4.1 5 130 5 1 MM3Z4V3W 1K 4 4.3 4.6 5 130 5 1 MM3Z4V7W 1M 4.4 4.7 5 5 130 2 1 MM3Z5V1W 1N 4.8 5.1 5.4 5 130 2 1.5 MM3Z5V6W 1 2.5 1P 5.2 5.6 6 5 80 MM3Z6V2W 1R 5.8 6.2 6.6 5 50 1 3 MM3Z6V8W 1X 6.4 6.8 7.2 5 30 0.5 3.5 MM3Z7V5W 1Y 7 7.5 7.9 5 30 0.5 4 MM3Z8V2W 1Z 7.7 8.2 8.7 5 30 0.5 5 MM3Z9V1W 2A 8.5 9.1 9.6 5 30 0.5 6 MM3Z10W 2B 9.4 10 10.6 5 30 0.1 7 MM3Z11W 2C 10.4 11 11.6 5 30 0.1 8 MM3Z12W 2D 11.4 12 12.7 5 35 0.1 9 MM3Z13W 2E 12.4 13 14. 1 5 35 0.1 10 MM3Z15W 2F 13.8 15 15.6 5 40 0.1 11 MM3Z16W 2H 15.3 16 17. 1 5 40 0.1 12 MM3Z18W 2J 16.8 18 19. 1 5 45 0.1 13 MM3Z20W 2K 18.8 20 21.2 5 50 0.1 15 MM3Z22W 2M 20.8 22 23.3 5 55 0.1 17 MM3Z24W 2N 22.8 24 25.6 5 60 0.1 19 MM3Z27W 2P 25.1 27 28.9 2 70 0.1 21 MM3Z30W 2R 28 30 32 2 80 0.1 23 MM3Z33W 2X 31 33 35 2 80 0.1 25 MM3Z36W 2Y 34 36 38 2 90 0.1 27 MM3Z39W 2Z 37 39 41 2 100 0.1 30 MM3Z43W 3A 40 43 46 2 130 0.1 33 MM3Z47W 3B 44 47 50 2 150 0.1 36 MM3Z51W 3C 48 51 54 2 180 0.1 39 MM3Z56W 3D 52 56 60 2 200 0.1 43 MM3Z62W 3E 58 62 66 2 215 0.1 47 MM3Z68W 3F 64 68 72 2 240 0.1 52 MM3Z75W 3H 70 75 2 265 0.1 56 79 www.jsmsemi.com 第2/2页
MM3Z3V0W
物料型号:STC15F2K60S2 器件简介:STC15F2K60S2是一款8051内核单片机,具有2K字节的程序存储空间,128字节的RAM,2K字节的EEPROM,以及多种外设接口。
引脚分配:共有44个引脚,包括电源引脚、地引脚、I/O引脚、串口通信引脚、晶振引脚等。
参数特性:工作电压为2.3V至5.5V,工作频率为12T/1T,具有看门狗定时器、低功耗模式等。
功能详解:支持ISP编程、IAP编程、EEPROM自编程、SPI/I2C通信、定时器/计数器、中断、PWM等功能。
应用信息:适用于工业控制、智能家居、消费电子等领域。
封装信息:封装形式为LQFP44。
MM3Z3V0W 价格&库存
很抱歉,暂时无法提供与“MM3Z3V0W”相匹配的价格&库存,您可以联系我们找货
