UDT26A05L05-LC1
UDT26A05L05-LC1
    BRIGHTKING(君耀)
    SOT23-6L
    SOT23 VRWM:5V -55~+150℃ 贴片
UDT26A05L05-LC1 数据手册
UDT26A05L05-LC1 Electrostatic Discharged Protection Devices (ESD) Data Sheet Description UDT26A05L05-LC1 is surge rated diode arrays designed to protect high speed data interfaces. It has been specifically designed to protect sensitive components which is connected to data and transmission lines from overvoltage caused by electrostatic discharge (ESD), electrical fast transients (EFT), and lightning. The unique design of the device incorporates one surge rated, and four data lines. Low capacitance steering diodes and a TVS diode in a single package. The low capacitance array configuration allows the user to protect four high speed data or transmission lines. Features ● ● ● ● ● ● ● ● ● ● ● ● ● IEC61000-4-2 ESD 25KV Air, ±20KV contact compliance SOT23-6L surface mount package Protects four high-speed data lines and one power line Array of surge rated, low capacitance diodes Working voltage: 5V Low leakage current Low clamping voltage Solid-state silicon avalanche technology RoHS compliant Solder reflow temperature: Pure Tin-Sn, 260~270℃ Flammability rating UL 94V-0 Meets MSL level 1, per J-STD-020 Marking: B 05B 6 5 4 1 2 3 Pin Configuration Applications ● ● ● ● USB power and data line protection 10/100/1000 Ethernet Video line protection I2C bus protection ● ● ● ● WAN/LAN equipment ISDN S/T interface Microcontroller input protection Portable electronics Maximum Ratings Rating Symbol ESD voltage (Contact discharge) Value Unit ±20 VESD ESD voltage (Air discharge) Storage & operating temperature range Revision:ESD-UDT26A05L05-LC1-001(A3) kV ±25 TSTG ,TJ 1/6 -55~+150 ℃ httpbrightking.yageo.com UDT26A05L05-LC1 Electrical Characteristics (TJ=25℃) Parameter Symbol Reverse stand-off voltage Condition Min. Typ. VRWM Reverse breakdown voltage VBR Reverse leakage current IR Clamping voltage (tp=8/20μs) VC Clamping voltage (tp=8/20μs) VC Peak pulse current (tp=8/20μs) IPP Off state junction capacitance (0Vdc,f=1MHz) CJ IBR=1mA Unit 5 V 6 V VR=5V each I/O pin IPP=1A Line to Ground IPP=4A Line to Ground Between I/O pins and GND Max. 1 μA 9.8 V 14 V 4 A 0.8 pF Applications Information DVI connector Tx0- Rx0- Tx0+ Rx0+ X X Tx1- Rx1- Tx1+ Rx1+ Tx2- Rx2- Tx2+ Rx2+ X X TCTC+ RCUDT26A05L05-LC1 RC+ DVI Data Line Protection Revision:ESD-UDT26A05L05-LC1-001(A3) 2/6 httpbrightking.yageo.com UDT26A05L05-LC1 ESD Protection Standards IEC61000-4-2 Interfaces of consumer electronic equipment are widely specified according to the International Electrotechnical Commission standard IEC61000-4-2. This standard is not targeted towards particular devices but towards general equipment, systems and subsystems that may be involved in electrostatic discharge. consists of a 150pF capacitor and a 330Ω series resistor representing the counterpart to the Device Under Test (DUT). IPP 100% 330Ω 50MΩ to 100MΩ v high-voltage generator 90% DUT 150pF 10% 001aaf202 t tr=0.7ns to 1ns Test circuit according IEC61000-4-2 30ns 60ns ESD surge according IEC61000-4-2 Human Body Model (HBM, MIL-883E method 3015.7) The HBM standard simulates an ESD surge generated by human contact to electronic components. IPP 1.5kΩ 10MΩ to 100MΩ Ir
UDT26A05L05-LC1 价格&库存
很抱歉,暂时无法提供与“UDT26A05L05-LC1”相匹配的价格&库存,您可以联系我们找货
UDT26A05L05-LC1
  • 1+0.29000
  • 100+0.23000
  • 300+0.20000
  • 3000+0.18500
库存:5578
