MCS0530-4R7MN2
MCS0530-4R7MN2
    PSA(信昌电陶)
    功率电感 4.7µH ±20% 50mΩ 0530
MCS0530-4R7MN2 数据手册
SPECIFICATION FOR APPROVAL CUSTOMER CUST. PART NO. CUST. DOC. REV. DESCRIPTION SAMPLE LOT NO. PART NO. DOC. REV. DATE HIGH CURRENT POWER CHOKE(ROHS+H.F) S201809-0056 MCS0530-XXXMN2 ORIG 9/18/’18 Once you approve this part, please sign and return this page to the following marked location. Customer Signature:___________________ Date:_________________ □This part currently development section. □Production line can produce this series of products. ■Sales Office-Headquarter No. 566-1, Kao-Shi Rd., Yangmei, Taoyuan 32668, Taiwan TEL: +886-3-475-3355 FAX: +886-3-485-4959 □Yong Zhou Plant Tao-Yuan Rd., Fenghuang Park, Lengshuitan District, Yongzhou, Hunan 425000, P.R.C. TEL: +86-746-8610-180 FAX: +86-746-8610-181 □Sales Office-Dong Guan,China No.638,Mei Jing West Road Xiniupo Administrative Zone Dalang Town,Dong Guan City,GuangDong Province,China. TEL: +86-769-8555-0979 FAX: +86-769-8555-0972 TESTED BY CHECKED BY APPROVED BY Zhikai Deng Tieqiao Gong Shengjun Zhou PROSPERITY DIELECTRICS CO., LTD. TABLE OF CONTENTS INDEX Page ■ Engineering Change Notice - Record ………………………. 2 ■ Product Identification ………….…………….…………………. 3 ■ Product Dimension 3 ……….…………….……………………. ■ Marking and Date code ….…………….……………………... 3 ■ Electrical Spec. ……………………………………………...…… 4 ■ Reliability Performance ………………………………………. 5 …………………………………………………….. 6 ■ Package Form ……………………………………………………. 7 ■ Reflow Chart ■ Test Report ……………………………………………………….. Rev.D . P1 .Prosperity Dielectrics Co., Ltd. SPECIFICATION FOR APPROVAL CUSTOMER P/N CUSTOMER REV. SPL. LOT NO. S201809-0056 - PART NAME PART NO. HIGH CURRENT POWER CHOKE(ROHS+H.F) REV. MCS0530-XXXMN2 DATE OF ISSUE ORIG Q'TY 9/18/’18 0 PCS ENGINEERING CHANGE NOTICE - RECORD REVISION NO. ORIG Rev.D REVISION DESCRIPTION P2 Prosperity Dielectrics Co., Ltd. AUTHOR DATE Zhikai Deng 9/18/’18 REMARK SPECIFICATION FOR APPROVAL ※This is a RoHS and REACH compliant product whose related documents are available on request. ※Graphic is only for dimensionally application. 1. PRODUCT IDENTIFICATION 2. PRODUCT DIMENSION UNIT: 3. MARKING AND DATE CODE Marking ex:2.2uH 2R2 Rev.D P3 Prosperity Dielectrics Co., Ltd. mm DIM. TOL. M1 5.4 ±0.3 M2 5.2 ±0.3 M3 3.0 Max M4 2.2 ±0.3 M5 1.2 ±0.2 SPECIFICATION FOR APPROVAL 4. ELECTRICAL SPEC. PART NO. MCS0530-R20MN2 MCS0530-R47MN2 MCS0530-R68MN2 MCS0530-1R0MN2 MCS0530-1R2MN2 MCS0530-1R5MN2 MCS0530-2R2MN2 MCS0530-3R3MN2 MCS0530-4R7MN2 MCS0530-6R8MN2 MCS0530-100MN2 Inductance (uH)±20% 0.20 0.47 0.68 1.0 1.2 1.5 2.2 3.3 4.7 6.8 10 DCR mΩ Typical 25℃ 3.5 7.4 11 13 15 20 25 32 50 75 110 DCR mΩ MAX.25℃ 3.9 8.5 12 14 16 25 29 38 60 90 125 Rated Current Typical (A) 18.0 13.5 8.5 7.0 6.5 6.0 5.5 5.0 3.5 3.0 2.5 I sat Typical (A) 14.5 12.0 14.0 11.0 11.0 8.5 7.5 6.0 5.0 4.0 3.5 TEST INSTRUMENT: CHROMA 16502 、Zentech1320+Zentech3305 (1). Test Freq : 100KHz , 0.5V (2). All test data is referenced to 25℃ ambient. (3). Operating Temperature Range -55℃ to +125℃. (4). Rated Current: DC current(A)that will cause an approximate△T of 40℃. (5). I sat: DC current(A)that will cause Lo to drop approximately 30%. (6). The part temperature(ambient +temp rise)should not exceed 125℃ under worst case operating conditions. Circuit design, component placement, PWB trace size and thickness, airflow and other cooling provisions all affect the part temperature Part temperature should be verified Rev.D P4 Prosperity Dielectrics Co., Ltd. SPECIFICATION FOR APPROVAL 5. RELIABILITY PERFORMANCE Reliability Experiment For Electrical Test Item Test Condition Standard Source Humidity Test +40℃± 2℃, humidity of 90% ± 5% (total 96 hours). MIL-STD-202G Method 103B Test Condition B High Temperature Test 1.Temperature: +125℃±2℃ 2.Test time: 48±2hrs IEC 68-2 Test Condition B Low Temperature Test 1.Temperature: -40℃±2℃ 2.Test time: 48±2hrs IEC 68-2 Test Condition A Thermal Shock +125℃±5℃ (30 minutes) ~ -40 ± 5℃ (30 minutes), temperature switch time: 5 minutes (total 50 cycles). MIL-STD-202G Method 107G Test Condition B-2 Life Test +70℃±5℃ (250Hours) MIL-STD-202G Method 108A Test Condition B Reliability Experiment For Physical Test Item Test Condition Standard Source Vibration Test 10-55-10HZ, amplitude: 1.5mm, direction: X, Y, Z axes, each axis 2 hours (total 6 hours). MIL-STD-202G Method 201A Solder Heat Resistance Test IR/convection reflow:Peak Temp 260±5℃ for 30Sec in air, Through 2 Cycle. Temperature Ramp:+1~4°C/sec; Above 217°C, must keep 90 s - 120 s. J-STD-020D Classification Reflow Profiles Solder Ability Test Soak in 245 ℃ solder pot of 3Sec, PAD must have 95% above coverage. J-STD-003B Rev.D P5 Prosperity Dielectrics Co., Ltd. SPECIFICATION FOR APPROVAL 6. TYPICAL RoHS REFLOW PROFILE Rev.D P6 Prosperity Dielectrics Co., Ltd. SPECIFICATION FOR APPROVAL 7. PACKAGING THE FORCE FOR TEARING OFF 130 GRAMS IN THE ARROW THICKNESS (t) 0.10 MAX 165 TO 180° TOP COVER TAPE EMBOSSED CAVITY BASE TAPE EMBOSSED CARRIER START END NO COMPONENTS NO COMPONENTS COMPONENTS 160 (mm) MIN MIN. 390 (mm) MAX. 560 (mm) COVER TAPE USER DIRECTION OF FEED DIMENSIONS OF CARRIER TAPE (mm) CARRIER TAPE REELS (mm) MATERIAL: PLASTIC E 2.0±0.1 4.0±0.1 1.75±0.1 A B 1.5 +0.1-0 W N C P C ※ 10 sprocket hole pitch cumulative tolerance ±0.20 2000 Parts per Reel UNIT : mm Rev.D A B C E N P W t A0 B0 K0 DIM. 330 25.0 13.0 12.5 100 8.0 12.0 0.4 5.7 5.9 3.6 TOL. 0.2 0.5 0.5 0.5 MIN 0.1 0.3 0.05 0.1 0.1 0.1 P7 Prosperity Dielectrics Co., Ltd.
MCS0530-4R7MN2 价格&库存
很抱歉,暂时无法提供与“MCS0530-4R7MN2”相匹配的价格&库存,您可以联系我们找货
MCS0530-4R7MN2
  • 5+0.53448
  • 20+0.48732
  • 100+0.44016
  • 500+0.39300
  • 1000+0.37099
  • 2000+0.35527
