MMBZ Series
Dual Common Anode Zener TVS
3
Features
Allows Either Two Separate Unidirectional
Configuations or a Single Bidirectional Configuations.
Low Leakage Current.
24-40 Watts Peak Power Protection.
Excellent Clamping Capability.
ESD Rating of Class N(exceeding 16KV)per the Human
Body Model.
Transient Voltage Suppressors Encapsulated in a SOT-23 Package.
2
1
■ Simplified outline(SOT-23)
3
MI
JS
1
2
O
CR
Mechanical Data
Characteristics
nd
co
Absolute Maximum Ratings Ta = 25
mi
Se
Case: Molded Epoxy
Marking: Marking Code
Maximum Case Temperature for Soldering Purpose: 260 C for 10 sec.
Weight: 0.008grams(approx.)
Symbol
Total Power Dissipation on Alumina Substrate (3)@ TA =25 C
Derate above 25 C
Thermal Resistance Junction-to-Ambient
Junction and Storage Temperature Range
Lead Solder Temperature-Maximum(10 Second Duration)
PD
R θJA
PD
R θJA
TJ ,TSTG
TL
W
24
40
225
1.8
556
300
2.4
417
mW
mW/ C
C/W
mW
mW/ C
C/W
-55 to +150
C
260
C
r
to
Total Power Dissipation on FR-5 Board (2) @ TA =25 C
Derate above 25 C
P PK
uc
_ 25 C (1)
Peak Power Dissipation @ 1.0 ms @ TL <
MMBZ5V6A thru MMBZ10VA
MMBZ12VA thru MMBZ33VA
Value
_
_
_
_
NOTE: 1. Non-Repetitive Current Pulse, per FIG 5 and Derated above TA =25 C per FIG 6.
2. FR-5=1.0 _ 0.75 _ 0.62 in.
3. Alumina=0.4 _ 0.3 _ 0.024m, 99.5% alumina
www.jsmsemi.com
第1/5页
MMBZ Series
ELECTRICALCHARACTERISTICS (TA = 25 C unless otherwise noted)
UNIDIRECTIONAL (Circuit tied to Pins 1 and 3 or Pins 2 and 3)
(V F = 0.9 V Max @ IF = 10 mA)
24 WATTS
MMBZ5V6A
MMBZ6V2A
MMBZ6V8A
MMB Z10V A
mA
IPP
Ω
Ω
mA
V
A
θVBR
mV/ C
1600
0.25
8.0
3.0
1.26
1.0
8.7
2.76
2.80
1.0
9.6
2.5
3.4
9.56
1.0
14
1.7
7.5
10.5
1.0
14.2
1.7
7.5
Volts
uA
Min
Nom
Max
5A6
3.0
5.0
5.32
5.6
5.88
6A2
3.0
0.5
5.89
6.2
6.51
6A8
4.5
0.5
6.46
6.8
7.14
9A1
6.0
0.3
8.65
9.1
10A
6.5
0.3
9.50
10
mi
Se
ZZT
@ I ZT
VC
VRWM
O
CR
MMBZ9V1A
@ IT
(6)
ZZK @ I ZK
VBR (4) (V)
Device
Marking
MI
JS
Device
IR @
VRWM
VC @ I P P
Max Zener
Impedance (5)
Breakdown Voltage
@ IT
Min
Max
mA
V
A
12.60
1.0
17
2.35
7.5
15.75
1.0
21
1.9
12.3
18.90
1.0
25
1.6
15.3
21.00
1.0
28
1.4
17.2
40
1.0
24.3
46
0.87
30.4
40 WATTS
VRWM
IR @
VRWM
Volts
nA
VC @ I PP(6)
Breakdown Voltage
VBR (4) (V)
MMBZ12VA
12A
8.5
200
11.40
12
MMBZ15VA
15A
12
50
14.25
15
MMBZ18VA
18A
14.5
50
17.10
18
MMBZ20VA
20A
17
50
19.00
MMBZ27VA
27A
22
50
25.65
27
28.35
1.0
MMBZ33VA
33A
26
50
31.35
33
34.65
1.0
Nom
VC
IPP
θVBR
mV/ C
r
to
uc
nd
co
Device
Device
Marking
4. V B R measured at pulse test current I T at an ambient temperature of 25 C .
5. Z ZT and Z ZK are measured by dividing the AC voltage drop across the device by the AC current applied. T he specified limits are for I Z(AC )
= 0.1 I Z(DC ) , with the AC frequency = 1.0 kHz.
6. S urge current waveform per F ig 5 and derate per F ig 6
www.jsmsemi.com
第2/5页
MMBZ Series
Electrical Characteristics
(TA =25 C unless otherwise noted)
UNIDIRECTIONAL (Circuit tied to Pins 1 and 3 or 2 and 3)
Symbol
I PP
Parameter
I
Maximum Reverse Peak Pulse Current
Clamping Voltage @ I PP
VC
VRWM
IF
MI
JS
Working Peak Reverse Votlage
Maximum Reverse Leakage Current @ VRWM
IR
θ VBR
VC VBR VR WM
Breakdown Voltage @ I T
IT
Test Current
Maximum Temperature Coef ficient of VBR
O
CR
VBR
IF
Forward Current
VF
Forward Voltage @ I F
ZZT
Maximum Zener Impedance @ I ZT
I ZK
Reverse Current
ZZK
Maximum Zener Impedance @ I ZK
IP P
Uni-Directional TVS
nd
co
mi
Se
1000
18
100
I R (nA)
12
9
10
1
6
0.1
3
+100
+150
0.01
-40
TEMPERATURE( C)
r
to
VBR @ IT
15
uc
BREAKDOWN VOLTAGE(V)
V
IR V F
IT
+25
+85
+125
TEMPERATURE( C)
FIG.1 Typical Breakdown Voltage
Versus Temperature
FIG.2 Typical Leakage Current
Versus Temperature
(Upper curve for each voltage is bidirectional mode,)
lower curve is undirectional mode)
www.jsmsemi.com
第3/5页
MMBZ Series
320
PD , POWER DISSIPATION(mW)
300
C, CPACITANCE( P F)
280
240
200
5.6 V
160
120
15 V
80
40
ALUMINA SUBSTRATE
200
150
100
FR-5 BOARD
50
2
MI
JS
1
250
50
BIAS(V)
FIG.3 Typical Capacitance Versus Bias Voltage
O
CR
PULSE WIDTH (t P ) IS DEFINED
AS THAT POINT WHERE THE
PEAK CURRENT DECAYS TO
50% OF I PP .
PEAK VALUE - I PP
HALF VALUE =
I PP
2
50
tP
3
2
4
FIG.5 Pulse Waveform
60
50
40
30
UNIDIRECTIONAL
1
10
100
1000
100
125
150
175
200
R E C TANGULAR
WAVEFORM, TA = 25 C
BIDIRECTIONAL
10
UNIDIRECTIONAL
1
0.1
1
10
100
1000
PW, PULSE WIDTH(ms)
PW, PULSE WIDTH(ms)
FIG.7 Maximum Non-repetitive Surge
Power, PPK Versus PW
Power is defined as VRSM x IZ(pk)where VRSM is
the clamping voltage at IZ (pk).
75
r
to
BIDIRECTIONAL
PPK , PEAK SURGE POWER(W)
100
RECTANGULAR
WAVEFORM, TA = 25 C
0.1
50
uc
70
FIG.6 Pulse Derating Curve
100
1
175
Ta , AMBIENT TEMPERATURE( C)
t, TIME(ms)
10
150
80
nd
co
100
90
mi
Se
VALUE(%)
100
100
FIG.4 Steady State Power Derating Curve
PEAK PULSE DERATING IN % OF PEAK
POWER OR CURRENT @ Ta =25 C
_10us
tr <
75
TEMPERATURE( C)
FIG.8 Maximum Non-repetitive Surge
Power, PPK (NOM)Versus PW
Power is defined as VZ (NOM) x I Z(pk)where VZ (NOM) is
the nominal Zener voltage measured at the low test current
used for voltage classification
www.jsmsemi.com
第4/5页
MMBZ Series
■ SOT-23
D
E
B
A
X
MI
JS
O
CR
HE
v M A
3
2
e1
bp
A
A1
nd
co
mi
Se
1
Q
w M B
e
c
Lp
detail X
2 mm
r
to
1
uc
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
max.
bp
c
D
E
e
e1
HE
Lp
Q
v
w
mm
1.1
0.9
0.1
0.48
0.38
0.15
0.09
3.0
2.8
1.4
1.2
1.9
0.95
2.5
2.1
0.45
0.15
0.55
0.45
0.2
0.1
www.jsmsemi.com
第5/5页
很抱歉,暂时无法提供与“MMBZ9V1A”相匹配的价格&库存,您可以联系我们找货
