FMF25FPJR015-LH
FMF25FPJR015-LH
    PSA(信昌电陶)
    电流采样电阻 2512 15mΩ ±1% ±70ppm/℃ 2W
FMF25FPJR015-LH 数据手册
信昌電子陶瓷股份有限公司 Prosperity Dielectrics Co., Ltd. No.566-1, Gaoshi Rd., Lujhu, Yangmei Dist., Taoyuan City 32668, Taiwan, R.O.C. Tel.:+886-3-4753355 Fax:+886-3-4854959 SPECIFICATION FOR APPROVAL DATE: CUSTOMER: PART NAME: Metal Strip Type Halogen Free Current Sensing Resistors CUSTOMER'S DWG. NO.: CUSTOMER'S PART NO.: PDC PART NO.: FMF SERIES APPROVED DESCRIPTION.: ACTION RESULT "V" CUSTOMER'S SIGNATURE NOTE FULL APPROVED CONDITIONAL APPROVED REJECTED OUR ACTION SIGNATURE PREPARED By Jenny Tseng CHECKED By Tony Chou APPROVED By Byron Tsai CUSTOMER SIGNATURE FOR ACCEPTANCE FMF series (AEC-Q200) Metal Strip High Power Lead Free Current Sensing Resistors 1. Features ………………………………………..……………..… 2 2. Applications…..…..………………………………..…………… 2 3. Dimension and construction ………………………..………… 2 4. Power Derating Curve …..…………………………….………. 2 5. Rating …………………………………………………………… 3 6. Part Number ………………………………..………………….. 5 7. Resistance Marking ……………………………………………. 5 8. Reliability Performance…………………………………………. 6 9. Packing ………………………………………………….………. 9 10. Storage &. Handling ………………………………………….… 10 1/10 FMF-REV.14.0.L44 FMF series (AEC-Q200) Metal Strip High Power Lead Free Current Sensing Resistors 1. Features        High power rating and low TCR. Low resistance and high precision (1%). Low inductance design, less than 1.0nH available. Excellent reliability and suitable cost. Suitable for lead free soldering. High precision trimming implement. RoHS compliant & Halogen Free. 2.Applications      Switching model power supply. Battery pack. Notebook, Tablet PC Test Instrument. Power Amplifier. 3.Dimension and Construction R005 Item Protective Molding Resistive Element Internal Terminal External Terminal Material Resin Alloy Metal Copper Solder FMF 1206 1~2mΩ 1206 3~30mΩ 2512 4~100mΩ 2512 1,2,3 mΩ 2512 3W 4~100mΩ 2512 3W 2,3 mΩ 2512 3W 1mΩ L 3.20±0.20 3.10±0.20 6.20±0.20 6.40±0.20 6.20±0.20 6.40±0.20 6.40±0.20 W 1.70±0.20 1.65±0.20 3.25±0.20 3.25±0.20 3.25±0.20 3.25±0.20 3.25±0.20 T 0.70±0.20 0.60±0.20 0.60±0.20 0.75±0.20 0.65±0.20 0.75±0.20 0.80±0.20 Unit:mm a 1.10±0.25 0.60±0.20 0.80±0.20 2.00±0.20 0.80±0.20 2.00±0.20 2.00±0.20 4.Power Derating Curve Operating Temperature Range: -55 to +170 deg.C 2/10 FMF-REV.14.0.L44 FMF series (AEC-Q200) Metal Strip High Power Lead Free Current Sensing Resistors 5.Rating Table A. Rating Tolerance (%) Type Rating 70℃ (W) Max. Working Current Max. Overload Current (Voltage)* (Voltage)* 22.4A 50.0A (111mV) (250mV) 10.0A 22.4A (111mV) (250mV) 31.6A 70.7A (158mV) (354mV) 14.1A 31.6A (173mV) (387mV) 31.6A 70.7A (158mV) (354mV) Temperature coefficient of Resistance (ppm/℃)** Resistance (mΩ) *** ±75 1,2 ±70 3,4,5,6,7,8,9, 10,15,20,25 ±50 5,10,15,15.5 18,20,25,30 ±75 1,2 ±70 3,4,5,6,7,8,9, 10,15,20,25 Standard ±50 5,10,15,15.5 18,20,25,30 Low EMF ±70 1,2,3,4,5 10,15,20,25 Alloy Type Low EMF 0.5 FMF06 1206 ±1%(F) ±2%(G) ±5%(J) Standard Low EMF 1 1 FMF25 2512 ±1%(F) ±2%(G) ±5%(J) 2 3,4,5,6,7,8,9,10 18.3A 40.8A (469mV) (1049mV) 44.7A 100A (224mV) (500mV) 25.8A 57.7A (548mV) (1225mV) 12,15,20,22,25,30 33,35,40,50,60,70 75,80,100 Standard ±50 Low EMF ±70 1,2,3,4,5 10,15,20,25 ±50 3,4,5,6,7,8,9,10 12,15,20,22,25,30 33,35,40,50,60,70 75,80,100,150 Standard Note: (i) (ii) E = P * R or Max. Working Voltage whichever is lower. E:Working Voltage(V),P:Rated Power (W),R:Resistance Value(Ω) (iii) Please keep the surface temperature do not exceed 105℃ when full rated power applied. Solder-pad and trace size should be >300 mm2 . (iv) * : Related number are depend on specific items only. ** : TCR Hot (+25~+155℃). (v) R-value might be variance depend on soldering conditions and please consider this influence before use milli-ohm resistors, and strongly suggest use the recommend solder pad to design your circuits. 3/10 FMF-REV.14.0.L44 FMF series (AEC-Q200) Metal Strip High Power Lead Free Current Sensing Resistors Table B. Rating Rating 70℃(W) Type FMF25 2512 Low EMF FMF25 2512 Standard Max. Working Current (Voltage)* Max. Temperature Resistance Overload coefficient of Tolerance Current Resistance (%) (Voltage)* (ppm/℃)** 54.8A 122.5A (245mV) (548mV) 3 3 24.5A 54.8A (812mV) (1817mV) ±1%(F) ±2%(G) ±5%(J) ±1%(F) ±2%(G) ±5%(J) Resistance (mΩ) *** ±70 1,2,3,4,5,6,7,8,9,10 ±50 20 ±70 5,6,8,10 ±50 12,14,15,16,18,20 25,30,33,35,40,50 60,75,80,100 Note: (i) E= or Max. Working Voltage whichever is lower. (ii) E:Working Voltage(V),P:Rated Power (W),R:Resistance Value(Ω ) (iii) Please keep the surface temperature do not exceed 105℃ when full rated power applied. Solder-pad and trace size should be >300 mm2 . (iv) * : Related number are depend on specific items only. (v) ** : TCR Hot (+25~+155℃). R-value might be variance depend on soldering conditions and please consider this influence before use milli-ohm resistors, and strongly suggest use the recommend solder pad to design your circuits. Table C. Metal Jumper Rating Max. Working Current Max. Overload Current Resistance 80A 100A Max. 0.2mΩ 120A 150A Max. 0.1mΩ Type FMF06 1206 FMF06JTH000 -LH FMF25 2512 FMF25JPJ000 -LH ※Temperature Coefficient Resistance not applicable. 4/10 FMF-REV.14.0.L44 FMF series (AEC-Q200) Metal Strip High Power Lead Free Current Sensing Resistors 6.Part Number Tolerance Packing Watt Size FMF 06 :1206 F :±1% T :Paper Tape F: XXXX -: General: 25 :2512 G :±2% 4Kpcs (For 1206) 1/2W 4 digit As Rating Standard table LH J :±5% Value H: TCR Special Type Code P :Plastic Tape 1W Jumper X: Low EMF 4Kpcs (For 2512) J: : 000_ Code use BH 2W _: means For 2512 AEC-Q200: K: blank. R001.R002 Standard R003 only LHM 3W Low EMF BHM Example: FMF06FTHR001-BH Metal strip, 1206 size, ±1%, paper tape, 1W, 1mΩ , low emf FMF25FPKR010-BHM Metal strip, 2512 size, ±1%, plastic tape, 3W, 10mΩ , low emf, AEC-Q200 FMF25FPKR003XBH Metal strip, 2512 size, ±1%, plastic tape, 3W, 3mΩ , low emf, General 7.Marking FMF 1206/2512 TOP:Marking. (4 Digits marking to identify the resistance value.) “R005”=5mΩ 2512 “R001”=1mΩ 1206 “1”=1mΩ R001 R R005 1 Recommend Solder Pad Dimensions: Unit:mm Type W D L 1206 1.80 1.30 4.70 1.80 2.30 5.60 3.70 1.60 7.60 4.00 3.00 7.30 1206 R001/R002 2512 2512 R001~R003 5/10 FMF-REV.14.0.L44 FMF series (AEC-Q200) Metal Strip High Power Lead Free Current Sensing Resistors 8. Reliability Performance (AEC-Q200) * Normal test items for general product. Test Item *DC Resistance Test Method Specification J:±5% (AEC-Q200. IEC 60115) G:±2% AEC-Q200 TABLE 7.1 F:±1% IEC 60115-1 / JIS C 5201-1 , Clause 4.5 Measure the resistance Value. High Temperature Exposure (Storage) J、G:△R≦ ±3% AEC-Q200 TABLE 7.3 F:△R≦ ±1% 1000 hrs. @ T=170℃. Unpowered. *Temperature J、G:ΔR≦ ±(1%+1mΩ) AEC-Q200 TABLE 7.4 Cycling F:ΔR≦ ±(0.5%+1mΩ) 1000 Cycles (-55°C to +125°C). Measurement at No mechanical damage. 24±2 hours after test conclusion. Measurement at 24 ±2 hours after test conclusion. IEC 60115-1 Clause 4.19 for General Type Repeat 5 cycles as follows -55℃(30min.)→25℃ (2~3min.)→155℃(30min.)→25℃(2~3min.) Moisture Resistance J、G:△R≦ ±(1%+0.5mΩ) AEC-Q200 TABLE 7.6 F:△R≦ ±(0.5%+0.5mΩ) Test 65℃/80~100%RH/10Cycles. Measurement at 24±2 hours after test conclusion. (t=24hrs/cycle). Biased Humidity J、G:△ R≦ ±(3%+0.5mΩ) AEC-Q200 TABLE 7.7 F:△ R≦ ±(1%+0.5mΩ) 1000 hours 85℃/85%RH. 10% of operating power. Measurement at 24 ±2 hours after test conclusion. Operational Life J、G:△ R≦ ±(3%+0.5mΩ) AEC-Q200 TABLE 7.8 F:△ R≦ ±(1%+0.5mΩ) Test 1000hr @ TA=125℃ at specified rated power. Measurement at 24±2 hours after test conclusion. External Visual No visual damage and refer AEC-Q200 TABLE 7.9 PDC marking code. Inspect device construction, marking and workmanship. Physical Within the spec. AEC-Q200 TABLE 7.10 Dimension Verify physical dimensions to the applicable device detail specification. 6/10 FMF-REV.14.0.L44 FMF series (AEC-Q200) Metal Strip High Power Lead Free Current Sensing Resistors Mechanical Shock Vibration Within product specification AEC-Q200 TABLE 7.13 tolerance and no visible Test Peak value:100g's,Wave:Hail-sine, damage. Duration:6ms,Velocity:12.3ft/sec. No mechanical damage. AEC-Q200 TABLE 7.14 5 g's for 20 min., 12 cycles each of 3 orientations. Test from 10-2000 Hz. *Resistance to Solder Heat J、G:ΔR≦ ±(1%+0.5mΩ) AEC-Q200 TABLE 7.15 F:ΔR≦ ±(0.5%+0.5mΩ) Solder dipping @ 270℃±5℃ for 10sec.±1sec. No mechanical damage. Thermal Shock ESD *Solder Ability J、G:ΔR≦ ±(1%+0.5mΩ) AEC-Q200 TABLE 7.16 F:ΔR≦ ±(0.5%+0.5mΩ) -55 to 155℃/ dwell time 15min/ Max transfer time No mechanical damage. 20sec/ 300cycles. ΔR≦ ±(1%+0.5mΩ) AEC-Q200-002 No mechanical damage. Test contact min. 1KV. Over 95% of termination AEC-Q200 TABLE 7.18 must be covered with a)Baking 155℃ 4H, dipping 235℃ 5s solder. b)Steam 1H, dipping 215℃ 5s c)Steam 1H, dipping 260℃ 7s IEC 60115-1, Clause 4.17 for General Type After immersing flux, dip in the 235±2℃ molten solder bath for 3±0.5 sec. Flammability Refer UL-94. AEC-Q200 TABLE 7.20 UL-94 V-0 or V-1 are acceptable *Board Flex J、G:ΔR≦ ±(1%+1mΩ) AEC-Q200 TABLE 7.21 F:ΔR≦ ±(0.5%+1mΩ) Bending 2mm 2512.1206 No mechanical damage. Terminal Strength No mechanical damage AEC-Q200 TABLE 7.22 Force 1 Kg for 60 seconds. 7/10 FMF-REV.14.0.L44 FMF series (AEC-Q200) Metal Strip High Power Lead Free Current Sensing Resistors *Short Time Overload J、G:ΔR≦ ±(2%+0.5mΩ) IEC 60115-1, Clause 4.13 *Load Life Humidity J、G:△ R≦ ±(3%+0.5mΩ) IEC 60115-1, Clause 4.24 F:ΔR≦ ±(1%+0.5mΩ) F:△ R≦ ±(1%+0.5mΩ) 5 × Rated power for 5 seconds 40±2℃ with relative humidity 90% ~ 95% D.C. rated voltage for 1.5 hours ON 30 minutes OFF. Cycle repeated 1000 hours. *Temperature Coefficient of Resistance (TCR) Within the spec. IEC 60115-1, Clause 4.8 T1 T2 Test temperature: 25℃~ +155℃ TCR(ppm/℃) = (R2-R1)/R1×1 / (T2-T1)×106 ( +25~ -55℃ please contact factory. ) *Load Life J、G:△ R≦ ±(3%+0.5mΩ) IEC 60115-1, Clause 4.25 F:△ R≦ ±(1%+0.5mΩ) Rated voltage for 1.5 hours for followed by a pause 0.5 hour at 70±2℃. Cycle repeated 1000 hours. *Insulation Resistance Between termination and IEC 60115-1, Clause 4.6 coating must over 1000MΩ Test voltage:100±15V 8/10 FMF-REV.14.0.L44 FMF series (AEC-Q200) Metal Strip High Power Lead Free Current Sensing Resistors 9. PACKAGING 9.1 Peel Strength of Top Cover Tape The peel speed shall be about 300 mm/min The peel force of top cover tape shall between 0.1 to 0.7N 9.2 Tape Packaging Dimensions Size A B W F E P1 P2 P0 D 1206 2.00±0.20 3.60±0.20 8.00±0.30 3.50±0.05 1.75±0.10 4.00±0.10 2.00±0.05 4.00±0.10 1.50±0.10 2512 3.50±0.20 6.75±0.20 12.0±0.30 5.50±0.05 1.75±0.10 4.00±0.10 2.00±0.05 4.00±0.10 1.50±0.10 unit:mm 9/10 FMF-REV.14.0.L44 FMF series (AEC-Q200) Metal Strip High Power Lead Free Current Sensing Resistors 9.3 Reel Dimensions C D B G T 1206 Packaging A N Q’ty 4kpcs/Reel 178.0±2.0 60.0±0.5 13.0±0.5 20(Min.) 2.0±0.5 10.0±1.5 14.9max. 2512 4kpcs/Reel 13.0±0.5 20(Min.) 2.0±0.5 13.8±1.5 16.7max. Size 178.0±2.0 60.0±0.5 10. Storage &. Handling … Products are recommended to be used up within one year as ensured shelf life. Check solder ability in case shelf life extension is needed. … To store products with following condition: Temperature:5 to 40℃;Humidity: 20 to 70% relative humidity. Precaution for use: The AEC-Q200 series resistors is mainly used on general automotive equipment without safety considerations. Please contact our company in advanced if you intend to use resistor for designing the equipment which may damage itself and the safety of third party. If necessary, please consider to add the protect circuit in devising process and obtaining fully safety evaluation. The contents of the acknowledgment is only used for our parent company, marketing subsidiaries and official marketing agents who purchase our products. Not applicable for the other nonofficial channels. ※ All products specification and data are subject to change without notice. 10/10 FMF-REV.14.0.L44
FMF25FPJR015-LH 价格&库存
很抱歉,暂时无法提供与“FMF25FPJR015-LH”相匹配的价格&库存,您可以联系我们找货
FMF25FPJR015-LH
  • 5+0.41453
  • 20+0.37567
  • 100+0.33681
  • 500+0.29794
  • 1000+0.27981
  • 2000+0.26685
库存:7216
