BRCS300P02ZJ
BRCS300P02ZJ
    BLUEROCKET(蓝箭电子)
    DFN6_2X2MM
    DFN 2*2B-6L 塑封封装 P 沟道 MOS 场效应管。
BRCS300P02ZJ 数据手册
BRCS300P02ZJ Rev.A Aug.-2020 DATA SHEET 描述 / Descriptions DFN 2*2B-6L 塑封封装 P 沟道 MOS 场效应管。 P-Channel Enhancement Mode Field Effect Transistor in a DFN 2*2B-6L Plastic Package. 特征 / Features VDS (V) = -20V ID = -8A RDS(ON)@-4.5V≤30mΩ 无卤产品。HF Product. 用途 / Applications 用于电源管理,便携式设备和电池供电系统。 Power Management in Notebook computer, Portable Equipment and Battery powered systems. 内部等效电路 / Equivalent Circuit 引脚排列 / Pinning 印章代码 / Marking 见印章说明 See Marking Instructions. http://www.fsbrec.com 1/8 BRCS300P02ZJ Rev.A Aug.-2020 极限参数 / DATA SHEET Absolute Maximum Ratings(Ta=25℃) 参数 Parameter 符号 Symbol 数值 Rating 单位 Unit Drain-Source Voltage VDSS -20 V Gate-Source Voltage VGSS ±12 V Continuous Drain Current ID (Ta=25°C) -7 A Continuous Drain Current ID (Ta=70°C) -5 A Pulsed Drain Current IDM -28 A Avalanche Current IAS 21 A Avalanche energy L=0.5mH EAS 308 mJ PD (Ta=25℃) Tj 2.8 W 150 ℃ Tstg -55~150 ℃ Thermal Resistance-Junction to Ambient RθJA(t≦10s) 45 ℃/W Thermal Resistance-Junction to Ambient RθJA 80 ℃/W Power Dissipation for Single Operation Maximum Junction Temperature Storage Temperature Range http://www.fsbrec.com 2/8 BRCS300P02ZJ Rev.A Aug.-2020 DATA SHEET 电性能参数 / Electrical Characteristics(Ta=25℃) 参数 Parameter Drain-Source Breakdown Voltage 符号 Symbol BVDSS 测试条件 Test Conditions 最小值 典型值 最大值 单位 Min Typ Max Unit ID=-250μA VGS=0V -20 -23 V VGS=0V VGS=0V -1.0 VGS=±20V ±100 nA -0.7 -1.0 V Zero Gate Voltage Drain Current IDSS Gate-Body leakage current IGSS VDS=-20V VDS=-20V TJ=55°C VDS=0V VGS(th) VDS=VGS ID=-250μA VGS=-10V ID=-3.5A 23.7 30 VGS=-4.5V ID=-2.8A 30.4 40 VGS=-2.5V ID=-2.0A 43.6 50 Gate Threshold Voltage Static Drain-Source On-Resistance RDS(ON) -5.0 -0.4 μA mΩ Forward Transconductance gFS VDS=-4.5V ID=-3.5A 8.8 S Diode Forward Voltage VSD IS=-1A VGS=0V 0.75 V Total Gate Charge Qg VGS=-4.5V ID=-8A VDS=-10V Gate-Source Charge Qgs Gate-Drain Charge Qgd Input Capacitance Ciss 13 2 3.4 1050 VGS=0V f=1MHz VDS=-25V Output Capacitance Coss Reverse Transfer Capacitance Crss 125 Turn-on Delay Time td(ON) 7 Turn-on Rise Time tr Turn-off Delay Time td(OFF) Turn-off Fall Time http://www.fsbrec.com tf nC VGS=-4.5V RL=1.25Ω VDS=-10V RGEN=3Ω 155 28 95 pF ns 46 3/8 BRCS300P02ZJ Rev.A Aug.-2020 DATA SHEET 电参数曲线图 / Electrical Characteristic Curve http://www.fsbrec.com 4/8 BRCS300P02ZJ Rev.A Aug.-2020 DATA SHEET 电参数曲线图 / Electrical Characteristic Curve http://www.fsbrec.com 5/8 BRCS300P02ZJ Rev.A Aug.-2020 DATA SHEET 外形尺寸图 / Package Dimensions http://www.fsbrec.com 6/8 BRCS300P02ZJ Rev.A Aug.-2020 DATA SHEET 印章说明 / Marking Instructions BR 300P02 **** 说明: BR: 为公司代码 300P02: 为型号代码 ****: 为生产批号代码,随生产批号变化。 Note: BR: Company Code. 300P02: Product Type ****: Lot No. Code, code change with Lot No. http://www.fsbrec.com 7/8 BRCS300P02ZJ Rev.A Aug.-2020 DATA SHEET 回流焊温度曲线图(无铅) / Temperature Profile for IR Reflow Soldering(Pb-Free) 说明: Note: 1、预热温度 150~180℃,时间 60~90sec; 1.Preheating:150~180℃, Time:60~90sec. 2、峰值温度 245±5℃,时间持续为 5±0.5sec; 2.Peak Temp.:245±5℃, Duration:5±0.5sec. 3、焊接制程冷却速度为 2~10℃/sec. 3. Cooling Speed: 2~10℃/sec. 耐焊接热试验条件 / Resistance to Soldering Heat Test Conditions 温度:260±5℃ 时间:10±1 sec. Temp.:260±5℃ Time:10±1 sec 包装规格 / Packaging SPEC. 卷盘包装 / REEL Package Type 封装形式 DFN 2*2B-6L Dimension 包装尺寸 (unit:mm3) Units 包装数量 Units/Reel 只/卷盘 Reels/Inner Box 卷盘/盒 Units/Inner Box 只/盒 Inner Boxes/Outer Box 盒/箱 Units/Outer Box 只/箱 Reel Inner Box 盒 Outer Box 箱 3,000 10 30,000 4 120,000 7〞×8 210×210×205 445×445×230 使用说明 / Notices http://www.fsbrec.com 8/8
BRCS300P02ZJ 价格&库存
很抱歉,暂时无法提供与“BRCS300P02ZJ”相匹配的价格&库存,您可以联系我们找货
BRCS300P02ZJ
  • 10+0.42477
  • 100+0.35802
  • 300+0.32465
库存:352
