SD103AWS/BWS/CWS
Rev.H Apr.-2018
DATA SHEET
Descriptions
SOD-323 塑封封装 肖特基二极管。
Schottky Diode in a SOD-323 Plastic Package.
特征
/ Features
低正向压降,可忽略的反向恢复时间。无卤产品。
Low positive pressure drop, can ignore the reverse recovery time. HF Product.
用途
Applications
肖特基二极管.。
Schottky diode.
内部等效电路
引脚排列
/ Equivalent Circuit
/ Pinning
1
2
PIN1:Cathode
放大及印章代码
Model
PIN2:Anode
/ hFE Classifications & Marking
SD103AWS
SD103BWS
SD103CWS
HS4
HS5
HS6
Marking
http://www.fsbrec.com
1/6
SD103AWS/BWS/CWS
Rev.H Apr.-2018
极限参数
DATA SHEET
Absolute Maximum Ratings(Ta=25℃)
参数
Parameter
符号
Symbol
Peak Repetitive Reverse Voltage ,
Working Peak Reverse Voltage
DC Reverse Voltage
RMS Reverse Voltage
Non-Repetitive Peak Forward
Current
Surge Current
Power Dissipation
Typical Thermal Resistance
Junction to Ambient
Junction and Storage
Temperature Range
电性能参数
单位
Unit
SD103AWS
SD103BWS
SD103CWS
40
30
V
28
21
14
V
VRRM
VRWM,
VR
VR(RMS)
IFM
350
mA
IFSM
1.5
A
PD
200
mW
RθJA
625
℃/W
TJ,Tstg
-65~125
/ Electrical Characteristics(Ta=25℃)
参数
Parameter
符号
Symbol
Reverse Breakdown Voltage
V(BR)
Forward Voltage Drop
VFM
Instantaneous
Reverse
Current
数值
Rating
SD103AWS
SD103BWS
测试条件
Test Conditions
IR=10uA
数值
Rating
最小值
Min
VR
典型值 最大值
Typ
Max
单位
Unit
V
IF=20mA
0.37
IF=200mA
0.6
V
VR=30V
IRM
SD103CWS
5.0
VR=20V
uA
VR=10V
Reverse Recovery Time
trr
IF=IR=200mA
RL=100Ω
Irr=0.1×IR
10
ns
Total Capacitance
CT
VR=0V
50
pF
f=1.0MHZ
2/6
SD103AWS/BWS/CWS
Rev.H Apr.-2018
电参数曲线图
DATA SHEET
/ Electrical Characteristic Curve
3/6
SD103AWS/BWS/CWS
Rev.H Apr.-2018
外形尺寸图
DATA SHEET
/ Package Dimensions
4/6
SD103AWS/BWS/CWS
Rev.H Apr.-2018
印章说明
DATA SHEET
Marking Instructions
HS4
说明:
H:
为公司代码
S4:
为型号代码
Note:
H:
Company Code.
S4:
Product Type.
5/6
SD103AWS/BWS/CWS
Rev.H Apr.-2018
DATA SHEET
回流焊温度曲线图(无铅)
Temperature Profile for IR Reflow Soldering(Pb-Free)
说明:
Note:
1、预热温度 150~180℃,时间 60~90sec;
1.Preheating:150~180℃, Time:60~90sec.
2、峰值温度 245±5℃,时间持续为 5±0.5sec;
2.Peak Temp.:245±5℃, Duration:5±0.5sec.
3、焊接制程冷却速度为 2~10℃/sec.
3. Cooling Speed: 2~10℃/sec.
耐焊接热试验条件
Resistance to Soldering Heat Test Conditions
温度:260±5℃
包装规格
Time:10±1 sec
/ REEL
Package Type
封装形式
使用说明
Temp.:260±5℃
/ Packaging SPEC.
卷盘包装
SOD-323
时间:10±1 sec.
Units 包装数量
Dimension
包装尺寸
3
(unit:mm )
Units/Reel
只/卷盘
Reels/Inner Box
卷盘/盒
Units/Inner Box
只/盒
Inner Boxes/Outer Box
盒/箱
Units/Outer Box
只/箱
Reel
Inner Box 盒
Outer Box 箱
3,000
10
30,000
6
180,000
7〞×8
180×120×180
390×385×205
/ Notices
6/6
很抱歉,暂时无法提供与“SD103AWS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.07128
- 500+0.05552
- 3000+0.04677
- 国内价格
- 50+0.06534
- 600+0.05089
- 1200+0.05013
- 3000+0.04287
