SS12~SS120
Rev. D Jun.-2021
DATA SHEET
描述 / Descriptions
表面贴装肖特基整流二极管,反向电压:20V~200V,正向电流:1.0A, SMA 封装。
Surface Mount Schottky Barrier Rectifiers, Reverse Voltage:20 to 200V,Forward Current:1.0A ,SMA
package.
特征 / Features
玻璃钝化芯片,无铅符合欧盟 RoHS 指令 2011/65/EU,适用表面贴装。无卤产品。
Glass Passivated Chip Junction, Lead free in comply with EU RoHS 2011/65/EU directives, For
surface mounted applications. HF product.
用途 /
Applications
一般用途.
General purpose.
内部等效电路 / Equivalent Circuit
引脚排列 / Pinning
印章代码 / Marking
见印章说明。See Marking Instructions.
http://www.fsbrec.com
1/7
SS12~SS120
Rev. D Jun.-2021
极限参数 /
DATA SHEET
Absolute Maximum Ratings(Ta=25℃)
参数
Parameter
符号
Symbol
Maximum Repetitive Peak
Reverse Voltage
Maximum RMS voltage
Maximum DC Blocking
Voltage
Maximum Average
Forward Rectified Current
Tc=100℃
Peak Forward Surge
Current 8.3 ms Single Half
Sine Wave Superimposed
on Rated Load
(JEDEC Method)
Typical Junction
Capacitance at
VR=4V f=1MHz
Typical Thermal
1)
Resistance
Operating and Storage
Temperature Range
数值
Rating
单位
Unit
SS12
SS14
SS16
SS18
SS110
SS112
SS115
SS120
VRRM
60
80
100
120
150
200
V
VRMS
14
28
42
56
70
84
105
140
V
VDC
60
80
100
120
150
200
V
IF(AV)
1.0
A
IFSM
25
A
Cj
110
80
RθJA
RθJC
Tj,Tstg
pF
90
15
℃/W
-55~+150
Note:
1)P.C.B. mounted with 2.0 X 2.0" (5 X5 cm) copper pad areas.
电性能参数 / Electrical Characteristics(Ta=25℃)
参数
Parameter
Maximum
Instantaneous
Forward Voltage
Maximum DC
Reverse Current
at Rated DC
Blocking Voltage
符号
Symbol
VF
测试条件
Test
Conditions
IF=1.0A
数值
Rating
SS12
SS14
0.55
SS16
0.70
SS18
SS110 SS122 SS115 SS120
单位
Unit
0.85
0.90
V
Ta=25℃
0.3
0.2
0.1
mA
Ta=100℃
10
5.0
2.0
mA
IR
2/7
SS12~SS120
Rev. D Jun.-2021
DATA SHEET
电参数曲线图 / Electrical Characteristic Curve
3/7
SS12~SS120
Rev. D Jun.-2021
DATA SHEET
外形尺寸图 / Package Dimensions
SMA
4/7
SS12~SS120
Rev. D Jun.-2021
DATA SHEET
印章说明 / Marking Instructions
5/7
SS12~SS120
Rev. D Jun.-2021
DATA SHEET
SS12
说明:
SS12:
为型号代码
: 为生产批号追溯码,第 1 个*为年月代码,后面 3 个*为当月小批号代码
Note:
SS12:
Product Type Code
Lot No. Code,The 1st * means:YM Code,The last 3 * means:little Lot No
Code
6/7
SS12~SS120
Rev. D Jun.-2021
DATA SHEET
回流焊温度曲线图(无铅) / Temperature Profile for IR Reflow Soldering(Pb-Free)
350
Temperature(℃)
300
245±5℃
250
5±0.5 sec
200
150
60~90 sec
100
50
60
80
100
120
140
160
180
200
220
240
260
280
Time(sec)
说明:
Note:
1、预热温度 150~180℃,时间 60~90sec;
1.Preheating:150~180℃, Time:60~90sec.
2、峰值温度 245±5℃,时间持续为 5±0.5sec;
2.Peak Temp.:245±5℃, Duration:5±0.5sec.
3、焊接制程冷却速度为 2~10℃/sec.
3. Cooling Speed: 2~10℃/sec.
耐焊接热试验条件 /
Resistance to Soldering Heat Test Conditions
温度:260±5℃
时间:10±1 sec.
Temp.:260±5℃
Time:10±1 sec
包装规格 / Packaging SPEC.
卷盘包装 / REEL
Package Type
封装形式
SMA
Dimension 包装尺寸 (unit:mm3)
Units 包装数量
Units/Reel
只/卷盘
Reels/Inner Box
卷盘/盒
Units/Inner Box
只/盒
Inner Boxes/Outer Box
盒/箱
Units/Outer Box
只/箱
Reel
Inner Box 盒
Outer Box 箱
5000
2
10000
7
70000
13〞×12
336X336X40
380X335X366
使用说明 / Notices
7/7
很抱歉,暂时无法提供与“SS14”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.12475
- 200+0.09633
- 国内价格
- 20+0.13749
- 200+0.10617
- 600+0.08878
