7805
7805
    BLUEROCKET(蓝箭电子)
    TO-220-3
    TO-220 塑封封装电压调整器 5V 1.5A
7805 数据手册
7805 Rev.F Sep.-2018 描述 / DATA SHEET Descriptions TO-220 塑封封装电压调整器。Voltage Regulator in a TO-220 Plastic Package. 特征 / Features 三端稳压调整器,输出电流高达 1.5A,内设过热保护和短路限制。 3-Terminal regulators ,output current up to 1.5A, internal thermal overload protection and short-circuit limiting. 用途 / Applications 电压调整器。 Voltage Regulator. 内部等效电路/应用电路 引脚排列 1 2 / Equivalent Circuit or Application Circuit / Pinning 3 PIN1:IN 印章代码 PIN 2:GND PIN 3:OUT / Marking 见印章说明。See Marking Instructions http://www.fsbrec.com 1/6 7805 Rev.F Sep.-2018 极限参数 / DATA SHEET Absolute Maximum Ratings(Ta=25℃) 参数 Parameter 符号 Symbol VI 数值 Rating 35 单位 Unit V Thermal Resistance Junction-ambient RθJA 62.5 ℃/W Thermal Resistance Junction-case RθJC 5.0 ℃/W TJ 150 ℃ Operating Junction Temperature Range TOPR 0~125 ℃ Storage temperature range  Tstg -65~150 ℃ Input voltage Junction Temperature 电性能参数 / Electrical Characteristics(Ta=25℃,Vi=10V,Io=500mA,unless otherwise specified) 参数 Parameter 符号 Symbol Output Voltage VO VLoad Load Regulation △ Line Regulation △ VLine Quiescent Current Iq Iq Quiescent Current Change Output Voltage Drift Output Noise Voltage Supply Voltage Rejection △ Vo/△T △ eN SVR 测试条件 Test Conditions Tj=25℃ Vi=7V-20V Po≤15W Io=5mA-1A Tj=25℃ Io=5mA-1.5A 单位 Unit 4.8 5.0 5.2 V 4.75 5.0 5.25 V 100 mV 50 mV Tj=25℃ Io=250mA-750mA Tj=25℃ Vi=7V-25V 3.0 100 mV Tj=25℃ Vi=8V-12V 1.0 50 mV Tj=25℃ 8.0 mA Vi=7V-25V 0.8 mA Io=5mA-1A 0.5 mA Io=5mA -1.1 B=10Hz-100KHz Tj=25℃ Vi=8V-18V f=120Hz Tj=25℃ Dropout Voltage Vd Io=1A Output Resistance Ro f=1KHz Short Circuit Current Isc Vi=35V Short Circuit Peak Current Iscp Tj=25℃ http://www.fsbrec.com 最小值 典型值 最大值 Min Typ Max Tj=25℃ mV/℃ 40 62 μV/Vo dB 2.0 V 17 mΩ 0.75 A 2.2 A 2/6 7805 Rev.F Sep.-2018 电参数曲线图 DATA SHEET / Electrical Characteristic Curve http://www.fsbrec.com 3/6 7805 Rev.F Sep.-2018 外形尺寸图 DATA SHEET / Package Dimensions http://www.fsbrec.com 4/6 7805 Rev.F Sep.-2018 印章说明 / DATA SHEET Marking Instructions BR **** CW7805 说明: BR: 为公司代码 CW7805: 为型号代码 ****: 为生产批号代码,随生产批号变化。 Note: BR: Company Code. CW7805: Product Type. ****: Lot No. Code, code change with Lot No. http://www.fsbrec.com 5/6 7805 Rev.F Sep.-2018 DATA SHEET 波峰焊温度曲线图(无铅) / Temperature Profile for Dip Soldering(Pb-Free) 说明: Note: 1、预热温度 25~150℃,时间 60~90sec; 1.Preheating:25~150℃, Time:60~90sec. 2、峰值温度 255±5℃,时间持续为 5±0.5sec; 2.Peak Temp.:255±5℃, Duration:5±0.5sec. 3、焊接制程冷却速度为 2~10℃/sec. 3. Cooling Speed: 2~10℃/sec. 耐焊接热试验条件 / 温度:270±5℃ 包装规格 散件包装 Time:10±1 sec Units 包装数量 Dimension 包装尺寸 (unit:mm3) Units/Bag 只/袋 Bags/Inner Box 袋/盒 Units/Inner Box 只/盒 Inner Boxes/Outer Box 盒/箱 Units/Outer Box 只/箱 Bag 袋 Inner Box 盒 Outer Box 箱 200 10 2,000 5 10,000 135×190 237×172×102 560×245×195 Units/Tube 只/套管 Tubes/Inner Box 套管/盒 Units/Inner Box 只/盒 Inner Boxes/Outer Box 盒/箱 Units/Outer Box 只/箱 Tube 套管 Inner Box 盒 Outer Box 箱 50 20 1,000 5 5,000 532×31.4×5.5 555×164×50 575×290×180 / TUBE Package Type 封装形式 使用说明 Temp:270±5℃ / BULK TO-220/F TO-220/F 时间:10±1 sec. / Packaging SPEC. Package Type 封装形式 套管包装 Resistance to Soldering Heat Test Conditions Units 包装数量 Dimension 包装尺寸 (unit:mm3) / Notices http://www.fsbrec.com 6/6
很抱歉,暂时无法提供与“7805”相匹配的价格&库存,您可以联系我们找货
  • 1+1.38209
  • 10+1.36136
  • 50+1.06722
  • 250+0.94443
库存:373
7805
    • 1+0.62700
    • 50+0.54450
    库存:56
