BZT52C2V0Q-BZT52C47Q
SMT-Type Zener Diode
FEATURES
Large selection of zener voltages: 2.0V ~ 47V
Tight voltage tolerance: ±5% for C-series
Ultra low-profile package well suited for automated assembly
MSL Class 1 compatible
to
r
APPLICATIONS
General voltage regulation
Mobile & handheld systems
Marking
See Page 2
co
BZT52C2V0Q - BZT52C47Q
Package
nd
Part Number
uc
ORDERING INFORMATION
SOD-123
MAXIMUM RATING (@ TA = 25C unless otherwise specified)
Symbol
Value
Unit
VF
0.9
V
PC
500
mW
Thermal Resistance (Junction-to-Ambient)
RθJA
250
C/W
Thermal Resistance (Junction-to-Case)
RθJC
140
C/W
Junction Temperature Range
TJ
-55 ~ +150
C
Storage Temperature Range
TSTG
-65 ~ +150
C
mi
Parameter
CR
O
Power Dissipation (Collector)
Se
Forward Voltage @ IF=10mA
JS
MI
Note: These ratings are limiting values above which the serviceability of the diodes may be impaired.
www.jsmsemi.com
第1/3页
ELECTRICAL CHARACTERISTICS (@ TA = 25C unless otherwise specified)
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
2
2
2
2
2
2
2
600
600
600
600
600
600
600
600
600
500
480
400
150
80
80
80
100
150
150
150
170
200
200
225
225
250
250
300
300
325
350
350
700
750
Min.
Max.
-3.5
-3.5
-3.5
-3.5
-3.5
-3.5
-3.5
-3.5
-3.5
-3.5
-2.7
-2.0
0.4
1.2
2.5
3.2
3.8
4.5
5.4
6.0
7.0
9.2
10.4
12.4
14.4
16.4
18.4
21.4
24.4
27.4
30.4
33.4
10.0
10.0
0.0
0.0
0.0
0.0
0.0
0.0
0.0
0.0
0.0
0.0
1.2
2.5
3.7
4.5
5.3
6.2
7.0
8.0
9.0
10.0
11.0
13.0
14.0
16.0
18.0
20.0
22.0
25.3
29.4
33.4
37.4
41.2
12.0
12.0
www.jsmsemi.com
Maximum
Reverse
Current
IR (A)
@ VR
(V)
150.000
150.000
50.000
20.000
10.000
5.000
5.000
3.000
3.000
3.000
2.000
1.000
3.000
2.000
1.000
0.700
0.500
0.200
0.100
0.100
0.100
0.100
0.100
0.100
0.100
0.100
0.100
0.100
0.100
0.100
0.100
0.100
0.100
0.100
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
2.0
2.0
2.0
4.0
4.0
5.0
5.0
6.0
7.0
8.0
8.0
8.0
10.5
11.2
12.6
14.0
15.4
16.8
18.9
21.0
23.1
25.2
27.3
32.0
35.0
to
r
2.10
2.31
2.52
2.84
3.15
3.47
3.78
4.10
4.52
4.94
5.36
5.88
6.51
7.14
7.88
8.61
9.56
10.50
11.55
12.60
13.65
15.75
16.80
18.90
21.00
23.10
25.20
28.35
31.50
34.65
37.80
40.95
45.15
49.35
@ IZK
(mA)
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
0.5
0.5
0.5
0.5
0.5
1.0
1.0
uc
2.00
2.20
2.40
2.70
3.00
3.30
3.60
3.90
4.30
4.70
5.10
5.60
6.20
6.80
7.50
8.20
9.10
10.00
11.00
12.00
13.00
15.00
16.00
18.00
20.00
22.00
24.00
27.00
30.00
33.00
36.00
39.00
43.00
47.00
ZZK ()
Temperature
Coefficient @
IZT
TC (mV/C)
nd
1.90
2.09
2.28
2.57
2.85
3.14
3.42
3.71
4.09
4.47
4.85
5.32
5.89
6.46
7.13
7.79
8.65
9.50
10.45
11.40
12.35
14.25
15.20
17.10
19.00
20.90
22.80
25.65
28.50
31.35
34.20
37.05
40.85
44.65
ZZT ()
@ IZT
100
100
100
100
95
95
90
90
90
80
60
40
10
15
15
15
15
30
30
40
45
55
55
70
80
80
80
90
130
100
100
co
Max.
Maximum Zener
Impedance
mi
Typ.
Se
WY
22•
WX
W1
W2
W3
W4
W5
W6
W7
W8
W9
WA
WB
WC
WD
WE
WF
WG
WH
WI
WJ
WK
WL
WM
WN
WO
WP
WQ
WR
WS
WT
WU
WV
@ IZT
(mA)
Min.
JS
MI
BZT52C2V0Q
BZT52C2V2Q
BZT52C2V4Q
BZT52C2V7Q
BZT52C3V0Q
BZT52C3V3Q
BZT52C3V6Q
BZT52C3V9Q
BZT52C4V3Q
BZT52C4V7Q
BZT52C5V1Q
BZT52C5V6Q
BZT52C6V2Q
BZT52C6V8Q
BZT52C7V5Q
BZT52C8V2Q
BZT52C9V1Q
BZT52C10Q
BZT52C11Q
BZT52C12Q
BZT52C13Q
BZT52C15Q
BZT52C16Q
BZT52C18Q
BZT52C20Q
BZT52C22Q
BZT52C24Q
BZT52C27Q
BZT52C30Q
BZT52C33Q
BZT52C36Q
BZT52C39Q
BZT52C43Q
BZT52C47Q
Marking
Code
CR
O
Part
Number
Zener Voltage
VZ (V)
第2/3页
JS
MI
CR
O
Se
mi
co
nd
uc
to
r
TYPICAL CHARACTERISTICS (@ TA = 25C unless otherwise specified)
www.jsmsemi.com
第3/3页
很抱歉,暂时无法提供与“BZT52C33Q”相匹配的价格&库存,您可以联系我们找货
