SLM Series
Multilayer Power Inductor
Pb
◆ Features
1、High DC bias current due to developed material.
2、Low profile and thin thickness.
3、Monolithic structure for high reliability.
4、Excellent solderability and high heat resistance
5、Low DC resistance.
6、No cross coupling due to magnetic shield
◆ Applications
◆ Test Instruments
◎HP4291B
DC-DC converter circuits for mobile phones,
RF IMPEDANCE / MATERIAL ANALYZER
DSCs, DVCs, HDDs, PDAs, etc.
◎HP4338A/B MILLIOHMMETER
◆ Lead Free Part Numbering
◆ Materials
No.
SLM 2520 4R7 M
I
T
(1)
(2)
(3)
(4) (5) (6)
(1)
(2)
(3)
(4)
1
2
Series Type
Dimension Length x Width
Inductance 4R7=4.7μH
Inductance Tolerance M= 20%;N= 30%
3
4
Homogeneous
Material Name
Ferrite
Element name
composition
Ferrite Powder
Inner Coils(Ag)
Terminal
Electrode(Ag)
Electro-Plating
(Ni/Sn)
Ag Pd
Ag
Ni Sn
(5) Company Code
(6) Packaging P – Embossed paper tape, 7" reel
Embossedplastic
plastictape,
tape,7"
7"reel
reel
EE––Embossed
Tape&&reel
reel
TT––Tape
◆ Dimensions
Size(EIA)
1608(0603)
2012 (0805)
2520 (1008)
L
1.60±0.150
2.00±0.20
2.50±0.20
W
0.80±0.150
1.25±0.20
2.00±0.20
T
0.80±0.150
0.90±0.10
0.90±0.10
E
0.30±0.20
0.50±0.30
0.50±0.30
◆ Package
Size EIA (EIA)
1608(0603)
2012(0805)
2520(1008)
Standard Packing Quantity (pcs / reel)
4000
4000
3000
Rev.01
Page 1 of 4
www.sunltech.com
SLM Series
◆ Specification
Part Number
Inductance
(µH)
Test Freq
(MHz)
S.R.F (MHz)
Min.
DCR±25%
Max. (Ω)
Rated current
(mA)
1.0
2.2
3.3
4.7
1
1
1
1
60
50
40
35
0.35
0.52
0.75
0.90
280
250
230
210
1.0
2.2
3.3
4.7
10
1
1
1
1
1
60
50
40
35
30
0.15
0.20
0.30
0.37
0.55
1000
900
850
750
360
1.0
2.2
3.3
4.7
10
1
1
1
1
1
60
40
35
30
0.080
0.100
0.110
0.210
1500
1200
1100
1000
550
SLM1608(EIA 0603)
SLM16081R0MIT
SLM16082R2MIT
SLM16083R3MIT
SLM16084R7MIT
SLM 2012 (EIA 0805)
SLM20121R0MIT
SLM20122R2MIT
SLM20123R3MIT
SLM20124R7MIT
SLM2012100MIT
SLM 2520 (EIA 1008)
SLM25201R0MIT
SLM25202R2MIT
SLM25203R3MIT
SLM25204R7MIT
SLM2520100MIT
◆ General Technical Data
Storage Condition
℃ ~ +125℃
-40℃ ~ +85℃
Less than 40℃ and 70% RH
Soldering Method
Reflow or Wave Soldering
Operating Temperature Range
Storage Temperature (on board)
-55
◆ Recommended Soldering conditions
Rev.01
Page 2 of 4
www.sunltech.com
SLM Series
◆ Reliability And Test Condition
Test item
Test condition
1. Solder temperature : 260 ± 5
Resistance to Solder Heat
Criteria
1.More than 95 % of terminal electrode
should be covered with new solder
2. Flux : Rosin
2. No mechanical damage
3. DIT time : 10 ± 1 sec
3. Inductance value should be within ± 20 %
℃ It shall be
of the initial value
1. Reflow temperature : 245
Soldered
Adhesive Test
on
the
substrate
applying
direction parallel to the substrate
2. Apply force(F) : 5 N
1. No mechanical damage
2. Soldering the products on PCB after the
pulling test force > 5 N
3. Test time : 10 sec
1. Temperature : 93
2. Test time : 8 hrs
Steam Aging Test
3. Solder temperature : 235 ± 5
4. Flux : Rosin
5. DIT time : 5 ± 1 sec
1. More than 95 % of terminal electrode
℃ For 30 minutes
1. Temperature:-40 ~ 85
each
Temperature Cycle
2. Cycle: 100 cycles
2. Inductance should be within ±20% of the
3. Measurement:At ambient temperature 24
initial value
hours after test completion
1. Temperature: 85 ± 5
Operational Life
2. Testing time: 1000 hrs
3. Applied current: Full rated current
2. Inductance should be within ± 20% of the
4. Measurement: At ambient temperature 24
initial value
℃ ± 2℃
1. Temperature: 40
2. Humidity: 90-95 % RH
Biased Humidity
4. Testing time: 1000 hrs
5. Measurement:At ambient temperature 24
initial value
Rated Current
Rev.01
At ambient temperature & humidity Testing
SLM product surface temp
time:5 minutes ( under full rated current )
temperature plus 40
Page 3 of 4
: below
room
www.sunltech.com
SLM Series
◆ Characteristics
Inductance vs. Frequency Characteristics
Rev.01
Page 4 of 4
www.sunltech.com
很抱歉,暂时无法提供与“SLM25203R3MIT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.30829
- 100+0.25126
- 600+0.24875
- 1200+0.24378
- 3000+0.23647
- 国内价格
- 10+0.33632
- 100+0.27411
- 300+0.24300
