BZT52C2V0SQ-BZT52C75SQ
SMT-Type Zener Diode
FEATURES
Large selection of zener voltages: 2.0V ~ 75V
Tight voltage tolerance: ±5% for C-series
Ultra low-profile package well suited for automated assembly
MSL Class 1 compatible
SOD-323
ct
General voltage regulation
Mobile & handheld systems
ORDERING INFORMATION
Marking
on
Part Number
du
or
APPLICATIONS
See Page 2
SOD-323
em
ic
BZT52C2V0SQ - BZT52C75SQ
Package
Parameter
S
MAXIMUM RATING (@ TA = 25°C unless otherwise specified)
Symbol
Value
Unit
VF
0.9
V
PC
200
mW
Thermal Resistance (Junction-to-Ambient)
RθJA
625
°C/W
Thermal Resistance (Junction-to-Case)
RθJC
337
°C/W
Junction Temperature Range
TJ
-55 ~ +150
°C
Storage Temperature Range
TSTG
-65 ~ +150
°C
CR
O
Forward Voltage @ IF=10mA
JS
MI
Power Dissipation (Collector)
Note: These ratings are limiting values above which the serviceability of the diodes may be impaired.
www.jsmsemi.com
第1/4页
ELECTRICAL CHARACTERISTICS (@ TA = 25°C unless otherwise specified)
or
-3.5
-3.5
-3.5
-3.5
-3.5
-3.5
-3.5
-3.5
-3.5
-3.5
-2.7
-2.0
0.4
1.2
2.5
3.2
3.8
4.5
5.4
6.0
7.0
9.2
10.4
12.4
14.4
16.4
18.4
21.4
24.4
27.4
30.4
33.4
10.0
10.0
10.0
10.0
10.0
10.0
10.0
www.jsmsemi.com
Maximum
Reverse @ VR
Current
(V)
IR (µA)
Max.
0.0
0.0
0.0
0.0
0.0
0.0
0.0
0.0
0.0
0.2
1.2
2.5
3.7
4.5
5.3
6.2
7.0
8.0
9.0
10.0
11.0
13.0
14.0
16.0
18.0
20.0
22.0
25.3
29.4
33.4
37.4
41.2
12.0
12.0
12.0
12.0
12.0
12.0
12.0
ct
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
2
2
2
2
2
2
2
2
2
2
2
2
Min.
du
2.10
2.31
2.52
2.84
3.15
3.47
3.78
4.10
4.52
4.94
5.36
5.88
6.51
7.14
7.88
8.61
9.56
10.50
11.55
12.60
13.65
15.75
16.80
18.90
21.00
23.10
25.20
28.35
31.50
34.65
37.80
40.95
45.15
49.35
53.55
58.80
65.10
71.40
78.75
on
2.00
2.20
2.40
2.70
3.00
3.30
3.60
3.90
4.30
4.70
5.10
5.60
6.20
6.80
7.50
8.20
9.10
10.00
11.00
12.00
13.00
15.00
16.00
18.00
20.00
22.00
24.00
27.00
30.00
33.00
36.00
39.00
43.00
47.00
51.00
56.00
62.00
68.00
75.00
ic
1.90
2.09
2.28
2.57
2.85
3.14
3.42
3.71
4.09
4.47
4.85
5.32
5.89
6.46
7.13
7.79
8.65
9.50
10.45
11.40
12.35
14.25
15.20
17.10
19.00
20.90
22.80
25.65
28.50
31.35
34.20
37.05
40.85
44.65
48.45
53.20
58.90
64.60
71.25
ZZT (Ω)
@ IZK
ZZK (Ω)
@ IZT
(mA)
100
600
1.0
100
600
1.0
100
600
1.0
100
600
1.0
95
600
1.0
95
600
1.0
90
600
1.0
90
600
1.0
90
600
1.0
80
500
1.0
60
480
1.0
40
400
1.0
10
150
1.0
15
80
1.0
15
80
1.0
15
80
1.0
15
100
1.0
1.0
1.0
25
150
1.0
30
170
1.0
30
200
1.0
40
200
1.0
45
225
1.0
55
225
1.0
55
250
1.0
70
250
1.0
80
300
0.5
80
300
0.5
80
325
0.5
0.5
90
350
130
350
0.5
100
700
1.0
100
750
1.0
100
750
1.0
200
400
0.5
215
423
0.5
240
447
0.5
255
470
0.5
em
Max.
S
WY
22•
WX
W1
W2
W3
W4
W5
W6
W7
W8
W9
WA
WB
WC
WD
WE
WF
WG
WH
WI
WJ
WK
WL
WM
WN
WO
WP
WQ
WR
WS
WT
WU
WV
WW
WX•
WY•
WZ
6H
Typ.
Temperature
Coefficient
@ IZT
TC (mV/°C)
Maximum Zener
Impedance
@ IZT
(mA)
Min.
JS
MI
BZT52C2V0SQ
BZT52C2V2SQ
BZT52C2V4SQ
BZT52C2V7SQ
BZT52C3V0SQ
BZT52C3V3SQ
BZT52C3V6SQ
BZT52C3V9SQ
BZT52C4V3SQ
BZT52C4V7SQ
BZT52C5V1SQ
BZT52C5V6SQ
BZT52C6V2SQ
BZT52C6V8SQ
BZT52C7V5SQ
BZT52C8V2SQ
BZT52C9V1SQ
BZT52C10SQ
BZT52C11SQ
BZT52C12SQ
BZT52C13SQ
BZT52C15SQ
BZT52C16SQ
BZT52C18SQ
BZT52C20SQ
BZT52C22SQ
BZT52C24SQ
BZT52C27SQ
BZT52C30SQ
BZT52C33SQ
BZT52C36SQ
BZT52C39SQ
BZT52C43SQ
BZT52C47SQ
BZT52C51SQ
BZT52C56SQ
BZT52C62SQ
BZT52C68SQ
BZT52C75SQ
Marking
Code
CR
O
Part
Number
Zener Voltage
VZ (V)
150.000
150.000
50.000
20.000
10.000
5.000
5.000
3.000
3.000
3.000
2.000
1.000
3.000
2.000
1.000
0.700
0.500
0.200
0.100
0.100
0.100
0.100
0.100
0.100
0.100
0.100
0.100
0.100
0.100
0.100
0.100
0.100
0.100
0.100
0.100
0.045
0.045
0.045
0.045
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
2.0
2.0
2.0
4.0
4.0
5.0
5.0
6.0
7.0
8.0
8.0
8.0
10.5
11.2
12.6
14.0
15.4
16.8
18.9
21.0
23.1
25.2
27.3
32.0
35.0
38.0
39.2
43.4
47.6
52.5
第2/4页
TYPICAL CHARACTERISTICS (@ TA = 25°C unless otherwise specified)
50
100
150
125
TA , AMBIENT TEMPERATURE (°C)
10
em
S
18
Test Current IZ
2mA
22
10
CR
O
IZ, ZENER CURRENT (mA)
15
Test Current IZ
5mA
33
JS
MI
or
4V7
5V1
5
5V6
6V2
6V8
7V5
2
8
4
6
V Z, ZENER VOLTAGE (V)
10
10
12
4V3
10
ic
TJ = 25°C
3V9
Fig. 2 Typical Zener Breakdown Characteristics
Fig. 1 Power Derating Curve
30
3V3
3V6
on
25
10
ct
0.2
2V0
2V4
2V7
3V0
du
0.3
PD, POWER DISSIPATION (W)
0.4
8
6
4
2
30
VZ, ZENER VOLTAGE (V)
Fig. 3 Typical Zener Breakdown Characteristics
30 40 50 60 70 80
VZ , ZENER VOLTAGE (V)
90 100
Fig. 4 Typical Zener Breakdown Characteristics
0.020
0.100
0.015
IZ = 5mA
0.080
TC of VZ (%/C)
TC of VZ (%/C)
0.010
IZ = 5mA
0.005
IZ = 50μA
0.000
-0.005
-0.010
0.060
0.040
0.020
0.000
-0.015
-0.020
IZ = 50μA
4
6
8
-0.020
10
10
40
50
60
70
80
Fig. 5 Typical Temperature Coefficient of Zener Voltage
Fig. 6 Typical Temperature Coefficient of Zener Voltage
www.jsmsemi.com
第3/4页
PACKAGE OUTLINE (Unit: mm)
Plastic surface mounted package
K
C
SOD-323
Min.
A
1.60
B
1.20
B
D
C
0.25
0.35
0.22
0.42
H
0.02
0.10
J
0.05
0.15
2.55
2.75
du
on
J
1.40
0.90
E
E
1.80
0.80
D
H
Max.
ct
Dimension
or
A
em
ic
K
S
MOUNTING PAD LAYOUT (Unit: mm)
CR
O
0.63
JS
MI
0.83
1.60
2.85
PACKAGE INFORMATION
Part Number
Package
Shipping Quantity
SOD-323
3000pcs / Tape & Reel
www.jsmsemi.com
第4/4页
很抱歉,暂时无法提供与“BZT52C7V5SQ”相匹配的价格&库存,您可以联系我们找货
