BZT52C10SQ
BZT52C10SQ
    JSMSEMI(杰盛微)
    SOD-323
    SMT型齐纳二极管
BZT52C10SQ 数据手册
BZT52C2V0SQ-BZT52C75SQ SMT-Type Zener Diode FEATURES • • • • Large selection of zener voltages: 2.0V ~ 75V Tight voltage tolerance: ±5% for C-series Ultra low-profile package well suited for automated assembly MSL Class 1 compatible SOD-323 ct General voltage regulation Mobile & handheld systems ORDERING INFORMATION Marking on Part Number du • • or APPLICATIONS See Page 2 SOD-323 em ic BZT52C2V0SQ - BZT52C75SQ Package Parameter  S MAXIMUM RATING (@ TA = 25°C unless otherwise specified) Symbol Value Unit VF 0.9 V PC 200 mW Thermal Resistance (Junction-to-Ambient) RθJA 625 °C/W Thermal Resistance (Junction-to-Case) RθJC 337 °C/W Junction Temperature Range TJ -55 ~ +150 °C Storage Temperature Range TSTG -65 ~ +150 °C CR O Forward Voltage @ IF=10mA JS MI Power Dissipation (Collector) Note: These ratings are limiting values above which the serviceability of the diodes may be impaired. www.jsmsemi.com 第1/4页 BZT52C2V0SQ-BZT52C75SQ SMT-Type Zener Diode ELECTRICAL CHARACTERISTICS (@ TA = 25°C unless otherwise specified) or -3.5 -3.5 -3.5 -3.5 -3.5 -3.5 -3.5 -3.5 -3.5 -3.5 -2.7 -2.0 0.4 1.2 2.5 3.2 3.8 4.5 5.4 6.0 7.0 9.2 10.4 12.4 14.4 16.4 18.4 21.4 24.4 27.4 30.4 33.4 10.0 10.0 10.0 10.0 10.0 10.0 10.0 www.jsmsemi.com Maximum Reverse @ VR Current (V) IR (µA) Max. 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.2 1.2 2.5 3.7 4.5 5.3 6.2 7.0 8.0 9.0 10.0 11.0 13.0 14.0 16.0 18.0 20.0 22.0 25.3 29.4 33.4 37.4 41.2 12.0 12.0 12.0 12.0 12.0 12.0 12.0 ct 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 2 2 2 2 2 2 2 2 2 2 2 2 Min. du 2.10 2.31 2.52 2.84 3.15 3.47 3.78 4.10 4.52 4.94 5.36 5.88 6.51 7.14 7.88 8.61 9.56 10.50 11.55 12.60 13.65 15.75 16.80 18.90 21.00 23.10 25.20 28.35 31.50 34.65 37.80 40.95 45.15 49.35 53.55 58.80 65.10 71.40 78.75 on 2.00 2.20 2.40 2.70 3.00 3.30 3.60 3.90 4.30 4.70 5.10 5.60 6.20 6.80 7.50 8.20 9.10 10.00 11.00 12.00 13.00 15.00 16.00 18.00 20.00 22.00 24.00 27.00 30.00 33.00 36.00 39.00 43.00 47.00 51.00 56.00 62.00 68.00 75.00 ic 1.90 2.09 2.28 2.57 2.85 3.14 3.42 3.71 4.09 4.47 4.85 5.32 5.89 6.46 7.13 7.79 8.65 9.50 10.45 11.40 12.35 14.25 15.20 17.10 19.00 20.90 22.80 25.65 28.50 31.35 34.20 37.05 40.85 44.65 48.45 53.20 58.90 64.60 71.25 ZZT (Ω) @ IZK ZZK (Ω) @ IZT (mA) 100 600 1.0 100 600 1.0 100 600 1.0 100 600 1.0 95 600 1.0 95 600 1.0 90 600 1.0 90 600 1.0 90 600 1.0 80 500 1.0 60 480 1.0 40 400 1.0 10 150 1.0 15 80 1.0 15 80 1.0 15 80 1.0 15 100 1.0 20 150 1.0 20 150 1.0 25 150 1.0 30 170 1.0 30 200 1.0 40 200 1.0 45 225 1.0 55 225 1.0 55 250 1.0 70 250 1.0 80 300 0.5 80 300 0.5 80 325 0.5 0.5 90 350 130 350 0.5 100 700 1.0 100 750 1.0 100 750 1.0 200 400 0.5 215 423 0.5 240 447 0.5 255 470 0.5 em Max.  S WY 22• WX W1 W2 W3 W4 W5 W6 W7 W8 W9 WA WB WC WD WE WF WG WH WI WJ WK WL WM WN WO WP WQ WR WS WT WU WV WW WX• WY• WZ 6H Typ. Temperature Coefficient @ IZT TC (mV/°C) Maximum Zener Impedance @ IZT (mA) Min. JS MI BZT52C2V0SQ BZT52C2V2SQ BZT52C2V4SQ BZT52C2V7SQ BZT52C3V0SQ BZT52C3V3SQ BZT52C3V6SQ BZT52C3V9SQ BZT52C4V3SQ BZT52C4V7SQ BZT52C5V1SQ BZT52C5V6SQ BZT52C6V2SQ BZT52C6V8SQ BZT52C7V5SQ BZT52C8V2SQ BZT52C9V1SQ BZT52C10SQ BZT52C11SQ BZT52C12SQ BZT52C13SQ BZT52C15SQ BZT52C16SQ BZT52C18SQ BZT52C20SQ BZT52C22SQ BZT52C24SQ BZT52C27SQ BZT52C30SQ BZT52C33SQ BZT52C36SQ BZT52C39SQ BZT52C43SQ BZT52C47SQ BZT52C51SQ BZT52C56SQ BZT52C62SQ BZT52C68SQ BZT52C75SQ Marking Code CR O Part Number Zener Voltage VZ (V) 150.000 150.000 50.000 20.000 10.000 5.000 5.000 3.000 3.000 3.000 2.000 1.000 3.000 2.000 1.000 0.700 0.500 0.200 0.100 0.100 0.100 0.100 0.100 0.100 0.100 0.100 0.100 0.100 0.100 0.100 0.100 0.100 0.100 0.100 0.100 0.045 0.045 0.045 0.045 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 2.0 2.0 2.0 4.0 4.0 5.0 5.0 6.0 7.0 8.0 8.0 8.0 10.5 11.2 12.6 14.0 15.4 16.8 18.9 21.0 23.1 25.2 27.3 32.0 35.0 38.0 39.2 43.4 47.6 52.5 第2/4页 BZT52C2V0SQ-BZT52C75SQ SMT-Type Zener Diode TYPICAL CHARACTERISTICS (@ TA = 25°C unless otherwise specified) 20 0.1 0 75 50 100 150 125 TA , AMBIENT TEMPERATURE (°C) 10 em  S 18 Test Current IZ 2mA 22 10 CR O IZ, ZENER CURRENT (mA) 15 20 27 Test Current IZ 5mA 33 JS MI 0 or 4V7 5V1 5 0 0 5V6 6V2 6V8 7V5 2 8 4 6 V Z, ZENER VOLTAGE (V) 10 10 12 0 4V3 10 ic TJ = 25°C 3V9 Fig. 2 Typical Zener Breakdown Characteristics Fig. 1 Power Derating Curve 30 3V3 3V6 on 25 10 20 36 IZ, ZENER CURRENT (mA) 0 15 ct 0.2 2V0 2V4 2V7 3V0 du 0.3 IZ, ZENER CURRENT (mA) PD, POWER DISSIPATION (W) 0.4 8 6 4 2 30 0 40 0 10 20 VZ, ZENER VOLTAGE (V) Fig. 3 Typical Zener Breakdown Characteristics 30 40 50 60 70 80 VZ , ZENER VOLTAGE (V) 90 100 Fig. 4 Typical Zener Breakdown Characteristics 0.020 0.100 0.015 IZ = 5mA 0.080 TC of VZ (%/C) TC of VZ (%/C) 0.010 IZ = 5mA 0.005 IZ = 50μA 0.000 -0.005 -0.010 0.060 0.040 0.020 0.000 -0.015 -0.020 IZ = 50μA 0 2 4 6 8 -0.020 10 VZ, ZENER VOLTAGE (V) 10 20 30 40 50 60 70 80 VZ, ZENER VOLTAGE (V) Fig. 5 Typical Temperature Coefficient of Zener Voltage Fig. 6 Typical Temperature Coefficient of Zener Voltage www.jsmsemi.com 第3/4页 BZT52C2V0SQ-BZT52C75SQ SMT-Type Zener Diode PACKAGE OUTLINE (Unit: mm) Plastic surface mounted package K C SOD-323 Min. A 1.60 B 1.20 B D C 0.25 0.35 0.22 0.42 H 0.02 0.10 J 0.05 0.15 2.55 2.75 du on J 1.40 0.90 E E 1.80 0.80 D H Max. ct Dimension or A em ic K  S MOUNTING PAD LAYOUT (Unit: mm) CR O 0.63 JS MI 0.83 1.60 2.85 PACKAGE INFORMATION Part Number Package Shipping Quantity BZT52C2V0SQ - BZT52C75SQ SOD-323 3000pcs / Tape & Reel www.jsmsemi.com 第4/4页
BZT52C10SQ 价格&库存
很抱歉,暂时无法提供与“BZT52C10SQ”相匹配的价格&库存,您可以联系我们找货
