SLO1770H Series
SMD Molding Power Inductor
◆ Features
Pb
、Magnetically shielded construction, low DC resistance;
、The use of magnetic iron powder ensure capability
for large current;
3、Low audible core noise;
4、Ideal for DC-DC converter applications in hand held
personal computer and etc;
5、Frequency Range: up to 3.0MHz;
6、RoHS compliant。
1
2
◆ Applications
、Smart phone、MID;
、Next-generation mobile devices with multifunction such
as adding color TV and digital movie cameras;
3、Flat-screen TVs, blue-ray disc recorders, set top box;
4、Notebooks, desktop computers, servers, graphic cards;
5、Portable gaming devices, personal navigation systems,
personal multimedia devices;
6、Automotive systems;
7、Telecomm base stations。
1
2
◆ Lead Free Part Numbering
SLO
(1)
1770
(2)
H
(3)
(1)
(2)
(3)
(4)
2R2 M
(4) (5)
T
T
(6) (7)
Series Type
Dimension A X C
Material Code
Inductance 2R2=2.2μH
100=10μH 101=100μH
(5) Inductance Tolerance M= 20%, Y= 30%
(6) Company Code
(7) Packaging packed in embossed carrier tape
◆ Dimensions
Series
SLO1770H
Rev.02
A (mm)
B (mm)
C (mm)
17.50 Max
17.50 ±0.1
7.0 Max
Page 1 of 7
D±0.3 (mm) E±0.3 (mm)
11
2.0
www.sunltech.com
SLO1770H Series
◆ Specification
Test a
condition
SATURATION
CURRENT(Isat)
DC AMPS2
(Typ.)
HEAT RATING
CURRENT(Idc)
DC AMPS1
(Typ.)
2.3
100KHz/1V
40
31
2.2
2.5
100KHz/1V
34
29
SLO1770H3R3MTT
3.3
3.95
100KHz/1V
30
24
SLO1770H4R7MTT
4.7
4.75
100KHz/1V
24
21
SLO1770H6R8MTT
6.8
7.5
100KHz/1V
22
17
SLO1770H8R2MTT
8.2
8.7
100KHz/1V
SLO1770H100MTT
10
9.9
100KHz/1V
19
12
SLO1770H150MTT
15
17
100KHz/1V
14.5
11
SLO1770H220MTT
22
23
100KHz/1V
11.5
8.5
SLO1770H330MTT
33
37
100KHz/1V
10
8.0
SLO1770H470MTT
47
47
100KHz/1V
7.5
6.0
SLO1770H680MTT
68
85
100KHz/1V
6.5
5.2
SLO1770H101MTT
100
130
100KHz/1V
5.0
3.7
Ω
INDUCTAN
CE
Lo( H)
Rdc
(m )
SLO1770H1R5MTT
1.5
SLO1770H2R2MTT
Part Number
μ
Max
SLO1770H Series
NOTES:
1. DC current (Idc) that will cause an approximate T of 40
2. DC current (Isat) that will cause Lo to drop approximately 20%
3. All test data is referenced to 25 ambient
4. Operating Temperature Range -55 to +150
5. The part temperature (ambient + temp rise) should not exceed 150
under the worst operating conditions. Circuit design, component placement,
PWB trace size and thickness, airflow and other cooling provisions all affect
the part temperature. Part temperature should be verified in the end application.
Rev.02
Page 2 of 7
www.sunltech.com
SLO1770H Series
◆ Reliability Test
Item
Specification and Requirement
1. No case deformation or change in
Solderability
apperarance
shock
apperarance
2.
1.Preheat
:155℃±5℃ ,60S±2S
2.Tin: lead-free.
2. New solder coverage More than 90%
Mechanical
Test Method
△L/Lo≦±10%
℃±5℃,flux 3.0S±0.5S.
3.Temperature:245
: 100G
2. Pulse time::6ms
1. Acceleration
3. 3 times in each positive and negative direction of 3
mutual perpendicular directions
apperarance
2.
1. The test samples shall be soldered to the board.
Then it shall be submitted to below test conditions.
△L/Lo≦±10%
Mechanical
vibration
Fre. Range
10~55Hz
Total Amplitude
1.5mm
Sweeping Method
10Hz to 55Hz to 10Hz
Time
For 2 hours on each X,Y,Z axis.
2. Recovery: At least 2 hours of recovery under the
standard condition after the test, followed by the
measurement within 24 ±2 hours.
℃ for 30 minutes,last 125℃ for 30
Inductance change:
1. First -55
Within ± 10% Without distinct damage
Thermal Shock
in appearance
minutes as 1 cycle. Go through 1000 cycles.
2. Max transfer time is 2 minutes.
3. Measured at room temperature after placing for
24±2 hours
Humidity
Resistance
Inductance change:
1.Reflow 2 times,
2.85
in appearance
3.Measured at room temperature after placing for
℃,85%RH,1000 hours
24±2 hours
Low
temperature
storage
High
temperature
storage
Rev.02
Inductance change:
1. Temperature -55 ± 2
2. Time 1000 hours
in appearance
24±2 hours
:+125 ± 2℃
Inductance change:
1. Temperature
2. Time 1000 hours
in appearance
24±2 hours
Page 3 of 7
www.sunltech.com
SLO1770H Series
Inductance change:
2、Place the 100mm X 40mm board into a fixture
1 Run through IR reflow for 2 times
in appearance
similar to the one shown in below Figure with the
component facing down
3 The apparatus shall consist of mechanical means
to apply a force which will bend the board (D) x = 2
mm minimum.
4 The duration of the applied forces shall be 60±5
sec. The force is to be applied only once to the oard.
Board Flex
No removal or split of the termination or
other defects shall occur.
2、Push the product vertically from the side of the
1 The test samples shall be soldered to the board
sample using the thrust tester.
3 Automotive electronics
:17.7N,60S±1s,X ,
Ydirect.
Terminal
Strength
Rev.02
Page 4 of 7
www.sunltech.com
SLO1770H Series
◆ Recommended Soldering Technologies
(1) Re-flowing Profile
Preheat condition: 150 ~200℃/60~180sec.
Allowed time above 217℃: 80~120sec.
Max temp: 260℃
Max time at max temp: 10 sec.
Solder paste: Sn/3.0Ag/0.5Cu
Allowed Reflow time: 2x max
(2) Iron Soldering Profile
Iron soldering power: Max. 30W
Pre-heating: 150℃/60sec.
Soldering time: 3sec. Max.
Max.1 times for iron soldering
Rev.02
Page 5 of 7
www.sunltech.com
SLO1770H Series
◆ Packaging Information
(Unit:mm)
(1) Tape Packaging Dimensions
D0
P2
E
P0
W
B0
F
T
A0
p
KO
Tape dimensions (mm)
Type
CMLO1770
W
P
P0
P2
D0
T
A0
B0
K0
E
F
32
24
4.0
2.0
1.5
0.5
17.5
18.1
7.3
1.75
14.2
±0.3 ±0.1 ±0.1 ±0.1 ±0.1 ±0.05 ±0.1 ±0.1 ±0.1 ±0.1 ±0.1
Taping Drawings (UNIT:mm)
Rev.02
Page 6 of 7
www.sunltech.com
SLO1770H Series
(Unit:mm)
(2) Reel Dimensions
B
N
C
W
A
±2.0
330
W
32.0
N
±0.5
B
±0.3
97 0.5
2.3
C
13.0
±0.2
(3) Packaging Quantity(PCS)
Standard Quantity
Type
Reel
SLO1770
Inner box
200 pcs / reel
2Reel / box (400 pcs)
Carton box
3 Middle boxes,
(1200 pcs)
(4) Peel force of top cover tape
The peel speed shall be about 300mm/minute
The peel force of top cover tape shall be between 0.1 to 1.3 N
Rev.02
Page 7 of 7
www.sunltech.com
A
很抱歉,暂时无法提供与“SLO1040H1R0MTT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.31496
- 50+1.10573
- 150+1.01606
- 型号:SLO1040H1R0MTT
- 品牌:Sunltech(顺磁)
- 封装:IND_10.8X10MM_SM
- 描述:特性:磁屏蔽结构,低直流电阻。使用磁铁粉确保大电流能力。低可听磁芯噪声。频率范围:高达3.0MHz。符合RoHS标准。应用:智能手机,MID。具有多功能的下一代移动设备,如添加彩色电视和数字电影摄像机。平板电视,蓝光光盘录像机,机顶盒。笔记本电脑,台式电脑,服务器,显卡。便携式游戏设备,个人导航系统,个人多媒体设备。汽车系统。电信基站
- 国内价格
- 5+1.44915
- 50+1.21857
- 150+1.11975
