Form No:
Specification for Approval
Date: 2021/08/09
Customer :
天诚科技
TAI-TECH P/N:
WCM3216F2SF-121T04
CUSTOMER P/N:
DESCRIPTION:
QUANTITY:
REMARK:
Customer Approval Feedback
西 北 臺 慶 科 技 股 份 有 限 公司
TAI-TECH Advanced Electronics Co., Ltd
Sales Dep.
Headquarter:
NO.1 YOU 4TH ROAD, YOUTH INDUSTRIAL DISTRICT, YANG-MEI,
TAO-YUAN HSIEN, TAIWAN, R.O.C.
TEL: +886-3-4641148 FAX: +886-3-4643565
http://www.tai-tech.com.tw
E-mail: sales@tai-tech.com.tw
APPROVED
CHECKED
夏暁曼
夏暁曼
R&D Center
APPROVED
CHECKED
DRAWN
羅宜春
梁周虎
卜文娟
□ 臺慶精密電子(昆山)有限公司
TAI-TECHADVANCEDELECTRONICS(KUNSHAN)CO., LTD
SHINWHA ROAD, KUNJIA HI-TECH INDUSTRIAL PARK, KUN-SHAN,
JIANG-SU, CHINA
TEL: +86-512-57619396 FAX: +86-512-57619688
E-mail: hui@tai-tech.com.tw
TA734003
TAI-TECH
P2
Wire Wound Type Common Mode Filter
WCM3216F2SF-121T04
1. Features
1. High common mode impedance at high frequency cause excellent noise
Halogen
suppression performance.
2. WCM3216F2SF series realizes small size and low profile. 3.2x1.6x2.0 mm.
Halogen-free
3. 100% Lead(Pb) & Halogen-Free and RoHS compliant.
4. Operating temperature-40~+125℃ (Including self - temperature rise)
2. Dimension
E
C
A
B
A(mm)
B(mm)
C(mm)
D1(mm)
D2(mm)
E(mm)
3216F2SF
3.2±0.2
1.6±0.2
2.0±0.2
0.5±0.1
0.5±0.1
0.15±0.1
D
Series
D
Units: mm
3. Part Numbering
WCM 3216
A
B
F
2
S
F
C
D
E
F
A: Series
B: Dimension
C: Material
D: Number of Lines
E: Type
F: Lead free type
G: Impedance
H: Packaging
I: Rated Current
121
T
04
G
H
I
Ferrite Core
2=2 lines
S=Shielded , N=Unshielded
121=120Ω
T=Taping and Reel
04=400mA
4. Specification
TAI-TECH
Part Number
WCM3216F2SF-121T04
DC
Common mode
Impedance Test Frequency Resistance
(MHz)
(Ω)
(Ω) max.
120±25%
100
Rated Current
(mA)max.
0.30
www.tai-tech.com.tw
400
Withstand
IR
Rated Volt.
(Vdc)max. Volt. (Vdc) (Ω) min.
Max.
50
125
10M
TAI-TECH
P3
Typical Impedance v.s. Frequency Curve
WCM3216F2SF-121
IMPEDANCE(Ohm)
1000
100
Common Mode
10
Normal Mode
1
0.1
1
10
100
1000
FREQUENCY(MHz)
5. Schematic Diagram
6. Materials
No.
Description
Specification
a.
Upper Plate
Ferrite
b.
Core
Ferrite Core
c
Termination
Ag/Ni/Sn
d
Wire
Enameled Copper Wire
www.tai-tech.com.tw
10000
TAI-TECH
P4
7. Reliability and Test Condition
Item
Performance
Storage temperature
-40~+125℃ (on board)
Test Condition
Electrical Performance Test
Z(common mode)
Agilent-4291A+ Agilent -16197A
Refer to standard electrical characteristics list.
Agilent-4338B
I.R.
Agilent4339
Temperature Rise Test
Rated Current ΔT 40℃Max
1.Applied the allowed DC current.
2.Temperature measured by digital surface thermometer
DCR
Reliability Test
Preconditioning: Run through IR reflow for 3 times.( IPC/JEDEC
J-STD-020E Classification Reflow Profiles)
Temperature:125±2℃
Life Test
Applied current:rated current
Duration:1000±12hrs
Measured at room temperature after placing for 24±2 hrs
Humidity:85±2% R.H,
Load Humidity
Temperature:85℃±2℃
Duration : 1000hrs Min. Bead : with 100% rated current ,
Inductance: with 10% rated current
Moisture Resistance
Appearance:No damage.
Impedance:within±15% of initial value
RDC:within ±15% of initial value and shall not
exceed the specification value
Profiles
1. Baked at50℃ for 25hrs, measured at room temperature after
placing for 4 hrs.
2. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and
keep 3 hours, cool down to 25℃ in 2.5hrs.
3. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and
2.5hrs,keep at 25℃ for 2 hrs then keep at -10℃ for 3 hrs
4. Keep at 25℃ 80-100%RH for 15min and vibrate at the
frequency of 10 to 55 Hz to 10 Hz, measure at
room temperature after placing for 1~2 hrs.
Reflow Profiles
Condition for 1 cycle
Step1:-40±2℃ 30±5min
Thermal
shock
Step2:25±2℃ ≦0.5min
Step3:125±2℃ 30±5min
Number of cycles: 500
Oscillation Frequency: 10Hz~2KHz~10Hz for 20 minute
Equipment: Vibration checker
Total Amplitude:10g
Testing Time : 12 hours(20 minutes, 12 cycles each of 3
orientations)。
Vibration
www.tai-tech.com.tw
TAI-TECH
Item
P5
Performance
Bending
Test Condition
Shall be mounted on a FR4 substrate of the
following dimensions: >=0805 inch(2012mm):40x100x1.2mm
=0805 inch(2012mm):1.2mm
0805:1kg ,
很抱歉,暂时无法提供与“WCM3216F2SF-121T04”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.65934
- 50+0.53482
- 150+0.47261
- 500+0.42596
- 国内价格
- 10+0.71426
- 100+0.65233
- 500+0.59040
- 1000+0.52847
- 2000+0.48718
- 4000+0.47480
