芯力特
SIT1040
5V,±40V BUS Protection,1Mbps High Speed CAN transceiver
FEATURES
OUTLINE
Fully compatible with the ISO 11898 standard
Thermally protected
Input levels compatible with 3.3 V and 5 V devices
Transmit Data (TXD) dominant time-out function
Very low-current standby mode with remote wake-up
Capability via the bus: 5μA Typical
Transceiver in unpowered state disengages from the
bus (zero load)
Provide Green and Environmentally
At least 110 nodes can be connected
Friendly Lead-free package
High speed (up to 1 MBaud)
*Provide HVSON8 / DFN3*3-8,
Very low Electro Magnetic Emission (EME)
Small Outline,Leadless Package
DESCRIPTION
The SIT1040 is the interface between the Controller Area Network (CAN) protocol controller and
the physical bus. It is primarily intended for high speed applications, up to 1 MBaud, in passenger cars.
The device provides differential transmit capability to the bus and differential receive capability to the
CAN controller.
PARAMETER
SYMBOL
CONDITION
Supply voltage
Vcc
Maximum transmission rate
1/tbit
CANH/CANL
input or output voltage
Vcan
-40
+40
V
Bus differential voltage
Vdiff
1.5
3.0
V
Virtual junction temperature
Tamb
-40
125
ESD
Vesd
Non-return to zero code
HBM
MIN.
MAX.
UNIT
4.5
5.5
V
1
±8
Mbaud
KV
PIN CONFIGURATION
TXD
STB
GND
VCC
CANH
SIT1040
RXD
REC V1.14 2022.01
CANL
SPLIT
1 / 15
www.sitcores.com
芯力特
SIT1040
LIMITING VALUES
PARAMETER
SYMBOL
VALUE
UNIT
Supply voltage
VCC
-0.3~+6
V
DC voltage on
TXD/RXD/STB pins
TXD,RXD,STB
-0.3~VCC+0.3
V
Voltage range at any bus
terminal (CANH, CANL,
SPLIT)
CANL,CANH,SPLIT
-40~40
V
Transient voltage on pins
CANH, CANL
and SPLIT
see Fig.7
Vtr
-200~+200
V
Storage temperature
-55~150
Virtual junction
temperature
-40~125
Welding temperature
range
300
The maximum limit parameters means that exceeding these values may cause irreversible damage to the
device. Under these conditions, it is not conducive to the normal opration of the device. The continuous
operation of the device at the maximum allowable rating may affect the reliability of the device. The
reference point for all voltages is ground.
PINNING
PIN
SYMBOL
DESCRIPTION
1
TXD
transmit data input
2
GND
ground supply
3
VCC
supply voltage
4
RXD
receive data output; reads out datafrom the bus lines
5
SPLIT
common-mode stabilization output
6
CANL
LOW-level CAN bus line
7
CANH
HIGH-level CAN bus line
8
STB
standby mode control input
REC V1.14 2022.01
2 / 15
www.sitcores.com
芯力特
SIT1040
DRIVER ELECTRICAL CHARACTERISTICS
PARAMETER
SYMBOL
CONDITION
MIN.
TYP.
MAX.
CANH dominant
output voltage
VOH(D)
2.9
3.4
4.5
CANL dominant
output voltage
VOL(D)
VI=0V, STB=0V,
RL=60Ω,
Fig.1, Fig.2
Bus recessive output
voltage
Bus dominant
differential output
voltage
0.8
VO(R)
VI=3V, STB=0V,
RL=60Ω,
Fig.1, Fig.2
2
VOD(D)
VI=0V, STB=0V,
RL=60Ω,
Fig.1, Fig.2
UNIT
1.5
2.5
3
V
1.5
3
V
VI=3V, S=0V,
Fig.1, Fig.2
-0.012
0.012
V
VI=3V, STB=0V,
NO LOAD
-0. 5
0.05
V
Bus recessive
differential output
voltage
VOD(R)
Transmitter dominant
voltage symmetry
Vdom(TX)sym
Vdom(TX)sym=VCCVCANH - VCANL
-400
400
mV
Transmitter voltage
symmetry
VTXsym
VTXsym= VCANH +
VCANL
0.9VCC
1.1VCC
V
Common-mode output
voltage
VOC
STB=0V, Fig.8
2
3
V
Peak-to-peak
Common-mode output
voltage
VOC
CANH=-12V,
CANL=open,
Fig.11
Short-circuit output
current
IOS
-105
CANH=12V,
CANL=open,
Fig.11
CANL=-12V,
CANH=open,
Fig.11
IO(R)
-27V
很抱歉,暂时无法提供与“SIT1040T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.68520
- 50+2.14620
- 500+1.62680
- 1000+1.60240
- 2500+1.48960
