ESD5681NXX
ESD5681NXX
1-Line, Uni-directional, Transient Voltage Suppressor
http//:www.sh-willsemi.com
Descriptions
The ESD5681NXX is a transient voltage suppressor
designed to protect power interfaces. It is suitable to replace
multiple discrete components in portable electronics.
The ESD5681NXX is specifically designed to protect USB
port. TVS diode with higher surge capability is used to protect
USB voltage bus pin.
DFN1006-2L (Bottom View)
The ESD5681NXX is available in DFN1006-2L package.
Standard products are Pb-free and Halogen-free.
Pin1
Pin2
Features
Reverse stand-off voltage: 7V ~ 15V
Surge protection according to IEC61000-4-5
Circuit diagram
see Table 4
ESD protection according to IEC61000-4-2
Low clamping voltage
Solid-state silicon technology
±30kV (contact and air discharge)
Pin1
Applications
Power supply protection
Power management
x*
Pin2
X
= Device code(I,J,W)
= Month code
Marking (Top View)
Order information
Table 1.
Device
Package
Shipping
Marking
ESD5681N07-2/TR DFN1006-2L 10000/Tape&Reel
I*
ESD5681N12-2/TR DFN1006-2L 10000/Tape&Reel
J*
ESD5681N15-2/TR DFN1006-2L 10000/Tape&Reel
W*
Will Semiconductor Ltd.
1
Revision 1.3, 2017/09/18
ESD5681NXX
Absolute maximum ratings
Table 2.
Parameter
Peak pulse power (tp=8/20μs)
ESD according to IEC61000-4-2 air discharge
Symbol
Rating
Unit
Ppk
450
W
±30
VESD
ESD according to IEC61000-4-2 contact discharge
Junction temperature
±30
TJ
Operating temperature
TOP
Lead temperature
TL
Storage temperature
TSTG
kV
125
o
-40~85
o
260
o
-55~150
o
C
C
C
C
Electrical characteristics (TA = 25oC, unless otherwise noted)
I
IPP
VF
Forward voltage
VRWM Reverse stand-off voltage
IF
Forward current
IR
Reverse leakage current
VFC
Forward clamping voltage
VBR
Reverse breakdown voltage
IPP
Peak pulse current
VCL
Clamping voltage
IPP
Peak pulse current
VFC VF
IBR
IR
VRWM VBR VCL
V
IF
IPP
Definitions of electrical characteristics
2
ESD5681NXX
o
Electrical characteristics (TA = 25 C, unless otherwise noted)
Table 3.
Reverse
Stand off
Type number
Breakdown voltage
Voltage
VBR(V)
IBR = 1mA
VRWM (V)
Junction
Reverse
leakage current
IRM(nA) at VRWM
Forward voltage
capacitance
VF(V) IF = 20mA
F=1MHz,
VR=0V (pF)
Max.
Min.
Typ.
Max.
Typ.
Max.
Min.
Max.
Typ.
Max.
ESD5681N07
7
8.0
9.0
10.0
10
1000
0.45
1.25
140
210
ESD5681N12
12
13.0
15.0
17.0
1
100
0.45
1.25
80
120
ESD5681N15
15
16.0
18.0
20.0
0.5
50
0.45
1.25
65
100
Table 4.
Type number
Rated peak pulse
current IPP (A)
1)3)
Clamping voltage
VCL(V) at IPP(A)
1)3)
Clamping voltage
VCL(V) at
IPP = 16A,
tp = 100ns
2)3)
Clamping voltage
VCL(V) at
VESD = 8kV
ESD5681N07
27
16
11
11
ESD5681N12
18
24
19
19
ESD5681N15
15
29
22
24
2)3)
Notes:
1) Non-repetitive current pulse, according to IEC61000-4-5.(8/20μs current waveform)
2) Non-repetitive current pulse, according to IEC61000-4-2.
3) Measured from pin 1 to pin 2.
3
ESD5681NXX
o
Time to half-value: T2= 20s
50
T2
10
10
T5
10
T1
15
Time (s)
32
CJ - Junction capacitance (pF)
28
26
24
22
16
14
12
ESD5681N07
ESD5681N12
ESD5681N15
10
8
-3
6
9
12
15
18
21
24
27
Time (ns)
Contact discharge current waveform per IEC61000-4-2
Pulse waveform:tp=8/20μS
30
tr = 0.7~1ns
t
60ns
30ns
30
8/20μs waveform per IEC61000-4-5
Vc-Clamping Voltage (V)
100
90
Front time: T1= 1.25 T = 8s
100
90
Current (%)
Peak pulse current (%)
Typical characteristics (TA = 25 C, unless otherwise noted)
150
140
130
120
110
100
90
80
70
60
50
40
30
30
f = 1MHz
VAC = 50mV
ESD5681N07
ESD5681N12
ESD5681N15
4
6
8
10
12
14
16
18
VR - Reverse voltage (V)
Ipp-Peak Pulse Current (A)
Clamping voltage vs. Peak pulse current
Capacitance vs. Reverse voltage
1000
% of Rated power
Peak pulse power (W)
100
100
1
10
100
Pulse time (s)
60
40
50
75
100
125
150
o
TA - Ambient temperature ( C)
Non-repetitive peak pulse power vs. Pulse time
80
Power derating vs. Ambient temperature
4
PACKAGE OUTLINE DIMENSIONS
DFN1006-2L
b
CATHODE MARKING
(Ⅰ)
L
E
(Ⅱ)
D
e
Top View
Bottom View
(Ⅲ)
(Ⅰ)
A
(Ⅱ)
A3
A1
Side View
Dimensions in Millimeters
Symbol
Min.
Typ.
Max.
A
0.340
0.450
0.530
A1
0.000
0.020
0.050
A3
0.125 Ref.
D
0.950
1.000
1.075
E
0.550
0.600
0.675
b
0.200
0.250
0.300
L
0.450
0.500
0.550
e
0.650 BSC
Recommended PCB Layout (Unit: mm)
0.55
0.60
0.30
Notes:
This recommended land pattern is for reference
0.85
1.40
purposes only. Please consult your manufacturing
group to ensure your PCB design guidelines are met.
5
TAPE AND REEL INFORMATION
RD
Reel Dimensions
W
Tape Dimensions
P1
Quadrant Assignments For PIN1 Orientation In Tape
Q1
Q2
Q1
Q2
Q3
Q4
Q3
Q4
User Direction of Feed
RD
Reel Dimension
7inch
13inch
W
Overall width of the carrier tape
8mm
12mm
P
Pitch between successive cavity centers
2mm
4mm
8mm
Pin1 Quadrant
Q1
Q2
Q3
Pin1
6
Q4
很抱歉,暂时无法提供与“ESD5681N07-2/TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.29260
- 500+0.19470
- 5000+0.16940
- 10000+0.15400
- 国内价格
- 20+0.30975
- 200+0.23922
- 600+0.20002
