CX70M-24P2
CX70M-24P2
    HRS(广濑)
    SMD
    USB连接器 Type-C 24P 卧贴 端口数:1 额定电流:5A 额定电压:48V 工作温度:-30℃~+105℃
CX70M-24P2 数据手册
USB Type-C Connector CX Series Feb.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. USB from Hirose Electric : Standard connections, inspired solutions. Note: Please contact HIROSE for TID acquisition status of each product. ■ Overview The CX series connector conforms to the next-generation USB standard “USB Type-C™”. It is expected to be widely adopted as a standard interface in various devices in the consumer, industrial machinery and automobile market. ※“USB Type-C™” is a registered trademark of USB Implementers Forum, INC Mid-mount Fig.1 ■ Features Fig.2 1. Easy mating with reversible form factor The symmetrical design eliminates concern for backward insertion. Simply insert the plug in either direction. 2. Conforms to the USB type-C standard 3. USB 3.1 Gen2, 10Gbps high speed transmission Fig.3 USB Type-C can transfer data twice as fast compared to a conventional USB 3.0 (5Gbps), 10Gbps (Max.) Also, if alternate mode is applied, it becomes possible to meet various video transmission standards such as MHL and Display Port. 4. Clear tactile click (Excellent Retention) CX series has a superior “click feel” when mating and is designed to prevent incomplete mating. Top-mount Fig.4 5. Design for superior mechanical strength Fig.5 6. Many varieties SMT+THR Hybrid type (Mid-mount) : Fig.1 Waterproof (Mid-mount) : Fig.2 Single-row SMT (Mid-mount/16PIN) : Fig.3 Vertical (Top-mount) : Fig.4 Double-row SMT (Top-mount) : Fig.5 Plug Harness Fig.6 7. Plug harness with slim overmold Type-C (C-to-C Type) : Fig.6 8. RoHS compliant, halogen-free product CX series is halogen-free product. (Maximum content of Br, Cl and Br+Cl total are 900ppm, 900ppm and 1500ppm, respectively.) In cases where the application will demand a high level of reliavility, such as automotive, please contact a company representative for further information. 2018�09 1 CX Series ● USB Type-C Connector ■ Product Specifications Ratings Rated Current Items 1. Contact resistance 2. Withstand voltage 3. Durability Feb.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 4. Overall insertion / Extraction forces DC 1.25A max. for each power pin (i.e. A1, A4, A9, A12, B1, B4, B5, B9, B12) DC 0.25A for the other pins 40mΩ max. Specifications Rated Voltage AC 20V Operating Temp. Range -40℃ to + 85℃ (Note 1, 2) Storage Temp. Range -10℃ to + 60℃ Conditions Measured at 100mA (DC or 1000Hz) No flashover or breakdown 100V AC / 1min. Insertion : 5~20N, Extraction : 8~20N Measured with applicable connector Contact resistance : Increase by 10mΩ or less from 10,000 mating cycles the initial value Note 1 : Includes temperature rise caused by current flow. Note 2 : The above specifications are representative of this series. Please refer to product specsheet for detail each of products. Note 3 : The above specifications are representative of this series. Hirose does not guarantee specified performance when mating with other manufacturers’ parts. ■ Materials / Finish ● Receptacle Parts Materials Insulator LCP or Polyamide Contact Copper alloy Ground-plate Stainless steel - Stainless steel Nickel plating Mid plate Shell ● Plug Parts Stainless steel Materials Insulator LCP or Polyamide Contact Copper alloy Lock spring Stainless steel Ground spring Shield Stainless steel Stainless steel Black/UL94V-0 Color/Finish Mating part : Gold flash plating over Nickel-palladium plating Mounting part : Gold flash plating Nickel plating Black/UL94V-0 Color/Finish Mating part:Gold flash plating over Nickel-palladium plating Mounting part:Gold flash plating Nickel plating Nickel plating Nickel plating ※ This is a halogen-free product. (Maximum content of Br, Cl and Br+Cl total are 900ppm and 1500ppm, respectively.) Note : The above data is representative of this series. Data may vary according to specifications. 2 CX Series ● USB Type-C Connector ■ Product Number Configurator Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ● Receptacle CX 90 1 2 3 4 5 ● Plug Feb.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. CX 60 1 2 CX 60 1 2 1 2 CX 60 - 7 6 SLDA 9 6 7 - 1 6 7 8 Mounting type 60 70 80 - UNIT 9 - 1000 C 10 2 Series name 11 3 Board mounting 4 Special Style (Receptacle) 5 No. of serial 6 No. of contact 7 8 9 Contact type No. of serial Plug components 10 Cable length 11 Harness Type 90 B M WD Blank P S UNIT SLDA C CX Paddle Card (PCB wire soldering) Right angle Hybrid (SMT+THR) Straight SMT (Vertical) Right angle SMT Top-mount Mid-mount Waterproof Standard None or 1, 2, 3, ... (CX80, CX90 Series) 16, 24 Receptacle (Male contacts) Plug (Female contacts) None or 1, 2, 3, ... (CX70 Series only) Plug unit Plug shell 1000mm Type C-to-Type-C 3 CX Series ● USB Type-C Connector ■ Product Variation PCB Mounting Type Mounting Method Product Name Size W x H x D (mm) Page CX70M-24P1 11.40x3.66x8.35 5 page CX70M-24P2 11.40x3.66x7.95 5 page Right angle (Double-row SMT) CX90MWD2-24P 11.60x3.46x8.35 6 page Right angle (Single-row SMT) CX90M-16P 11.00x2.96x6.55 6 page Vertical (SMT) CX80B1-24P 8.94x3.14x6.50 7 page Right angle (Double-row SMT) CX90B1-24P 8.94x3.14x8.15 7 page Double-row SMT CX60-24S-UNIT 8.25x2.40x11.10 8 page 3D Image Feb.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Right angle Hybrid (SMT+THR) Mid-mount Receptacle Top-mount Plug Unit 4 Paddle Card Plug Shell ‒ CX60-SLDA 10.25x4.40x23.35 8 page Plug harness ‒ CX60-24S-1000-C 12.35x6.50x1000 9 page CX Series ● USB Type-C Connector ■ Receptacle ● Mid-mount Type (Right angle Hybrid) - Length 8.35mm Part No. Feb.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. CX70M-24P1 HRS No. Packaging 480-0304-0 00 1,500pcs/Reel HRS No. Packaging Recommended PCB layout (Component side) ● Mid-mount Type (Right angle Hybrid) - Length 7.95mm Part No. CX70M-24P2 480-0329-0 00 1,500pcs/Reel Recommended PCB layout (Component side) 5 CX Series ● USB Type-C Connector ● Mid-mount type (Right angle Double-row SMT) - Waterproof (IPX8) Part No. CX90MWD2-24P HRS No. Packaging 480-0609-0 00 1,500pcs/Reel HRS No. Packaging ※ IPX8 waterproof (unmated) test condition : Immersed in 1.5meter of water for 30 minutes Feb.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Recommended PCB layout (Component side) ● Mid-mount type (Right angle Single-row SMT) - 16 Pin Part No. CX90M-16P Recommended PCB layout (Component side) 6 480-0513-0 00 1,600pcs/Reel CX Series ● USB Type-C Connector ● Top-mount type (Vertical SMT) Part No. CX80B1-24P HRS No. Packaging 480-0625-0 00 600pcs/Reel HRS No. Packaging Feb.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Recommended PCB layout (Component side) ● Top-mount type (Right angle Double-row SMT) Part No. CX90B1-24P 480-0497-0 00 1,500pcs/Reel Recommended PCB layout (Component side) 7 CX Series ● USB Type-C Connector ■ Plug ● Plug unit Part No. CX60-24S-UNIT HRS No. 480-0465-0 00 Packaging 150pcs/Tray Feb.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Recommended PCB layout (Component side) ● Plug Shell Part No. CX60-SLDA 8 HRS No. 480-0522-0 00 Packaging 3,000pcs/Reel Cable diameter Φ4.8 CX Series ● USB Type-C Connector ● Plug Harness Part No. 480-0618-0 00 Packaging 1pcs/Vinyl bag Feb.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. CX60-24S-1000-C HRS No. 9 CX Series ● USB Type-C Connector Receptacle Packaging Specification (JIS C 0806-3 compliant) Feb.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ● Emboss Carrier Tape Dimensions Part No. A ● Reel Dimensions B C CX70M-24P1 24 11.5 12 CX80B1-24P 24 11.5 16 CX70M-24P2 CX90B1-24P CX90MWD2-24P CX90M-16P 24 24 24 24 11.5 11.5 11.5 11.5 Part No. CX70M-24P1 12 CX70M-24P2 12 CX90B1-24P 12 12 CX80B1-24P CX90MWD2-24P CX90M-16P D 30 30 30 E 26 26 26 30 26 30 26 30 26 Receptacle Recommended Solder Temperature Profile The temperature profile is based on demonstrated conditions. In individual applications the actual temperature may vary, depending on solder paste type, volume/thickness and board size/thickness. Contact your solder paste and equipment manufacturer for specific recommendations. Note 1 : Reflow is allowed up to 2times with the same conditions. Please allow the parts to return to the ambient temperature before the second run is started. Note 2 : The measured temperature is the temperature of the PCB surface around the connector leads. 10 CX Series ● USB Type-C Connector Precautions Feb.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1. Please handle connectors with care. Excessive external force may damage the connectors. 2. To extract the plug, hold the plug body itself and remove straight from the receptacle. Do not pull on the cable to extract the plug as this may damage the connector. 3. Due to the assembly process there may be some abrasions on the surface of the receptacle. This will not have a negative impact on the performance of the product. 4. Due to external variances, the plating appearance on the surface of the receptacles may differ from lot to lot. This difference will not affect the performance of this product. 11 Feb.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. CX Series ● USB Type-C Connector 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com 12 The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 09/2018. Contents are subject to change without notice for the purpose of improvements.
CX70M-24P2 价格&库存
很抱歉,暂时无法提供与“CX70M-24P2”相匹配的价格&库存,您可以联系我们找货
CX70M-24P2
    CX70M-24P2
    • 1+20.709451+2.68260
    • 10+17.5577310+2.27434
    • 25+16.4614025+2.13233
    • 50+15.6733150+2.03025
    • 100+14.92413100+1.93320
    • 250+13.98944250+1.81213
    • 500+13.32169500+1.72563
    库存:1022
    CX70M-24P2
    • 10+16.8436110+2.18184
    • 25+15.5234525+2.01083
    • 50+14.5978750+1.89094
    • 100+13.72718100+1.77815
    • 250+12.65606250+1.63941
    • 500+11.90174500+1.54170
    库存:1022
    CX70M-24P2
    • 1500+13.767561500+1.78338
    • 3000+13.110923000+1.69833
    • 4500+12.741604500+1.65049
    库存:1022
    CX70M-24P2
      库存:11228
