JSM12N60F
JSM12N60F
    JSMSEMI(杰盛微)
    TO-220F
    600V N沟道MOSFET
JSM12N60F 数据手册
JSM12N60F 600V N-Channnel MOSFET du ct or ●Features: ■ 12.0A, 600V, RDS(on)(Typ) =0.63Ω@VGS=10V ■ Low Gate Charge ■ Low Crss ■ 100% Avalanche Tested ■ Fast Switching ■ Improved dv/dt Capability ●Application: ■ High Frequency Switching Mode Power Supply ■ Active Power Factor Correction IDM ic ID Drain-Source Voltage Drain Current - Continuous(Tc=25C) - Continuous(Tc=100C) Drain Current em VDSS on Absolute Maximum Ratings(Tc=25C unless otherwise noted) Symbol Parameter -Pulsed (Note1) Value Unit 600 V 12.0* A 7.4* A 48* A ±30 V Gate-Source Voltage EAS Single Pulsed Avalanche Energy (Note2) 880 mJ IAR Avalanche Current (Note1) 12.0 A EAR Repetitive Avalanche Energy (Note1) 25 mJ Peak Diode Recovery dv/dt (Note3) 4.5 V/ns CR O dv/dt  S VGSS Power Dissipation(TC =25C) -Derate above 25°C 51 W 0.41 W/C Tj Operating Junction Temperature 150 C -55 to+150 C Max Unit JS MI PD Tstg Storage Temperature Range * Drain Current Limited by Maximum Junction Temperature. Thermal Characteristics Symbol Parameter RθJC Thermal Resistance,Junction to Case 2.45 C /W RθJA Thermal Resistance,Junction to Ambient 62.5 C /W www.jsmsemi.com 第1/5页 JSM12N60F 600V N-Channnel MOSFET IDSS Zero Gate Voltage Drain Current Gate-Body Leakage Current,Forward IGSSF Gate-Body Leakage Current,Reverse IGSSR On Characteristics VGS(th) Gate Threshold Voltage RDS(on) Static Drain-Source On-Resistance Forward Transconductance Unit 600 -- -- V -- 0.7 -- V/C ----- ----- 1 10 100 -100 μA μA nA nA -4.0 0.63 0.80 V Ω -- 7.8 -- S ---- 1760 182 21 ---- pF pF pF -------- 30 85 140 90 48 8.5 21 -------- ns ns ns ns nC nC nC ------ ---425 4.31 12 48 1.3 --- A A V ns μC ID=250μA (Referenced to 25C) VDS=600V,VGS=0V VDS=480V,Tc=125C VGS=+30V, VDS=0V VGS=-30V, VDS=0V VDS= VGS, ID=250μA VGS=10 V, ID=6.0A VDS=40 V, ID=6.0A on gFS Max or Breakdown Voltage Temperature Coefficient Typ 2.0 -- du △BVDSS /△TJ Min ct Electrical Characteristics(Tc=25C unless otherwise noted) Symbol Parameter Test Conditons Off Characteristics BVDSS Drain-source Breakdown Voltage VGS=0V ,ID=250μA (Note4) JS MI CR O  S em ic Dynamic Characteristics Input Capacitance Ciss VDS=25V,VGS=0V, Output Capacitance Coss f=1.0MHz Reverse Transfer Capacitance Crss Switching Characteristics Turn-On Delay Time td(on) Turn-On Rise Time tr VDD = 300 V, ID = 12 A, RG = 25 Ω (Note4,5) Turn-Off Delay Time td(off) Turn-Off Fall Time tf Total Gate Charge Qg VDS = 480 V, ID =12 A, Gate-Source Charge Qgs VGS = 10 V (Note4,5) Gate-Drain Charge Qgd Drain-Source Diode Characteristics and Maximum Ratings Maximum Continuous Drain-Source Diode Forward Current IS Maximum Pulsed Drain-Source Diode Forward Current ISM Drain-Source Diode Forward Voltage VGS =0V,IS=12.0A VSD Reverse Recovery Time trr VGS =0V, IS=12.0A, d IF /dt=100A/μs (Note4) Reverse Recovery Charge Qrr Notes: 1、Repetitive Rating:Pulse Width Limited by Maximum Junction Temperature. 2、L = 11mH, IAS =12.0A, VDD = 50V, RG = 25 Ω, Starting TJ = 25C. 3、ISD≤12.0A, di/dt≤200A/μs, VDD≤BVDSS, Starting TJ = 25C. 4、Pulse Test : Pulse Width ≤300 µ s, Duty Cycle≤2%. 5、Essentially Independent of Operating Temperature. www.jsmsemi.com 第2/5页 JSM12N60F 600V N-Channnel MOSFET Transfer Characteristics du ct or On-Regin Characteristics Body Diode Forward Voltage Variation vs. Source Current and Temperature CR O  S em ic on On-Resistance Variation vs. Drain Current and Gate Voltage JS MI Capacitance Characteristics Gate Charge Characteristics www.jsmsemi.com 第3/5页 JSM12N60F 600V N-Channnel MOSFET On-Resistance Variation vs. Temperature on du ct or Breakdown Voltage Variation vs. Temperature Maximum Drain Current Vs. Case Temperature JS MI CR O  S em ic Maximum Safe Operating Area www.jsmsemi.com 第4/5页 JSM12N60F 600V N-Channnel MOSFET TO-220F Package Dimensions 3.40 9.90 16.40 4.95 7.40 3.70 17.00 10.80 SYMBOL D D1 D2 D3 E E1 E2 E3 E4 α(度) min nom 2.54 1.15 0.60 0.20 2.24 1.55 1.00 0.50 2.84 or 7.00 max 10.60 0.70 1.0×45° 0.35 2.30 ct 2.90 9.10 15.40 4.35 6.00 3.00 15.00 8.80 nom du min 9.80 30° 0.65 3.30 JS MI CR O  S em ic on SYMBOL A A1 A2 A3 B1 B2 B3 C C1 C2 UNIT:mm max www.jsmsemi.com 第5/5页
JSM12N60F 价格&库存
很抱歉,暂时无法提供与“JSM12N60F”相匹配的价格&库存,您可以联系我们找货
