UX60SC-MB-5ST(80)
UX60SC-MB-5ST(80)
    HRS(广濑)
    SMD
    USB连接器 Mini-B 5P 卧贴 端口数:1 额定电流:1A 额定电压:30VAC 工作温度:-30℃~+75℃
UX60SC-MB-5ST(80) 数据手册
USB 2.0 Standard Connectors UX Series Feb.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Meets requirements of USB 2.0 Standard USB 2.0 certified ■Features Equal electrical length design(between twisted pairs) 1. Compatible to USB 2.0 Standard The UX series connectors are cer tified by a certification organization specified by the USB Association. The connectors are able to meet high-speed transmissions up to 480 Mbps, delivering optimal PC peripheral connections. 2. Low skew structure An equal electrical length design between twisted pairs (contact numbers 2 and 3) for both the receptacles and the plugs provides for a theoretical zero skew. (Fig.1) 8dciVXiCd#( 8dciVXiCd#' 3. No heat-shrink tube needed The wire termination section of the plug is fixed on the mold. In addition Hirose's unique metal shield structure allows the over-mold resin to easily flow into the wire termination section preventing short circuits from occurring even without using heat shrink tubing. This feature allows shor tening of the length of untwisted part resulting in impedance unmatching at the wire termination sections. Fig.1 Ideal for the connection of personal computer peripherals 4. Easy to handle plug The plug is a snap lock type that gives a clear tactile click, assuring secure connector mating.The over-mold section also has a thin structure for space saving. 5. Metal shield for SMT or DIP mounting Metal shields with either SMT or solder dip type are available to match the PCB design. Fig.2 6. With or without positioning boss Versions with or without positioning bosses can be selected to match the PCB design. 7. Suitable for automatic mounting A heat resistant tape for vacuum pickup is applied to the receptacle allowing for the use of automatic mounting machines. Receptacles without tape are also available. 8. RoHS compliant All materials and substances used to produce this product comply with RoHS standards. In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2017.12r 1 UX Series●USB 2.0 Standard Connectors ■Product Specifications Voltage rating 30V AC Current rating 1A Ratings Item Specification Conditions 1.Contact resistance 50mø max. 100mA 2.Insulation resistance 100Mø min. 100V DC 3.Withstanding voltage No flashover or insulation breakdown 100V AC / 1 minute 4.Capacitance 2pF max. Measure between adjacent contacts at 1,000 ±10Hz 5.Total insertion/ Insertion force : 35N max. Withdrawal force : 7N min. withdrawal force 6.Durability Feb.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. -30 to +75ç (Note1) Operating temperature range Measure with an applicable connector. With corresponding HRS connector. (mating/unmating) Contact resistance : 70mø max. 5,000 cycles Withdrawal force : 3N min. Frequency 10 to 55Hz, single amplitude of 0.75mm, 7.Vibration 8.Random vibration No electrical discontinuity of 1µs or longer No damage, cracks or parts dislocation. 9.Shock 2 hours in each of the 3 axial directions Frequency 50 to 2,000Hz, 3 directions for 15 minutes each. Acceleration of 490m/s2, 11ms continuous time, sine half-wave, 3 cycles in each of the 6 directions 10.Heat Shock Contact resistance : 70mø max. Temperature : -55ç / +20ç to 35ç / +85ç / +20ç to 35ç / 2 to 3 min. / 30 min. / 2 to 3 minutes Time : 30min. 10 cycles 11.Temperature cycle Insulation resistance : 10Mø min. (when dry) 7 cycles (168 hours) at -10 to 65ç , humidity of 93 ± 3% 12.Salt spray Contact resistance : 70mø max. 48 hours, 5% solution of salt water 13.Solderablity Wet state, solder coverage area 95% min. Solder temperature 245ç, immersion time 2 to 3 seconds Note 1 : The term “storage” refers to connectors stored for a long period of time prior to mounting and use. Materials / Finish ●Receptacle Part Insulator Material Synthetic resin Contacts Copper alloy Metal shield Tape for vacuum pickup Copper alloy Polyamide Finish Color : Black Contact area : Gold plated Lead area : Gold plated Tin alloy plated --------------- Remarks UL94V-0 ------------------------------------------- ●Plug Part Insulator Material Synthetic resin Contacts Copper alloy Metal shield Over-mold (Note1) Steel PVC resin (Note2) Finish Color : Black Contact : Gold plated Wiring side : Tin alloy plated Tin alloy plated Color : Black (Note3) Remarks UL94V-0 ------------------------------------------- Note 1 : Single over-molded plug is not available as over-mold is created when forming the connector together with harness assembly. Note 2 : Halogen-free material is also available. Note 3 : Various colors are available for over-molds and cables. Contact our sales department for details. 2 UX Series●USB 2.0 Standard Connectors ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ●Receptacle UX 60S C - MB - 5 S T ❶ ❷ ❸ ❺ ❹ ❻ ❼ ●Plug UX 40 A - MB - 5 P Feb.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ❶ ❷ ❽ ❹ ❺ ❻ ●Plug harness UX 40 A - MB - 5 P A - 1000 - 1001 ❶ ❷ ❽ ❹ ❺ ❻ ❶ Series name UX series ❷ Contact termination style 60S : SMT type ❾ 40 : Solder termination type ❸ Receptacle shape/type C : Standard type ❹ Connector type MB : Type Mini B ❺ Number of contacts 5 : 5 contacts ❻ Contact gender S : Female P : Male ❼ Metal shield shape T : SMT type 8 : Solder DIP type ❽ Plug serial symbol A : Type for thick cable ❾ Type of connector on the opposite-side A : Standard A Cable length 1000 : 1000mm(Note 1) Additional type number Note 1 : Optional cable lengths of up to 3000mm are available. Contact our sales department for details. 3 UX Series●USB 2.0 Standard Connectors ●Receptacle - Standard – Shell SMT Part No. HRS No. UX60SC-MB-5ST(80) 240-0016-6 80 RoHS Note 1 : Tape and reel packaging (1,500pcs/reel). : No conductive traces Contact No.1 5.1 1 3.3 Vacuum pick-up area (1.6) Contact No.5 9.8 7.7 7 3 5.9 7.7 10.9 Outline of the connector 0.8 (0.5) PCB edge 1.3 1.8 5.4 3.6 2.1 5.6 3.95 1.4 0.8 0.5 0.3 0.8 1.6 0.8 1.6 All dimensions : mm ●Receptacle - Standard - Shell through Hole Part No. HRS No. UX60SC-MB-5S8(80) 240-0020-3 80 RoHS Note 1 : Tape and reel packaging (1,000pcs/reel). BRecommended PCB mounting pattern : No conductive traces (0.5) (1.5) Order by number of reels. Vacuum pick-up area (1.6) Contact No.1 Contact No.5 7.7 7 ) ole .35 ugh h 0 R ro (Th 0.4 7.7 0.8 1.3 3.7 7.3 (0.5) 3 5.9 3.2 (Through hole) 3.6 (Land) 7.3 0.7(Through hole) 1.1(Land) 0.8 1.6 0.8 R0 1.4 PCB edge Outline of the connector 3.9 La nd 5( 0.8 0.5 .5 0.8 ) 1.6 1.6 5.4 3.6 2.1 Feb.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1.6 1.6 0.8 (0.5) BRecommended PCB mounting pattern (1.5) 1 Order by number of reels. 0.3 0.8 1.6 2.8 4.2 All dimensions : mm 4 UX Series●USB 2.0 Standard Connectors ■Plug 3 1.2 2.4 CONTACT No.1 CONTACT No.5 Part No. UX40-MB-5P UX40A-MB-5P HRS No. 240-0004-7 240-0005-0 Dimension A 6.2 7.85 (0.5) (A) 3 (0.75) 1.2 2.4 (2.4) 22.7 B (0.2) ●Connector unit 14.4 Dimension B 6.95 7.85 Applicable cable(Note) Ø3.5~4.0 Ø4.1~4.6 RoHS (Note) The applicable cable diameters show approximate values (they may differ due to the insulation hardness). ■Plug Harness Part No. UX40-MB-5PA-1000-2003 HRS No. 240-2003-5 RoHS 1000 (55) (8.2) B (16.2) (Ø3.9) (30.9) (6.5) (9.5) Feb.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 7.45 ●Assembled state 5 UX Series●USB 2.0 Standard Connectors Recommended clearance areas Mated Assembly – Receptacle Dimensions shown in the illustrations below must be free of any materials or components, as this may interfere with the free movement of the ground contacts. ●Shown for Reference 4.7 5MIN 1MIN Receptacle Plug 1.1MIN 0.35MIN 0.4MIN 2.3MIN (1.5) Feb.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. All dimensions: mm Packaging Specifications (JIS C 0806-3) ●Embossed carrier tape dimensions (The diagram represents a standard type) (30.4) .5 (24.4) ) Ø1 Unreeling direction 24 22.25 11.5 (Ø 1.75 4 2 Unreeling direction 13 12 ●Reel Dimensions 0) 38 (Ø Recommended temperature profile ●Lead-free solder paste Temperature:(ç) 250 230 170±10ç 80~110S 230ç min. MAX 50S 200 170 The temperature profile is based on the shown conditions. In individual applications the temperature may vary, depending on solder paste type, volume/ thickness and board size/thickness. Consult your solder paste and equipment manufacturer for specific recommendations. 200ç min. MAX 80S 0 Time (Seconds) Average slope 2ç / sec. ® 6 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 12/2017. Contents are subject to change without notice for the purpose of improvements.
UX60SC-MB-5ST(80) 价格&库存
很抱歉,暂时无法提供与“UX60SC-MB-5ST(80)”相匹配的价格&库存,您可以联系我们找货
UX60SC-MB-5ST(80)
  • 1+3.02893
  • 10+2.79229
  • 30+2.74497
  • 100+2.60299
UX60SC-MB-5ST(80)
    • 1500+2.97660
    库存:3000
