DPC-817C
DPC-817C
    MICRONE(南京微盟)
    DIP-4
    4针DIP光电晶体管光电耦合器
DPC-817C 数据手册
DPC-817 4 PIN DIP PHOTOTRANSISTOR PHOTOCOUPLER General Description Features ●The DPC-817 series are optically coupled isolators ●Current transfer ratio (CTR: 50~600% at IF =5mA, containing a GaAs light emitting diode and an NPN VCE =5V) ●High isolation voltage between input and output silicon phototransistor (Viso=5000 Vrms ) ●The lead pitch is 2.54mm ●Creepage distance >7.62 mm ●Operating temperature up to +110°C ● Compact small outline package Rank Table Of Current Transfer Ratio (CTR) ●UL approved (No.E343249) RANK MARK. Min. ( %) Max. ( %) L 50 100 A 80 160 Applications B 130 260 ● Computer terminals. C 200 400 D 300 600 50 600 L or A or B or C or D Notes: ●Pb free and RoHS compliant. ● System appliances, measuring instruments. ● Registers, copiers, automatic vending machines. ● Electric home appliances, such as fan heaters, etc, of different potentials and Conditions: IF=5mA, VCE=5V, Ta=25℃. impedances. ● Signal transmission between circuits Pin Configuration Pin Assignment Pin num. Symbol 1 Anode 2 Cathode 3 Emitter 4 Collector Functions Input Output V01 www.microne.com.cn Page 1 of 8 DPC-817 Absolute Maximum Ratings (Ta=25℃) Symbol Rating Unit Forward Current IF 50 mA Reverse Voltage VR 6 V Power Dissipation P 70 mW Collector-Emitter Voltage VCEO 35 Emitter- Collector Voltage VECO 6 Collector Current IC 50 mA Collector Power Dissipation PC 150 mW Total Power Dissipation Ptot 200 mW Isolation Voltage(NOTE) VISO 5000 Vrms Rated impulse isolation voltage VIOTM 6000 V Rated repetitive peak isolation voltage VIORM 630 V operating Junction Temperature TJ TOPR -40 to 85 Storage Temperature TSTQ -55 to 125 Lead Temperature (Soldering, 10secs) TSOL 260 Parameter INPUT OUTPUT V ℃ Notes: AC For minute, R.H. =40~60% Isolation voltage shall be measured using the following method. (1) Short between anode and cathode on the primary side and between collector and emitter on the secondary side. (2) The isolation voltage tester with zero-cross circuit shall be used. (3) The waveform of applied voltage shall be a sine wave. Caution: The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions. Block Diagram V01 www.microne.com.cn Page 2 of 8 DPC-817 Electrical Characteristics (TA =25 °C, unless otherwise noted.) Item Symbol Test condition Min Typ Max Unit 1.2 1.4 V 10 uA 250 PF 100 nA Input Section Forward Voltage VF IF=20mA Reverse Current IR VR=4V Terminal Capacitance Ct V=0, f=1KHz 30 Output Section Collector Dark Current ICEO Collector-Emitter Breakdown Voltage BVCEO Emitter-Collector Breakdown Voltage BVECO Transfer VCE=20V, IF=0 IC=0.1mA IF=0 IE=10µA IF=0 35 V 6 V Characteristic Section Collector Current Ic Current Transfer Ratio(note) CTR Collector-Emitter Saturation Voltage VCE(sat) Isolation Resistance Riso DC500V 40~60%R.H. Floating Capacitance Cf V=0, f=1MHz 0.6 Cut-Off Frequency fc VCE=5V,IC=2mA RL=100Ω,-3dB 80 Response Time(Rise) tr VCE=2V,IC=2mA Response Time(Fall) tf Note: IF=5mA VCE=5V 2.5 30 mA 50 600 % 0.2 V 1 pF IF=20mA 0.1 IC= 1mA RL=100Ω 5×1010 1×1011 kHz 4 18 uS 3 18 uS CTR= IC / IF × 100% V01 www.microne.com.cn Page 3 of 8 DPC-817 Typical performance characteristics (1) Forward Current vs. Ambient Temperature (2) Collector Power Dissipation vs. Ambient Temperature (3) Collector-emitter Saturation Voltage vs. Forward Current (4) Forward Current vs. Forward Voltage (5) Current Transfer Ratio vs. Forward Current (6) Collector Current vs. Collector-emitter Voltage V01 www.microne.com.cn Page 4 of 8 DPC-817 (7) Relative Current Transfer Ratio vs. Ambient Temperature (9) Collector Dark Current vs. Ambient Temperature (11) Frequency Response V01 (8)Collector-emitter Saturation Voltage vs. Ambient Temperature (10) Response Time vs. Load Resistance Test Circuit for Response Time www.microne.com.cn Page 5 of 8 DPC-817 Reliability Test Classification Test Item Operation Life High Temperature High Humidity Reverse Bias (H3TRB) Endurance Test Test Conditions MIL-STD-750:1026 MIL-STD-883:1005 JIS C 7021 : B-1 JIS C 7021 :B-11 Result Connect with a power If=50mA Ta=Under room temperature Test time=1,000hrs 0/20 Ta=+85℃±5℃, RH=85% PTR=VCE Absolute max rating*80% Test time=1000hrs 0/20 0/20 High Temperature Reverse Bias (HTRB) JIS C 7021 : B- 8 Ta=+105℃±5℃ PTR=VCE absolute max rating Test time=1000hrs High Temperature Storage MIL-STD-883:1008 JIS C 7021 :B-10 High Ta=+125℃±5℃ Test time=1,000hrs 0/20 Low Ta=-55℃±5℃ Test time=1,000hrs 0/20 P=15PSIG, Ta=121℃ Humi. =100%RH, 48hrs 0/20 Low Temperature Storage Environmental Test Reference Standard JIS-C-7021 :B-12 Autoclave JESD 22-A102-B Temperature Cycling MIL-STD-202:107D MIL-STD-750:1051 MIL-STD-883:1010 JIS C 7021 :A-4 125℃ ~ 25℃ ~ -55℃ ~ 25℃ 30min 5min 30min 5min Test Time=20cycle Thermal Shock MIL-STD-202:107D MIL-STD-750:1051 MIL-STD-883:1011 125℃ ~-55℃ 20min 20min Test Time=20cycle Solder Resistance MIL-STD-202:201A MIL-STD-750:2031 JIS C 7021 :A-1 Solder Ability MIL-S-883:2003 JIS C 7021 :A-2 0/20 Operation heating:300℃, 0/20 within 10±1seconds. Operation heating:260℃, Judgment Criteria Of Failure For The Reliability Symbol Measuring conditions 0/20 within 5±1seconds. Judgment criteria for failure VF (V) If=20mA Over Ux1.0 Ir(uA) Vr=4V Over Ux1.0 CTR(%) If=5mA, VCE=5V Shift>1.2 VCE(sat) IF=20mA, IC= 1mA Over Ux1.0 BVCEO IC=0.1mA, IF=0 Over Ux1.0 BVECO IE=10µA, IF=0 Over Ux1.0 V01 www.microne.com.cn 0/20 Page 6 of 8 DPC-817 Package Information Package type:DIP4 Unit:mm(inch) Dimension (mm) Dimension (Inches) Character Min Max Min Max A 6.200 6.600 0.244 0.260 B 4.280 4.880 0.169 0.192 C 0.300(Typ.) D 7.620 9.500 0.300 0.374 E 4.200 4.800 0.165 0.189 F 2.300 3.300 0.090 0.130 a 1.2 1.4 0.047 0.055 b 0.3 0.5 0.012 0.020 c 0.4 0.6 0.016 0.024 d 2.54Typ.) 0.060(Typ.) e 0.25(Typ.) (Typ.) θ V01 7.620(Typ.) 00 150 www.microne.com.cn 00 150 Page 7 of 8 DPC-817 z z z z z The information described herein is subject to change without notice. Nanjing Micro One Electronics Inc is not responsible for any problems caused by circuits or diagrams described herein whose related industrial properties, patents, or other rights belong to third parties. The application circuit examples explain typical applications of the products, and do not guarantee the success of any specific mass-production design. Use of the information described herein for other purposes and/or reproduction or copying without the express permission of Nanjing Micro One Electronics Inc is strictly prohibited. The products described herein cannot be used as part of any device or equipment affecting the human body, such as exercise equipment, medical equipment, security systems, gas equipment, or any apparatus installed in airplanes and other vehicles, without prior written permission of Nanjing Micro One Electronics Inc. Although Nanjing Micro One Electronics Inc exerts the greatest possible effort to ensure high quality and reliability, the failure or malfunction of semiconductor products may occur. The user of these products should therefore give thorough consideration to safety design, including redundancy, fire-prevention measures, and malfunction prevention, to prevent any accidents, fires, or community damage that may ensue. V01 www.microne.com.cn Page 8 of 8
DPC-817C 价格&库存
很抱歉,暂时无法提供与“DPC-817C”相匹配的价格&库存,您可以联系我们找货
