JSM501
JSM501
    JSMSEMI(杰盛微)
    SOT-23
    高压霍尔效应开关系列
JSM501 数据手册
JSM501-JSM511 High Voltage Hall Effect Switch Family Vinbelltech Co. Ltd Introduction to r JSM50X family consists of different Hall switches produced in BCDMOS technology. All Hall sensors include a temperature-compensated Hall plate with active offset compensation, a comparator, and an output driver. The family consists of 3-wire devices, the corresponding output driver being an opendrain output transistor and a current source respectively. The comparator compares the actual magnetic flux with the fixed reference values (switching points). Accordingly the output transistor is switched on or off in 3-wire version. The active offset compensation leads to constant magnetic characteristics over supply voltage and temperature range. In addition, the magnetic parameters are robust against mechanical stress effects. The sensors are designed for industrial and automotive applications and operate with supply voltages from 2.7 V to 30V in ambient temperature range from -40 °C up to 150 °C. uc The family JSM50X is available in SOT-23 and the leaded version TO92S packages. Features Applications                       nd Speed and RPM sensing Tachometer, counter pickup Flow-rate sensing Brushless dc motor commutation Motor and fan control Robotics control Proximity sensor Position sensor Seat position detection Seat belt buckles Hood/trunk/door latches Sun roof/convertible top/tailgate/liftgate actuation Brake/clutch pedals Electric power steering (EPS) Transmissions and shift selectors Wiper motor co mi Se  CR O  JS MI  SOT-23 and TO92S packages Low current consumptions of typ. 2.5 mA Operates from 2.7 V to 30 V supply voltage Overvoltage protection capability up to 40 V Highest ESD performance up to ±12 kV Short-circuit protected open-drain output and thermal shut down for 3-wire applications Magnetic characteristics are robust regarding mechanical stress effects Constant switching points over a wide supply voltage and temperature range Wide operating temperature range from -40 °C to 150 °C The decrease of magnetic flux density caused by rising temperature in the sensor system is compensated by a built-in negative temperature coefficient of the magnetic characteristics Reverse-voltage protection at Vcc pin Ideal sensor for applications in extreme automotive and industrial environments Qualified according to AEC-Q100 test standard for automotive electronics industry to provide the highest quality expectation     Package SOT23 www.jsmsemi.com TO92 第1页,共15页 JSM501-JSM511 High Voltage Hall Effect Switch Family Contents Title Page JSM50X Family Overview 3 2. Ordering Information 5 2.1 Marking Code 2.2 Operating Ambient Temperature Range 2.3 Hall Sensor Package Codes 3. Functional Description 4. Diagnostic Features 5. Specifications 5.1 Outline Dimensions 5.2 Pin assignment 5.3 Absolute Maximum Ratings 5.4 ESD and Latch-up 11 5.5 Recommended Operating Conditions 11 5.6 Characteristics 12 5.7 Magnetic Characteristics Overview 13 6. Magnetoelecric conversion characteristics 13 7. Application circui 14 to r 1. CR O Section 6 JS MI Se mi co nd uc 6 www.jsmsemi.com 6 6 7 8 8 10 10 第2页,共15页 JSM501-JSM511 High Voltage Hall Effect Switch Family 1. JSM50X Family Overview The types within each family differ according to the magnetic flux density values for the magnetic switching points, the temperature behavior of the magnetic switching points, the mode of switching, the number of pins and the average current consumption. Table 1 to Table 4 list some devices classified in terms of switching behavior and sensitivity: higher Table 1: JSM50X 3-wire devices co nd Sensitivity Very high Very high Very high High Medium Medium Low High High Medium Medium Se mi Switching Behavior Bipolar Latching Unipolar Latching Latching Unipolar Uipolar Unipolar Unipolar inverted Unipolar Unipolar JS MI CR O Type Sensitivity JSM501 JSM502 JSM503 JSM504 JSM505 JSM506 JSM507 JSM508 JSM509 JSM510 JSM511 uc to r sensitivity correlates to lower switching points. The following definitions outline the device behavior for different switching points: Latching Sensors: 3-wire: The output turns low with the magnetic south pole on the branded side of the package and turns high with the magnetic north pole on the branded side. The output does not change if the magnetic field is removed. For changing the output state, the opposite magnetic field polarity must be applied. www.jsmsemi.com 第3页,共15页 JSM501-JSM511 High Voltage Hall Effect Switch Family Output Voltage VOH BHYS VOL Bop 0 B to r Brp Fig. 1: Definition of magnetic switching points for 3- wire latching sensor. uc Bipolar Switching Sensors (3-wire only): The output turns low with the magnetic south pole on the branded side of the package and turns high with the magnetic nd north pole on the branded side. The output state is not defined if the magnetic field is removed again. Some sensors will change the output state and some sensors will not. mi co Output Voltage VOH Se BHYS VOL 0 Bop B JS MI CR O Brp www.jsmsemi.com 第4页,共15页 JSM501-JSM511 High Voltage Hall Effect Switch Family Vinbelltech Co.ofLtd Fig. 2: Definition magnetic switching points for 3- wire bipolar sensor. Unipolar Switching Sensors: 3-wire: The output turns low with the magnetic south pole on the branded side of the package and turns high if the mi co nd uc to r magnetic field is removed. The sensor does not respond to the magnetic north pole on the branded side. Se Fig. 3: Definition of magnetic switching points for 3-wire unipolar sensor. Unipolar Switching Sensors with Inverted Output: CR O 3-wire: The output turns high with the magnetic south pole on the branded side of the package and turns low if the JS MI magnetic field is removed. The sensor does not respond to the magnetic north pole on the branded side. Fig. 4: Definition of magnetic switching points for 3- wire unipolar sensor with inverted output. 2. Ordering Information www.jsmsemi.com 第5页,共15页 JSM501-JSM511 High Voltage Hall Effect Switch Family Vinbelltech 2.1. MarkingCo. Code Ltd All Hall sensors have a marking on the package surface (branded side). This marking includes the name of the sensor and date code. 2.2. Operating Ambient Temperature Range The Hall sensors from Vinbelltech are specified to the ambient temperature. to r TA = -40 °C up to 150 °C 2.3. Hall Sensor Package Codes uc Hall sensors are available in a wide variety of packaging versions and quantities. nd Ordering information Package Packing JSM50X TO92S Bulk, 1000 pieces/bag JSM50X SOT23 Tape&Reel, 3000 pieces/reel Ambient, TA -40℃ to 150℃ -40℃ to 150℃ CR O Se mi co Part number 3. Functional Description JS MI JSM50X Hall effect sensor switches are available with different magnetic switching levels and output polarity. JSM50X sensors are monolithic integrated circuits which switch in response to magnetic fields. If a magnetic field with flux lines perpendicular to the sensitive area is applied to the sensor, the biased Hall plate forces a Hall voltage proportional to this field. The Hall voltage is compared with the actual threshold level in the comparator. If the magnetic field exceeds the threshold levels, the output stage (open drain output for 3-wire devices or current source for 2-wire devices) is switched to the appropriate state. The built-in hysteresis eliminates oscillation and provides switching behavior of output without bouncing. Magnetic offset caused by mechanical stress is compensated by using the chopping offset compensation technique. A serial resistor or diode on the supply line is not required thanks to the built-in reverse voltage protection. www.jsmsemi.com 第6页,共15页 JSM501-JSM511 High Voltage Hall Effect Switch Family Vinbelltech Co.output Ltd is forced to a safe, high-impedance state (tri-state), in any of the following fault conditions: The open drain overtemperature, and undervoltage. In addition, the output current is limited (short-circuit protection). The device is able to withstand a maximum supply voltage of 28 V for unlimited time and features overvoltage capability Se CR O Fig. 5: JSM50x- 3-wire - Block diagram mi co nd uc to r (40V load dump). 4. Diagnostic Features JS MI Internal states are monitored and in an error condition flagged with a tri-state at the output (3-wire devices): – Internal voltage regulator: under and over voltage detection – Monitoring of internal bias and current levels – Monitoring of the internal reference voltage – Monitoring of the Hall plate voltage www.jsmsemi.com 第7页,共15页 Vinbelltech Co. Ltd 5. Specifications 5.1. Outline Dimensions Symbol Size (mm) minimum maximum 1.42 1.67 0.66 0.86 0.35 0.56 0.4 0.55 0.36 0.51 3.9 4.2 2.97 3.27 2.9 3.28 1.270 TYP 2.44 2.64 13.5 15.5 2.025TYP 1.545TYP 0.500TYP 45˚TYP JS MI A A1 b b1 C D D1 E e e1 L x y z θ CR O TO92S dimensions Se mi co nd uc to r TO92S Size (in inches) minimum maximum 0.056 0.066 0.026 0.034 0.014 0.022 0.016 0.022 0.014 0.02 0.154 0.165 0.117 0.129 0.114 0.129 0.050 TYP 0.096 0.104 0.531 0.61 0.080TYP 0.061TYP 0.020TYP 45˚TYP www.jsmsemi.com 第8页,共15页 JSM501-JSM511 High Voltage Hall Effect Switch Family nd (0~9) (1~52) 1.05 1.25 A1 0 0.1 A2 1.05 1.15 b 0.3 c D mi A Size (in inches) minimum minimum 0.041 0.049 Se Size (mm) maximu minimum m co SOT23 dimensions Symbol 0.004 0.041 0.045 0.5 0.012 0.02 0. 100 0.2 0.004 2.82 3.02 0.111 0.119 0.008 E 1.5 1.7 0.059 0.067 E1 2.65 2.95 0.104 0.116 JS MI CR O 0 e 0.950 TYP 0.037 TYP e1 1.8 2 0.071 0.079 L 0.3 0.6 0.012 0.024 x 1.460TYP 0.057TYP y 0.800TYP 0.032TYP z 0.600TYP 0.024TYP θ 0˚ uc to r Vinbelltech Co. Ltd 8˚ 0˚ 8˚ www.jsmsemi.com 第9页,共15页 JSM501-JSM511 High Voltage Hall Effect Switch Family TO92S SOT23 mi Fig.6: Pin assignment of TO92S and SOT23 co nd uc to r Vinbelltech Co. Ltd 5.2. Pin assignment Name 1 2 3 VCC GND Vout Function Power supply Ground Output JS MI CR O Pin number Se Pin assignment 5.3. Absolute Maximum Ratings Stresses beyond those listed in the “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress rating only. Functional operation of the device at these conditions is not implied. Exposure to absolute maximum rating conditions for extended periods will affect device reliability. This device contains circuitry to protect the inputs and outputs against damage due to high static voltages or electric fields; however, it is advised that normal precautions be taken to avoid application of any voltage higher than absolute maximum-rated voltages to this circuit. All voltages listed are referenced to ground (GND). www.jsmsemi.com 第10页,共15页 JSM501-JSM511 High Voltage Hall Effect Switch Family Vinbelltech Ltd Symbol Co. Parameter VCC Supply voltage Pin No Min. 20 1 Max. Unit Conditions  V t < 1000 h 1) 34 V t < 96 h1) 36 V t < 5 min1) 40 V t < 5 x 400 ms1) Output voltage 0.5 3  V 34 V 36 V 3 IOR Reverse output current 3 TA Ambient temperature range 5.4. ESD and Latch-up t < 5 min1) mA mA 170 °C t < 5 x 400 ms1) with series resistor RL > 100  t < 96 h1) Se No cumulative stress 40 t < 96 h1) CR O 1) 50 65 co Output current mi IO V nd 40 t < 1000 h1) uc VOUT to r with series resistor RV > 100  The output pin has to be in tri-state (high impedance) for ESD measurements. JS MI ESD and latch-up Symbol Parameter Min Max Unit Ilatch Maximum latch-up free current at any pin (measurement according to AEC Q100-004), class 1 100 100 mA VHBM Human body model (according to AEC Q100-002) 12  kV 5.5. Recommended Operating Conditions Functional operation of the device beyond those indicated in the “Recommended Operating Conditions” of this specification is not implied, may result in unpredictable behavior of the device and may reduce reliability and lifetime. All voltages listed are referenced to ground (GND). www.jsmsemi.com 第11页,共15页 JSM501-JSM511 High Voltage Hall Effect Switch Family Parameter VCC Supply voltage TA Ambient temperature range VOUT Output voltage IOUT Output current Pin No 1 Min Typ Max Unit 2.7 30 V 40 150 °C 3 30 V 3 25 mA 3-wire uc 5.6. Characteristics Conditions to r Symbol at TA = -40 °C to 150 °C, VCC = 3.0 V to 24 V, at Recommended Operation Conditions if not otherwise Symbol Parameter Pin No Supply current IccR Reverse current Port Output 3 Max Unit 2.5 3.2 mA 3-wire 1 mA for Vcc = -18 V 0.4 V IO = 20 mA 0.5 V IO = 25 mA 1 µs 0.13 Output fall time JS MI tf Port low output voltage CR O Vol 1 Typ Se Icc Min mi Supply co nd specified in the column “Conditions”. Typical Characteristics for TA= 25 °C and VCC = 12 V tr Output rise time Bnoise Effective noise of magnetic switching points tj Output jitter td Delay time tsamp Output refresh period ten Enable time of output after settling of Vcc Conditions Vcc = 12V; RL = 820 ; CL = 20 pF 1 0.1 0.5 16 1.6 2 50 µs mT For square wave signal with 1 kHz µs For square wave signal with 1 kHz µs 2.66 µs µs VCC = 12V B > Bon + 2 mT or B < Boff - 2 mT www.jsmsemi.com 第12页,共15页 JSM501-JSM511 High Voltage Hall Effect Switch Family 5.7. Magnetic Characteristics Overview TA = -40 °C to 150 °C, Vcc = 3.0 V to 30 V, GND = 0 V, recommended operation conditions if not otherwise specified in the column “Conditions”. Typical characteristics for TA= 25 °C. On point BON [mT] TC Min [ppm/K] Typ Off point BOFF [mT] Max Min 3-wire JSM501 bipolar 0 JSM502 latching 1000 2.5 JSM503 unipolar 1000 5.5 JSM504 latching   JSM505 latching   JSM506 unipolar -1000 JSM507 unipolar 300 JSM508 unipolar JSM509 unipolar JSM510 unipolar JSM511 unipolar 1) [mT] Max Min 0.9 nd uc 0.9  co  Typ Hysteresis BHYS to r Sensor Switching Type Temp. coeff. of magnetic thresh.   Typ 1.8 2.5 5.0 3.5 2.0           16.0 2.0 27.0 23.0 4.0 1000 5.5 3.5 2.0 1000 3.5 5.5 2.0 1000 10 8 2.0 1000 8 10 2.0  JS MI CR O Se mi 18.0  Max 6. Magnetoelectric conversion characteristics Apply a magnetic field greater than Bop on the seal side of TO92S package (near the South Pole), and the output becomes low;Apply a magnetic field less than Brp (near the North Pole) and the output becomes high.When the chip is first powered on, if the magnetic field is between the Bop and the Brp, the output state is in an undefined state (high or low).The magnetic field polarity of the operating and releasing points of SOT23 package is opposite to that of TO92S.See below. www.jsmsemi.com 第13页,共15页 JSM501-JSM511 High Voltage Hall Effect Switch Family Vinbelltech Co. Ltd Output Voltage VOH BHYS VOL VOUT=high B TO92S output state nd uc VOUT=low Bop 0 to r Brp 7. Application circuit VOUT=high Brp 0 Bop B SOT23-3L output state JS MI 3-Wire Devices BHYS CR O VOUT=low VOH VOL Se mi co Output Voltage Typical application circuit (see Fig.7) www.jsmsemi.com 第14页,共15页 nd uc to r JSM501-JSM511 High Voltage Hall Effect Switch Family co Fig. 7: Example 3-wire application circuit 1 For applications with disturbances on the supply line or radiated disturbances, a series resistor R V and two capacitors CP mi and CL all placed close to the sensor are recommended (see Fig.8). JS MI CR O Se For example: RV =100 ohms, CP = 4.7 nF, and CL = 1 nF. Fig. 8: Example 3-wire application circuit 2 www.jsmsemi.com 第15页,共15页
JSM501 价格&库存
很抱歉,暂时无法提供与“JSM501”相匹配的价格&库存,您可以联系我们找货
