DF63-4S-3.96C
DF63-4S-3.96C
    HRS(广濑)
    P=3.96mm
    胶壳 间距P=3.96mm 4Pin(1x4)
DF63-4S-3.96C 数据手册
DF63 Series Feb.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 15A 3.96mm pitch Wire-to-Board Connectors for Internal Power Supply (UL, C-UL and TÜV Listed) Product page https://www.hirose.com/product/en/products/DF63/ Special features page https://www.hirose.com/product/en/pr/enerbee/ May 2021 ⑦ DF63 Series/15A 3.96mm pitch Wire-to-Board Connectors for Internal Power Supply (UL, C-UL and TÜV Listed) Features 1. Rated for up to 15A Feb.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. DF63 has the capacity to handle a Max. of 15A when using 16 AWG wire. ( Please refer to the chart for the rated current in other pin counts. ) * Supports 7. 92mm pitch Also supports 7. 92mm pitch with 2 or 3 pos. without pins. The product will be available upon request. Please contact Hirose representative. 2. Secure mating and clear tactile click [A-A] A→ The locking mechanism delivers a clear and tactile click, which prevents incomplete mating and reduces burden on workers for improved work efficiency. A→ Crimp contact Lock portions of the plug and the header start to engage. No contact yet Header contact Lock structure 3. Prevents incomplete insertion of the crimp contact Crimp contact (insufficiently inserted) A structure to prevent incomplete insertion of the crimp contacts is provided. Lock does not work. Lance and header protection mechanism meet. Prevention of insufficient insertion of the crimp contact 2 DF63 Series/15A 3.96mm pitch Wire-to-Board Connectors for Internal Power Supply (UL, C-UL and TÜV Listed) 4. Prevents incorrect mating ■Standard type (color : black) A mechanism has been added to prevent reverse mating and incorrect mating between different number of positions. Feb.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. * Keying options were provided to prevent incorrect connections. Keying options prevent incorrect connections due to the use of multiple connectors on the same board. When using identical pin counts, two versions are available with different keying options. The product will be available upon request. Please contact Hirose representative. ■R-type (color : white) Keying options are available to prevent incorrect connections due to the use of multiple connectors on the same board. 5. Reverse mounting prevention to PCB Unique locking mechanism is contained inside the header The pin header is equipped with a guide post to prevent reverse insertion on the PCB. Socket and header design avoids short-circuit between adjacent contacts. 6. Short- circuit prevention The wall structure between the contacts helps to isolate the contacts and prevents short circuits between contacts. 7. Molded lance design The lance is actually part of the housing instead of being a part of the terminal. This prevents tangled wires during assembly. 8. Suitable for potting Capable of being potted, up to 5mm. 9. Solder crack prevention Glass- reinforced resin is used on the pin header to prevent solder cracks due to thermal contraction. 3 Guide keys prevent incorrect insertion Guide pins temporarily hold and assure proper orientation of the connector. DF63 Series/15A 3.96mm pitch Wire-to-Board Connectors for Internal Power Supply (UL, C-UL and TÜV Listed) Product Specifications Feb.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Rated Current No of Pos. 16 AWG 18 AWG 20 AWG 22 AWG 1 15A 13A 11A 9A Storage Temperature Range (Note 3) 2 14A 12A 10A 8A Operating Humidity Range (Note 4) 20 to 80% 3 12A 10A 8A 7A Storage Humidity Range (Note 3) 40 to 70% 4 10A 8A 7A 6A 5 10A 8A 7A 6A 6 10A 8A 7A 6A 2 (7.92mm Pitch) 15A 13A 11A 9A 3 (7.92mm Pitch) 12A 11A 9A 8A Rated Voltage Operating Temperature (Note 2) -55 to +105℃ -10 to +60℃ 630V AC/DC Voltage Rating UL 600V AC/DC C-UL 600V AC/DC TÜV 300V AC/DC UL/TÜV File No. and Recognition No. UL  : E52653 C-UL : E52653 TÜV : R50318850 Item Specifications Conditions Insulation Resistance No less than 1,000M Ω Measured at 500V DC Withstand Voltage No flashover or breakdown 1,500V AC is applied for 1 min. Contact Resistance No more than 10m Ω Measured at 1mA and no higher than 20mV Vibration Resistance No electrical discontinuity of 1μ s or greater Frequency 10 to 55 Hz, half amplitude 0.75 mm, 10 times in each of the 3 directions Shock Resistance No electrical discontinuity of 1μ s or greater Accelerated velocity : 490 m/s2 for 11ms, half-sine wave in 3 directions, 3 times for each direction Moistureresistance Contact resistance : no more than 20m Ω Insulation resistance : no less than 500M Ω Temperature : 40 ± 2℃ ; humidity : 90 to 95%, left as it is for 96 hours Temperature Cycles Contact resistance : no more than 20m Ω Insulation resistance : no less than 1,000M Ω -55℃ : 30 minutes → +85℃ : 30 minutes 5 cycles Mating Durability Contact resistance : no more than 20m Ω Tin Plated : 30 mating cycles Gold Plated : 50 mating cycles Solder Heat Resistance Note Note Note Note Note 1 2 3 4 5 : : : : : The resin parts should withstand the temperature and resist melting. Straight Header Flow : 260℃ , 5 sec Hand soldering : temperature of soldering iron at 290℃ for 3 seconds Right Angle Header Flow : 260℃ , 10 sec Hand soldering : temperature of soldering iron at 300℃ for 3 seconds This is the maximum current rating while all pins are powered or used as all power lines. Includes temperature rise caused by current flow. Applicable to unused product packaging. Use without condensation on parts. Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for a specific part number shown. 4 DF63 Series/15A 3.96mm pitch Wire-to-Board Connectors for Internal Power Supply (UL, C-UL and TÜV Listed) Materials / Finish Component Header Crimp socket In-line plug Crimp contact Part Material Finish UL Specification Insulator PBT (glass-reinforced) Black or White UL94V-0 Contact Brass Tin plated or Gold plated - Insulator PBT (glass-reinforced) Black or White UL94V-0 Contact Copper alloy Tin plated or Gold plated - Feb.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ■ Connector DF63 # - # P - 3.96 DSA ❶ ❷ ❸ ❹ ❺ ❻ ■ Crimp contact DF63 # - 1618 SCF ❶ ❷ ❼ ❽ ❶ Series name DF63 ❺ Contact Pitch 3.96mm 7.92mm ❷ Form Type Header Blank or M : Black R : Guide post/Guide Key Type, White Sockets Blank : Black R : Guide Key Type, White In-line Plugs Blank : Panel Lock Type A : Without Panel Lock Socket contacts A : Standard In-Line plug contacts Blank : Standard ❻ Type of housing DSA : Straight header DS : Right angle header C : Crimp housing ❸ Number of Contacts 1,2,3,4,5,6 ❼ Applicable Conductor 1618 : 16-18 AWG 2022 : 20-22 AWG ❹ Connector type P : Pin Header S : Crimp socket EP : In-line plug ❽ Packaging SCF : Socket contacts/Reel/Tin plated SCFA : Socket contacts/Reel/Gold plated SC : Socket contacts/Pack/Tin plated SCA : Socket contacts/Pack/Gold plated PCF : In-line plug contacts/Reel/Tin plated PCFA : In-line plug contacts/Reel/Gold plated PC : In-line plug contacts/Pack/Tin plated PCA : In-line plug contacts/Pack/Gold plated 5 DF63 Series/15A 3.96mm pitch Wire-to-Board Connectors for Internal Power Supply (UL, C-UL and TÜV Listed) Straight Header [1 pos.] [2 to 6 pos.] A B 6.2 P=3.96 8 7.05 10 8 7.05 10 3.5 3.5 □1.14 □1.14 *Diagram of standard type. ● Recommended PCB Layout (Board thickness : 1.6±0.1) [1 to 6 pos.] B±0.1 1.5±0.05 .1 +00 .6 φ1 .1 +00 .8 φ1 Outline of the connector P=3.96±0.05 3.25±0.05 Feb.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Polarization mark Standard Type (Guide post : Left Side, Color : Black) Part No. HRS No. Unit : mm No. of Pos. A B DF63M-1P-3.96DSA(##) CL0680-0566-0-## 1 6.20 - DF63M-2P-3.96DSA(##) CL0680-0567-0-## 2 8.66 3.96 DF63M-3P-3.96DSA(##) CL0680-0568-0-## 3 12.62 7.92 DF63M-4P-3.96DSA(##) CL0680-0569-0-## 4 16.58 11.88 DF63-5P-3.96DSA(##) CL0680-0506-7-## 5 20.54 15.84 DF63-6P-3.96DSA(##) CL0680-0507-0-## 6 24.50 19.80 R Type (Guide post : Right Side, Guide key, Color : White) Part No. DF63R-5P-3.96DSA(##) HRS No. 100pcs per bag Unit : mm No. of Pos. A B Purchase Unit 5 20.54 15.84 100pcs per bag No. of Pos. A B Purchase Unit 2 12.62 7.92 3 20.54 15.84 CL0680-0520-8-## 7.92mm pitch Part No. Purchase Unit Unit : mm HRS No. DF63M-2P-7.92DSA(##) CL0680-0581-0-## DF63-3P-7.92DSA(##) CL0680-0537-0-## DF63R-3P-7.92DSA(##) CL0680-0562-0-## [Specification number(##), -##] None : Tin plated, (01) : Gold plated Note : Please contact Hirose representative if you have request for (01) specification. 6 100pcs per bag DF63 Series/15A 3.96mm pitch Wire-to-Board Connectors for Internal Power Supply (UL, C-UL and TÜV Listed) Right Angle Header □1.14 A B 1.5±0.05 φ 1.8 + 0. φ1.4 0 P=3.96±0.05 P=3.96 Outline of the connector 2G08M Polarization mark 14.2 Feb.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. φ1. +0 6 .1 0 1 9 1.55 3.5 HRS mark 1.5±0.05 Lot mark Standard Type (Color : Black) Part No. HRS No. Unit : mm No. of Pos. A B DF63M-1P-3.96DS(##) CL0680-0570-0-## 1 6.20 - DF63M-2P-3.96DS(##) CL0680-0571-0-## 2 8.66 3.96 DF63M-3P-3.96DS(##) CL0680-0572-0-## 3 12.62 7.92 DF63-4P-3.96DS(##) CL0680-0545-0-## 4 16.58 11.88 DF63-5P-3.96DS(##) CL0680-0546-0-## 5 20.54 15.84 DF63-6P-3.96DS(##) CL0680-0547-0-## 6 24.50 19.80 No. of Pos. A B 7.92mm pitch Part No. Purchase Unit 100pcs per bag Unit : mm HRS No. DF63M-2P-7.92DS(##) CL0680-0583-0-## 2 12.62 7.92 DF63-3P-7.92DS(##) CL0680-0559-0-## 3 20.54 15.84 [Specification number(##), -##] None : Tin plated, (01) : Gold plated Note : Please contact Hirose representative if you have request for (01) specification. 7 Purchase Unit 100pcs per bag DF63 Series/15A 3.96mm pitch Wire-to-Board Connectors for Internal Power Supply (UL, C-UL and TÜV Listed) Crimp Socket [1 pos.] [2 to 6 pos.] 6.2 A B P=3.96 8.8 13.3 (Note 2) Polarization mark 13.3 Feb.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 8.8 Shown with terminated and contacts installed. Standard Type Unit : mm Part No. HRS No. No. of Pos. A B DF63-1S-3.96C(##) CL0680-0508-2-## 1 6.20 - DF63-2S-3.96C(##) CL0680-0509-5-## 2 8.36 3.96 DF63-3S-3.96C(##) CL0680-0502-6-## 3 12.32 7.92 DF63-4S-3.96C(##) CL0680-0510-4-## 4 16.28 11.88 DF63-5S-3.96C(##) CL0680-0511-7-## 5 20.24 15.84 DF63-6S-3.96C(##) CL0680-0512-0-## 6 24.20 19.80 Purchase Unit 100pcs per bag [Specification number(##), -##] None : Black R Type (Guide key) Part No. DF63R-5S-3.96C(##) Unit : mm HRS No. No. of Pos. A B Purchase Unit 5 20.24 15.84 100pcs per bag CL0680-0525-1-## [Specification number(##), -##] None : White 8 DF63 Series/15A 3.96mm pitch Wire-to-Board Connectors for Internal Power Supply (UL, C-UL and TÜV Listed) In-line Plug (Panel Lock Type) 8.56 P=3.96 Shown with terminated and contacts installed. 2.75 5.35 Polarization mark ■ Recommended Panel Cutout E 6.4 2.75 9.16 5.75 [1 pos.] 6.4 [2 to 6 pos.] E C D 2.75 9.16 7.45 5.75 Feb.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 12.65 23.75 A B C Unit : mm Part No. HRS No. No. of Pos. A B C D DF63-1EP-3.96C(##) CL0680-0551-0-## 1 14.20 6.20 - - DF63-2EP-3.96C(##) CL0680-0533-0-## 2 16.66 8.66 8.86 4.96 DF63-3EP-3.96C(##) CL0680-0532-7-## 3 20.62 12.62 12.82 8.32 DF63-4EP-3.96C(##) CL0680-0552-0-## 4 24.58 16.58 16.78 12.28 DF63-5EP-3.96C(##) CL0680-0553-0-## 5 28.54 20.54 20.74 16.24 DF63-6EP-3.96C(##) CL0680-0554-0-## 6 32.50 24.50 24.70 20.20 E Purchase Unit 100pcs per bag Unit : mm No. of Pos. Panel thickness 1 2 3 4 5 6 0.5 to 0.6 10.30 12.76 16.72 20.68 24.64 28.60 0.7 to 1.1 10.80 13.26 17.22 21.18 25.14 29.10 1.2 to 1.7 11.30 13.76 17.72 21.68 25.64 29.60 2.0 to 2.3 11.80 14.26 18.22 22.18 26.14 30.10 [Specification number(##), -##] None : Black 9 DF63 Series/15A 3.96mm pitch Wire-to-Board Connectors for Internal Power Supply (UL, C-UL and TÜV Listed) In-line Plug 8.56 P=3.96 A Feb.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 23.75 Polarization mark Shown with terminated and contacts installed. Unit : mm Part No. HRS No. No. of Pos. A DF63A-1EP-3.96C(##) CL0680-0555-0-## 1 6.20 DF63A-2EP-3.96C(##) CL0680-0535-5-## 2 8.66 DF63A-3EP-3.96C(##) CL0680-0534-2-## 3 12.62 DF63A-4EP-3.96C(##) CL0680-0556-0-## 4 16.58 DF63A-5EP-3.96C(##) CL0680-0557-0-## 5 20.54 DF63A-6EP-3.96C(##) CL0680-0558-0-## 6 24.50 [Specification number(##), -##] None : Black 10 Purchase Unit 100pcs per bag DF63 Series/15A 3.96mm pitch Wire-to-Board Connectors for Internal Power Supply (UL, C-UL and TÜV Listed) Crimp Contact for Socket 2.14 2.96 10.45 φ 2 4 15.25 Applicable wire gauge mark 16 18 t=0.25 P=9.5 Reel Contact (4,000pcs per reel) *Applicable tool : Applicator Applicable Wire (Tin Plated Annealed Copper) (Note 1) Feb.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. HRS No. Finish UL Wire Size Stranded Wire Structure Calculated Cross-section DF63A-1618SCF CL0680-0573-0-00 Tin Plated 1007 1015 16 AWG 26/0.254mm 1.317m 18 AWG 34/0.18mm 0.865m2 DF63A-1618SCFA CL0680-0646-0-00 Gold Plated 1007 1015 16 AWG 26/0.254mm 1.317m2 18 AWG 34/0.18mm 0.865m2 20 AWG 21/0.18mm 0.534m2 22 AWG 17/0.16mm 0.342m2 20 AWG 21/0.18mm 0.534m2 22 AWG 17/0.16mm 0.342m2 DF63A-2022SCF CL0680-0097-0-00 Tin Plated 1007 DF63A-2022SCFA CL0680-0647-0-00 Gold Plated 1007 Jacket Diameter RoHS 2 φ 2.1 to 3.2mm φ 2.1 to 3.2mm ○ φ 1.7 to 1.8mm φ 1.7 to 1.8mm Note 1 : When using a wire other than the applicable wires please contact a Hirose representative. Loose piece (100pcs per bag) *Applicable tool : Hand crimping tool Applicable Wire (Tin Plated Annealed Copper) (Note 1) Part No. HRS No. Finish UL 1007 DF63A-1618SC CL0680-0648-0-00 Tin Plated 1015 1007 DF63A-1618SCA CL0680-0650-0-00 Gold Plated 1015 DF63A-2022SC DF63A-2022SCA CL0680-0649-0-00 CL0680-0651-0-00 Tin Plated Gold Plated 1007 1007 Wire Size Stranded Wire Structure Calculated Cross-section Jacket Diameter 16 AWG 26/0.254mm 1.317m2 2.5mm 18 AWG 34/0.18mm 0.865m2 2.1mm 16 AWG 26/0.254mm 1.317m2 3.2mm 18 AWG 34/0.18mm 0.865m2 2.9mm 16 AWG 26/0.254mm 1.317m2 2.5mm 18 AWG 34/0.18mm 0.865m2 2.1mm 16 AWG 26/0.254mm 1.317m2 3.2mm 18 AWG 34/0.18mm 0.865m2 2.9mm 20 AWG 21/0.18mm 0.534m2 1.8mm 22 AWG 17/0.16mm 0.342m 1.7mm 20 AWG 21/0.18mm 0.534m 1.8mm 22 AWG 17/0.16mm 0.342m 1.7mm Note 1 : When crimping using a hand crimping tool only the above wires are applicable. ● Crimp Contact extraction tool DF- C- PO( B) , Flat- bladed screwdriver, 1. 2mm blade width ● Strip length 2. 9 to 3. 6mm 11 2 2 2 RoHS ○ DF63 Series/15A 3.96mm pitch Wire-to-Board Connectors for Internal Power Supply (UL, C-UL and TÜV Listed) Crimp Contact for In-line Plug 19.1 Applicable wire gauge mark 16 18 4 φ2 23.9 2.14 4.75 t=0.25 Feb.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. P=9.5 Reel Contact(4,000pcs per reel) *Applicable tool : Applicator Applicable Wire (Tin Plated Annealed Copper) (Note 1) Part No. HRS No. Finish UL Wire Size Stranded Wire Structure Calculated Cross-section DF63-1618PCF CL0680-0529-2-00 Tin Plated 1007 1015 16 AWG 26/0.254mm 1.317m 18 AWG 34/0.18mm 0.865m2 DF63-1618PCFA CL0680-0636-0-00 Gold Plated 1007 1015 16 AWG 26/0.254mm 1.317m2 18 AWG 34/0.18mm 0.865m2 20 AWG 21/0.18mm 0.534m2 22 AWG 17/0.16mm 0.342m2 20 AWG 21/0.18mm 0.534m2 22 AWG 17/0.16mm 0.342m2 DF63-2022PCF CL0680-0538-3-00 Tin Plated 1007 DF63-2022PCFA CL0680-0638-0-00 Gold Plated 1007 Jacket Diameter RoHS 2 φ2.1 to 3.2mm φ2.1 to 3.2mm ○ φ1.7 to 1.8mm φ1.7 to 1.8mm Note 1 : When using a wire other than the applicable wires please contact a Hirose representative. Loose piece(100pcs per bag) *Applicable tool : Hand crimping tool Applicable Wire (Tin Plated Annealed Copper) (Note 1) Part No. HRS No. Finish UL 1007 DF63-1618PC CL0680-0536-8-00 Tin Plated 1015 1007 DF63-1618PCA CL0680-0637-0-00 Gold Plated 1015 DF63-2022PC DF63-2022PCA CL0680-0539-6-00 CL0680-0639-0-00 Tin Plated Gold Plated 1007 1007 Wire Size Stranded Wire Structure Calculated Cross-section Jacket Diameter 16 AWG 26/0.254mm 1.317m 2.5mm 18 AWG 34/0.18mm 16 AWG 2 2 0.865m 2.1mm 26/0.254mm 1.317m 2 3.2mm 18 AWG 34/0.18mm 16 AWG 2 0.865m 2.9mm 26/0.254mm 1.317m 2 2.5mm 18 AWG 34/0.18mm 16 AWG 2 0.865m 2.1mm 26/0.254mm 1.317m 2 3.2mm 18 AWG 34/0.18mm 0.865m2 2.9mm 20 AWG 21/0.18mm 0.534m 1.8mm 22 AWG 17/0.16mm 0.342m 1.7mm 20 AWG 21/0.18mm 0.534m 1.8mm 22 AWG 17/0.16mm 0.342m 1.7mm Note 1 : When crimping using a hand crimping tool only the above wires are applicable. ● Crimp Contact extraction tool DF- C- PO( B) , Flat- bladed screwdriver, 1. 2mm blade width ● Strip length 2. 9 to 3. 6mm 12 2 2 2 2 RoHS ○ DF63 Series/15A 3.96mm pitch Wire-to-Board Connectors for Internal Power Supply (UL, C-UL and TÜV Listed) Mated Dimensions ●Board-to-Wire Connection using the straight pin header (8.91) ●Socket to Right Angle Header Connection ●Socket to In-line Plug Connection DF63-#S-3.96C (20) (29.55) DF63-#S-3.96C (11.1) (8.91) DF63(M)-#P-3.96DSA (9.41) (15.8) DF63-#S-3.96C Feb.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. DF63(M)-#P-3.96DS 13 DF63-#EP-3.96C DF63 Series/15A 3.96mm pitch Wire-to-Board Connectors for Internal Power Supply (UL, C-UL and TÜV Listed) Applicable Crimping Tool Type Feb.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Applicator Hand tool Part No. HRS No. Wire Type AP105-DF63-1618S-1 CL0901-4634-1-00 UL1007 (Note 3) AP105-DF63-1618S-2 CL0901-4635-4-00 UL1015 (Note 3) CHS893400H-UP (Note 8) - UL1015 AP105-DF63-1618-3 CL0901-4642-0-00 UL1007 (Note 3) AP105-DF63-1618-4 CL0901-4643-2-00 UL1015 (Note 3) CHS893500H-UP (Note 8) - UL1015 AP105-DF63-2022-1 CL0901-4617-0-00 UL1007 (Note 3) HT802/DF63-1618S-1 CL0550-0411-2-00 UL1007 (Note 4, 5) HT802/DF63-1618S-2 CL0550-0413-8-00 UL1015 (Note 4, 6) HT802/DF63-1618P-1 CL0550-0423-1-00 UL1007 (Note 4, 5) HT802/DF63-1618P-2 CL0550-0424-4-00 UL1015 (Note 4, 6) HT802/DF63-2022S-1 CL0550-0432-0-00 CL0550-0433-0-00 DF63A-1618SCF DF63A-1618SCFA DF63-1618PCF DF63-1618PCFA DF63A-2022SCF DF63A-2022SCFA DF63-2022PCF DF63-2022PCFA DF63A-1618SC DF63A-1618SCA DF63-1618PC DF63-1618PCA DF63A-2022SC UL1007 (Note 4, 7) HT802/DF63-2022P-1 Applicable Contacts DF63A-2022SCA DF63-2022PC DF63-2022PCA Note 1 : Please conduct crimping work according to the "Crimping quality control statement of standards (ETAD-H0730-00, ETAD-H0810-00)" and "Crimping condition table". Note 2 : Any problems that occur from using tools other than those specified by Hirose, are not covered by warranty. Note 3 : Applicator dies can be switched to crimp the other wire size and type. The additional dies are sold separately. Note 4 : Hand tool dies cannot be switched. Note 5 : The compatible wire is limited to UL1007, 16 to 18 AWG Note 6 : The compatible wire is limited to UL1015, 16 to 18 AWG Note 7 : The compatible wire is limited to UL1007, 20 to 22 AWG Note 8 : Applicator manufactured by JAPAN AUTOMATIC MACHINE (J.A.M.). Please access to HP of J.A.M., if you make inquiries about the applicator or crimp defect. (URL : http://www.jam-net.co.jp) 14 DF63 Series/15A 3.96mm pitch Wire-to-Board Connectors for Internal Power Supply (UL, C-UL and TÜV Listed) Contact Extraction Contact extraction tool : Flat- bladed screwdriver. 1. 2mm blade width or DF- C- PO( B) Intended crimp Contacts : DF63A- 1618SC( F) ( A) , DF63A- 2022SC( F) ( A) , DF63- 1618PC( F) ( A) , DF63- 2022PC( F) ( A) ●   1.   2. Work Method Refer to the drawing No. 1. Insert correct size contact extraction tool in the insulator against the molded- in lance. Deflect the lance as shown. Assure that the lance is deflected to release the contact and pull- out wire with the terminated contact. Feb.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Housing Cross Sectional Diagram Contact extraction tool 2 1 DF63-*S-3.96C 2 1 DF63-*EP-3.96C * Using crimping socket after repair could induce decrease of lance strength, use new socket to avoid such fuilures.   Caution There are parts on the crimp contact that can cause injuries, please use caution when unmating the               contacts. 15 DF63 Series/15A 3.96mm pitch Wire-to-Board Connectors for Internal Power Supply (UL, C-UL and TÜV Listed) Precautions for use Feb.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1. The connector could be damaged if it is pulled out forcibly. When it is hard to pull out, push it in slightly first and then depress the lock and un- mate. 2. When thick, short sections of wire are used, the connector could be deformed due to the force of the wires' position. Route cables in such a way that they do twist when being installed. 3. Make sure to turn off the power when mating or un- mating the connector. 4. Please do not touch any area around the contact part with your hand when the power is on; it could be very dangerous. 5. Please refer to the materials listed below when handling this product.   ■ Crimping quality control statement of standards ( ETAD- H0730- 00, ETAD- H0810- 00)   ■ Harness procedure manual ( ETAD- H0737- 00)   ■ Insertion/ extraction manual ( ETAD- H0892- 00)   ■ User Guide for Wire- to- Board Connector Rated values ・ Please avoid using the connectors above the ratings. Also, do not insert or pull out energized or " live" wires. ・”Live wire insertion”refers to insertion while electricity is running. Operating environment ・ Please contact us if you are designing this connector into environmental conditions where high and low temperatures are repeated. While Taking into Consideration Specifications mentioned in this catalog are reference values. When considering to order or use this product, please confirm the Drawing and Product Specifications sheets. Use an appropriate cable when using the connector in combination with cables. If considering usage of a non- specified cable, please contact your sales representative. If assembly process is done by jigs & tools which are not identified by Hirose, assurance will not be given. If considering usage for below mentioned applications, please contact your sales representative. In cases where the application will demand a high level of reliability, such as automotive, medical instruments, public infrastructure, aerospace/ defense etc. Hirose must review before assurance of reliability can be given. 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN        https://www.hirose.com ※ The contents of this catalog are current as of date of 5/ 2021. Contents are subject to change without notice for the purpose of improvements. 16
DF63-4S-3.96C 价格&库存
很抱歉,暂时无法提供与“DF63-4S-3.96C”相匹配的价格&库存,您可以联系我们找货
DF63-4S-3.96C
  • 1+3.135311+0.37586
DF63-4S-3.96C
  • 4+1.13990
