JSM543
JSM543
    JSMICRO(杰盛微)
    SOT-23
    高压霍尔效应开关系列
JSM543 数据手册
JSM541-JSM546 High Voltage Hall Effect Switch Family Vinbelltech Co. Ltd Introduction JSM54X family consists of different Hall switches produced in BCDMOS technology. All Hall sensors include a temperature-compensated Hall plate with active offset compensation, a comparator, and an output driver. The family consists of 2-wire devices, the corresponding output driver being an open-drain output transistor and a current source respectively. The comparator compares the actual magnetic flux with the fixed reference values (switching points). Accordingly the output transistor in the current source is switched on (high current consumption) or off (low current consumption) in 2-wire version. The active offset compensation leads to constant magnetic characteristics over supply voltage and temperature range. In addition, the magnetic parameters are robust against mechanical stress effects. to r The sensors are designed for industrial and automotive applications and operate with supply voltages from 2.7 V to 30V in ambient temperature range from -40 °C up to 150 °C. The family JSM54X is available in SOT-23 and the leaded version TO92S packages.     co mi Se  CR O  SOT-23 and TO92S packages Low current consumptions of typ. 2.5 mA Operates from 2.7 V to 30 V supply voltage Overvoltage protection capability up to 40 V Highest ESD performance up to ±12 kV Current output for 2-wire applications Magnetic characteristics are robust regarding mechanical stress effects Constant switching points over a wide supply voltage and temperature range Wide operating temperature range from -40 °C to 150 °C The decrease of magnetic flux density caused by rising temperature in the sensor system is compensated by a built-in negative temperature coefficient of the magnetic characteristics Reverse-voltage protection at Vcc pin Ideal sensor for applications in extreme automotive and industrial environments Qualified according to AEC-Q100 test standard for automotive electronics industry to provide the highest quality expectation Speed and RPM sensing Tachometer, counter pickup Flow-rate sensing Brushless dc motor commutation Motor and fan control Robotics control Proximity sensor Position sensor Seat position detection Seat belt buckles Hood/trunk/door latches Sun roof/convertible top/tailgate/liftgate actuation Brake/clutch pedals Electric power steering (EPS) Transmissions and shift selectors Wiper motor     Package JS MI                    nd Features uc Applications SOT23 www.jsmsemi.com TO92 第1页,共12页 JSM541-JSM546 High Voltage Hall Effect Switch Family Vinbelltech Co. Ltd Contents Title Page JSM54X Family Overview 3 2. Ordering Information 4 2.1 Marking Code 2.2 Operating Ambient Temperature Range 2.3 Hall Sensor Package Codes 3. Functional Description 4. Diagnostic Features 5. Specifications 5.1 Outline Dimensions 5.2 Pin assignment 5.3 Absolute Maximum Ratings 5.4 ESD and Latch-up 10 5.5 Recommended Operating Conditions 10 5.6 Characteristics 10 5.7 Magnetic Characteristics Overview 11 6. Application circui 12 6.1 2-Wire Devices 12 to r 1. CR O Section 4 JS MI Se mi co nd uc 4 www.jsmsemi.com 4 4 5 6 6 8 9 第2页,共12页 JSM541-JSM546 High Voltage Hall Effect Switch Family Vinbelltech Co. Ltd 1. AH54y Family Overview The types within each family differ according to the magnetic flux density values for the magnetic switching points, the temperature behavior of the magnetic switching points, the mode of switching, the number of pins and the average current consumption. Table 1 list some devices classified in terms of switching behavior and sensitivity: higher sensitivity correlates to lower switching points. Sensitivity Very high Medium High Very high Very high High uc Switching Behavior Latching Latching Unipolar inverted Unipolar inverted Unipolar Uipolar nd Type Sensitivity JSM541 JSM542 JSM543 JSM544 JSM545 JSM546 to r Table 1: JSM54X 2-wire devices co The following definitions outline the device behavior for different switching points: mi Unipolar Switching Sensors: 2-wire: The sensor turns to high current consumption with the magnetic south pole on the branded side of the package Se and turns to low consumption if the magnetic field is removed. The sensor does not respond to the magnetic north pole on the branded side. JS MI CR O Current consumption IHi BHYS ILo 0 Brp Bop B Fig. 1: Definition of magnetic switching points for 2- wire unipolar sensor. Unipolar Switching Sensors with Inverted Output: www.jsmsemi.com 第3页,共12页 JSM541-JSM546 High Voltage Hall Effect Switch Family Vinbelltech Co. Ltd 2-wire: The sensor turns to low current consumption with the magnetic south pole on the branded side of the package and turns to high consumption if the magnetic field is removed. The sensor does not respond to the magnetic north pole on the branded side. Current consumption IHi BHYS Brp Bop B uc 0 to r ILo Fig. 2: Definition of magnetic switching points for 2- wire unipolar sensor with inverted output. nd 2. Ordering Information co 2.1. Marking Code All Hall sensors have a marking on the package surface (branded side). This marking includes the name of the sensor and 2.2. Operating Ambient Temperature Range mi date code. Se The Hall sensors from Vinbelltech are specified to the ambient temperature. TA = -40 °C up to 150 °C CR O 2.3. Hall Sensor Package Codes Hall sensors are available in a wide variety of packaging versions and quantities. JS MI Ordering information Part number Package Packing Ambient, TA JSM54X TO92S Bulk, 1000 pieces/bag -40℃ to 150℃ JSM54X SOT23 Tape&Reel, 3000 pieces/reel -40℃ to 150℃ 3. Functional Description www.jsmsemi.com 第4页,共12页 JSM541-JSM546 High Voltage Hall Effect Switch Family Vinbelltech JSM54X Hall Co. effect Ltd sensor switches are available with different magnetic switching levels and output polarity. JSM54X sensors are monolithic integrated circuits which switch in response to magnetic fields. If a magnetic field with flux lines perpendicular to the sensitive area is applied to the sensor, the biased Hall plate forces a Hall voltage proportional to this field. The Hall voltage is compared with the actual threshold level in the comparator. If the magnetic field exceeds the to r threshold levels, the output stage (current source for 2-wire devices) is switched to the appropriate state. The built-in hysteresis eliminates oscillation and provides switching behavior of output without bouncing. Magnetic offset caused by mechanical stress is compensated by using the chopping offset compensation technique. A uc serial resistor or diode on the supply line is not required thanks to the built-in reverse voltage protection. nd The open drain output is forced to a safe, high-impedance state (tri-state), in any of the following fault conditions: overtemperature, and undervoltage. In addition, the output current is limited (short-circuit protection). co The device is able to withstand a maximum supply voltage of 28 V for unlimited time and features overvoltage capability JS MI CR O Se mi (40V load dump). Fig.3:JSM54X- 2-wire - Block diagram 4. Diagnostic Features www.jsmsemi.com 第5页,共12页 JSM541-JSM546 High Voltage Hall Effect Switch Family Vinbelltech Co. Internal states are Ltd monitored and in an error condition flagged with a tri-state at the outputr a low current level (2-wires devices): – Internal voltage regulator: under and over voltage detection – Monitoring of internal bias and current levels – Monitoring of the internal reference voltage to r – Monitoring of the Hall plate voltage uc 5. Specifications nd 5.1. Outline Dimensions JS MI CR O Se mi co TO92S www.jsmsemi.com 第6页,共12页 uc nd Size (in inches) minimum maximum 0.056 0.066 0.026 0.034 0.014 0.022 0.016 0.022 0.014 0.02 0.154 0.165 0.117 0.129 0.114 0.129 0.050 TYP 0.096 0.104 0.531 0.61 0.080TYP 0.061TYP 0.020TYP 45˚TYP JS MI CR O Se mi A A1 b b1 C D D1 E e e1 L x y z θ Size (mm) minimum maximum 1.42 1.67 0.66 0.86 0.35 0.56 0.4 0.55 0.36 0.51 3.9 4.2 2.97 3.27 2.9 3.28 1.270 TYP 2.44 2.64 13.5 15.5 2.025TYP 1.545TYP 0.500TYP 45˚TYP co Symbol to r Vinbelltech Co. Ltd TO92S dimensions (0~9) (1~52) SOT23 dimensions www.jsmsemi.com 第7页,共12页 JSM541-JSM546 High Voltage Hall Effect Switch Family Vinbelltech Co. Ltd Symbol Size (in inches) Size (mm) minimum maximum maximum 1.05 1.25 0.041 0.049 A1 0 0.1 0 0.004 A2 1.05 1.15 0.041 0.045 b 0.3 0.5 0.012 0.02 c 0. 100 0.2 0.004 0.008 D 2.82 3.02 0.111 0.119 E 1.5 1.7 0.059 0.067 E1 2.65 2.95 0.104 0.116 e1 1.8 2 0.071 L 0.3 0.6 0.012 uc 0.037 TYP nd 0.950 TYP 0.079 0.024 co e to r minimum A 1.460TYP 0.057TYP y 0.800TYP 0.032TYP z 0.600TYP θ 0˚ mi x 8˚ CR O Se 0.024TYP JS MI 5.2. Pin assignment TO92S SOT23 Fig.4: Pin assignment of TO92S and SOT23 www.jsmsemi.com 第8页,共12页 JSM541-JSM546 High Voltage Hall Effect Switch Family Vinbelltech Co. Ltd Pin assignment Pin number Name Function 1 2 3 VCC GND Vout Power supply Ground Output 5.3. Absolute Maximum Ratings Stresses beyond those listed in the “Absolute Maximum Ratings” may cause permanent damage to the device. to r This is a stress rating only. Functional operation of the device at these conditions is not implied. Exposure to absolute maximum rating conditions for extended periods will affect device reliability. This device contains circuitry to protect the inputs and outputs against damage due to high static voltages or uc electric fields; however, it is advised that normal precautions be taken to avoid application of any voltage higher nd than absolute maximum-rated voltages to this circuit. Symbol Supply voltage Pin No 1 Min. 20 Max. Unit  V t < 1000 h 1) 34 V t < 96 h1) 36 V t < 5 min1) 40 V t < 5 x 400 ms1) Output voltage 3 0.5  V t < 1000 h1) 34 V t < 96 h1) 36 V t < 5 min1) 40 V t < 5 x 400 ms1) with series resistor RL > 100  IO Output current 3 IOR Reverse output current 3 TA Ambient temperature range 1) Conditions with series resistor RV > 100  JS MI VOUT CR O Se mi VCC Parameter co All voltages listed are referenced to ground (GND). 65 50 40 mA mA 170 °C t < 96 h1) No cumulative stress www.jsmsemi.com 第9页,共12页 JSM541-JSM546 High Voltage Hall Effect Switch Family Vinbelltech Ltd 5.4. ESD andCo. Latch-up The output pin has to be in tri-state (high impedance) for ESD measurements. ESD and latch-up Symbol Parameter Min Max Unit Maximum latch-up free current at any pin (measurement according to AEC Q100-004), class 1 100 100 mA VHBM Human body model (according to AEC Q100-002) 12  kV to r Ilatch uc 5.5. Recommended Operating Conditions Functional operation of the device beyond those indicated in the “Recommended Operating Conditions” of this specification is not implied, may result in unpredictable behavior of the device and may reduce reliability and nd lifetime. Supply voltage TA Ambient temperature range VOUT Output voltage IOUT Output current 1 Min Typ Max mi VCC Pin No Unit 30 V 150 °C 3 30 V 3 25 mA 3.0 Se Parameter 40 Conditions 2-wire JS MI CR O Symbol co All voltages listed are referenced to ground (GND). 5.6. Characteristics at TA = -40 °C to 150 °C, VCC = 3.0 V to 24 V, at Recommended Operation Conditions if not otherwise specified in the column “Conditions”. Typical Characteristics for TA= 25 °C and VCC = 12 V Symbol Parameter Pin No Min 1 2 Typ Max Unit 5 mA Conditions Supply Icclo Low supply current 2-wire JSM544, JSM545 www.jsmsemi.com 第10页,共12页 JSM541-JSM546 High Voltage Hall Effect Switch Family Icclo supply current Vinbelltech Co.Low Ltd 1 5 7 mA 2-wire JSM541 JSM542 JSM543 JSM546 High supply current IccR Reverse current 1 12 17 mA 2-wire 1 mA for Vcc = -18 V 0.4 V to r Icchi Port Output Port low output voltage 3 0.13 IO = 20 mA uc Vol Output fall time tr Output rise time Bnoise Effective noise of magnetic switching points tj Output jitter td Delay time tsamp Output refresh period ten Enable time of output after settling of Vcc V IO = 25 mA 1 µs Vcc = 12V; RL = 1 µs co nd tf 0.5 0.5 16 1.6 2 CR O Se mi 0.1 820 ; CL = 20 pF mT For square wave signal with 1 kHz µs For square wave signal with 1 kHz µs 2.66 µs 50 µs VCC = 12V JS MI B > Bon + 2 mT or B < Boff - 2 mT 5.7. Magnetic Characteristics Overview TA = -40 °C to 150 °C, Vcc = 3.0 V to 30 V, GND = 0 V, recommended operation conditions if not otherwise specified in the column “Conditions”. Typical characteristics for TA= 25 °C. Sensor Switching Type Temp. coeff. of magnetic thresh. TC [ppm/K] On point BON [mT] Min Typ Off point BOFF [mT] Max Min Typ Hysteresis BHYS [mT] Max Min Typ Max 2-wire www.jsmsemi.com 第11页,共12页 JSM541-JSM546 High Voltage Hall Effect Switch Family latching Vinbelltech Ltd JSM541 Co.  4.0 4.0  8.0  latching 0 12.0 12.0  24.0  JSM543 unipolar inverted 0 7.0 9.0  2.0  JSM544 unipolar inverted 0 4.0 6.0  2.0  JSM545 unipolar 0 6.0 4.0  2.0  JSM546 unipolar 0 9.0 7.0  2.0  uc The hysteresis is the difference between the switching points BHYS = BON  BOFF to r JSM542 6. Application circuit 6. 1. 2-Wire Devices nd Fig.5 shows a simple application with a 2-wire sensor. The current consumption can be detected by measuring the voltage over RL. For correct functioning of the sensor, the voltage between Vcc and GND must be a minimum of VCCmin. – CR O Se mi co With the maximum current consumption of Icchimax, the maximum RL can be calculated as:RLmax JS MI Fig. 6 :Example 2-wire application circuit 1 Fig. 7: Example 2-wire application circuit 2 For applications with disturbances on the supply line or radiated disturbances, a series resistor RV and a capacitor CP both placed close to the sensor are recommended (see Fig. 6). In this case, the maximum RL can be calculated as: RLmax – www.jsmsemi.com 第12页,共12页
JSM543 价格&库存
很抱歉,暂时无法提供与“JSM543”相匹配的价格&库存,您可以联系我们找货
