MG630
MG630
    MATRIXOPTO(矩阵光电)
    SSOT4_1.5X1.5MM
    砷化镓霍尔元件,SSOT-4封装
MG630 数据手册
Matrix Opto Co., Ltd -MG630 GaAs Hall Element- MG630 GaAs Hall Element Linear GaAs Hall Element with Excellent thermal characteristics SSOT-4 package Shipped in Packet-tape Reel (4000pcs devices per Reel) Dimensional Drawing (Unit MM) Absolute Maximum Rating Operating Temperature Range Storage Temperature Range Maximum Input Current Icmax -40℃ ~ 125℃ -40℃ ~ 150℃ 11mA Figure 1. Maximum input current Icmax Copy Right Reserved JZWI-DS-003 Version 2.0 Matrixopto.Co.,Ltd is the owner of the trademarks used in this document, which has the exclusive right to prevent any third parties not having the owner’s consent from using in the course of trade identical or similar signs for goods or services where such use would result in a likelihood of confusion. Matrix Opto Co., Ltd -MG630 GaAs Hall Element- Electrical Characteristics (RT=25℃) Table 1. Electrical Characteristics of MG630. Item Symbol Hall Voltage VH Input Resist. Rin Output Resist. Rout Offset Voltage Vos Temp. Coeffi. of VH |αVH| Temp. Coeffi. of Rin αRin Linearity of VH ΔK Test Condi. B = 50mT, IC = 5mA Ta = RT B = 0mT, IC = 0.1mA Ta = RT B = 0mT, IC = 0.1mA Ta = RT B = 0mT, IC = 5mA Ta = RT B = 50mT, IC = 1mA, Ta =25℃ ~ 125℃ B = 0mT, IC = 0.1mA, Ta = 25℃ ~ 125℃ B = 0.1 - 0.5T, IC = 1mA Ta = RT Min. Typ. Max. Unit 90 100 110 mV 1000 1250 1500 Ω 1800 2500 3000 Ω +8 mV 0.06 %/℃ 0.3 %/℃ +2 % -8 -2 Note: 1. �H = �H−M − �os In which V H-M is the Output Hall Voltage, �H is the Hall Voltage and �os is the offset Voltage under the identical electrical stimuli. 2. 3. 4. 1 α�H = �H(��1 ) α�in = �in(��1 ) Δ� = 1 × × � �1 −� �2 � �1 +� �2 2 �H (��2 )−�H(��1 ) ��2 −��1 ��n ��2 −��� (��1 ) ��2 −��1 × 100 �= × 100 ��1 = 25℃, ��2 = 125℃ × 100 �H �� ×� ��1 = 25℃, ��2 = 125℃ �1 = 0.5T, B2 = 0.1T Copy Right Reserved JZWI-DS-003 Version 2.0 Matrixopto.Co.,Ltd is the owner of the trademarks used in this document, which has the exclusive right to prevent any third parties not having the owner’s consent from using in the course of trade identical or similar signs for goods or services where such use would result in a likelihood of confusion. Matrix Opto Co., Ltd -MG630 GaAs Hall Element- Characteristic Curves Figure 2.Input resistance Rin as a function of ambient temperature Ta . VH- B 700 @RT Hall Voltage VH [mV] 600 500 I = 5mA c 400 Vc = 6V 300 200 100 0 0 100 200 300 Magnetic Flux Density B [mT] Figure 3. Hall voltage VH as a function of magnetic flux density B . Copy Right Reserved JZWI-DS-003 Version 2.0 Matrixopto.Co.,Ltd is the owner of the trademarks used in this document, which has the exclusive right to prevent any third parties not having the owner’s consent from using in the course of trade identical or similar signs for goods or services where such use would result in a likelihood of confusion. Matrix Opto Co., Ltd -MG630 GaAs Hall Element- VH-Ta 140 @50mT Hall Voltage VH [mV] 120 I = 5mA c 100 80 Vc = 6V 60 40 20 0 -50 0 50 100 150 Ambient Temperature Ta [celsius] Figure 4. Hall voltage VH as a function of ambient temperature Ta . VH - Ic/Vc 160 @50mT @RT 140 Hall Voltage VH 120 Ic 100 Vc 80 60 40 20 0 0 2 4 6 8 10 Input Current/Voltage Ic/Vc [mA/V] Figure 5. Hall voltage VH as a function of electrical stimuli Ic/ Vc. Copy Right Reserved JZWI-DS-003 Version 2.0 Matrixopto.Co.,Ltd is the owner of the trademarks used in this document, which has the exclusive right to prevent any third parties not having the owner’s consent from using in the course of trade identical or similar signs for goods or services where such use would result in a likelihood of confusion. Matrix Opto Co., Ltd -MG630 GaAs Hall Element- Reliability Test Terms Table 2. Reliability Test Terms, Conditions and Duration. No. 1 Terms Conditions Duration High Temperature Storage 【JEITA EIAJ ED-4701】 (HTS) Ta =150(0 ~ +10)℃ 1000 hrs 【JEITA EIAJ ED-4701】 2 T a=-55℃~150 ℃ Heat Cycle (HC) high temp. 30 min 3 4 5 normal temp. - 5 min - low temp. 30 min Temp. Humidity Storage 【JEITA EIAJ ED-4701】 (THS) Ta =85±3 ℃,RH =85±5 % Reflow Soldering 【JEITA EIAJ ED-4701】 (RS) 260±5 ℃ High Temp. Operating (HTO) 50 cycles Ta =125 ℃,Vc =7.5V 1000 hrs 10 sec 1000 hrs Criteria: - Variation of Hall Voltage �H and input/output resistances Rin/out are less than 20%. - Variation of offset voltage �os is less than ±16mV. - Other parameters in Table 1. are still within their ranges stated in Table 1. Copy Right Reserved JZWI-DS-003 Version 2.0 Matrixopto.Co.,Ltd is the owner of the trademarks used in this document, which has the exclusive right to prevent any third parties not having the owner’s consent from using in the course of trade identical or similar signs for goods or services where such use would result in a likelihood of confusion. Matrix Opto Co., Ltd -MG630 GaAs Hall Element- Soldering Conditions The following conditions should be preserved. Solder ability should be checked by yourself, because it is depend on solder paste material and other parameters. Material of solder flux - Use the resin based flux and refrain from using organic or inorganic acid based and water-soluble one. Cleansing of solder flux conditions - Use Ethanol or Isopropyl alcohol as cleansing material. - Process temperature should be 50 ℃ or less. - Duration should be 5 min or less. Hand soldering conditions - Solder at temperature 300 ℃ for less than 3s. Soldering conditions - Temperature in Pre-heating zone should be lower than 150℃. - Temperature in Soldering zone should be lower than 280℃. Copy Right Reserved JZWI-DS-003 Version 2.0 Matrixopto.Co.,Ltd is the owner of the trademarks used in this document, which has the exclusive right to prevent any third parties not having the owner’s consent from using in the course of trade identical or similar signs for goods or services where such use would result in a likelihood of confusion. Matrix Opto Co., Ltd -MG630 GaAs Hall Element- Precautions for ESD This product is the device that is sensitive to ESD (Electrostatic Discharge). Handling Hall Elements with the ESD-Caution mark under the environment in which - Static electrical charge is unlikely to arise. (Ex; Relative Humidity; over 40%RH). - Wearing the antistatic suit and wristband when handling the devices. - Implementing measures against ESD as for containers that directly touch the devices. Precautions for Storage - Products should be stored at an appropriate temperature and humidity (5 to 35°C, 40 to 85%RH). Keep products away from chlorine and corrosive gas. - Long-term storage may result in poor lead solder ability and degraded electrical performance even under proper conditions. For those parts, which stored long –term shall be check solder ability before it is used. - For storage longer than 2 years, it is recommended to store in nitrogen atmosphere. Oxygen of atmosphere oxidizes leads of products and lead solder ability get worse. Precautions for Safety - Do not alter the form of this product into a gas, powder or liquid through burning, crushing or chemical processing. - Observe laws and company regulations when discarding this product. Copy Right Reserved JZWI-DS-003 Version 2.0 Matrixopto.Co.,Ltd is the owner of the trademarks used in this document, which has the exclusive right to prevent any third parties not having the owner’s consent from using in the course of trade identical or similar signs for goods or services where such use would result in a likelihood of confusion.
MG630 价格&库存
很抱歉,暂时无法提供与“MG630”相匹配的价格&库存,您可以联系我们找货
MG630
  • 1+3.14000
  • 10+2.94000
  • 50+2.64000
  • 150+2.44000
  • 300+2.30000
  • 500+2.24000
