WNM2046C
WNM2046C
Single N-Channel, 20V, 0.6A, Power MOSFET
VDS (V)
https://www.omnivision-group.com
G
Typical RDS(on) (Ω)
S
D
0.42 @ VGS =4.5V
0.58 @ VGS=2.5V
0.84 @ VGS=1.8V
DFN1006-3L
Descriptions
D
The WPM2046C is N-Channel enhancement MOS
Field Effect Transistor. Uses advanced trench
technology and design to provide excellent RDS(ON)
with low gate charge. This device is suitable for use
in DC-DC conversion, power switch and charging
circuit. Standard Product WNM2046C is Pb-free.
G
Pin configuration (Top view)
Features
Trench Technology
Supper high density cell design
Excellent ON resistance
Extremely Low Threshold Voltage
Small package DFN1006-3L
S
6 = Device Code
* = Month(A~Z)
Applications
Marking
DC/DC converters
Power supply converters circuit
Load/Power Switching for portable device
Will Semiconductor Ltd.
Order information
Device
Package
Shipping
WNM2046C-3/TR
DFN1006-3L
10K/Tape&Reel
1
2022/4/21 - Rev.1.1
WNM2046C
Absolute Maximum ratings
Parameter
Symbol
10 s
Steady State
Drain-Source Voltage
VDS
Gate-Source Voltage
VGS
±10
Continuous Drain Current a d
Maximum Power Dissipation a d
Continuous Drain Current b d
Maximum Power Dissipation b d
TA=25°C
ID
TA=70°C
TA=25°C
PD
TA=70°C
TA=25°C
ID
TA=70°C
TA=25°C
PD
TA=70°C
Unit
V
0.6
0.55
0.48
0.44
0.32
0.27
0.21
0.18
0.57
0.52
0.45
0.42
0.29
0.25
0.18
0.16
A
W
A
W
Pulsed Drain Current c
IDM
1.4
A
Operating Junction Temperature
TJ
-55 to 150
°C
Lead Temperature
TL
260
°C
Storage Temperature Range
Tstg
-55 to 150
°C
Thermal resistance ratings
Parameter
Junction-to-Ambient Thermal Resistance a
Junction-to-Ambient Thermal Resistance b
Junction-to-Case Thermal Resistance
Symbol
t ≤ 10 s
Steady State
t ≤ 10 s
Steady State
Steady State
RθJA
RθJA
RθJC
Typical
Maximum
350
390
395
455
397
435
445
505
240
280
a.
Surface mounted on FR4 Board using 1 in sq pad size, 1oz Cu.
b.
Surface mounted on FR4 board using the minimum recommended pad size, 1oz Cu.
c.
Repetitive rating, pulse width limited by junction temperature, tp=10µs, Duty Cycle=1%.
d.
Repetitive rating, pulse width limited by junction temperature TJ(MAX)=150°C.
2
Unit
°C/W
2022/4/21 - Rev.1.1
WNM2046C
Electronics Characteristics (Ta=25oC, unless otherwise noted)
Parameter
Symbol
Test Conditions
Min
Typ
Max
Unit
OFF CHARACTERISTICS
Drain-to-Source Breakdown Voltage
BVDSS
VGS = 0 V, ID = 250uA
V
Zero Gate Voltage Drain Current
IDSS
VDS = 16V, VGS = 0V
1
uA
Gate-to-source Leakage Current
IGSS
VDS = 0 V, VGS = ±10V
±5
uA
VGS(TH)
VGS = VDS, ID = 250uA
0.70
1.0
V
VGS = 4.5V, ID = 0.35A
420
600
VGS = 3.1V, ID = 0.20A
500
700
VGS = 2.5V, ID = 0.20A
580
800
VGS = 1.8V, ID = 0.20A
840
1300
VGS = 1.5V, ID = 0.04A
1100
1600
VDS = 10 V, ID = 0.35A
0.85
ON CHARACTERISTICS
Gate Threshold Voltage
Drain-to-source On-resistance
Forward Transconductance
RDS(on)
gFS
0.45
mΩ
S
CHARGES, CAPACITANCES AND GATE RESISTANCE
Input Capacitance
CISS
Output Capacitance
COSS
Reverse Transfer Capacitance
CRSS
Total Gate Charge
QG(TOT)
Threshold Gate Charge
QG(TH)
VGS = 4.5 V, VDS = 10 V,
0.12
Gate-to-Source Charge
QGS
ID = 0.54 A
0.32
Gate-to-Drain Charge
QGD
0.14
Turn-On Delay Time
td(ON)
7.2
Rise Time
tr
9.5
Turn-Off Delay Time
td(OFF)
ID = 0.54A, RG = 6Ω
19.6
Fall Time
tf
VGS = 0 V, f = 1.0MHz, VDS =
10 V
30
7
pF
5
1.07
nC
SWITCHING CHARACTERISTICS
ns
4.6
BODY DIODE CHARACTERISTICS
Forward Voltage
VSD
VGS = 0 V, IS = 0.3A
3
0.85
1.5
V
2022/4/21 - Rev.1.1
WNM2046C
Typical Characteristics (Ta=25oC, unless otherwise noted)
1.0
2.0
IDS-Drain-to-Source Current (A)
15
VGS=3.0V~4.5V
1.5
VGS=2.5V
1.0
VGS=2.0V
0.5
VGS=1.5V
0.0
0.0
0.5
1.0
1.5
2.0
VDS=1.0V
0.8
0.6
o
T= -50 C
o
T= 25 C
o
T= 150 C
0.4
0.2
0.0
0.0
0.5
VDS-Drain-to-Source Voltage (V)
1.5
1.0
2.0
2.5
3.0
VGS-Gate-to-Source Voltage (V)
Output characteristics
Transfer characteristics
1.0
2.0
RDS(ON)-On-Resistance ()
VGS=5.5V
VGS=1.8V
0.8
VGS=2.5V
0.6
VGS=3.1V
0.4
VGS=4.5V
0.2
0.0
0.2
0.4
0.6
1.5
1.0
0.5
0.0
1.5
0.8
2.0
On-Resistance vs. Drain current
VGS=4.5V,ID=0.54A
1.4
1.3
1.2
1.1
1.0
0.9
0.8
0.7
0.6
-50
-25
50
75
100
125
150
o
Temperature ( C)
4.0
3.5
4.5
5.0
1.3
ID=250uA
1.2
1.1
1.0
0.9
0.8
0.7
0.6
-50
-25
50
75
100
125
150
Temperature (oC)
On-Resistance vs. Junction temperature
3.0
On-Resistance vs. Gate-to-source voltage
1.6
1.5
2.5
Gate Threshold Voltage Normalize
VGS=6V
10
IDS-Drain-to Source Current (A)
=8V
GS
5
VDS-Drain-to-Source Voltage(V)
VGS=10VV
RDS(ON)-On-Resistance Normalize
6
4
2
Threshold voltage vs. Temperature
4
2022/4/21 - Rev.1.1
WNM2046C
0.8
IS-Source-to-Drain Current (A)
60
VGS=0V
C -Capacitance (pF)
50
F=1MHz
40
30
Ciss
Coss
Crss
10
4
6
8
0.6
o
o
T=25 C
0.2
0.0
0.0
10
T=150 C
0.4
0.1
0.2
VDS-Drain Voltage (V)
0.3
0.4
0.5
0.6
0.7
0.8
0.9
1.0
1.1
V -Source-to-Drain Voltage (V)
SD
Capacitance
Body diode forward voltage
80
10
o
TJ(MAX)=150 C
70
o
ID-Drain Current (A)
TA=25 C
Power (W)
60
50
40
30
Limit by Rdson
1
100us
1ms
0.1
10s
1E-6
0.01
1E-5
1E-4
1E-3
0.01
0.1
1
10
100
TA=25 C
1
10
100
VDS-Drain to Source Voltage(V)
*VGS>minimum VGS at which RDS(ON) is specified
Safe operating Area
Single pulse power
Gate Voltage (V)
1s
Single Pulse
0.1
Pulse width (S)
4
100ms
DC
o
10
10ms
VGS=4.5V, VDS=10V, ID=0.54A
3
2
1
0.4
0.8
1.2
Qg (nc)
Gate Charge Characteristics
5
2022/4/21 - Rev.1.1
WNM2046C
Transient thermal response (Junction-to-Ambient)
Normalized Effective Transient
Thermal Impedance
1
0.1
Duty cycle=0.5
0.2
0.1
0.05
0.01
0.02
PDM
single pulse
t1
t2
1E-3
1E-4
1E-6
1. Duty Cycle, D=t1/t2
2. Per Unit Base =RθJA= 455°C/W
3. TJM-TA = PDM RθJA
4. Surface Mounted
1E-5
1E-4
1E-3
0.01
0.1
1
10
100
1000
Square Wave Pulse Duration (sec)
6
2022/4/21 - Rev.1.1
WNM2046C
PACKAGE OUTLINE DIMENSIONS
DFN1006-3L
L
L1
L
b1
E
b2
e1
D
e2
(Ⅰ)
Top View
Bottom View
(Ⅱ)
(Ⅱ)
0.2 0.25
0.45
0.7
A1
0.45
A
(Ⅰ)
0.25
Side View
Symbol
RECOMMENDED LAND PATTERN(Unit:mm)
Dimensions in Millimeters
Min.
Typ.
Max.
A
0.31
0.40
A1
0.00
0.05
D
0.95
1.00
1.05
E
0.55
0.60
0.65
b1
0.10
0.15
0.20
b2
0.45
0.50
0.60
L
0.20
0.25
0.30
L1
0.20
0.30
0.40
e1
0.35Ref
e2
0.65 Ref
7
2022/4/21 - Rev.1.1
WNM2046C
TAPE AND REEL INFORMATION
Reel Dimensions
RD
Reel Dimensions
W
Tape Dimensions
P1
Quadrant Assignments For PIN1 Orientation In Tape
Q1
Q2
Q1
Q2
Q3
Q4
Q3
Q4
RD
Reel Dimension
W
Overall width of the carrier tape
P1
Pin1
User Direction of Feed
7inch
13inch
8mm
12mm
16mm
Pitch between successive cavity centers
2mm
4mm
8mm
Pin1 Quadrant
Q1
Q2
Q3
1
8
Q4
2022/4/21 - Rev.1.1
很抱歉,暂时无法提供与“WNM2046C-3/TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.53698
- 100+0.44857
- 2000+0.37125
- 4000+0.34472
- 10000+0.34127
- 国内价格
- 10+0.58580
- 100+0.48935
- 300+0.44118
- 1000+0.40500
- 5000+0.37606
- 国内价格
- 5+0.68070
- 20+0.63530
- 100+0.59000
- 500+0.54450
- 1000+0.49920
- 2000+0.45380
