2SB624
2SB624
    YONGYUTAI(永裕泰)
    SOT-23
    晶体管类型:PNP 集射极击穿电压(Vceo):25V 集电极电流(Ic):700mA 功率(Pd):200mW 集电极截止电流(Icbo):100nA SOT23
2SB624 数据手册
2SB624 2SB624 TRANSI STOR (PNP) Equivalent Circuit: SOT-23 1.BASE 2.EMITTER 3.COLLECTOR FEATURES: ※ Complimentary to 2SD596 ※ High DC Current gain MAXIMUM RATINGS (Ta=25℃ unless otherwise noted) Parameter Symbol Value Unit Collector-Base Voltage VCBO -30 V Collector-Emitter Voltage VCEO -25 V Emitter-Base Voltage VEBO -5 V Collector Current IC -700 mA Collector Power Dissipation PC 200 mW RΘJA 325 ℃/W Junction Temperature Tj 150 ℃ Storage Temperature Tstg -55~+150 ℃ Thermal Resistance From Junction To Ambient www.yongyutai.com PAGE 1 2SB624 ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified) Parameter Symbol Test Condition Min V(BR)CBO IC= -100μA, IE=0 -30 V Collector-emitter breakdown voltage V(BR)CEO IC= -1mA, IB=0 -25 V Emitter-base breakdown voltage V(BR)EBO IE=-100μA, IC=0 -5 V Collector cut-off current ICBO VCB=-30 V , IE=0 -0.1 μA Emitter cut-off current IEBO VEB= -5V , IC=0 -0.1 μA hFE VCE=-1V, IC= -100mA 100 hFE VCE=-1V, IC=- 700mA 50 Collector-base breakdown voltage Typ Max Unit 400 DC current gain Collector-emitter saturation voltage VCE(sat) IC=-700 mA, IB= -70mA -0.6 V Base-emitter saturation voltage VBE(sat) VCE=-6V, IC=- 10mA -0.7 V fT VCE=-6V, IC= -10mA f=100MHz Cob VCE=-6V, IE= 0 f=1MHz Transition frequency Collector Output Capacitance 160 MHz 17 pf ※ Pulse test: Pulse width≤350μs,Duty Cycle≤2% CLASSIFICATION OF hFE MARKING BV1 BV2 BV3 BV4 BV5 Range 110-180 135-220 170-270 200-320 250-400 www.yongyutai.com PAGE 2 2SB624 TYPICAL ELEC TRICAL AND THERMAL CHARACTERISTICS www.yongyutai.com PAGE 3 2SB624 www.yongyutai.com PAGE 4
2SB624 价格&库存
很抱歉,暂时无法提供与“2SB624”相匹配的价格&库存,您可以联系我们找货
2SB624
  • 50+0.10952
  • 500+0.08316
  • 3000+0.07215
  • 6000+0.06340
  • 24000+0.05573
  • 51000+0.05163
库存:1187
2SB624
  • 1+0.08700
  • 100+0.08120
  • 300+0.07540
  • 500+0.06960
  • 2000+0.06670
  • 5000+0.06496
