FRL0603FR220TS
FRL0603FR220TS
    FOJAN(富捷)
    贴片电阻 0603 220mΩ ±1% 1/10W ±300ppm/℃
FRL0603FR220TS 数据手册
FRL-Series Low Resistance Thick Chip Resistor FRL 系列低阻厚膜片晶片电阻 ■ 低阻厚膜晶片电阻(Low Resistance Thick Film Chip Resistor) ■ 应用(Application) - Entertainment:Stereo, TV tuners,Tape recorder - 娱乐:立体声,电视调谐器,录音机 - Appliance: Air conditioner, Refrigerator - 电器:空调、冰箱 - Computer & relative products : Main board, PDA - 电脑及相关产品:主板、掌上电脑 - Communication equipment: Cell phone, Fax machine - 通讯设备:手机、传真机 - Power equipment: Power supply , II Lumination equipment - 电源设备:电源、二级照明设备 - Measuring instrument: Electric meter, Navigation equipment - 测量仪器:电表、导航设备 ■ 特点(Features) - Small size and light weight - 体积小,重量轻 - Reliability, high quality - 可靠性,高质量 - Low Resistance & Suitable for Large Current Application Ultra-low Value - 低阻值, 适合大电流通过 - 超低阻值 ■料号说明(Parts Number Explanation): 示例 Example: FRL1206JR470TSW F R L 公司名 产品别 功能别 FOJAN 1206 型别 F R470 T S W 公差 字码 包装别 端电极 特殊型 R:Resistor C:Normal 0402 B:±0.1% ±5%:E24 T: 7 inch reel S:Sn A:10ppm C:Capacitor P:Hi-Power 0603 C:±0.25% 3-digits+blank Q:10 inch reel C:Cu E:15ppm L:Inductor L:Lowohmic 0805 D:±0.5% 102=1KΩ R:13 inch reel A:Au X:25ppm D:Diode A:Array 1206 F:±1% 1R0=1Ω B:Bulk A:Audion S:Surge 1210 J:±5% ±1%&Below: H:Hi-Precision 2010 P:Jumper E24+E96: V:Hi-Voltage 1812 4-digits Q:Auto-motive 2512 1001=1KΩ R:Anti-sulfur V:50ppm W:100PPm 1R00=1Ω M:Metal D: LED Company code 1 Type code Functional code FJ-JS-3004-V1.0 / 2024.1.24 Size code Tolerance code Resistance code Packaging Termination Special code code code www.fojan.cn FRL-Series Low Resistance Thick Chip Resistor FRL 系列低阻厚膜晶片电阻 ■尺寸 (Dimension) 尺寸 dimension 单位(unit): mm 型别(Type) L W H T1 T2 0402 1.00±0.05 0.50±0.05 0.35±0.05 0.20±0.10 0.25±0.10 0603 1.60±0.10 0.80±0.10 0.45±0.10 0.25±0.15 0.25±0.15 0805 2.00±0.10 1.25±0.10 0.50±0.10 0.35±0.20 0.35±0.20 1206 3.10±0.10 1.60±0.10 0.55±0.10 0.45±0.20 0.40±0.20 1210 3.10±0.10 2.50±0.15 0.55±0.10 0.45±0.15 0.50±0.20 2010 5.00±0.10 2.50±0.15 0.55±0.10 0.45±0.15 0.50±0.20 1812 4.50±0.20 3.10±0.20 0.55±0.10 0.55±0.20 0.70±0.20 2512 6.35±0.10 3.10±0.15 0.55±0.10 0.60±0.20 0.90±0.20 ■ 电阻结构(Construction) FJ-JS-3004-V1.0 / 2024.1.24 NO. 结构 construction 主要材料 Major material 1 陶瓷基板 Ceramic substrate 三氧化二铝 2 银电极 Conductive layer 银 Ag 3 侧电极 Side conductive layer 镍铬合金 NiCr 4 阻体层 Resistive layer 氧化钌+玻璃 RuO2 + glass 5 内保护层 Inner protective layer 玻璃 Glass 6 外保护层 Outer Protective layer 环氧树脂 Epoxy 7 文字 Marking 环氧树脂 Epoxy 8 镍电极 Ni plating layer 镍 Ni 9 锡电极 Sn plating layer 锡 Matte Tin Al2O3 www.fojan.cn FRL-Series Low Resistance Thick Chip Resistor FRL 系列低阻厚膜晶片电阻 ■ 功率衰减曲线( Derating Curve) ■ 阻值范围(Resistance range) 阻值范围 Resistance Range 型别 Type 1% 5% 0402 0R1~1Ω 0R1~1Ω 0603 0R01~1Ω 0R01~1Ω 0805 0R01~1Ω 0R01~1Ω 1206 0R01~1Ω 0R01~1Ω 1210 0R01~1Ω 0R01~1Ω 2010 0R01~1Ω 0R01~1Ω 1812 0R01~1Ω 0R01~1Ω 2512 0R01~1Ω 0R01~1Ω 如有非标准品的需求,请联系我们的业务部门 For non-standard parts, please contact our sales dept. ■电气特性(Electrical characteristics) 型别 Type 额定功率 (Power Rating at 70℃) 绝缘耐压 Dielectric Withstandin g Voltage 额定电流 Rated Current of Jumper 最大电流 Max Current of Jumper 0402 1/16W 100V 0.79A 1.97A 0603 1/10W 100V 2.23A 5.59A 0805 1/8W 300V 2.5A 6.25A 1206 1/4W 500V 3.53A 8.83A 1210 1/2W 500V 5A 12.50A 1812 3/4W 500V 6.12A 15.30A 2010 3/4W 500V 6.12A 15.30A 2512 1W 500V 7.07A 17.67A FJ-JS-3004-V1.0 / 2024.1.24 T.C.R. (PPM/℃) 0.02Ω~0.06(含): 阻值范围 Resistance Range 0R1~1Ω ±1200PPM/℃ 0.06Ω~0.2(含): ±600PPM/℃ 0R01~1Ω 0.2Ω~0.5(含): ±300PPM/℃ >0.5Ω:±200PPM/℃ www.fojan.cn FRL-Series Low Resistance Thick Chip Resistor FRL 系列低阻厚膜晶片电阻 备注(remark): 额定电流计算公式(The rated current is calculated by the following formula): I= P /R I:额定电流(Rated Current) (V) P:额定功率(Rated Power ) (W) R:电阻阻值(Resistance ) (ohm) 如果计算出的电流超过此型别的最大工作电流,则此型别的最大工作电流为此电阻的额定电流。 In case the value calculated by the formula exceed the maximum working current as above table 8, the maximum working current shall be regarded as rated current. ■ 性能(Performance Specifications) 内容 Item 测试方法 Test Methods 测试条件 Test Conditions 规格 Specification TCR=(R-R0 )/(t-t0)R0 ×106 (ppm) R0 电阻在室温下的阻值(resistance at 0.02Ω~0.06(含): ±1200PPM/℃ 0.06Ω~0.2(含): 温度系数 Temperature Coefficient room temperature) JIS C 5201 4.8 R 电阻在 125 或-55℃下的阻值(resistance ±600PPM/℃ 0.2Ω~0.5(含): at 125℃ or -55℃) t0 室温(room temperature) t 测试温度(test temperature 125℃ ±300PPM/℃ >0.5Ω: ±200PPM/℃ or -55℃) 加载 2.5 倍的额定电压,时间 5 秒后测 量试验前后的阻值变化率。 短时间过负荷 Short-time overload JIS C 5201 4.13 Applied 2.5 times of rated voltage for 5 ±(1.00% +0.05Ω) second. Measure the variation of resistance. 沾助焊剂后浸入锡炉,锡炉温度 245±5℃ 焊锡性 Solderability JIS C 5201 4.17 ,时间 3±0.5 秒。 Dip the terminal in a flux and then dip into a >95%面积上锡 (>95% coverage) soldering bath at 245±5℃ ,for 3±0.5sec. FJ-JS-3004-V1.0 / 2024.1.24 www.fojan.cn FRL-Series Low Resistance Thick Chip Resistor FRL 系列低阻厚膜晶片电阻 内容 Item 测试方法 Test Methods 测试条件 Test Conditions 规格 Specification 沾助焊剂后浸入锡炉,锡炉温度 260±5℃ ,时间 10±0.5 秒, 测量试验前后的阻值 抗焊锡热 Resist to soldering heat 变化率。 JIS C 5201 4.18 Dip the terminal in a flux and then dip into a ±(1.00% +0.05Ω) soldering bath at 260±5℃, for 10±0.5sec. Measure the variation of resistance. 电阻本体上加载绝缘耐压 60±5 秒后,测 量绝缘阻抗。 绝缘电阻 Insulation resistance JIS C 5201 4.6 Applied the dielectric withstanding >10GΩ voltage on the center of body for 60±5seconds. Then measure insulation resistance. 电阻本体上加载绝缘耐压 60±5 秒。 绝缘耐压 Dielectric withstanding voltage JIS C 5201 4.7 无击穿、飞弧及可见机械性 损伤 Applied the dielectric withstanding No evidence of flashover, voltage on the center of body mechanical damage arcing for60±5seconds. or insulation breakdown 电阻焊接在测试板上进行弯折,弯折保持 时间 20±1 秒,1206(含) 以下的尺寸弯 曲 5+0.2/0 mm; 1206 以上的尺寸弯曲 2+0.2/0 mm; 量测试验前后阻值变化率 Specimen shall be mounted on test 端子弯曲 Terminal bending JIS C 5201 4.33 board, then bend the board and ±(1.00% +0.05Ω) maintained for 20±1s. the distance of bending is 5+0.2/0 mm for resistors which size no larger than 1206 or 2+0.2/0 mm which size larger than 1206. Measure the variation of resistance. FJ-JS-3004-V1.0 / 2024.1.24 www.fojan.cn FRL-Series Low Resistance Thick Chip Resistor FRL 系列低阻厚膜晶片电阻 内容 Item 测试方法 Test Methods 测试条件 Test Conditions 规格 Specification 电阻放入温度循环机中,T1 温度:-55± 3℃;T2 温度:155±3℃./125±3℃,放 置 30 分钟,共 300 个循环。量测试验前 温度快速变化 Rapid temperature 后阻值变化率. JIS C 5201 4.19 Put specimen in a chamber which ±(1.00% +0.05Ω) temperature can be T1: -55±3℃; changes T2: 155±3℃/125±3℃, 30min, repeated 300 cycles. Measure the variation of resistance. 电阻放入恒温恒湿箱,温度 40±2℃ ,湿度 90~95 %RH;通电额定电压 1.5 小 时,断电 0.5 小时;重复通断电至试验时 间 1000 +48/-0 小时. 量测试验前后阻值 变化率. 耐湿特性 Humidity JIS C 5201 4.24 Put the specimen in a chamber at 40±2℃ ±(2.00% +0.05Ω) temperature and 90~95% relative humidity, then applied rated voltage for1.5H and rested for 0.5H repeatedly till total test time is 1000+48/-0 H. Measure the variation of resistance. 电阻放入恒温箱中,温度 70±2℃,ON TIME:1.5H,OFF TIME:0.5H,通电额定电 压 1000 +24/-0 小时,量测试验前后阻值变化 率. 负荷寿命 Load life JIS C 5201 4.25.1 Put the specimen in a chamber at 70±2℃ ±(2.00% +0.05Ω) temperature, ON TIME:1.5H,OFF TIME:0.5H, and applied rated voltage for 1000 +24/-0H. Measure the variation of resistance. FJ-JS-3004-V1.0 / 2024.1.24 www.fojan.cn FRL-Series Low Resistance Thick Chip Resistor FRL 系列低阻厚膜晶片电阻 25°C~65°C,90~100%RH, 2.5 小时; 65°C 90~100%RH, 3 小时; 65°C~25°C,80~100%RH,2.5 小时,10 个 循环,试验结束 24±4 小时后进行测试. 温湿循环 Moisture resistance MIL-STD-202 METHOD 106 25°C~65°C,90~100%RH, 2.5H; 65°C ±(2.00% +0.05Ω) 90~100%RH, 3H; 65°C~25°C 80~100%RH, 2.5H, 10 cycles, Measurement at 24±4 hours after test conclusion. FJ-JS-3004-V1.0 / 2024.1.24 www.fojan.cn FRL-Series Low Resistance Thick Chip Resistor FRL 系列低阻厚膜晶片电阻 ■ 包装规格(Tapping Specification) -卷盘尺寸(Reel dimension) Type Size Unit A B C F W 0402 7” 10K/Reel mm 178±2.0 60.0±1.0 13.5±0.5 11.4±0.1 9.00±0.3 0402 13” 40K/50K Reel mm 330±2.0 100.0±1.0 13.5±0.5 11.4±0.1 9.00±0.3 0603 0805 1206 1210 7” 5K/Reel mm 178±2.0 60.0±1.0 13.5±0.5 11.4±0.1 9.00±0.3 10” 10K/Reel mm 254±2.0 100.0±1.0 13.5±0.5 11.4±0.1 9.00±0.3 13” 20K/Reel mm 330±2.0 100.0±1.0 13.5±0.5 11.4±0.1 9.00±0.3 7” 4K/Reel mm 178±2.0 60.0±1.0 13.5±0.5 15.4±1.0 13.0±0.3 0603 0805 1206 0603 0805 1206 1812 2010 2512 -包装尺寸(packing dimension) Unit: mm FJ-JS-3004-V1.0 / 2024.1.24 www.fojan.cn FRL-Series Low Resistance Thick Chip Resistor FRL 系列低阻厚膜晶片电阻 Dimensions A B D F P0 P1 P2 W 0402 0.65±0.10 1.15±0.10 1.50± 0.1 0. 0 3.50±0.05 4.00±0.10 2.00±0.10 2.00±0.05 8.00±0.20 0603 1.10±0.10 1.90±0.10 1.50± 0.1 0. 0 3.50±0.05 4.00±0.10 4.00±0.10 2.00±0.05 8.00±0.20 0805 1.65±0.20 2.40±0.20 1.50± 0.1 0. 0 3.50±0.05 4.00±0.10 4.00±0.10 2.00±0.05 8.00±0.20 1206 1.90±0.20 3.50±0.20 1.50± 0.1 0. 0 3.50±0.05 4.00±0.10 4.00±0.10 2.00±0.05 8.00±0.20 1210 2.80±0.20 3.50±0.20 1.50± 0.1 0. 0 3.50±0.05 4.00±0.10 4.00±0.10 2.00±0.05 8.00±0.20 1812 3.30±0.20 4.60±0.20 1.50± 0.1 0. 0 5.50±0.05 4.00±0.10 4.00±0.10 2.00±0.05 12.0±0.10 2010 2.90±0.10 5.30±0.10 1.50± 0.1 0. 0 5.50±0.05 4.00±0.10 4.00±0.10 2.00±0.05 12.0±0.10 2512 3.40±0.10 6.60±0.10 1.50± 0.1 0. 0 5.50±0.05 4.00±0.10 4.00±0.10 2.00±0.05 12.0±0.10 ■ 上胶带剥离力测试(Peel force of top cover tape) 上胶带以 200mm/分钟的速度,沿 165~180 度角的方向进行剥离,如下图所示。纸带的剥离力范围为 10g~70g; 载带的剥离力范围为 30~100g。 The top cover tape is pulled at a speed of 200 mm/min with the angle between the tape during peel and the direction of unreeling maintained at 165 to 180 degree as following picture. The peel force of paper carrier tape shall be 0.1N to 0.7N(10 to 70 g), the peel force of plastic carrier tape shall be 0.3N to 1N (30 to 100 g) FJ-JS-3004-V1.0 / 2024.1.24 www.fojan.cn FRL-Series Low Resistance Thick Chip Resistor FRL 系列低阻厚膜晶片电阻 ■ 焊接 (soldering) - 建议回流焊曲线(Recommend reflow soldering profile) -建议波峰焊曲线(Recommend wave soldering profile) -手工焊温度(hand soldering temperature) 烙鐵温度 350±10℃ 3 秒之內,避免烙铁接触电阻本体 The iron temperature is 350±10℃, hand soldering time less than 3S. Avoid solder iron tip direct touch the components body FJ-JS-3004-V1.0 / 2024.1.24 www.fojan.cn FRL-Series Low Resistance Thick Chip Resistor FRL 系列低阻厚膜晶片电阻 ■ 厚膜电阻器使用说明(Chip Resistor Instructions for use) - 本产品在以下特殊环境下应用,性能可能会收到影响(Application of the products in a special environment can deteriorate product performance): 1. 高温; High temperature 2. 有海风或腐蚀性气体,包括氯气,硫化氢,氨气,二氧化硫,二氧化氮等; Near the sea ,or corrosive gas, such as Cl2,H2S,NH3,SO2,and NO2,etc; 3. 各种类型的液体,包括水,油,化学品,有机溶剂的使用; Unverified liquids, such as water,oil,chenical or organic solvent; 4. 在用树脂或其他涂层材料密封产品的情况下使用; Unverified resin or paint to cover products; 5. 焊接后使用不洁焊剂或使用水或水溶性清洁剂清洗产品 Products should be washed with soluble cheaner even if non cleaning flux. - 储存 / 搬运条件(STORAGE / CARRY CONDITIONS) 6. 储存温度 25±5℃ Temperature:25±5℃ 7. 湿度 30~70%RH Humidity:30~70%RH 8. 储存期限:先进先出,2 年 Storage life:2years FIFO 9. 存放和搬运时,请保持盒子的正确方向。严禁跌落在箱体上,否则可能损坏产品电极或本体 Please hold box correct orientation when storing and carrying.It is strictly prohibited to fall on the box.otherwise the product electrode or body may be damaged. FJ-JS-3004-V1.0 / 2024.1.24 www.fojan.cn
FRL0603FR220TS
物料型号:FRL系列,具体型号示例为FRL1206JR470TS。
器件简介:FRL系列是低阻厚膜晶片电阻,具有体积小、重量轻、可靠性高、高质量、低阻值适合大电流通过等特点。
引脚分配:文档中没有提供具体的引脚分配图,但通常这类电阻为端电极设计。
参数特性: - 尺寸范围:0402、0603、0805、1206、1210、2010、1812、2512等。 - 额定功率:根据尺寸不同,从1/16W至1W不等。 - 绝缘耐压:100V至500V。 - 额定电流和最大电流:根据尺寸不同,额定电流从0.79A至7.07A,最大电流从1.97A至17.67A。 - 温度系数:不同阻值范围的电阻具有不同的温度系数,范围从±1200PPM/C至>0.50 +200PPM/C。
功能详解:FRL系列电阻适用于多种应用场景,包括娱乐设备、家用电器、电脑及周边产品、通讯设备、电源设备、测量仪器等。
应用信息:文档中提到了电阻的应用领域,但没有提供具体的应用电路或配置示例。
封装信息:提供了详细的尺寸信息,包括长度、宽度、高度等,以及不同尺寸的电阻的封装类型。
FRL0603FR220TS 价格&库存
很抱歉,暂时无法提供与“FRL0603FR220TS”相匹配的价格&库存,您可以联系我们找货
FRL0603FR220TS
  • 50+0.01568
  • 500+0.01425
  • 5000+0.01235
  • 30000+0.01188
  • 90000+0.01140
库存:5000
FRL0603FR220TS
  • 1+0.16390
  • 500+0.05467
  • 2500+0.03641
  • 5000+0.02981
FRL0603FR220TS
  • 50+0.01764
  • 150+0.01519
  • 1000+0.01274
  • 5000+0.01176
库存:933
FRL0603FR220TS
  • 100+0.03270
  • 1000+0.02600
  • 5000+0.02130
  • 10000+0.01970
  • 50000+0.01750
库存:8998
