FRL0805JR075TS
FRL0805JR075TS
    FOJAN(富捷)
    贴片电阻 0805 75mΩ ±5% 1/8W ±600ppm/℃
FRL0805JR075TS 数据手册
FRL-Series Low Resistance Thick Chip Resistor FRL 系列低阻厚膜片晶片电阻 ■ 低阻厚膜晶片电阻(Low Resistance Thick Film Chip Resistor) ■ 应用(Application) - Entertainment:Stereo, TV tuners,Tape recorder - 娱乐:立体声,电视调谐器,录音机 - Appliance: Air conditioner, Refrigerator - 电器:空调、冰箱 - Computer & relative products : Main board, PDA - 电脑及相关产品:主板、掌上电脑 - Communication equipment: Cell phone, Fax machine - 通讯设备:手机、传真机 - Power equipment: Power supply , II Lumination equipment - 电源设备:电源、二级照明设备 - Measuring instrument: Electric meter, Navigation equipment - 测量仪器:电表、导航设备 ■ 特点(Features) - Small size and light weight - 体积小,重量轻 - Reliability, high quality - 可靠性,高质量 - Low Resistance & Suitable for Large Current Application - Ultra-low Value - 低阻值, 适合大电流通过 - 超低阻值 ■料号说明(Parts Number Explanation): 示例 Example: FRL1206JR470TS F R L 公司名 产品别 功能别 FOJAN 1206 型别 F R470 T S 公差 字码 包装别 端电极 特殊型 R:Resistor C:Normal 0402 B:±0.1% ±5%:E24 T: 7 inch reel S:Sn N: C:Capacitor P:Hi-Power 0603 C:±0.25% 3-digits+blank Q:10 inch reel C:Cu Normal L:Inductor L:Lowohmic 0805 D:±0.5% 102=1KΩ R:13 inch reel A:Au D:LED D:Diode A:Array 1206 F:±1% 1R0=1Ω B:Bulk A:Audion S:Surge 1210 J:±5% ±1%&Below: H:Hi-Precision 2010 P:Jumper E24+E96: V:Hi-Voltage 1812 4-digits Q:Auto-motive 2512 1001=1KΩ Termination Special code code R:Anti-sulfur 1R00=1Ω M:Metal D: LED Company code 1 Type code Functional code FJ-JS-3004-V1.0 / 2021.1.25 Size code Tolerance code Resistance code Packaging code www.fojan.cn FRL-Series Low Resistance Thick Chip Resistor FRL 系列低阻厚膜晶片电阻 ■尺寸 (Dimension) 尺寸 dimension 单位(unit): mm 型别(Type) L W H T1 T2 0402 1.00±0.05 0.50±0.05 0.35±0.05 0.20±0.10 0.25±0.10 0603 1.60±0.10 0.80±0.10 0.45±0.10 0.25±0.15 0.25±0.15 0805 2.00±0.10 1.25±0.10 0.50±0.10 0.35±0.20 0.35±0.20 1206 3.10±0.10 1.60±0.10 0.55±0.10 0.45±0.20 0.40±0.20 1210 3.10±0.10 2.60±0.15 0.55±0.10 0.45±0.15 0.50±0.20 2010 5.00±0.10 2.50±0.15 0.55±0.10 0.45±0.15 0.50±0.20 1812 4.50±0.20 3.10±0.20 0.55±0.10 0.55±0.20 0.70±0.20 2512 6.35±0.10 3.10±0.15 0.55±0.10 0.60±0.20 0.50±0.20 ■ 电阻结构(Construction) FJ-JS-3004-V1.0 / 2021.1.25 NO. 结构 construction 主要材料 Major material 1 陶瓷基板 Ceramic substrate Al2O3 2 银电极 Conductive layer 银 Ag 3 侧电极 Side conductive layer 镍铬合金 NiCr 4 阻体层 Resistive layer RuO2 + glass 5 内保护层 Inner protective layer 玻璃 Glass 6 外保护层 Outer Protective layer 环氧树脂 Epoxy 7 文字 Marking 环氧树脂 Epoxy 8 镍电极 Ni plating layer 镍 Ni 9 锡电极 Sn plating layer 锡 Matte Tin 三氧化二铝 氧化钌+玻璃 www.fojan.cn FRL-Series Low Resistance Thick Chip Resistor FRL 系列低阻厚膜晶片电阻 ■ 功率衰减曲线( Derating Curve) ■ 阻值范围(Resistance range) 阻值范围 Resistance Range 型别 Type 1% 5% 0402 0R1~1Ω 0R1~1Ω 0603 0R01~1Ω 0R01~1Ω 0805 0R01~1Ω 0R01~1Ω 1206 0R01~1Ω 0R01~1Ω 1210 0R01~1Ω 0R01~1Ω 2010 0R01~1Ω 0R01~1Ω 1812 0R01~1Ω 0R01~1Ω 2512 0R01~1Ω 0R01~1Ω 如有非标准品的需求,请联系我们的业务部门 For non-standard parts, please contact our sales dept. ■电气特性(Electrical characteristics) 型别 Type 额定功率 (Power Rating at 70℃) 绝缘耐压 Dielectric Withstandin g Voltage 额定电流 Rated Current of Jumper 最大电流 Max Current of Jumper T.C.R. (PPM/℃) 阻值范围 Resistance Range 0402 1/16W 100V 0.79A 1.97A 0.02Ω~0.06(含): 0R1~1Ω 0603 1/10W 100V 2.23A 5.59A ±1200PPM/℃ 0805 1/8W 300V 2.5A 6.25A 0.06Ω~0.2(含): 1206 1/4W 500V 3.53A 8.83A ±600PPM/℃ 1210 1/3W 500V 5A 12.50A 0.2Ω~0.5(含): 2010 3/4W 500V 6.12A 15.30A ±300PPM/℃ 2512 1W 500V 7.07A 17.67A >0.5Ω:±200PPM/℃ FJ-JS-3004-V1.0 / 2021.1.25 0R01~1Ω www.fojan.cn FRL-Series Low Resistance Thick Chip Resistor FRL 系列低阻厚膜晶片电阻 ■ 性能(Performance Specifications) 内容 Item 温度系数 Temperature Coefficient 测试方法 Test Methods JIS C 5201 4.8 测试条件 Test Conditions 规格 Specification TCR=(R-R0 )/(t-t0)R0 ×106(ppm) 0.02Ω~0.06(含): R0 电阻在室温下的阻值(resistance at ±1200PPM/℃ room temperature) 0.06Ω~0.2(含): R 电阻在 125℃或-55℃下的阻值 ±600PPM/℃ (resistance at 125℃ or -55℃) 0.2Ω~0.5(含): t0 室温(room temperature) ±300PPM/℃ t 测试温度(test temperature 125℃ or >0.5Ω: -55℃) ±200PPM/℃ 加载 2.5 倍的额定电压,时间 5 秒后测量 试验前后的阻值变化率。 短时间过负荷 Short-time overload JIS C 5201 4.13 Applied 2.5 times of rated voltage for 5 ±(1.00% +0.05Ω) second. Measure the variation of resistance. 沾助焊剂后浸入锡炉, 锡炉温度 245±5℃, 时间 3±0.5 秒。 焊锡性 Solderability JIS C 5201 4.17 Dip the terminal in a flux and then dip >95%面积上锡 (>95% coverage) into a soldering bath at 245±5℃ for 3±0.5sec. 沾助焊剂后浸入锡炉, 锡炉温度 260±5℃, 时间 10±0.5 秒, 测量试验前后的阻值变 抗焊锡热 Resist to soldering heat 化率。 JIS C 5201 4.18 Dip the terminal in a flux and then dip ±(1.00% +0.05Ω) into a soldering bath at 260±5℃ for 10±0.5sec. Measure the variation of resistance. 内容 Item FJ-JS-3004-V1.0 / 2021.1.25 测试方法 Test Methods 测试条件 Test Conditions 规格 Specification www.fojan.cn FRL-Series Low Resistance Thick Chip Resistor FRL 系列低阻厚膜晶片电阻 电阻本体上加载绝缘耐压 60±5 秒后,测 量绝缘阻抗。 绝缘电阻 Insulation resistance JIS C 5201 4.6 Applied the dielectric withstanding >10GΩ voltage on the center of body for 60±5seconds. Then measure insulation resistance. 电阻本体上加载绝缘耐压 60±5 秒。 绝缘耐压 Dielectric withstanding voltage JIS C 5201 4.7 无击穿、飞弧及可见机械性 损伤 Applied the dielectric withstanding No evidence of flashover, voltage on the center of body mechanical damage arcing for60±5seconds. or insulation breakdown 电阻焊接在测试板上进行弯折,弯折保持 时间 20±1 秒,1206(含) 以下的尺寸弯曲 5+0.2/0 mm; 1206 以上的尺寸弯曲 2+0.2/0 mm; 量测试验前后阻值变化率 Specimen shall be mounted on test 端子弯曲 Terminal bending JIS C 5201 4.33 board, then bend the board and ±(1.00% +0.05Ω) maintained for 20±1s. the distance of bending is 5+0.2/0 mm for resistors which size no larger than 1206 or 2+0.2/0 mm which size larger than 1206. Measure the variation of resistance. 电阻放入温度循环机中,温度 155±2℃至 -55±3℃,共 5 个循环。量测试验前后阻 值变化率. 温度循环 Temperature Cycling JIS C 5201 4.19 Put specimen in a chamber which ±(2.00% +0.05Ω) temperature can be changed to 155±2℃ or -55±3℃, repeated 5 times. Measure the variation of resistance. 内容 Item FJ-JS-3004-V1.0 / 2021.1.25 测试方法 Test Methods 测试条件 Test Conditions 规格 Specification www.fojan.cn FRL-Series Low Resistance Thick Chip Resistor FRL 系列低阻厚膜晶片电阻 电阻放入恒温恒湿箱,温度 40±2℃,湿 度 90~95 %RH;通电额定电压 1.5 小时, 断电 0.5 小时;重复通断电至试验时间 1000 +48/ -0 小时. 量测试验前后阻值变化 率. 耐湿特性 Humidity JIS C 5201 4.24 Put the specimen in a chamber at ±(2.00% +0.05Ω) 40±2℃ temperature and 90~95% relative humidity, then applied rated voltage for1.5H and rested for 0.5H repeatedly till total test time is 1000+48/-0 H. Measure the variation of resistance. 电阻放入恒温箱中,温度 70±2℃,ON TIME:1.5H,OFF TIME:0.5H,通电额定 电压 1000 +24/-0 小时,量测试验前后阻值 变化率. 负荷寿命 Load life JIS C 5201 4.25.1 Put the specimen in a chamber at ±(2.00% +0.05Ω) 70±2℃ temperature, ON TIME:1.5H, OFF TIME:0.5H, and applied rated voltage for 1000 +24 /-0H. Measure the variation of resistance. 25°C~65°C,90~100%RH, 2.5 小时; 65°C 90~100%RH, 3 小时; 65°C~25°C,80~100%RH,2.5 小时,10 个 循环,试验结束 24±4 小时后进行测试. 温湿循环 Moisture resistance MIL-STD-202 106 METHOD 25°C~65°C,90~100%RH, 2.5H; 65°C ±(2.00% +0.05Ω) 90~100%RH, 3H; 65°C~25°C 80~100%RH, 2.5H, 10 cycles, Measurement at 24±4 hours after test conclusion. FJ-JS-3004-V1.0 / 2021.1.25 www.fojan.cn FRL-Series : Low Resistance Document No. FJ-JS-3001-V1.0 Thick Chip Resistor Product Revision Date 2021/1/20 Specifications Page No 7 of 9 ■ 包装规格(Tapping Specification) -卷盘尺寸(Reel dimension) Type Size Unit A B C F W 0402 7” 10K/Reel mm 178±2.0 60.0±1.0 13.5±0.5 11.4±0.1 9.00±0.3 0402 13” 40K/50K Reel mm 178±2.0 60.0±1.0 13.5±0.5 11.4±0.1 9.00±0.3 0603 0805 1206 1210 7” 5K/Reel mm 178±2.0 60.0±1.0 13.5±0.5 11.4±0.1 9.00±0.3 10” 10K/Reel mm 178±2.0 60.0±1.0 13.5±0.5 11.4±0.1 9.00±0.3 13” 20K/Reel mm 178±2.0 60.0±1.0 13.5±0.5 11.4±0.1 9.00±0.3 7” 4K/Reel mm 178±2.0 60.0±1.0 13.5±0.5 15.4±1.0 13.0±0.3 0603 0805 1206 0603 0805 1206 2010 2512 -包装尺寸(packing dimension) FJ-JS-3004-V1.0 / 2021.1.25 7 www.fojan.cn FRL-Series : Low Resistance Document No. FJ-JS-3001-V1.0 Thick Chip Resistor Product Revision Date 2021/1/20 Specifications Page No 8 of 9 Unit: mm Dimensions A B D F P0 P1 P2 W 0402 0.65±0.10 1.15±0.10 1.50± 0.1 0.0 3.50±0.05 4.00±0.10 2.00±0.10 2.00±0.05 8.00±0.20 0603 1.10±0.10 1.90±0.10 1.50± 0.1 0.0 3.50±0.05 4.00±0.10 4.00±0.10 2.00±0.05 8.00±0.20 0805 1.65±0.20 2.40±0.20 1.50± 0.1 0.0 3.50±0.05 4.00±0.10 4.00±0.10 2.00±0.05 8.00±0.20 1206 1.90±0.20 3.50±0.20 1.50± 0.1 0.0 3.50±0.05 4.00±0.10 4.00±0.10 2.00±0.05 8.00±0.20 1210 2.80±0.20 3.50±0.20 1.50± 0.1 0.0 3.50±0.05 4.00±0.10 4.00±0.10 2.00±0.05 8.00±0.20 2010 2.90±0.10 5.30±0.10 1.50± 0.1 0.0 5.50±0.05 4.00±0.10 4.00±0.10 2.00±0.05 12.0±0.10 2512 3.40±0.10 6.60±0.10 1.50± 0.1 0.0 5.50±0.05 4.00±0.10 4.00±0.10 2.00±0.05 12.0±0.10 ■ 上胶带剥离力测试(Peel force of top cover tape) 上胶带以 200mm/分钟的速度,沿 165~180 度角的方向进行剥离,如下图所示。纸带的剥离力范围为 10g~70g; 载带的剥离力范围为 30~100g。 The top cover tape is pulled at a speed of 200 mm/min with the angle between the tape during peel and the direction of unreeling maintained at 165 to 180 degree as following picture. The peel force of paper carrier tape shall be 0.1N to 0.7N(10 to 70 g), the peel force of plastic carrier tape shall be 0.3N to 1N (30 to 100 g) FJ-JS-3004-V1.0 / 2021.1.25 8 www.fojan.cn FRL-Series : Low Resistance Document No. FJ-JS-3001-V1.0 Thick Chip Resistor Product Revision Date 2021/1/20 Specifications Page No 9 of 9 ■ 焊接 (soldering) - 建议回流焊曲线(Recommend reflow soldering profile) -建议波峰焊曲线(Recommend wave soldering profile) -手工焊温度(hand soldering temperature) 烙鐵温度 350±10℃ 3 秒之內,避免烙铁接触电阻本体 The iron temperature is 350±10℃, hand soldering time less than 3S. Avoid solder iron tip direct touch the components body FJ-JS-3004-V1.0 / 2021.1.25 9 www.fojan.cn
FRL0805JR075TS
物料型号:FRL系列,具体型号示例为FRL1206JR470TS。
器件简介:FRL系列是低阻厚膜晶片电阻,具有体积小、重量轻、可靠性高、高质量、低阻值适合大电流通过等特点。
引脚分配:文档中没有提供具体的引脚分配图,但通常这类电阻为端电极设计。
参数特性: - 尺寸范围:0402、0603、0805、1206、1210、2010、1812、2512等。 - 额定功率:根据尺寸不同,从1/16W至1W不等。 - 绝缘耐压:100V至500V。 - 额定电流和最大电流:根据尺寸不同,额定电流从0.79A至7.07A,最大电流从1.97A至17.67A。 - 温度系数:不同阻值范围的电阻具有不同的温度系数,范围从±1200PPM/C至>0.50 +200PPM/C。
功能详解:FRL系列电阻适用于多种应用场景,包括娱乐设备、家用电器、电脑及周边产品、通讯设备、电源设备、测量仪器等。
应用信息:文档中提到了电阻的应用领域,但没有提供具体的应用电路或配置示例。
封装信息:提供了详细的尺寸信息,包括长度、宽度、高度等,以及不同尺寸的电阻的封装类型。
FRL0805JR075TS 价格&库存
很抱歉,暂时无法提供与“FRL0805JR075TS”相匹配的价格&库存,您可以联系我们找货
FRL0805JR075TS
    • 50+0.05238
    • 500+0.04223
    • 1500+0.03662
    • 5000+0.03186
    • 25000+0.02895
    • 50000+0.02733
    库存:98343
    FRL0805JR075TS
    • 100+0.03717
    • 500+0.03507
    • 1000+0.03192
    • 5000+0.02772
    • 10000+0.02520
    库存:5000
