ESD9N5B
ESD9N5B
1-Line, Bi-directional, Normal-Capacitance,
http//:www.omnivision-group.com
Transient Voltage Suppressor
Descriptions
The ESD9N5B is a Bi-directional transient voltage
suppressor (TVS) to protect sensitive electronic
components from electrostatic discharge (ESD). It is
DFN1006-2L (Bottom View)
particularly well-suited for cellular phones, PMP, MID,
PDA, digital cameras and other electronic equipment.
The ESD9N5B may be used to provide ESD protection
up to ±30kV (contact and air discharge) according to
Pin1
Pin2
IEC61000-4-2, and withstand peak pulse current up to
8A (8/20μs) according to IEC61000-4-5.
The ESD9N5B is available in DFN1006-2L package.
Pin configuration
Standard products are Pb-free and Halogen-free.
Features
Reverse stand-off voltage: ±5V Max
Transient protection for each line according to
*B
IEC61000-4-2 (ESD): ±30kV (Contact and Air)
IEC61000-4-4 (EFT): 40A (5/50ns)
* = Month (A~Z)
IEC61000-4-5 (surge): 8A (8/20μs)
Capacitance: CJ = 17.5pF typ.
Low leakage current: IR < 1nA typ.
Low clamping voltage
Solid-state silicon technology
B = Device code
Marking
Order information
Applications
Cell phone
PMP
MID
PDA
Digital camera
Other electronics equipment
Will Semiconductor Ltd.
1
Device
Package
Shipping
ESD9N5B-2/TR
DFN1006-2L
10000/Tape&Reel
Revision 3.6, 2022/04/22
ESD9N5B
Absolute maximum ratings
Parameter
Symbol
Rating
Unit
Peak pulse power (tp=8/20μs)
Ppk
96
W
Peak pulse current (tp=8/20μs)
Ipp
8
A
ESD according to IEC61000-4-2 air discharge
±30
VESD
ESD according to IEC61000-4-2 contact discharge
kV
±30
TJ
125
oC
Operating temperature
TOP
-40~85
oC
Lead temperature
TL
260
oC
TSTG
-55~150
oC
Junction temperature
Storage temperature
Electrical characteristics (TA=25 oC, unless otherwise noted)
I
VRWM Reverse stand-off voltage
IR
Reverse leakage current
VCL
Clamping voltage
IPP
Peak pulse current
IPP
IHOLD
VCL
VTRIG VHOLD
VBR VRWM
IBR
ITRIG
IR
IR
ITRIG
IBR
VRWM VBR
VHOLD VTRIG
VCL
V
IHOLD
VTRIG Reverse trigger voltage
ITRIG
Reverse trigger current
VBR
Reverse breakdown voltage
IBR
Reverse breakdown current
VHOLD Reverse holding voltage
IPP
IHOLD Reverse holding current
Definitions of electrical characteristics
2
ESD9N5B
Electronics characteristics (Ta=25 oC, unless otherwise noted)
Parameter
Symbol
VRWM
IR
Min.
Typ.
VRWM = 5.0V
VBR
Condition
VHOLD
Max.
Unit
±5.0
V
1
μA
IBR = 1mA
5.6
8.5
V
IHOLD = 50mA
5.6
8.5
V
Clamping voltage 1)
VCL
IPP = 16A, tp = 100ns
11
V
Clamping voltage 2)
VCL
VESD = 8kV
11
V
Clamping voltage 3)
VCL
Junction capacitance
IPP = 1A, tp = 8/20μs
9
V
IPP = 8A, tp = 8/20μs
12
V
VR = 0V, f = 1MHz
17.5
22
pF
VR = 5.0V, f = 1MHz
11.5
15
pF
CJ
Notes:
1) TLP parameter: Z0 = 50Ω, tp = 100ns, tr = 2ns, averaging window from 60ns to 80ns. RDYN is calculated from 4A to
16A.
Contact discharge mode, according to IEC61000-4-2.
3)
Non-repetitive current pulse, according to IEC61000-4-5.
100
90
Front time: T1= 1.25 T = 8μs
100
90
Time to half-value: T2= 20μs
Current (%)
Peak pulse current (%)
2)
50
T2
10
T
5
T1
10
15
Time (μs)
tr = 0.7~1ns
8/20μs waveform per IEC61000-4-5
60ns
30ns
30
t
Time (ns)
Contact discharge current waveform per IEC61000-4-2
3
ESD9N5B
Typical characteristics (Ta=25oC, unless otherwise noted)
CJ - Junction capacitance (pF)
VC - Clamping voltage (V)
11
Pulse waveform: tp = 8/20s
10
Pin2 to Pin1
9
Pin1 to Pin2
8
f = 1MHz
VAC = 50mV
18
16
14
12
7
2
3
4
5
6
7
8
10
-5
9
IPP - Peak pulse current (A)
-4
-3
-2
-1
2
3
4
5
VR - Reverse voltage (V)
Clamping voltage vs. Peak pulse current
Capacitance vs. Reverse voltage
10V/div
10V/div
20ns/div
20ns/div
ESD clamping
ESD clamping
TLP current (A)
(+8kV contact discharge per IEC61000-4-2)
24
12
8
4
-8
-12
-16
-20
-24
-14 -12 -10 -8 -6 -4 -2 0
(-8kV contact discharge per IEC61000-4-2)
Z0 = 50
tr = 2ns
tp = 100ns
2
4
6
8 10 12 14
TLP voltage (V)
TLP Measurement
4
ESD9N5B
PACKAGE OUTLINE DIMENSIONS
DFN1006-2L
I
b
1.
II
2.
3.
L
E
I
II
1.
III
e
2.
D
III
1.
BOTTOM VIEW
TOP VIEW
2.
0.55
SIDE VIEW
Symbol
A3
A1
A
0.6
0.3
0.85
1.4
RECOMMENDED LAND PATTERN(Unit:mm)
Dimensions in Millimeters
Min.
Typ.
Max.
A
0.36
0.45
0.50
A1
0.00
0.02
0.05
A3
0.125 Ref.
D
0.95
1.00
1.05
E
0.55
0.60
0.65
b
0.20
0.25
0.30
L
0.45
0.50
0.55
e
0.65 BSC
5
ESD9N5B
TAPE AND REEL INFORMATION
Reel Dimensions
RD
Reel Dimensions
W
Tape Dimensions
P1
Quadrant Assignments For PIN1 Orientation In Tape
Q1
Q2
Q1
Q2
Q3
Q4
Q3
Q4
RD
Reel Dimension
W
Overall width of the carrier tape
P1
Pitch between successive cavity centers
Pin1
Pin1 Quadrant
User Direction of Feed
6
7inch
13inch
1 8mm
12mm
16mm
2mm
4mm
8mm
Q1
Q2
Q3
Q4
很抱歉,暂时无法提供与“ESD9N5B-2/TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.14656
- 500+0.11913
- 1500+0.10379
- 国内价格
- 1+0.35750
- 500+0.11880
- 5000+0.07953
- 10000+0.06523
