KIA
11A, 350V
N-CHANNEL MOSFET
6035A
SEMICONDUCTORS
1.Description
This Power MOSFET is produced using KIA`s advanced planar stripe DMOS technology. This
advanced technology has been especially tailored to minimize on-state resistance, provide superior
switching performance, and withstand high energy pulse in the avalanche and commutation mode. These
devices are well suited for high efficiency switched mode power supplies, active power factor correction
based on half bridge topology.
2. Features
n
RDS(ON)=0.38Ω@VGS=10V.
n
Low gate charge (typical 15nC)
n
High ruggedness
n
Fast switching capability
n
Avalanche energy specified
n
Improved dv/dt capability
3. Pin configuration
1 of 5
Pin
Function
1
Gate
2
Drain
3
Source
4
Drain
Rev 1.0 JAN 2015
11A, 350V
N-CHANNEL MOSFET
KIA
6035A
SEMICONDUCTORS
4. Absolute maximum ratings
Parameter
Symbol
Drain-source voltage
Gate-source voltage
Drain current continuous
VDSS
VGSS
TC=25ºC
TC=100ºC
ID
Drain current pulsed (note1)
Avalanche Enlsed
IDM
EAR
EAS
IAR
dv/dt
Repetitive (note1)
Single pulse (note2)
Avalanche current (note 1)
Peak diode recovery dv/dt (note3)
TC=25ºC
Total power dissipation
PD
Derate above 25ºC
Operating and storage temperature range
TJ, TSTG
Maximum lead temperature for soldering
TL
Purposes,1/8`` form case for 5 seconds
*Drain current limited by maximum junction temperature.
(TC= 25ºC, unless otherwise noted)
Rating
Units
TO-220
TO-252
350
V
±20
V
11
11*
A
6.6
6.6*
A
36
A
9.91
mJ
423
mJ
9.0
A
4.5
V/ns
99
W
0.79
W/ ºC
-55~+150
ºC
ºC
300
5. Thermal characteristics
Parameter
Symbol
Rating
Unit
Thermal resistance,Junction-amient
RthJA
62.5
ºC/W
Thermal resistance,case-to-sink typ.
RthJS
0.5
ºC/W
Thermal resistance,Junction-case
RthJC
1.26
ºC/W
2 of 5
Rev 1.0 JAN 2015
KIA
11A, 350V
N-CHANNEL MOSFET
6035A
SEMICONDUCTORS
6. Electrical characteristics
Parameter
Off characteristics
Drain-source breakdown voltage
Zero gate voltage drain current
Gate-body leakage Forward
current
Reverse
Breakdown voltage temperature
coefficient
On characteristics
Gate threshold voltage
Static drain-source on- resistance
Forward transconductance
Dynamic characteristics
Input capacitance
Output capacitance
Reverse transfer capacitance
Switching characteristics
Turn-on delay time
Rise time
Turn-off delay time
Fall time
Total gate charge
Gate-source charge
Gate-drain charge
Drain-source diode characteristics
drain-source diode forward voltage
Continuous drain-source current
Pulsed drain-source current
Reverse recovery time
Reverse recovery charge
(TC= 25 ºC, unless otherwise noted)
Test conditions
Min
Typ Max Unit
Symbol
BVDSS
VGS=0V,ID=250μA
VDS=350V, VGS=0V
VDS=280V, TC=125ºC
VGS=20V, VDS=0V
VGS=-20V,VDS=0V
350
1
10
10
-10
V
μA
μA
uA
uA
△BVDSS/△TJ
ID=250μA
0.35
V/ ºC
VGS(TH)
RDS(ON)
gFS
VDS= VGS ID=250μA
VDS=10V,ID=4.5A
VDS=40V,ID=4.5A(note4)
2.0
0.38
7.8
4.0
0.48
V
Ω
S
CISS
COSS
CRSS
VDS=25V,VGS=0V,
f=1MHz
844
162
4
pF
pF
pF
25
23.5
77
47.5
15
4
5
ns
ns
ns
ns
nC
nC
nC
1.4
11
36
V
A
A
ns
μC
IDSS
IGSS
tD(ON)
tR
tD(OFF)
tF
QG
QGS
QGD
VSD
IS
ISM*
tRR
QRR
VDD=175V,ID=9.0A,
RG=25Ω (note4,5)
VDS=280V,ID=9.0A
VGS=10V (note4,5)
VGS=0V,ISD=11A
IS=9.0A
dISD/dt=100A/μs (note4)
317
2.5
Notes:1.repetitive rating:pulse width limited by maximum junction temperature
2.L=6.3mH,IAS=9.0A,VDD=50V,RG=25Ω,starting TJ=25ºC
3.ISD
很抱歉,暂时无法提供与“KIA6035AD”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.26000
- 30+1.21500
- 100+1.17000
- 500+1.08000
- 1000+1.03500
- 2000+1.00800
