BB41-80KT-1B-LHR
BB41-80KT-1B-LHR
    STWXE(深台帏翔)
    SMD,P=0.8mm
    板对板连接器 立贴 针脚数:80Pin 间距:0.8mm 排数:2
BB41-80KT-1B-LHR 数据手册
REV. 1 2 ECN Number Description CS21060033 初版发行 增加导柱尺寸 E21120011 100PIN:BB41-AOKT-1B-XHR 备注: 1.塑胶材料:LCP-KD246BI,黑色,防火等级:UL 94V-0 2.端子材料:铜合金 3.额定电压:50V AC/DC for 1 minute 4.接触阻抗:50mΩmax. initial(不包括导体阻抗) 5.耐电压:500V AC for 1 minute 6.绝缘阻抗:100MΩ min. 7.额定电流:0.5A 8.寿命:30次 min 9.插入力:150gf max./pin,拔出力:8.5gf min./pin 10.保持力:250gf 最小/pin 11.有害物质需符合Rohs2.0标准。 12.尺寸符合ANSI Y14.5M-1994。 料号说明: BB41-XXKT-1B-XHR 39.20 3D VIWE (With out cover) 3.30 5.40 10.50 9.90 0.10 ALL THE PIN (0.75) (With cover) 5.55 (8.50) (0.75) PCB 0.80 0.50 2.00 公头 0.95 39.20 PCB (0.68) (4.20) (0.68) (公母合高) SCALE 1:1 UNIT mm TOLERANCE UNLESS OTHERWISE SPECIFIED ShenZhen ShenTai weixiang Electronics Co., Ltd X.X ±0.35 X.XX ±0.20 X.XXX X. ±5° X.X ±3° X.XX ±2° SIZE A4 2.00 母座 2.30 (7.05) 2- 0 (3.20) 2- 6 0. (1.55) 43.08 Pin数 3.00 39.20 11.75±0.50 0.80 K:公母合高11.25mm-12.25mm 2.30 42.20 3D VIWE (With cover) 0.8 0 44.30 Drawn 2021/05/18 2021/12/11 ORIGINAL DRAWN: Qin Su CHECK: Wolfe Liu APPROVE: Wolfe Liu X方向浮动量:±0.5 Y方向浮动量:±0.5 Z方向浮动量:±0.5 RECOMMENDED PCB LAYOUT TOLERANCE:±0.05mm DATE DWG.NO. 2021/12/11 600-0000-0565 DATE 2021/12/11 PARTS NO.(INTENDED USE) DATE BB41-XXKT-1B-XHR 2021/12/11 TITLE 0.80mm Pitch 浮动BTB 客户图 REV. 2 SHEET 1/2 60PIN: BB41-6OKT-1B-XHR 15.20 23.20 31.20 20.30 28.30 36.30 18.20 26.20 34.20 0.80 0.80 23.20 0.80 0.50 0. X.XX ±0.20 X.XXX SCALE 1:1 X. ±5° UNIT mm X.X ±3° X.XX ±2° SIZE A4 ORIGINAL DRAWN: Qin Su CHECK: Wolfe Liu APPROVE: Wolfe Liu 31.20 2.00 2.30 2.00 RECOMMENDED PCB LAYOUT TOLERANCE:±0.05mm TOLERANCE UNLESS OTHERWISE SPECIFIED ShenZhen ShenTai weixiang Electronics Co., Ltd 0.50 3.00 RECOMMENDED PCB LAYOUT TOLERANCE:±0.05mm ±0.35 0.80 0. 0.95 23.20 2.30 2.00 2.30 0.95 X.X 2.00 23.00 3.00 0.95 15.20 60 2- 2- 80 0. 2.00 2- 0.50 35.08 60 2- 2.30 2- 0.80 27.08 0 6 0. 0. 80 19.08 31.20 2.30 15.20 2.30 0.80 2.00 80PIN: BB41-8OKT-1B-XHR 0. 80 40PIN: BB41-4OKT-1B-XHR RECOMMENDED PCB LAYOUT TOLERANCE:±0.05mm DATE DWG.NO. 2021/12/11 600-0000-0565 DATE 2021/12/11 PARTS NO.(INTENDED USE) DATE BB41-XXKT-1B-XHR 2021/12/11 TITLE 0.80mm Pitch 浮动BTB 客户图 REV. 2 SHEET 2/2
BB41-80KT-1B-LHR 价格&库存
很抱歉,暂时无法提供与“BB41-80KT-1B-LHR”相匹配的价格&库存,您可以联系我们找货
BB41-80KT-1B-LHR
    • 1+14.12640
    • 10+11.91240
    • 30+10.51920
    • 100+8.66160
    • 450+8.01360
    • 900+7.74360
