BB41-80GT-1B-LHR
BB41-80GT-1B-LHR
    STWXE(深台帏翔)
    SMD,P=0.8mm
    板对板连接器 立贴 针脚数:80Pin 间距:0.8mm 排数:2
BB41-80GT-1B-LHR 数据手册
REV. 1 ECN Number Description Drawn CS20120080 初版发行 2020/12/09 100PIN:BB41-AOGT-1B-XHR 备注: 1.塑胶材料:LCP-GA130,黑色,防火等级:UL 94v-0 2.端子材料:铜合金 3.额定电压:50V AC/DC for 1 minute 4.接触阻抗:50mΩmax. initial(不包括导体阻抗) 5.耐电压:500V AC for 1 minute 6.绝缘阻抗:100MΩ min. 7.额定电流:0.5A 8.寿命:30次 min 9.插入力:150gf max./pin,拔出力:8.5gf min./pin 10.保持力:250gf 最小/pin 11.有害物质需符合Rohs2.0标准。 12.尺寸符合ANSI Y14.5M-1994。 料号说明: BB41-XXGT-1B-XHR 39.20 3D VIWE (With out cover) 3.30 5.40 11.50 10.90 (With cover) 5.55 (8.50) (0.75) PCB (1.55) (3.20) (7.05) 43.08 母座 (4.20) (0.68) (公母合高) SCALE 1:1 ShenZhen ShenTai weixiang Electronics Co., Ltd X.X ±0.35 X.XX ±0.20 X.XXX X. ±5° UNIT mm X.X ±3° X.XX ±2° SIZE A4 ORIGINAL DRAWN: Qinghua Fu CHECK: Guangyu Guo APPROVE: Ady Zhou 0.50 2.00 0.95 公头 (0.68) TOLERANCE UNLESS OTHERWISE SPECIFIED 0.80 2.30 (0.75) Pin数 3.00 0.10 ALL THE PIN 39.20 12.75±0.50 0.80 G:公母合高12.25mm-13.25mm 39.20 2.00 42.20 3D VIWE (With cover) 2.30 44.30 PCB X方向浮动量:±0.5 Y方向浮动量:±0.5 Z方向浮动量:±0.5 RECOMMENDED PCB LAYOUT TOLERANCE:±0.05mm DATE DWG.NO. 2020/12/09 600-0000-0450 DATE 2020/12/09 PARTS NO.(INTENDED USE) DATE BB41-XXGT-1B-XHR 2020/12/09 TITLE 0.80mm Pitch 浮动BTB (配高12.75mm)客户图 REV. 1 SHEET 1/2 60PIN: BB41-6OGT-1B-XHR 15.20 23.20 31.20 20.30 28.30 36.30 18.20 26.20 34.20 0.80 0.80 0.80 31.20 19.08 27.08 35.08 2.00 0.80 0.50 RECOMMENDED PCB LAYOUT TOLERANCE:±0.05mm ShenZhen ShenTai weixiang Electronics Co., Ltd ±0.35 X.XX ±0.20 X.XXX X. ±5° X.X ±3° X.XX ±2° SCALE 1:1 UNIT mm SIZE 0.50 A4 ORIGINAL DRAWN: Smark CHECK: Guangyu Guo APPROVE: Ady Zhou 31.20 2.00 2.30 2.00 RECOMMENDED PCB LAYOUT TOLERANCE:±0.05mm TOLERANCE UNLESS OTHERWISE SPECIFIED X.X 0.80 0.95 23.20 2.30 2.00 0.95 2.30 0.95 15.20 2.00 3.00 0.50 3.00 0.80 2.30 23.20 2.30 15.20 3.00 2.00 80PIN: BB41-8OGT-1B-XHR 2.30 40PIN: BB41-4OGT-1B-XHR RECOMMENDED PCB LAYOUT TOLERANCE:±0.05mm DATE DWG.NO. 2020/12/09 600-0000-0450 DATE 2020/12/09 PARTS NO.(INTENDED USE) DATE BB41-XXGT-1B-XHR 2020/12/09 TITLE 0.80mm Pitch 浮动BTB 客户图 REV. 1 SHEET 2/2
BB41-80GT-1B-LHR 价格&库存
很抱歉,暂时无法提供与“BB41-80GT-1B-LHR”相匹配的价格&库存,您可以联系我们找货
BB41-80GT-1B-LHR
    • 1+17.51760
    • 10+14.82840
    • 30+13.14360
    • 100+10.88640
    • 430+10.10880
    • 860+9.77400
