BB41-80FT-1B-LHR
BB41-80FT-1B-LHR
    STWXE(深台帏翔)
    SMD,P=0.8mm
    板对板连接器 立贴 针脚数:80Pin 间距:0.8mm 排数:2
BB41-80FT-1B-LHR 数据手册
REV. 1 ECN Number Description CS21100033 初版发行 100PIN: BB41-AOFT-1B-XHR 备注: 1.塑胶材料:LCP-GA130,黑色,防火等级:UL 94v-0 2.端子材料:铜合金 3.额定电压:50V AC/DC for 1 minute 4.接触阻抗:50mΩmax. initial(不包括导体阻抗) 5.耐电压:500V AC for 1 minute 6.绝缘阻抗:100MΩ min. 7.额定电流:0.5A 8.寿命:30次 min 9.插入力:150gf max./pin,拔出力:8.5gf min./pin 10.保持力:250gf 最小/pin 11.有害物质需符合Rohs2.0标准。 12.尺寸符合ANSI Y14.5M-1994。 料号说明: BB41-XXFT-1B-XHR 39.20 3D VIWE (With out cover) 3.30 5.40 43.00 (0.75) (With cover) 5.40 8.00 (8.50) (0.75) 43.08 公头 (4.50) SCALE 1:1 UNIT mm TOLERANCE UNLESS OTHERWISE SPECIFIED ShenZhen ShenTai weixiang Electronics Co., Ltd X.XX ±0.20 X.XXX X. ±5° X.X ±3° X.XX ±2° SIZE A4 PCB (1.75) ORIGINAL DRAWN: Qin Su CHECK: Guangyu Guo APPROVE: Ady Zhou 0.80 0.50 3.00 5.40 13.20±0.50 (7.05) (1.55) (3.20) 母座 (公母合高) ±0.35 39.20 PCB (1.75) X.X 12.00 11.35 11.40 0.10 ALL THE PIN 0.80 F:塑胶高度11.35mm 公母合高12.70mm-13.70mm Pin数 2.00 1.00 X方向浮动量:±0.5 Y方向浮动量:±0.5 Z方向浮动量:±0.5 9.20 42.20 3D VIWE (With cover) 3.05 3.10 3.05 44.30 Drawn 2021/10/13 0.75 0.50 43.00 RECOMMENDED PCB LAYOUT TOLERANCE:±0.05mm DATE DWG.NO. 2021/10/13 DATE 2021/10/13 PARTS NO.(INTENDED USE) DATE BB41-XXFT-1B-XHR 2021/10/13 TITLE 0.80mm Pitch 浮动BTB 客户图 REV. 1 SHEET 1/2 60PIN: BB41-6OFT-1B-XHR 15.20 20.30 23.20 28.30 31.20 36.30 18.20 26.20 34.20 0.80 0.80 19.00 35.08 23.20 31.20 19.00 0.50 27.00 RECOMMENDED PCB LAYOUT TOLERANCE:±0.05mm X.XX ±0.20 X.XXX 5.40 3.00 2.00 1.00 RECOMMENDED PCB LAYOUT TOLERANCE:±0.05mm SCALE 1:1 UNIT mm TOLERANCE UNLESS OTHERWISE SPECIFIED ±0.35 0.75 9.20 3.05 3.10 3.05 2.00 1.00 0.75 X.X 0.80 0.50 5.40 3.00 9.20 5.40 3.00 3.05 3.10 3.05 0.80 0.50 0.50 35.00 X. ±5° X.X ±3° X.XX ±2° SIZE A4 ORIGINAL DRAWN: Qin Su CHECK: Guangyu Guo APPROVE: Ady Zhou 3.05 3.10 3.05 15.20 0.80 0.50 ShenZhen ShenTai weixiang Electronics Co., Ltd 0.80 27.00 27.08 19.08 2.00 1.00 80PIN: BB41-8OFT-1B-XHR 9.20 40PIN: BB41-4OFT-1B-XHR 0.75 0.50 35.00 RECOMMENDED PCB LAYOUT TOLERANCE:±0.05mm DATE DWG.NO. 2021/10/13 DATE 2021/10/13 PARTS NO.(INTENDED USE) DATE BB41-XXFT-1B-XHR 2021/10/13 TITLE 0.80mm Pitch 浮动BTB 客户图 REV. 1 SHEET 2/2
