BB41-80CT-1B-LHR
BB41-80CT-1B-LHR
    STWXE(深台帏翔)
    SMD,P=0.8mm
    板对板连接器 立贴 针脚数:80Pin 间距:0.8mm 排数:2
BB41-80CT-1B-LHR 数据手册
1 2 3 4 5 7 6 REV. ECN Number 1 CS18100015 2 E19080009 8 Description Drawn LGJ_2018.10.10 First issue LGJ_2019.08.22 Improve labeling method A 2 NOTES: A 8.00 1. Housing material:high temperature plastics black,UL94V-0. 2. Contact material:copper alloy. 3. Rated voltage : 50V AC/DC 4. . 5. Dielectric Withstanding Voltage : 500V AC for 1 minutes. 6. InsulationResistance : 100 min,Initial . 7. Current Rating : 0.5 A. 8. Durability : 30 cycles . 9. Ambient Temperature Range 10.Storage Temperature Range B 11.All material must be comply with "ROHS 2.0". 12.Product nunber matrix: 0.30(80X) 2 0.80(78X) 2 B 31.20 36.30 BB41-80CT-1B-XXX packing:TAPE&REEL H:Halogen free F:high temperature thermoplastic Pitch:0.80mm Male PIN NO:80 pin 6.00 34.20 SMT TYPE 3.90 C Plating code: Definition C Code Duplex plated flash K 14.70 0.05 14.10 0.10 L N 15u" P Q T 30u" U 25u" S D 0.80(78X) 2 0.50(76X) 2 9.20 5.40 35.00 3.05 E 2.00(2X) SECTION A-A 1u" 31.20 2 view with cap 8.00 3u" M 10u" 3.05 5.40 0.60(2X) 20u" 3.00(2X) D 5u" 2 2.00(2X) 2 1.00(2X) 2 0.25(4X) E 2 0.75(4X) 35.00 RECOMMENDED PCB LAYOUT TOLERANCE UNLESS OTHERWISE SPECIFIED F ShenZhen ShenTai weixiang Electronics Co., Ltd. 1 SCALE UNIT X.X X.XX X.XXX ORIGINAL DRAWN: LGJ CHECK: Yang hong APPROVE: Ady Zhou 1:1 mm SIZE A4 2 3 4 DATE 2019.08.22 DATE 2019.08.22 DATE 2019.08.22 5 DWG.NO. REV. TITLE 600-0000-0393 2 BB41-80CT-1B-XXX CUSTOMER DRAWING PARTS NO.(INTENDED USE) SHEET 1/1 BB41-80CT-1B-LHR 6 7 8 F
BB41-80CT-1B-LHR 价格&库存
很抱歉,暂时无法提供与“BB41-80CT-1B-LHR”相匹配的价格&库存,您可以联系我们找货
BB41-80CT-1B-LHR
  • 1+13.12200
  • 10+12.05280
  • 30+11.39400
  • 100+10.20600
  • 500+9.89280
  • 1000+9.76320
库存:225
