NXH25VB470M8*15_3.5TP
    SAMYOUNG(韩国三莹)
    插件,D8xL15mm
    直插铝电解电容 插件,D8xL15mm 470µF ±20% Ф8.00 x 15.00mm 25V 45mΩ 1.33A 8000Hrs@105℃
NXH25VB470M8*15_3.5TP 数据手册
MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS NXH Series 105℃ 6,000~10,000Hrs assured. Non-solvent proof. Low Impedance. Long Life. For LED TV BLU Inverter, SMPS, IP-Board, Adaptor. NXB NXH Long Life RoHS compliant. Halogen-free capacitors are also available. SPECIFICATIONS Item Characteristics Rated Voltage Range Operating Temperature Range Capacitance Tolerance 6 . 3 ~ 1 0 0 V DC -40 ~ +105℃ ±20%(M) Leakage Current Dissipation Factor(Tan δ) (at 20℃, 120Hz) I=0.01CV(μA) or 3μA, whichever is greater. Where, I:Max. Leakage current(μA), C:Nominal capacitance(μF), V:Rated voltage(VDC) (at 20℃, 2 minutes) Rated voltage(VDC) 6.3 10 16 25 35 50 63 Tan δ(Max.) 0.22 0.19 0.16 0.14 0.12 0.10 0.09 When the capacitance exceeds 1,000μ F, 0.02 shall be added every 1,000μ F increase. Temperature Characteristics (Max. Impedance ratio) Load Life Z(-25℃)/Z(+20℃) 2 Z(-40℃)/Z(+20℃) 3 80 100 0.08 0.08 (at 20℃, 120Hz) (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage with the rated ripple current is applied (the peak voltage shall not exceed the rated voltage) at 105℃ for the specified period of time. Rated voltage(VDC) 6.3~10 16~100 ØD Life Time Capacitance change ±30% of the initial value ±25% of the initial value Ø5~Ø6.3 6,000 hours Tan δ 200% of the initial specified value Ø8 8,000 hours Leakage current The initial specified value Ø10~ 10,000 hours The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without voltage applied. The rated voltage shall be applied to the capacitors for a minimum of 30 minutes, at least 24 hours and not more than 48 hours before the measurements. Shelf Life Others Rated voltage(VDC) Capacitance change Tan δ Leakage current 6.3~10 16~100 ±30% of the initial value ±25% of the initial value 200% of the initial specified value The initial specified value Satisfied characteristics KS C IEC 60384-4 Unit(mm) 127 Series Marking : YELLOW SLEEVE, BLACK INK ØD 18 10 12.5 16 8 6.3 5 Ød 0.5 0.5 0.6 0.6 0.6 0.8 0.8 F 2.0 2.5 3.5 5.0 5.0 7.5 7.5 ØD′ ØD+0.5 max. L′ L+1.5 max. L+2.0 max. ※Ø10 x 12L, L′ L+1.5 NXH DIMENSIONS OF NXH Series MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS RATINGS OF NXH Series V DC ㎌ ØD×L(mm) 5×11 5×15 6.3×11 6.3×15 8×11.5 8×15 8×20 10×12 10×12.5 10×16 10×20 10×25 10×33 12.5×20 12.5×25 12.5×30 12.5×35 16×20 16×25 18×25 220 470 470 560 820 1,200 1,500 1,200 1,200 1,800 2,200 2,700 3,300 3,900 4,700 5,600 6,800 6,800 8,200 10,000 ㎌ 10 16 IMP. IMP. Ripple 20℃ -10℃ 0.22 0.13 0.094 0.084 0.056 0.045 0.029 0.039 0.039 0.028 0.020 0.018 0.015 0.017 0.015 0.013 0.012 0.015 0.013 0.012 0.80 0.47 0.35 0.31 0.19 0.15 0.11 0.14 0.14 0.10 0.060 0.054 0.045 0.043 0.038 0.033 0.031 0.038 0.035 0.031 V DC ØD×L(mm) 6.3 IMP. 20℃ 345 480 540 620 945 1,250 1,500 1,330 1,330 1,760 1,960 2,250 2,550 2,480 2,900 3,450 3,570 3,250 3,630 3,650 ㎌ 150 330 330 470 680 1,000 1,500 1,000 1,000 1,500 1,800 2,200 2,700 3,300 3,900 4,700 5,600 4,700 6,800 8,200 Ripple 20℃ -10℃ 0.22 0.13 0.094 0.084 0.056 0.045 0.029 0.039 0.039 0.028 0.020 0.018 0.015 0.017 0.015 0.013 0.012 0.015 0.013 0.012 0.80 0.47 0.35 0.31 0.19 0.15 0.11 0.14 0.14 0.10 0.060 0.054 0.045 0.043 0.038 0.033 0.031 0.038 0.035 0.031 345 480 540 620 945 1,250 1,500 1,330 1,330 1,760 1,960 2,250 2,550 2,480 2,900 3,450 3,570 3,250 3,630 3,650 ㎌ 100 220 220 330 470 680 1,000 680 680 1,000 1,500 1,800 2,200 2,200 2,700 3,300 3,900 3,300 4,700 5,600 -10℃ 0.22 0.13 0.094 0.084 0.056 0.045 0.029 0.039 0.039 0.028 0.020 0.018 0.015 0.017 0.015 0.013 0.012 0.015 0.013 0.012 0.80 0.47 0.35 0.31 0.19 0.15 0.11 0.14 0.14 0.10 0.060 0.054 0.045 0.043 0.038 0.033 0.031 0.038 0.035 0.031 25 35 50 IMP. IMP. IMP. Ripple -10℃ ㎌ 20℃ Ripple -10℃ ㎌ Ripple 20℃ 345 480 540 620 945 1,250 1,500 1,330 1,330 1,760 1,960 2,250 2,550 2,480 2,900 3,450 3,570 3,250 3,630 3,650 Ripple 20℃ -10℃ 2.5 2.5 1.0 0.40 0.34 0.16 0.20 0.14 0.14 0.12 0.074 8.68 8.68 3.47 1.39 1.18 0.56 0.71 0.50 0.50 0.43 0.22 120 120 145 195 238 350 320 450 450 586 724 5×11 68 0.22 0.80 345 47 0.22 0.80 345 5×15 150 0.13 0.47 480 100 0.13 0.47 480 6.3×11 150 0.094 0.35 540 100 0.094 0.35 540 6.3×15 8×11.5 220 330 390 470 0.084 0.056 0.045 0.045 0.31 0.19 0.15 0.15 620 945 1,250 1,330 150 220 0.084 0.056 0.31 0.19 620 945 2.2 4.7 10 22 27 56 33 47 56 100 100 270 0.045 0.15 1,250 120 0.061 0.18 950 8×20 560 0.029 0.11 1,500 390 470 0.029 0.029 0.11 1,500 1,600 180 0.046 0.14 1,190 10×12 470 0.039 0.14 1,330 330 0.039 0.14 1,330 10×12.5 470 0.039 0.14 1,330 330 0.039 0.14 1,330 680 820 1,000 1,000 1,200 1,000 1,500 1,800 2,200 2,700 2,200 2,700 3,300 3,900 0.028 0.020 0.020 0.018 0.015 0.018 0.017 0.015 0.013 0.012 0.015 0.015 0.013 0.012 0.10 0.060 0.060 0.054 0.045 0.045 0.043 0.038 0.033 0.031 0.038 0.038 0.035 0.031 1,760 1,960 1,960 2,250 2,550 2,500 2,550 2,900 3,450 3,570 3,250 3,250 3,630 3,650 470 560 680 680 1,000 0.028 0.020 0.025 0.018 0.015 0.10 0.060 0.075 0.054 0.045 1,760 1,960 1,850 2,250 2,550 68 150 68 150 220 0.070 0.061 0.070 0.061 0.042 0.21 0.18 0.21 0.18 0.12 750 979 750 979 1,370 270 0.030 0.090 1,580 330 470 0.028 0.025 0.085 0.076 1,870 2,110 1,000 0.017 0.043 2,480 470 0.027 0.068 2,050 1,200 1,500 1,800 0.015 0.013 0.012 0.038 0.033 0.031 2,900 3,450 3,570 1,500 0.015 0.038 3,250 2,200 2,700 0.013 0.012 0.035 0.031 3,630 3,650 560 680 820 820 1,000 1,000 1,500 0.023 0.021 0.019 0.023 0.023 0.021 0.019 0.059 0.052 0.051 0.059 0.059 0.056 0.051 2,410 2,860 2,960 2,730 2,730 3,010 3,290 8×15 10×16 10×20 10×25 10×33 12.5×20 12.5×25 12.5×30 12.5×35 16×20 16×25 18×25 128 MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS RATINGS OF NXH Series 63 V DC ㎌ ØD×L(mm) 5×11 6.3×11 8×11.5 8×15 8×20 10×12 10×12.5 10×16 10×20 10×25 12.5×20 12.5×25 12.5×30 12.5×35 16×20 16×25 18 47 82 100 150 120 120 180 270 330 390 470 560 680 560 820 IMP. -10℃ 0.45 0.30 0.20 0.18 0.16 0.16 0.16 0.10 0.080 0.070 0.050 0.037 0.032 0.030 0.035 0.030 1.8 1.2 0.80 0.72 0.64 0.64 0.64 0.40 0.32 0.28 0.20 0.15 0.13 0.12 0.14 0.12 ㎌ 12 33 56 68 100 82 82 120 180 220 180 270 330 390 470 560 390 560 680 820 1,000 560 820 1,000 1,200 1,500 100 IMP. Ripple 20℃ -10℃ 1.2 0.46 0.29 0.20 0.16 0.17 0.17 0.11 0.084 0.069 0.11 0.062 0.047 0.042 0.036 0.032 0.048 0.038 0.032 0.029 0.027 0.045 0.036 0.030 0.027 0.026 5.33 2.03 1.31 0.90 0.72 0.68 0.68 0.44 0.35 0.28 0.33 0.19 0.15 0.14 0.11 0.096 0.16 0.11 0.096 0.087 0.081 0.14 0.11 0.090 0.081 0.078 163 267 462 585 735 624 624 780 1,040 1,170 975 1,430 1,620 1,950 2,140 2,340 1,750 2,210 2,400 2,600 2,860 1,950 2,270 2,470 2,860 3,510 IMP. ㎌ 8.2 18 33 47 68 47 47 68 100 120 100 150 220 270 330 390 270 390 470 560 680 390 470 560 680 820 Ripple 20℃ -10℃ 1.2 0.46 0.29 0.20 0.16 0.17 0.17 0.11 0.084 0.069 0.11 0.062 0.047 0.042 0.036 0.032 0.048 0.038 0.032 0.029 0.027 0.045 0.036 0.030 0.027 0.026 5.33 2.03 1.31 0.90 0.72 0.68 0.68 0.44 0.35 0.28 0.33 0.19 0.15 0.14 0.11 0.096 0.16 0.11 0.096 0.087 0.081 0.14 0.11 0.090 0.081 0.078 163 267 462 585 735 624 624 780 1,040 1,170 975 1,430 1,620 1,950 2,140 2340 1,750 2,210 2,400 2,600 2,860 1,950 2,270 2,470 2,860 3,510 NXH 5×11 6.3×11 8×11.5 8×15 8×20 10×12 10×12.5 10×16 10×20 10×25 12.5×16 12.5×20 12.5×25 12.5×30 12.5×35 12.5 x 40 16×20 16×25 16×31.5 16×35.5 16×40 18×20 18×25 18×31.5 18×35.5 18×40 173 278 525 688 861 725 725 998 1,200 1,410 1,570 1,990 2,410 2,620 2,100 2,430 80 V DC ØD×L(mm) Ripple 20℃ Series Rated Ripple Current (mArms/105℃, 100kHz) Impedance (Ωmax./100kHz) Nominal Capacitance(㎌) RIPPLE CURRENT MULTIPLIERS Frequency Multipliers Cap.(㎌) Freq.(Hz) 2.2 ~ 22 27 ~ 33 39 ~ 270 330 ~ 680 820 ~ 1,800 2,200 ~ 10,000 120 1k 10k 50k 100k 0.40 0.42 0.50 0.55 0.60 0.70 0.66 0.70 0.73 0.77 0.80 0.85 0.85 0.90 0.92 0.94 0.96 0.98 0.90 0.93 0.95 0.96 0.97 0.99 1.00 1.00 1.00 1.00 1.00 1.00 129
NXH25VB470M8*15_3.5TP 价格&库存
很抱歉,暂时无法提供与“NXH25VB470M8*15_3.5TP”相匹配的价格&库存,您可以联系我们找货
  • 10+0.55422
  • 100+0.50322
  • 500+0.45222
  • 1000+0.40122
  • 2000+0.36722
  • 4000+0.35702
库存:562
