SLW4010S4R7MST
SLW4010S4R7MST
    SUNLTECH(顺磁)
    SMD,4x4mm
    功率电感 4.7µH ±20% IND_4X4MM_SM 1.00mm 4.00 x 4.00mm 140mΩ 1.2A 47MHz
SLW4010S4R7MST 数据手册
SLW 4010S Series Wire Wound SMD Power Inductor Pb ◆ Features 1、Magnetic-resin shielded construction reduces buzz noise to ultra-low levels; 2、Metallization on ferrite core results in excellent shock resistance and damage-free durability; 3、Closed magnetic circuit design reduces leakage flux and Electro Magnetic Interference (EMI); 4、30% higher current rating than conventional inductors of equal size; 5、Take up less PCB real estate and save more power。 ◆ Applications ◆ Lead Free Part Numbering 1、LED Lighting; 2、Mobile devices with multifunction such as adding color TV and camera; 3、Flat-screen TVs, blue-ray disc recorders, set top boxes; 4、Notebooks, desktop computers, servers, graphic cards; 5、Portable gaming devices, personal navigation systems, personal multimedia devices; 6、Automotive systems SLW (1) (1) (2) (3) (4) 4010 (2) S 100 M (3) (4) (5) S T (6) (7) Series Type Dimension:L X H Material Code Inductance:2R2=2.2μH ; 100=10µH;101=100µH (5) Inductance Tolerance:M= 20%, N= 30% (6) Company Code (7) Packaging Tape Carrier Package ± ± : 7、Telecomm base stations ◆ Dimensions Recommended Land Pattern Unit:mm Series A B C D E F a Typ. b Typ. c Typ. SLW4010S 4.0±0.2 4.0±0.2 1.0Max. 3.3±0.2 0.95±0.2 2.10±0.2 1.9 1.1 3.7 Rev.01 Page 1 of 3 www. sunltech.com SLW4010S Series ◆ Electrical Characteristics ( : ℃ ℃ ℃ ℃ 1) Operating temperature range Including self-heating) -40 ~ +125 2) Storage temperature range (packaging conditions): -10 ~+40 and RH 70% (Max.) ◆ Construction and material ◆ REFLOW-PROFILE Rev.01 Page 2 of 3 www. sunltech.com SLW4010S Series ◆ Specification Inductance Part Number @100KHz,1V (µH) DC Resistance (Ω) DCR ±30% Frequency MHz Saturation Current(A) Heat Rating Current (A) S.R.F Isat Irms Min.Self-resonant ( ) SLW4010 Series SLW4010S1R0NST 1.0±30% 0.056 116 2.40 2.10 SLW4010S1R5NST 1.5±30% 0.070 94 2.08 1.80 SLW4010S2R2MST 2.2±20% 0.085 73 1.80 1.60 SLW4010S3R3MST 3.3±20% 0.100 58 1.40 1.30 SLW4010S4R7MST 4.7±20% 0.140 47 1.30 1.20 SLW4010S6R8MST 6.8±20% 0.200 38 1.00 1.00 SLW4010S100MST 10±20% 0.300 31 0.80 0.80 SLW4010S150MST 15±20% 0.430 24 0.65 0.65 SLW4010S220MST 22±20% 0.570 19 0.45 0.45 ◆ Note 1:All test data is referenced to 20°C ambient; 2:Rated current: Isat or Irms, whichever is smaller; 3:Isat: DC current at which the inductance drops approximate 30% from its value without current; 4:Irms: DC current that causes the temperature rise (△T =40°C) from 20°C ambient. ◆ Standard Packing Quantity: :1000 pcs/reel ◆ TYPICAL ELECTRICAL CHARACTERISTICS SLW4010S Series Rev.01 Page 3 of 3 www. sunltech.com
