SF11WS THRU SF18WS
Reverse Voltage - 50 to 600Volts Forward Current - 0.5 Ampere
SURFACE MOUNT SUPER FAST RECOVERY RECTIFIER
Features
SOD-323
Easy to pick and place
For surface mounted applications
Low profile package
Built-in strain relief
0.008(0.20)max.
Cathode bar
0.055(1.40)
0.016(0.40)
0.009(0.25)
0.047(1.20)
Superfast recovery times for high efficiency
0.070 (1.80)
0.063 (1.40)
0.108 (2.75)
0.019 (0.475) ref.
0.10 (0.0031)
8°
0.0079 (0.20)
0° to
Case: 6OD-323
Terminals: Solderable per MIL-STD-750,Method 2026
Polarity: Polarity symbol marking on body
Mounting Position: Any
Appro .Weight : 0.0019 ounce, 0.0548 grams
0.15 (0.0059)
0.016 (0.45)
0.008 (0.2 )
Mechanical Data
0.032 (0.8)
0.043 (1.10)
0.100 (2.55)
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SF11WS
SF12WS
SF13WS
SF14WS
SF15WS
SF16WS
SF18WS
F11
F12
F13
F14
F15
F16
F18
50
35
50
100
70
100
150
105
150
200
140
200
300
210
300
400
280
400
600
420
600
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
VRMM
VRMS
VDC
UNITS
V
V
V
Maximum average forward rectified current at
Tc = 125 °C
IF(AV)
0.5
A
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
IFSM
15
A
Maximum instantaneous forward voltage at 0.5A
VF
Maximum DC reverse current
at rated DCblocking voltage
IR
TA=25℃
TA=125℃
Typical junction capacitance (NOTE 3)
Typical reverse recovery time (NOTE 2)
CJ
Trr
Operating junction temperature range
Storage temperature range
1.0
1.25
5
100
15
1.68
V
uA
pF
35
ns
TJ
-55 to +150
TSTG
-55 to +150
Note:1.P.C.B. mounted with 0.2" X 0.2" (5 X 5 mm) copper pad areas.
2.Measured with IF=0.5A,IR =1A,Irr=0.25A
3.Measured at 1.0MHz and applied reverse voltage of 4.0V D.C.
4.The typical data above is for reference only.
http://www.microdiode.com
Rev:2024A1
Page :1
SF11WS THRU SF18WS
Typical Characterisitics
Fig.1 Reverse Recovery Time Characteristic And Test Circuit Diagram
t rr
10 ohm
Noninductive
50 ohm
Noninductive
+0.5
D.U.T
PULSE
GENERATOR
Note 2
25Vdc
approx
1 ohm
NonInductive
OSCILLOSCOPE
Note 1
-1.0
Note:1.Rise Time = 7ns, max.
Input Impedance = 1megohm,22pF.
2. Ries Time =10ns, max.
Source Impedance = 50 ohms.
10ns/div
Set time Base for 10ns/div
Fig.3 Typical Reverse Characteristics
300
0.6
0.5
I R - Reverse Current (μA)
Average Forward Current (A)
Fig.2 Maximum Average Forward Current Rating
0.4
0.3
0.2
0.1
Single phase half-wave 60 Hz
0.0
25
50
75
100
125
150
175
100
T J =125°C
10
T J =75°C
1.0
T J =25°C
0.1
40
Case Temperature (°C)
T J =25°C
1.0
SF11WS~SF14WS
SF15WS/SF16WS
SF18WS
0.01
0.001
1.0
1.5
100
Fig.5 Typical Junction Capacitance
Junction Capacitance (pF)
Instaneous Forward Current (A)
Fig.4 Typical Forward Characteristics
0.1
80
60
% of PIV.VOLTS
2.0
2.5
Instaneous Forward Voltage (V)
100
10
1
T J=25°C
f = 1.0MHz
V sig = 50mV p-p
0.1
1.0
10
100
Reverse Voltage (V)
Peak Forward Surage Current (A)
Fig.6 Maximum Non-Repetitive Peak
25
10
05
00
8 . 3 ms
m s Si
S i n g l e H a l f Si
Sine W
Wa
ave
( J E D E C Me
Method)
10
1
100
Number of Cycles
The curve above is for reference only.
Rev:2024A1
Page :2
SF11WS THRU SF18WS
Packing information
unit:mm
P0
P1
d
Item
Symbol
Tolerance
Carrier width
Carrier length
Carrier depth
Sprocket hole
13" Reel outside diameter
13" Reel inner diameter
7" Reel outside diameter
7" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
A
B
C
d
D
D1
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
SOD-323
E
F
B
A
W
P
D2
T
D1
C
W1
D
1.46
2.90
1.25
1.50
330.00
50.00
178.00
54.40
13.00
1.75
3.50
4.00
4.00
2.00
0.06
8.00
12.30
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
SOD-323
REEL SIZE
7"
REEL
(pcs)
COMPONENT
SPACING
(m/m)
BOX
(pcs)
INNER
BOX
(m/m)
REEL
DIA,
(m/m)
3,000
4.0
45,000
210*208*203
178
CARTON
SIZE
(m/m)
430*430*235
CARTON
(pcs)
APPROX.
GROSS WEIGHT
(kg)
180,000
9.0
Suggested Pad Layout
Symbol
A
Unit (mm)
Unit (inch)
0.047
B
1.2
1.2
C
3.6
0.141
D
1.4
0.055
E
3.8
0.149
0.047
Rev:2024A1
Page :3
很抱歉,暂时无法提供与“SF18WS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.15840
- 300+0.12771
- 1200+0.12579
- 3000+0.12108
- 国内价格
- 10+0.17280
- 100+0.15131
- 300+0.13932
- 3000+0.13209
- 6000+0.12593
- 9000+0.12258
