FP6165ADXR-G1
FP6165ADXR-G1
    FEELING(遠翔科技)
    ESOP-8
    1.5MHz,3A同步降压调节器
FP6165ADXR-G1 数据手册
FP6165 1.5MHz, 3A Synchronous Step-Down Regulator General Description The FP6165 is a high efficiency current mode synchronous buck PWM DC-DC regulator. The internal generated 0.6V precision feedback reference voltage is designed for low output voltage. Low RDS (ON) synchronous switch dramatically reduces conduction loss. To extend battery life for portable application, 100% duty cycle is supported for low-dropout operation. Shutdown mode also helps saving the current consumption. The FP6165 is packaged in MSOP-10L, DFN-10L and SOP-8L to reduce PCB space. Features  Input Voltage Range: 2.5 to 5.5V  Adjustable Output Voltage From 0.6V to VIN  Precision Feedback Reference Voltage: 0.6V (±2%)  Output Current: 3A (Max.)  Duty Cycle: 0~100%  Internal Fixed PWM Frequency: 1.5MHz  Low Quiescent Current: 100μA  No Schottky Diode Required  Built-in Soft Start  Current Mode Operation  Over Temperature Protection  Package: MSOP-10L (EP), DFN-10L, SOP-8L (EP) Applications  Cellular Telephone  Wireless and DSL Modems  Digital Still Cameras  Portable Products  MP3 Players Typical Application Circuit This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Rev. 0.71 Website: http://www.feeling-tech.com.tw 1/20 FP6165 Function Block Diagram This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Rev. 0.71 Website: http://www.feeling-tech.com.tw 2/20 FP6165 Pin Descriptions MSOP-10L (EP) DFN-10L Name No. I / O Description EN 1 I Enable / UVLO VCC 2 P Supply Voltage AVCC 3 P Analog Supply Voltage PGOOD 4 O Power Good Open Drain Output FB / VOUT 5 I Feedback AGND 6 P Analog Ground SW 7 O Switch SW 8 O Switch GND 9 P Ground GND 10 P Ground EP 11 P Exposed PAD - Must Connect to Ground Name No. I / O Description EN 1 I Enable / UVLO VCC 2 P Supply Voltage AVCC 3 P Analog Supply Voltage PGOOD 4 O Power Good Open Drain Output FB / VOUT 5 I Feedback AGND 6 P Analog Ground SW 7 O Switch SW 8 O Switch GND 9 P Ground GND 10 P Ground EP 11 P Exposed PAD - Must Connect to Ground SOP-8L (EP) Name No. I / O EN 1 I Description Enable / UVLO VCC 2 P Supply Voltage AVCC 3 P Analog Supply Voltage FB / VOUT 4 I Feedback AGND 5 P Analog Ground SW 6 O Switch GND 7 P Ground GND 8 P Ground EP 9 P Exposed PAD - Must connect to Ground This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Rev. 0.71 Website: http://www.feeling-tech.com.tw 3/20 FP6165 Marking Information MSOP-10L (EP) Reference Voltage Code Ext: AD →0.6V 6165AD Halogen Free Lot Number Internal ID Per-Half Month Year DFN-10L SOP-8L (EP) 6165-AD 9Fa-86L Reference Voltage Code Ext: AD →0.6V Halogen Free Lot Number Internal ID Per-Half Month Year Halogen Free: Halogen free product indicator Lot Number: Wafer lot number’s last two digits For Example: 132386TB  86 Internal ID: Internal Identification Code Per-Half Month: Production period indicated in half month time unit For Example: January → A (Front Half Month), B (Last Half Month) February → C (Front Half Month), D (Last Half Month) Year: Production year’s last digit This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Rev. 0.71 Website: http://www.feeling-tech.com.tw 4/20 FP6165 Ordering Information Part Number Operating Temperature Package MOQ Description -40°C ~ +85°C -40°C ~ +85°C -40°C ~ +85°C MSOP-10L (EP) DFN-10L SOP-8L (EP) 3000EA 2500EA 2500EA Tape & Reel Tape & Reel Tape & Reel FP6165ADgR-G1 FP6165ADdR-G1 FP6165ADXR-G1 Absolute Maximum Ratings Max. Unit -0.3 6 V -0.3 VIN V P-Channel Switch Source Current (DC) 3.9 A N-Channel Switch Source Current (DC) 3.9 A 6 A MSOP-10L +70 °C / W DFN-10L +65 °C / W SOP-8L +50 °C / W MSOP-10L +10 °C / W DFN-10L +10 °C / W SOP-8L +10 °C / W +150 °C +150 °C +260 °C Parameter Input Supply Voltage Symbol Conditions VIN EN, VFB, SW Voltage Min. Peak SW Switch Sink and Source Current (AC) Thermal Resistance (Junction to Ambient) Thermal Resistance (Junction to Case) θJA θJC Junction Temperature Storage Temperature -65 Lead Temperature (soldering, 10 sec) Typ. Suggested IR Re-flow Soldering Curve This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Rev. 0.71 Website: http://www.feeling-tech.com.tw 5/20 FP6165 Recommended Operating Conditions Parameter Symbol Supply Voltage Conditions VIN Operating Temperature Min. Typ. Max. Unit 2.5 5.5 V -40 +85 °C DC Electrical Characteristics (VIN=3.6V ,TA= 25°C , unless otherwise noted) Parameter Min. Typ. Max. Unit TA=25°C 0.588 0.6 0.612 V -40°C~+85°C 0.582 0.6 0.618 V Symbol Conditions Regulated Feedback Voltage VFB Line Regulation with VREF VFB VIN=2.5V to 5.5V 0.04 0.4 /V Output Voltage LineRegulation VOUT VIN=2.5 to 5.5V 0.04 0.4 %/V RDS (ON) of P-Channel FET RDS (ON) P ISW=100mA 60 90 mΩ RDS (ON) of N-Channel FET RDS(ON) N ISW =-100mA 60 90 mΩ ±0.01 ±1 µA SW Leakage ILSW VEN=0V, VIN=5V Peak Inductor Current IPK VFB=0.5V 3.75 Input Voltage Range VIN -40°C~+85°C 2.5 Quiescent Current ICC 5 6 A 5.5 V 1 µA Shutdown, VEN=0V 0.1 Active, VFB=0.5V, VEN=VIN 100 µA PFM, VFB=0.7V, VEN=VIN 80 µA EN Threshold VEN -40°C~ +85°C EN Leakage Current IEN -40°C ~+85°C Oscillator Frequency FOSC VFB=0.6V, -40°C ~+85°C 0.3 1.2 1 1.5 V ±0.01 ±1 µA 1.5 1.8 MHz This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Rev. 0.71 Website: http://www.feeling-tech.com.tw 6/20 FP6165 Typical Operating Characteristics (TA= 25°C, VIN=3.3V, unless otherwise noted) Quiescent Current VS. Input Voltage Shutdown Current VS. Input Voltage 100 0.5 VFB=0.65V 90 0.4 Shutdown Current (uA) 80 Quiescent Current (uA) VEN=0 V 0.45 70 0.35 60 50 0.3 0.25 40 30 0.2 0.15 20 10 0.1 0.05 0 0 2.5 3 3.5 4 Input Voltage (V) 4.5 5 5.5 2.5 3 3.5 Line Regulation 5 1.8 1.79 1.78 1.77 1.76 1.75 1.74 1.73 1.72 1.71 1.7 VIN=3.3V Vout=1.8V 0.608 5.5 VIN=3.3V Vout=1.8V Output Voltage (V) 0.606 Reference Voltage (V) 4.5 Load Regulation 0.61 0.604 0.602 0.6 0.598 0.596 0.594 0.592 0.59 2.5 3 3.5 4 Input Voltage (V) 4.5 5 0.5 5.5 1 Reference Volatge VS. Temperature 1.5 2 Output Current (A) 2.5 3 Frequency VS. Input Voltage 0.61 1.65 VIN=3.3V Vout=1.8V 0.608 VIN=3.3V Vout=1.8V 1.63 0.606 1.61 0.604 1.59 Frequency (MHz) Reference Volatge (V) 4 Input Voltage (V) 0.602 0.6 0.598 0.596 1.57 1.55 1.53 1.51 0.594 1.49 0.592 1.47 0.59 1.45 -40 -20 0 20 40 Temperature (℃) 60 80 100 2.5 3 3.5 4 Input Voltage (V) 4.5 5 5.5 Body Temperature VS. Output Current Frequency VS. Temperature 100 1.65 VIN=3.3V Vout=1.8V 1.63 VIN=3.3V Vout=1.8V 90 Body Temperature (℃) 1.61 Frequency (MHz) 1.59 1.57 1.55 1.53 1.51 1.49 80 70 60 50 40 30 20 10 1.47 0 1.45 -40 -20 0 20 40 Temperature (℃) 60 80 100 0.5 1 1.5 2 Output Current (A) 2.5 3 This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Rev. 0.71 Website: http://www.feeling-tech.com.tw 7/20 FP6165 Function Description Control Loop The FP6165 is a high efficiency current mode synchronous buck regulator. Both the main (P-channel MOSFET) and synchronous (N-channel MOSFET) switches are built internally. With current mode operation, the PWM duty is controlled both by the error amplifier output and the peak inductor current. At the beginning of each cycle, the oscillator turn on the P-MOSFET switch to source current from VIN to SW output. Then, the chip starts to compare the inductor current with the error amplifier output. Once the inductor current is larger than the error amplifier output, the P-MOSFET switch is turned off. When the load current increases, the feedback voltage FB will slightly drop. This causes the error amplifier to output a higher current level until the prior mentioned peak inductor current reach the same level. The output voltage then can be sustained at the same. When the top P-MOSFET switch is off, the bottom synchronous N-MOSFET switch is turned on. Once the inductor current reverses, both top and bottom MOSFET will be turn off to leave the SW pin into high impedance state. The FP6165’s current mode control loop also includes slope compensation to suppress sub-harmonic oscillations at high duty cycles. This slope compensation is achieved by adding a compensation ramp to the inductor current signal. LDO Mode The FP6165’s maximum duty cycle can reach 100%. That means the driver’s main switch is turn on through out whole clock cycle. Once the duty reaches 100%, the feedback path no longer controls the output voltage. The output voltage will be the input voltage minus the main switch voltage drop. Over Current Protection FP6165 limits the peak main switch current cycle by cycle. When over current occurs, chip will turn off the main switch and turn the synchronous switch on until next cycle. Short Circuit Protection When the FB pin is drop below 300mV, the chip will tri-state the output pin SW automatically. After 300us rest to avoid over heating, chip will re-initiate PWM operation with soft start. Power Good The power good pin is an open-drain output. Connects a 100kΩ pull up resistor between VIN and this pin to obtain a PGOOD voltage. When the output voltage is not within ±10% of setting output This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Rev. 0.71 Website: http://www.feeling-tech.com.tw 8/20 FP6165 voltage, the PGOOD pin will be pulled down to ground immediately. After the output voltage is within ±10% of setting output voltage for 42.7µs (typ.), the PGOOD pin pull-down is turned off. Then it can be pulled up to VIN through external pull-high resister. Connect this pin to AGND if not used. Thermal Protection FP6165 will shutdown automatically when the internal junction temperature reaches 150℃ to protect both the part and the system. This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Rev. 0.71 Website: http://www.feeling-tech.com.tw 9/20 FP6165 Application Information Input capacitor Selection The input capacitor must be connected to the VIN pin and GND pin of FP6165 to maintain steady input voltage and filter out the pulsing input current. The voltage rating of input capacitor must be greater than maximum input voltage plus ripple voltage. In switch mode, the input current is discontinuous in a buck converter. The source current waveform of the high-side MOSFET is a square wave. To prevent large voltage transients, a low ESR input capacitor sized for the maximum RMS current must be used. The RMS value of input capacitor current can be calculated by: IRMS  IO _ MAX VO VIN  V  1  O  VIN   It can be seen that when VO is half of VIN, CIN is under the worst current stress. The worst current stress on CIN is IO_MAX/2. Inductor Selection The value of the inductor is selected based on the desired ripple current. Large inductance gives low inductor ripple current and small inductance result in high ripple current. However, the larger value inductor has a larger physical size, higher series resistance, and/or lower saturation current. In experience, the value is to allow the peak-to-peak ripple current in the inductor to be 10%~20% maximum load current. The inductance value can be calculated by: L ( VIN  VO ) VO ( VIN  VO ) VO  f  IL VIN f  2  (10% ~ 20%)IO  VIN The inductor ripple current can be calculated by: IL  VO  V   1  O  f  L  VIN  Choose an inductor that does not saturate under the worst-case load conditions, which is the load current plus half the peak-to-peak inductor ripple current, even at the highest operating temperature. The peak inductor current is: IL _ PEAK  IO  IL 2 The inductors in different shape and style are available from manufacturers. Shielded inductors are small and radiate less EMI issue. But they cost more than unshielded inductors. The choice depends on EMI requirement, price and size. This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Rev. 0.71 Website: http://www.feeling-tech.com.tw 10/20 FP6165 Dimensions (mm) Component Supplier 1.0 8.3×8.3×4.5 FENG-JUI TPRH8D43-2R2M 1.0 10.3×10.3×4.0 FENG-JUI TPRH10D40-2R2M 2.2 8.3×8.3×4.5 FENG-JUI TPRH8D43-3R3M 2.2 10.3×10.3×4.0 FENG-JUI TPRH10D40-3R3M Inductor Value (µH) Model Output Capacitor Selection The output capacitor is required to maintain the DC output voltage. Low ESR capacitors are preferred to keep the output voltage ripple low. In a buck converter circuit, output ripple voltage is determined by inductor value, switching frequency, output capacitor value and ESR. The output ripple is determined by:  1 VO  IL   ESR COUT  8  f  COUT     Where f = operating frequency, COUT= output capacitance and ΔIL = ripple current in the inductor. For a fixed output voltage, the output ripple is highest at maximum input voltage since ΔIL increases with input voltage. Capacitor Value Case Size Component Supplier Model 10μF 0805 Taiyo Yuden JMK212BJ106MG 10μF 0805 TDK C12012X5ROJ106K 22μF 0805 1206 TDK C2012JB0J226M Using Ceramic Input and Output Capacitors Care must be taken when ceramic capacitors are used at the input and the output. When a ceramic capacitor is used at the input and the power is supplied by a wall adapter through long wires, a load step at the output can induce ringing at the input, VIN. At best, this ringing can couple to the output and be mistaken as loop instability. At worst, a sudden inrush current through the long wires can potentially cause a voltage spike at VIN, which may large enough to damage the part. When choosing the input and output ceramic capacitors, choose the X5R or X7R specification. Their dielectrics have the best temperature and voltage characteristics of all the ceramics for a given value and size. Output Voltage Programming In the adjustable version, the output voltage is set using a resistive voltage divider from the output voltage to FB. The output voltage is:  R  VO  0.6 V 1  1   R2  This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Rev. 0.71 Website: http://www.feeling-tech.com.tw 11/20 FP6165 The recommended resistor value is summarized below: VOUT (V) R1 (Ω) R2 (Ω) C3 (F) 0.6 200k Not Used Not Used 1.2 200k 200k 10p 1.5 300k 200k 10p 1.8 200k 100k 10p 2.5 270k 85k 10p 3.3 306k 68k 10p PC Board Layout Checklist 1. The power traces, consisting of the GND, SW and VIN trace should be kept short, direct and wide. 2. Place CIN near VIN pin as closely as possible to maintain input voltage steady and filter out the pulsing input current. 3. The resistive divider R1 and R2 must be connected to FB pin directly and as closely as possible. 4. FB is a sensitive node. Please keep it away from switching node, SW. A good approach is to route the feedback trace on another PCB layer and have a ground plane between the top and feedback trace routing layer. This reduces EMI radiation on to the DC-DC converter its own voltage feedback trace. 5. Keep the GND plates of CIN and COUT as close as possible. Then connect this to the ground plane (if one is used) with several vias. This reduces ground plane noise by preventing the switching currents from circulating through the ground plane. It also reduces ground bounce at FP6161 by giving it a low impedance ground connection. This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Rev. 0.71 Website: http://www.feeling-tech.com.tw 12/20 FP6165 Suggested Layout for DFN-10L / MSOP-10L Suggested Layout for SOP-8L This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Rev. 0.71 Website: http://www.feeling-tech.com.tw 13/20 FP6165 Typical Application VIN 2.5V / 5.5V C1 22μF R3 100K 1 EN 2 VCC GND GND 10 9 L1 1.0μH FP6165 3 AVCC SW 8 4 PGOOD SW 7 5 FB / VOUT AGND 6 VOUT 1.8V / 2A R1 200K C3 10pF C2 22μF GND R2 100K DFN-10L / MSOP-10L This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Rev. 0.71 Website: http://www.feeling-tech.com.tw 14/20 FP6165 VIN = 3.3V, VOUT = 1.8V, L = 1μH, TA = +25ºC Load Transient Response Enable ON ILOAD: 300mA~3A ILOAD: 3A Output Ripple Voltage Power Good ILOAD: 3A Power ON Power Good ILOAD: 3A This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Rev. 0.71 Website: http://www.feeling-tech.com.tw 15/20 FP6165 Short Circuit Efficiency Efficiency VS. Output Current 100.00 90.00 80.00 Efficiency (%) 70.00 60.00 2.7V 50.00 3.6V 4.2V 40.00 30.00 20.00 10.00 0.00 0 1 10 100 1000 10000 Output Current (mA) This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Rev. 0.71 Website: http://www.feeling-tech.com.tw 16/20 FP6165 Package Outline MSOP-10L (EP) UNIT: mm Symbols Min. (mm) Max. (mm) A 1.100 A1 0.000 0.150 A2 0.750 0.950 b 0.170 0.270 c 0.080 0.230 D 3.000 BSC. E 4.900 BSC. E1 3.000 BSC. e 0.500 BSC. L 0.400 L1 θ° 0.800 0.950 REF. 0° 8° This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Rev. 0.71 Website: http://www.feeling-tech.com.tw 17/20 FP6165 MSOP-10L (EP) continued Exposed PAD Dimensions: Symbols Min. (mm) Max. (mm) E2 1.715 REF D1 1.600 REF Note: 1. Package dimensions are in compliance with JEDEC outline: MO-187 BA-T. 2. Dimension “D” does not include molding flash, protrusions or gate burrs. 3. Dimension “E1” does not include inter-lead flash or protrusions. This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Rev. 0.71 Website: http://www.feeling-tech.com.tw 18/20 FP6165 DFN-10L (EP) UNIT: mm Symbols Min. (mm) Max. (mm) A 0.700 0.800 A1 0.000 0.050 A3 b 0.20REF 0.180 0.300 D 3.00 E 3.00 D2 2.200 2.700 E2 1.400 1.750 e 0.500 L 0.300 K 0.200 0.500 This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Rev. 0.71 Website: http://www.feeling-tech.com.tw 19/20 FP6165 SOP-8L (EP) UNIT: mm Symbols Min. (mm) Max. (mm) A 1.346 1.752 A1 0.050 0.152 A2 1.498 D 4.800 4.978 E 3.810 3.987 H 5.791 6.197 L 0.406 1.270 θ° 0° 8° Min. (mm) Max. (mm) Exposed PAD Dimensions: Symbols E1 2.184 REF D1 2.971 REF Note: 1. Package dimensions are in compliance with JEDEC outline: MS-012 AA. 2. Dimension “D” does not include molding flash, protrusions or gate burrs. 3. Dimension “E” does not include inter-lead flash or protrusions This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product. Rev. 0.71 Website: http://www.feeling-tech.com.tw 20/20
FP6165ADXR-G1 价格&库存
很抱歉,暂时无法提供与“FP6165ADXR-G1”相匹配的价格&库存,您可以联系我们找货
FP6165ADXR-G1
  • 1+2.48000
  • 30+2.40250
  • 100+2.24750
  • 500+2.09250
  • 1000+2.01500
库存:1402
