PESD24VS1UB
Features
Description
* 420W peak pulse power (8/20μs)
The PESD24VS1UB is a bi-directional TVS diode,
uti-lizing leading monolithic silicon technology to
pro-vide fast response time and low ESD clamping
volt-age, making this device an ideal solution for
pro-tecting voltage sensitive data and power line.
The PESD24VS1UB complies with the IEC
61000-4-2 (ESD) standard with ±15 kV air and ±8
kV contact discharge. It is assembled into an ultrasmall SOD-523 lead-free package. The small
size and high ESD surge protection make
PESD24VS1UB an ideal choice to protect cell
phone, digital cameras, audio players and many
other portable applications.
* Protects one data or power line
* Ultra low leakage: nA level
* Operating voltage: 24V
* Ultra low clamping voltage
* Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±30kV
Contact discharge: ±30kV
– IEC61000-4-5 (Lightning) 9A (8/20ns)
RoHS Compliant
Package: SOD-523
Lead Finish: Matte Tin
Applications
Circuit Diagram
Marking Diagram
Cellular Handsets and Accessories
Personal Digital Assistants
Notebooks and Handhelds
Portable Instrumentation
Peripherals
Pagers Peripherals
Desktop and Servers
Ordering Information
Part Number
5Y
W5B
Packaging
Reel Size
PESD24VS1UB 3000/Tape & Reel
7 inch
Transparent top view
W5B: Device Marking Code
Ver.: A1 2019-02-22 AW
0571-87006810
www.dowosemi.cn
1/4
PESD24VS1UB
Absolute Maximum Ratings (TA=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
Peak Pulse Power (8/20µs)
Ppk
420
W
Peak Pulse Current (8/20µs)
IPP
9
A
ESD per IEC 61000−4−2 (Air)
±30
VESD
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
Storage Temperature Range
kV
±30
TJ
−55 to +125
°C
Tstg
−55 to +150
°C
Electrical Characteristics (TA=25°C unless otherwise specified)
Parameter
Symbol
Reverse Working Voltage
Breakdown Voltage
Test Condition
Min
Typ
VRWM
VBR
IT = 1mA
26.0
28.0
Max Unit
24
V
30.5
V
Reverse Leakage Current
IR
VRWM = 24.0V
0.5
µA
Clamping Voltage
VC
IPP = 1A (8 x 20µs pulse)
35
V
Clamping Voltage
VC
IPP = 9A (8 x 20µs pulse)
40
45
V
Junction Capacitance
CJ
VR = 0V, f = 1MHz
30
50
pF
Portion Electronics Parameter
Symbol
IT
IPP
Vc
Parameter
Test Current
Maximum Reverse Peak Pulse Current
Clamping Voltage @Ic
0571-87006810
www.dowosemi.cn
2/4
PESD24VS1UB
Typical Performance Characteristics (TA=25°C unless otherwise Specified)
60
50
Vc-Clamping Voltage(V)
CJ-Junction Capacitance (pF)
45
40
35
30
25
10
5
40
30
8
12
16
VR—Reverse Voltage(V)
4
6
8
10
Ipp-Peak Pulse Current(A)
Clamping Voltage vs. Peak Pulse Current
Junction Capacitance vs. Reverse Voltage
10
Voltage (V)
Peak Power_Ppp(kW)
100
1
0.1
-20
0.1
1.0
10.0
Pulse Duration_tp(uS)
100
100
80
60
40
75
100
125
150
Ipp-Peak Pulse Current-%of Ipp
% of Rated Power
120
25
40
60
80
Ambient Temperature_Ta(℃)
80
60
40
-20
T-Time(us)
8 X 20us Pulse Waveform
Power Derating Curve
0571-87006810
100
IEC61000−4−2 Pulse Waveform
120
Time (nS)
Peak Pulse Power vs. Pulse Time
www.dowosemi.cn
3/4
60
PESD24VS1UB
SOD-523 Package Outline Drawing
DIMENSIONS
DIMN
INCHES
MM
NOTE
.MIN
MAX
MIN
MAX
A
.043
.051
1.10
1.30
B
.028
.035
0.70
0.90
C
.059
.067
1.50
1.70
D
.020
.028
0.50
0.70
E
.010
.014
0.25
0.35
F
.004
.008
0.10
0.20
G
.020
.028
0.50
0.70
Suggested Land Pattern
DIMENSIONS
DIMN
INCHES
MM
NOTE
MIN
MAX
MIN
MAX
C
.067
1.70
REF
G
.043
1.10
X
.031
0.80
REF
Y
.024
0.60
Z
.091
2.30
0571-87006810
www.dowosemi.cn
4/4
很抱歉,暂时无法提供与“PESD24VS1UB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.24735
- 200+0.20031
- 国内价格
- 1+0.23540
- 200+0.15180
- 1500+0.13200
- 3000+0.11660
- 国内价格
- 20+0.27260
- 200+0.22076
- 600+0.19484
- 3000+0.18015
- 9000+0.16460
- 21000+0.15671
