PESD5V0S1BA
Features
* 450W peak pulse power (8/20μs)
* Protects one data or power line
* Ultra low leakage: nA level
* Operating voltage: 5V
* Ultra low clamping voltage
* Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±30kV
Contact discharge: ±30kV
– IEC61000-4-4 (Lightning) 30A (8/20ns)
RoHS Compliant
Package: SOD-323
Lead Finish: Matte Tin
Circuit Diagram
Marking Diagram
Description
The PESD5V0S1BA is designed to replace multilayer
varistors in portable applications such as cell phones,
notebook computers and PDA’s, using monolithic silicon
technology to provide fast response time and ultra low ESD
clamping voltage, making this device an ideal solu-tion for
protecting sensitive semiconductor components from
damage.
The PESD5V0S1BA complies with the IEC 61000-4-2
(ESD) standard with ±15kV air and ±8kV contact
discharge. The PESD5V0S1BA is assembled into a
lead-free SOD-323 package and will protect one
unidi-rectional line. These devices will fit on the same
PCB pad area as an 0805 MLV device.
Applications
Cellular Handsets and Accessories
Personal Digital Assistants
Notebooks and Handhelds
Portable Instrumentation
Peripherals
Pagers Peripherals
Desktop and Servers
Ordering Information
Part Number
5Y
Packaging
PESD5V0S1BA 3000/Tape & Reel
Reel Size
7 inch
Transparent top view
05B:Device Marking Code
Ver.: A1 2019-02-22 AW
0571-87006810
www.dowosemi.cn
1/4
PESD5V0S1BA
Absolute Maximum Ratings (TA=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
Peak Pulse Power (8/20µs)
Ppk
450
W
Peak Pulse Current (8/20µs)
IPP
30
A
ESD per IEC 61000−4−2 (Air)
±30
VESD
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
Storage Temperature Range
kV
±30
TJ
−55 to +125
°C
Tstg
−55 to +150
°C
Electrical Characteristics (TA=25°C unless otherwise specified)
Parameter
Symbol
Reverse Working Voltage
Breakdown Voltage
Test Condition
Min
Typ
VRWM
VBR
Reverse Leakage Current
IR
Clamping Voltage
VC
Clamping Voltage
VC
Junction Capacitance
CJ
IT = 1mA(Pin1-Pin2)
6.0
5
V
8.0
V
0.5
µA
9.0
11.0
V
12.0
15.0
V
60
100
pF
7.0
VRWM = 5.0V(Pin2-Pin1)
IPP = 10A (8 x 20µs pulse)
(Pin1-Pin2)
IPP = 30A (8 x 20µs pulse)
(Pin1-Pin2)
VR = 0V, f = 1MHz
(Pin1-Pin2)
Max Unit
Portion Electronics Parameter
Symbol
IT
Parameter
Test Current
IPP
Vc
Maximum Reverse Peak Pulse Current
Clamping Voltage @Ic
0571-87006810
www.dowosemi.cn
2/4
PESD5V0S1BA
Typical Performance Characteristics (TA=25°C unless otherwise Specified)
100
Vc-Clamping Voltage(V)
CJ-Junction Capacitance (pF)
90
80
70
60
50
40
30
18
16
14
12
10
8
6
4
2
2
3
4
VR—Reverse Voltage(V)
Junction Capacitance vs. Reverse Voltage
5
10
15
30
Ipp-Peak Pulse Current(A)
Clamping Voltage vs. Peak Pulse Current
10
Voltage (V)
Peak Power_Ppp(kW)
100
1
-20
0.1
0.1
1.0
10.0
Pulse Duration_tp(uS)
100
100
80
60
40
100
125
150
Ipp-Peak Pulse Current-%of Ipp
% of Rated Power
120
50
40
60
80
Ambient Temperature_Ta(℃)
80
60
40
-20
T-Time(us)
8 X 20us Pulse Waveform
Power Derating Curve
0571-87006810
100
IEC61000−4−2 Pulse Waveform
120
25
Time (nS)
Peak Pulse Power vs. Pulse Time
www.dowosemi.cn
3/4
60
PESD5V0S1BA
SOD-323 Package Outline Drawing
DIMENSIONS
SYM
MILLIMETERS
INCHES
MIN
MAX
MIN
MAX
A
1.50
1.80
0.060
0.071
B
1.20
1.40
0.045
0.054
C
2.30
2.70
0.090
0.107
D
1.10
0.043
E
0.30
0.40
0.012
0.016
F
0.10
0.25
0.004
0.010
H
0.10
0.004
Suggested Land Pattern
SYM
DIMENSIONS
MILLIMETERS
INCHES
A
3.15
0.120
B
0.80
0.031
C
0.80
0.031
0571-87006810
www.dowosemi.cn
4/4
很抱歉,暂时无法提供与“PESD5V0S1BA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.13951
- 100+0.13051
- 500+0.12151
- 2000+0.10801
- 5000+0.10351
- 10000+0.10081
- 国内价格
- 20+0.18220
- 200+0.14721
- 600+0.12777
- 3000+0.11211
- 9000+0.10206
- 21000+0.09656
- 国内价格
- 1+0.37097
- 200+0.12436
- 1500+0.07723
- 3000+0.06124
