SJD12 Series
Working Voltage: 5.0 to 350 V
Peak Pulse Power: 200 W
Surface Mount
Transient Voltage Suppressors
Features
Glass passivated chip
200 W peak pulse power capability with a
10/1000 μs waveform, repetitive rate (duty
cycle):0.01 %
Low leakage
Uni and Bidirectional unit
Excellent clamping capability
Very fast response time
RoHS compliant
SOD-123
Mechanical Data
Case: Molded plastic
Epoxy: UL 94V-0 rate flame retardant
Lead: Solderable per MIL-STD-750, method
2026
Polarity: Color band denotes cathode end
except Bipolar
Mounting position: Any
Maximum Ratings(TA=25℃ unless otherwise noted)
Parameter
Peak power dissipation with a 10/1000μs waveform(1)
Peak power dissipation with a 8/20μs waveform(1)
Peak pulse current wih a 10/1000μs waveform(1)
Power dissipation on infinite heatsink at TL = 75 °C
Peak forward surge current, 8.3 ms single half sinewave unidirectional only(2)
Maximum instantaneous forward voltage at 25 A for
unidirectional only
Operating junction and storage temperature range
Value
Symbol
PPP
200
PPP
1000
IPP
See Next Table
0.4
PD
UNIT
W
W
A
W
IFSM
A
VF
3.5
V
TJ, TSTG
- 55 to +150
°C
Note:
(1)Non-repetitive current pulse per Fig.5 and derated above TA= 25 °C per Fig.1
(2)Measured on 8.3 ms single half sine-wave or equivalent square wave, duty cycle = 4 pulses per minute maximum
P. 1
SJD12 Series
Ratings and Characteristics Curves (TA=25℃ unless otherwise noted)
100
20 TJ = TJ max.
1
8.3 ms Single Half Sine-Wave
25
Peak Forward Surge Current, (A)
Peak Pulse Derating in Percentage of Peak
Power or Current, (%)
AMBIE AVERAGE FORWARD CURRENT, (A)
100
100
75
150
25
50
75
100
125
150
175
200
1
Fig. 1 - Pulse Derating Curve
Fig. 2 - Maximum Non-Repetitive
Surge Current
0.6
10
0.1
7
70 0.5 0.4
4500
0.1
Peak Power (kW)
Steady State Power Dissipation, (W)
0.4
100
10
Number of Cycles at 60 Hz
Ambient Temperature ,TA (℃)
0.3
0.2
1
0.1
0.1
0.0
50
75
100
125
150
175
0.1
200
1
10
100
1000
10000
Pulse Width ,td (μs)
Lead Temperature , TL (℃)
Fig. 3 - Steady State Power Derating Curve
Fig. 4 - Peak Pulse Power Rating Curve
10000
Tr=10μs
Peak Value
(Ipp)
5
1000
0.2
100
0.5 = Ipp 76
Half Value
2
1
50
1.5
33
10/1000
μsec.
Waveform
2as defined23
by R.E.A.
3
13
4
10
50
td
Junction Capacitance,CJ (pF)
Peak Pulse Current , (% )
100
TJ = 25 °C
Pulse Width (td) is defined as the
point where the peak current decays
to 500% of Ipp 0
100
Bi-directional
@zero bias
450
2000
30
5
450
1000
18
5
450
Uni-directional
@zero bias
700
2RWM
Uni-directional
@V
10
5
450
500
3
TJ=25 °C
f=1.0MHz
Bi-directional @VRWM
1
2
Time , (ms)
Fig. 5 - Pulse Waveform
3
4
1
10
100
1000
Reverse Breakdown Voltage,VBR (V)
Fig. 6 - Typical Junction Capacitance
P. 2
SJD12 Series
Electrical Characteristics(TA=25℃
Part Number Part Number
(Uni)
(Bi)
SJD12A05L01
SJD12A06L01
SJD12A6.5L01
SJD12A07L01
SJD12A7.5L01
SJD12A08L01
SJD12A8.5L01
SJD12A09L01
SJD12A10L01
SJD12A11L01
SJD12A12L01
SJD12A13L01
SJD12A14L01
SJD12A15L01
SJD12A16L01
SJD12A17L01
SJD12A18L01
SJD12A19L01
SJD12A20L01
SJD12A22L01
SJD12A24L01
SJD12A26L01
SJD12A28L01
SJD12A30L01
SJD12A33L01
SJD12A36L01
SJD12A40L01
SJD12A43L01
SJD12A45L01
SJD12A48L01
SJD12A51L01
SJD12A54L01
SJD12A58L01
SJD12A60L01
SJD12A64L01
SJD12A70L01
SJD12A75L01
SJD12A78L01
SJD12A80L01
SJD12A85L01
SJD12A90L01
SJD12A100L01
SJD12A110L01
SJD12A120L01
SJD12A130L01
SJD12A140L01
SJD12A150L01
SJD12A160L01
SJD12A170L01
SJD12A180L01
SJD12A190L01
SJD12A200L01
SJD12A220L01
SJD12A250L01
SJD12A300L01
SJD12A350L01
SJD12C05L01
SJD12C06L01
SJD12C6.5L01
SJD12C07L01
SJD12C7.5L01
SJD12C08L01
SJD12C8.5L01
SJD12C09L01
SJD12C10L01
SJD12C11L01
SJD12C12L01
SJD12C13L01
SJD12C14L01
SJD12C15L01
SJD12C16L01
SJD12C17L01
SJD12C18L01
SJD12C19L01
SJD12C20L01
SJD12C22L01
SJD12C24L01
SJD12C26L01
SJD12C28L01
SJD12C30L01
SJD12C33L01
SJD12C36L01
SJD12C40L01
SJD12C43L01
SJD12C45L01
SJD12C48L01
SJD12C51L01
SJD12C54L01
SJD12C58L01
SJD12C60L01
SJD12C64L01
SJD12C70L01
SJD12C75L01
SJD12C78L01
SJD12C80L01
SJD12C85L01
SJD12C90L01
SJD12C100L01
SJD12C110L01
SJD12C120L01
SJD12C130L01
SJD12C140L01
SJD12C150L01
SJD12C160L01
SJD12C170L01
SJD12C180L01
SJD12C190L01
SJD12C200L01
SJD12C220L01
Device
Marking
Code
Uni
Bi
FE
FG
FK
FM
FP
FR
FT
FV
FX
FZ
HE
HG
HK
HM
HP
HR
HT
HB
HV
HX
HZ
JE
JG
JK
JM
JP
JR
JT
JV
JX
JZ
XE
XG
XK
XM
XP
XR
XT
XB
XV
XX
XZ
TE
TG
TK
TB
TM
TP
TR
TT
TV
TX
TZ
YE
YG
YK
KE
KG
KK
KM
KP
KR
KT
KV
KX
KZ
LE
LG
LK
LM
LP
LR
LT
LB
LV
LX
LZ
ME
MG
MK
MM
MP
MR
MT
MV
MX
MZ
NE
NG
NK
NM
NP
NR
NT
NB
NV
NX
NZ
PE
PG
PK
PB
PM
PP
PR
PT
PV
PX
PZ
Maximum
Reverse
Leakage IR
@VRWM
IT (mA)
(uA)
Breakdown Voltage VBR @IT
Min (V)
Max (V)
6.40
6.67
7.22
7.78
8.33
8.89
9.44
10.00
11.10
12.20
13.30
14.40
15.60
16.70
17.80
18.90
20.00
21.10
22.20
24.40
26.70
28.90
31.10
33.30
36.70
40.00
44.40
47.80
50.00
53.30
56.70
60.00
64.40
66.70
71.10
77.80
83.30
86.70
88.80
94.40
100.00
111.00
122.00
133.00
144.00
155.00
167.00
178.00
189.00
200.00
211.00
224.00
246.00
279.00
335.00
391.00
7.00
7.37
7.98
8.60
9.21
9.83
10.40
11.10
12.30
13.50
14.70
15.90
17.20
18.50
19.70
20.90
22.10
23.30
24.50
26.90
29.50
31.90
34.40
36.80
40.60
44.20
49.10
52.80
55.30
58.90
62.70
66.30
71.20
73.70
78.60
86.00
92.10
95.80
97.60
104.00
111.00
123.00
135.00
147.00
159.00
171.00
185.00
197.00
209.00
220.00
232.00
247.00
272.00
309.00
371.00
432.00
10
10
10
10
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
400
400
250
100
50
25
10
5
2.5
2.5
2.5
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
Working
Peak
Reverse
Voltage
VRWM
(V)
5.0
6.0
6.5
7.0
7.5
8.0
8.5
9.0
10.0
11.0
12.0
13.0
14.0
15.0
16.0
17.0
18.0
19.0
20.0
22.0
24.0
26.0
28.0
30.0
33.0
36.0
40.0
43.0
45.0
48.0
51.0
54.0
58.0
60.0
64.0
70.0
75.0
78.0
80.0
85.0
90.0
100.0
110.0
120.0
130.0
140.0
150.0
160.0
170.0
180.0
190.0
200.0
220.0
250.0
300.0
350.0
Maximum Maximum
Clamping
Reverse
Voltage VC
Surge
@IPP
Current IPP
(A)
(V)
21.74
19.42
17.86
16.67
15.50
14.71
13.89
12.99
11.76
10.99
10.05
9.30
8.62
8.20
7.69
7.25
6.85
6.54
6.17
5.63
5.14
4.75
4.41
4.13
3.75
3.44
3.10
2.88
2.75
2.58
2.43
2.30
2.14
2.07
1.94
1.77
1.65
1.59
1.55
1.46
1.37
1.23
1.13
1.04
0.96
0.89
0.82
0.77
0.73
0.68
0.65
0.62
0.56
0.50
0.41
0.36
9.2
10.3
11.2
12.0
12.9
13.6
14.4
15.4
17.0
18.2
19.9
21.5
23.2
24.4
26.0
27.6
29.2
30.6
32.4
35.5
38.9
42.1
45.4
48.4
53.3
58.1
64.5
69.4
72.7
77.4
82.4
87.1
93.6
96.8
103.0
113.0
121.0
126.0
129.0
137.0
146.0
162.0
177.0
193.0
209.0
224.0
243.0
259.0
275.0
292.0
308.0
324.0
356.0
405.0
486.0
567.0
Note:
1. The available parts are "A" type only,the parts without A(VBR is ±10%) is not available
2. Add suffix 'C 'or ' CA ' after part number to specify Bi-directional devices
3. For Bi-Directional devices having VR of 10 volts and under, the IR limit is double
P. 3
很抱歉,暂时无法提供与“SJD12A36L01”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.14101
- 100+0.13101
- 300+0.12101
- 500+0.11101
- 2000+0.10601
- 5000+0.10301
- 国内价格
- 20+0.20596
- 200+0.15930
- 600+0.13338
- 3000+0.12302
- 9000+0.10952
- 21000+0.10228
