SMF Series
Working Voltage: 5.0 to 350 V
Peak Pulse Power: 200 W
Surface Mount
Transient Voltage Suppressors
Features
SOD-123
Glass passivated chip
200 W peak pulse power capability with a
10/1000 μs waveform, repetitive rate (duty
cycle):0.01 %
Low leakage
Uni and Bidirectional unit
Excellent clamping capability
Very fast response time
RoHS compliant
Mechanical Data
Case: Molded plastic
Epoxy: UL 94V-0 rate flame retardant
Lead: Solderable per MIL-STD-750, method
2026
Polarity: Color band denotes cathode end
except Bipolar
Mounting position: Any
Maximum Ratings(TA=25℃ unless otherwise noted)
Parameter
(1)
Peak power dissipation with a 10/1000μs waveform
Peak power dissipation with a 8/20μs waveform(1)
Peak pulse current wih a 10/1000μs waveform(1)
Power dissipation on infinite heatsink at TL = 75 °C
Peak forward surge current, 8.3 ms single half sinewave unidirectional only(2)
Maximum instantaneous forward voltage at 25 A for
unidirectional only
Operating junction and storage temperature range
Value
Symbol
PPP
200
PPP
1000
IPP
See Next Table
PD
0.4
UNIT
W
W
A
W
IFSM
A
VF
3.5
V
TJ, TSTG
- 55 to +150
°C
Note:
(1)Non-repetitive current pulse per Fig.5 and derated above TA= 25 °C per Fig.1
(2)Measured on 8.3 ms single half sine-wave or equivalent square wave, duty cycle = 4 pulses per minute maximum
www.dowosemi.cn
P. 1
SMF Series
AVERAGE
FORWARD
CURRENT, (A)
AMBIENT
TEMPERATURE
100
100
25
100
75
150
25
50
75
100
125
150
175
100
1
10
Fig. 2 - Maximum Non-Repetitive
Surge Current
0.6
10
0.4
0.1
7
70 0.5 0.4
4500
0.1
Peak Power (kW)
Steady State Power Dissipation, (W)
100
Number of Cycles at 60 Hz
Fig. 1 - Pulse Derating Curve
8.3 ms Single Half Sine-Wave
10
6
Ambient Temperature ,TA (℃)
20 TJ = TJ max.
1
Peak Forward Surge Current, (A)
Peak Pulse Derating in Percentage of Peak
Power or Current, (%)
Ratings and Characteristics Curves (TA=25℃ unless otherwise noted)
0.3
0.2
1
0.1
0.0
50
75
100
125
150
175
0.1
200
0.1
1
10
100
1000
10000
Pulse Width ,td (μs)
Lead Temperature , TL (℃)
Fig. 3 - Steady State Power Derating Curve
Fig. 4 - Peak Pulse Power Rating Curve
10000
Tr=10μs
Peak Value
(Ipp)
1000
0.2
100
0.5 = Ipp 76
Half Value
2
1
50
1.5
33
μsec.
210/1000
23 Waveform
as defined by R.E.A.
3
13
4
10
50
td
Junction Capacitance,CJ (pF)
Peak Pulse Current , (% )
100
TJ = 25 °C
Pulse Width (td) is defined as the
point where the peak current decays
to 500% of Ipp 0
100
1
Time , (ms)
2
3
2000
30
5
450
1000
18
5
450
10
5
450
500
3
TJ=25 °C
f=1.0MHz
4
Bi-directional
@zero bias
Uni-directional
@zero bias
Uni-directional
@V
700
2 RWM
1
1
Bi-directional @VRWM
10
100
1000
Reverse Breakdown Voltage,VBR (V)
Fig. 5 - Pulse Waveform
Fig. 6 - Typical Junction Capacitance
www.dowosemi.cn
P. 2
SMF Series
Electrical Characteristics(TA=25℃ unless otherwise noted)
Part Number Part Number
(Uni)
(Bi)
SMF5.0A
SMF6.0A
SMF6.5A
SMF7.0A
SMF7.5A
SMF8.0A
SMF8.5A
SMF9.0A
SMF10A
SMF11A
SMF12A
SMF13A
SMF14A
SMF15A
SMF16A
SMF17A
SMF18A
SMF19A
SMF20A
SMF22A
SMF24A
SMF26A
SMF28A
SMF30A
SMF33A
SMF36A
SMF40A
SMF43A
SMF45A
SMF48A
SMF51A
SMF54A
SMF58A
SMF60A
SMF64A
SMF70A
SMF75A
SMF78A
SMF80A
SMF85A
SMF90A
SMF100A
SMF110A
SMF120A
SMF130A
SMF140A
SMF150A
SMF160A
SMF170A
SMF180A
SMF190A
SMF200A
SMF220A
SMF250A
SMF300A
SMF350A
Note:
SMF5.0CA
SMF6.0CA
SMF6.5CA
SMF7.0CA
SMF7.5CA
SMF8.0CA
SMF8.5CA
SMF9.0CA
SMF10CA
SMF11CA
SMF12CA
SMF13CA
SMF14CA
SMF15CA
SMF16CA
SMF17CA
SMF18CA
SMF19CA
SMF20CA
SMF22CA
SMF24CA
SMF26CA
SMF28CA
SMF30CA
SMF33CA
SMF36CA
SMF40CA
SMF43CA
SMF45CA
SMF48CA
SMF51CA
SMF54CA
SMF58CA
SMF60CA
SMF64CA
SMF70CA
SMF75CA
SMF78CA
SMF80CA
SMF85CA
SMF90CA
SMF100CA
SMF110CA
SMF120CA
SMF130CA
SMF140CA
SMF150CA
SMF160CA
SMF170CA
SMF180CA
SMF190CA
SMF200CA
SMF220CA
Device
Marking
Code
Uni
Bi
FE
FG
FK
FM
FP
FR
FT
FV
FX
FZ
HE
HG
HK
HM
HP
HR
HT
HB
HV
HX
HZ
JE
JG
JK
JM
JP
JR
JT
JV
JX
JZ
XE
XG
XK
XM
XP
XR
XT
XB
XV
XX
XZ
TE
TG
TK
TB
TM
TP
TR
TT
TV
TX
TZ
YE
YG
YK
KE
KG
KK
KM
KP
KR
KT
KV
KX
KZ
LE
LG
LK
LM
LP
LR
LT
LB
LV
LX
LZ
ME
MG
MK
MM
MP
MR
MT
MV
MX
MZ
NE
NG
NK
NM
NP
NR
NT
NB
NV
NX
NZ
PE
PG
PK
PB
PM
PP
PR
PT
PV
PX
PZ
Maximum
Reverse
Leakage IR
@VRWM
IT (mA)
(uA)
Breakdown Voltage VBR @IT
Min (V)
Max (V)
6.40
6.67
7.22
7.78
8.33
8.89
9.44
10.00
11.10
12.20
13.30
14.40
15.60
16.70
17.80
18.90
20.00
21.10
22.20
24.40
26.70
28.90
31.10
33.30
36.70
40.00
44.40
47.80
50.00
53.30
56.70
60.00
64.40
66.70
71.10
77.80
83.30
86.70
88.80
94.40
100.00
111.00
122.00
133.00
144.00
155.00
167.00
178.00
189.00
200.00
211.00
224.00
246.00
279.00
335.00
391.00
7.00
7.37
7.98
8.60
9.21
9.83
10.40
11.10
12.30
13.50
14.70
15.90
17.20
18.50
19.70
20.90
22.10
23.30
24.50
26.90
29.50
31.90
34.40
36.80
40.60
44.20
49.10
52.80
55.30
58.90
62.70
66.30
71.20
73.70
78.60
86.00
92.10
95.80
97.60
104.00
111.00
123.00
135.00
147.00
159.00
171.00
185.00
197.00
209.00
220.00
232.00
247.00
272.00
309.00
371.00
432.00
10
10
10
10
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
400
400
250
100
50
25
10
5
2.5
2.5
2.5
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
Working
Peak
Reverse
Voltage
VRWM
(V)
5.0
6.0
6.5
7.0
7.5
8.0
8.5
9.0
10.0
11.0
12.0
13.0
14.0
15.0
16.0
17.0
18.0
19.0
20.0
22.0
24.0
26.0
28.0
30.0
33.0
36.0
40.0
43.0
45.0
48.0
51.0
54.0
58.0
60.0
64.0
70.0
75.0
78.0
80.0
85.0
90.0
100.0
110.0
120.0
130.0
140.0
150.0
160.0
170.0
180.0
190.0
200.0
220.0
250.0
300.0
350.0
Maximum Maximum
Clamping
Reverse
Voltage VC
Surge
Current IPP
@IPP
(A)
(V)
21.74
19.42
17.86
16.67
15.50
14.71
13.89
12.99
11.76
10.99
10.05
9.30
8.62
8.20
7.69
7.25
6.85
6.54
6.17
5.63
5.14
4.75
4.41
4.13
3.75
3.44
3.10
2.88
2.75
2.58
2.43
2.30
2.14
2.07
1.94
1.77
1.65
1.59
1.55
1.46
1.37
1.23
1.13
1.04
0.96
0.89
0.82
0.77
0.73
0.68
0.65
0.62
0.56
0.50
0.41
0.36
9.2
10.3
11.2
12.0
12.9
13.6
14.4
15.4
17.0
18.2
19.9
21.5
23.2
24.4
26.0
27.6
29.2
30.6
32.4
35.5
38.9
42.1
45.4
48.4
53.3
58.1
64.5
69.4
72.7
77.4
82.4
87.1
93.6
96.8
103.0
113.0
121.0
126.0
129.0
137.0
146.0
162.0
177.0
193.0
209.0
224.0
243.0
259.0
275.0
292.0
308.0
324.0
356.0
405.0
486.0
567.0
1. The available parts are "A" type only,the parts without A(V BR is ±10%) is not available
2. Add suffix 'C 'or ' CA ' after part number to specify Bi-directional devices
3. For Bi-Directional devices having VR of 10 volts and under, the IR limit is double
www.dowosemi.cn
P. 3
很抱歉,暂时无法提供与“SMF24CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.17032
- 200+0.13241
- 600+0.11135
- 3000+0.09342
- 9000+0.08241
- 21000+0.07658
- 国内价格
- 10+0.15397
- 100+0.15166
- 600+0.10265
- 1200+0.10111
- 3000+0.08695
