TVS/ESD
Arrays
RLSD92Q051LC Series
Circuit Protection
System
Revision:DEC-16
Please refer to http://www.ruilon.com.cn for current information.
TVS/ESD Arrays - RLSD92Q051LC Series
Features
• 90 Watts Peak Pulse Power per Line (tp = 8/20μs)
• Working voltages: 5V
• Low Leakage Current
• Low operating and clamping voltages
• Lead Free/RoHS compliant
• Solid-state silicon avalanche technology
• Provides ESD protection to IEC61000-4-2(ESD):
±24kV (air discharge)
±8kV (contact discharge)
Mechanical Characteristics
Pinout and Functional Block Diagram
• SOD-882 package
• Molding compound flammability rating: UL 94V-0
• Quantity Per Reel :10,000pcs
• Reel Size : 7 inch
• Lead Finish : Lead Free
Applications
• Video I/O ports protection
• Set Top Boxes
• Portable Instrumentation
• Notebooks, Desktops, and Servers
• Pagers Peripherals
Part Number Code
R
L
LOGO
S
D
9
Package
2
Q
VRWM:5V
1
L
Low
Capacitance
SOD-882
C
V= Unidirectional
C= Bidirectional
Protects 1
Lines
Circuit Protection
System
Revision:DEC-16
Page:1
Absolute Maximum Rating
Rating
Symbol
Value
Units
Ppk
90
Watts
ESD Voltage (Contact)
VESD
±8
Kv
ESD Voltage (Air)
VESD
±15
Kv
Lead Soldering Temperature
TL
260 (10 sec.)
°C
Operating Temperature
TJ
-55 to +125
°C
TSTG
-55 to +150
°C
Peak Pulse Power (tp =8/20μs)
Storage Temperature
Electrical Parameters (T=25°C)
Electrical Characteristics(@ 25°C Unless Otherwise Specified)
Reverse
Stand-Off
Voltage
Minimum
Breakdown
Voltage
Peak Pulse
Voltage
@8/20μS
Peak Pulse
Current
@8/20μS
Reverse
Leakage
@VRWM
VRWM
VBR@1mA
VC@1A
IPP
IR@VRWM
V
V
V
A
μA
pF
5
6
9.8
3
1
1
Type Number
RLSD92Q051LC
Circuit Protection
System
Typical
Capacitance
DC=0V
CJ@ 1 MHz
Revision:DEC-16
Please refer to http://www.ruilon.com.cn for current information. Page:2
Typical Characteristics
Circuit Protection
System
Revision:DEC-16
Page:3
Recommended Soldering Conditions
Profile Feature
Pb-Free Assembly
Average ramp-up rate (TL to TP)
3°C/second max.
Preheat
-Temperature Min (TS min)
-Temperature Max (TS max)
-Time (min to max) (ts)
TS max to TL
-Ramp-up Rate
Time maintained above:
-Temperature (TL)
-Time (tL)
150°C
200°C
60-180 seconds
3°C/second max.
217°C
60-150 seconds
Peak Temperature (TP)
260°C
Time within 5°C of actual Peak Temperature (tP)
Ramp-down Rate
Time 25°C to Peak Temperature
Circuit Protection
System
20-40 seconds
6°C/second max.
8 minutes max.
Revision:DEC-16
Please refer to http://www.ruilon.com.cn for current information. Page:4
Package dimension SOD-882
Dimensions(Millimeters)
Symbol
Min
Nom
Max
A
0.45
0.55
A1
0.01
0.05
A3
D
0.951
1.05
E
0.55
0.65
0.65
b
0.200
0.25
0.30
L
0.450
0.50
0.55
e
Circuit Protection
System
0.150Ref
0.65 BSC
Revision:DEC-16
Page:5
很抱歉,暂时无法提供与“RLSD92Q051LC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 100+0.15537
- 1000+0.14667
- 国内价格
- 10+0.12744
- 100+0.10152
- 300+0.08856
- 1000+0.07884
- 5000+0.07107
- 10000+0.06718
