TVS/ESD Arrays
RLSD32AXX1LC
Features
l
l
l
l
l
l
300 Watts Peak Pulse Power per Line (tp = 8/20μs)
Bidirectional Configuration
Protects One Power or I/O Port
ESD Protection > 40 kilovolts
Low Clamping Voltages
Ultra Low Capacitance: 1.0 pF Typical
SOD-323
Electrical symbol
1
Applications
l
l
l
l
l
Ethernet - 10/100/1000 Base T
Cellular Phones
Handheld - Wireless Systems
Personal Digital Assistant (PDA)
USB Interface
2
Part Number Code
R
L
S
D
3
2
Package
LOGO
A
Straight foot
overhanging
SOD-323
1
L
C
Protects 1 Lines
V= Unidirectional
C= Bidirectional
VRWM:5V
Low
Capacitance
Absolute Maximum Rating
Rating
Symbol
Value
Units
Peak Pulse Power (tp =8/20μs)
PPP
300
Watts
ESD Voltage (Contact)
VESD
±8
kV
ESD Voltage (Air)
VESD
±15
kV
Operating Temperature
TOPT
-55 to 150
°C
Storage Temperature
TSTG
-55 to 150
°C
Electrical Characteristics
(@ 25°C Unless Otherwise Specified)
Reverse
Stand-Off
Voltage
Minimum
Breakdown
Voltage
Peak Pulse
Voltage
@8/20μS
Reverse
Leakage
@VRWM
Typical
Capacitance
VRWM
VBR @1mA
VC@1A
(max.)
@IPP
IR@VRWM
DC=0V
CJ@ 1 MHz
V
V
V
V
A
μA
pF
RLSD32A051LC
5.0
6.0
9.8
1
RLSD32A081LC
8.0
8.5
13.4
25
15
1
1
RLSD32A121LC
12.0
13.3
19.0
30
8
1
1
RLSD32A151LC
15.0
16.7
24.0
40
6
1
1
RLSD32A241LC
24.0
26.7
43.0
60
3
1
1
VC
@8/20μS
Type Number
Specifications are subject to change without notice.
Please refer to http://www.ruilon.com.cn for current information.
Revised: 2021-02-07
Page:1
TVS/ESD Arrays
RLSD32AXX1LC
Electrical Parameters (T=25°C)
Symbol
I
Parameter
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
VRWM
Ipp
Working Peak Reverse Voltage
IR
VBR
IT
IR
VC VBR VRWM
Maximum Reverse Leakage Current @ VRWM
IR
IT
Breakdown Voltage @ IT
IT
Test Current
IF
Forward Current
VF
Forward Voltage @ IF
VRWM VBR VC
V
Ipp
Characteristic Curves
8/20μs Pulse Waveform
Fig2.ESD Pulse Waveform (according to IEC61000-4-2)
120
tr
100
Test
Waveform
Parameters
tr=8μS
td=20μS
Peak Value Ipp
80
Percent of Peak Pulse Current%
Ipp-Peak Pulse Current-%of Ipp
Fig 1.
60
40
td=t
Ipp/2
100%
90%
10%
0.7~1ns
Time(ns)
10
15
30
t-Time(μS)
Figure 4.ESD Clamping(8KV Contact per IEC61000-4-2)
Fig 3. Power Derating Curve
Tek Run:5.00GS/s
Sample we05s
Percent of Rated Power for IPP
110
100
90
80
70
60
50
40
30
R1
50
75
100
125
150
Ch1 5.00mV
M10.0ns Ch1 1.36V
Ambient Temperature-TA(°C)
Revised: 2021-02-07
Page:2
TVS/ESD Arrays
RLSD32AXX1LC
Dimensions
Millimeters
Inches
DIM
Min
Max
Min
Max
A
1.60
1.80
0.063
0.071
B
0.25
0.35
0.010
0.014
C
2.50
2.70
0.098
0.106
D
0.00
1.00
0.00
0.039
E
1.20
1.40
0.047
0.055
F
0.08
0.15
0.003
0.006
L
0.475REF
0.019REF
L1
0.25
0.40
0.010
0.016
H
0.00
0.10
0.00
0.004
Part Number
Component
package
Quantity
Reel Size
Molding
compound
flammability rating
Lead Finish
RLSD32A051LC
SOD-323
3000
7 inch
UL 94V-0
Lead Free
Mounting PAD (mm)
Soldering Parameters - Reflow Soldering (Surface Mount Devices)
Reflow Condition
TP
Ramp-up
Critical Zone
TL to TP
TL
Pre
Heat
Temperature
TS(max)
Ramp-down
TS(min)
Preheat
Time to peak temperature
(t 25℃ to peak)
150°C
-Temperature Max (Ts(max))
200°C
- Time (min to max) (ts)
60 -180 Seconds
3°C/second max
TS(max) to TL - Ramp-up Rate
3°C/second max
Time
-Temperature Min (Ts(min))
Average ramp up rate ( Liquids
Temp TL) to peak
Reflo
w
25
Pb - Free assembly
- Temperature (TL)
(Liquids)
217°C
60 -150 Seconds
Peak Temperature (TP)
260 +0/-5°C
Time within 5°C of actual peak
Temperature (tp)
20 - 40 Seconds
Ramp-down Rate
6°C/second max
Time 25°C to peak Temperature (TP)
8 minutes Max
Do not exceed
280°C
Revised: 2021-02-07
Page:3
很抱歉,暂时无法提供与“RLSD32A151LC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.52537
- 50+0.41340
- 150+0.35741
- 500+0.31542
- 3000+0.28188
- 6000+0.26507
- 国内价格
- 20+0.50999
- 200+0.47599
- 600+0.44199
- 3000+0.40799
