Revision: A
Date: 2018-04-24 Page
No.: 1 OF 1
PPTC RESETTALBE
电路保护元器件专业制造商
FUSES
TRF(250V) Series
Features
◆ Radial Leaded Devices
◆ Cured, flame retardant epoxy polymer insulating material meets UL 94V-0
requirements ◆ Bulk Package, or tape and reel
available on most models
◆ UL(Pending), C-UL(Pending), TUV(R50322002)
◆ RoHS, Reach, HF compliance
Applications
Almost anywhere there is a low voltage power
supply, up to DC60V and a load to be protected,
including: ◆ Security and fire alarm systems
◆ Analog and digital line cards
◆ Modems and DSL
电气特性 :
保持电流
跳脱电流
最大电压
最大电流 最大冲击电压
最大动作时间
IT, (A)
V max, (V)
I max, (A)
V max, (V)
(A)
(Sec.)
消耗功率
0.020
0.045
60
3.0
250
0.10
3.0
1.0
TRF004
0.040
0.080
60
3.0
250
0.20
3.0
TRF006
0.060
0.120
60
3.0
250
0.30
3.0
TRF008
0.080
0.160
60
3.0
250
0.35
TRF009
0.090
0.220
60
3.0
250
TRF011
0.110
0.220
60
3.0
250
TRF012
0.120
0.240
60
3.0
TRF012U
0.120
0.240
60
TRF014
0.145
0.29
60
TRF014U
0.145
0.29
TRF018
0.180
TRF018U
0.180
TRF020
0.200
电阻范围(Ω)
P/N
IH, (A)
TRF002
Pd typ, (W) R min,
R max, R1 max,
65
145
1.0
24
65.0
97.5
1.0
22.0
36.0
56.0
4.0
1.0
14.0
22.0
33.0
1.00
1.0
1.0
9.7
20.6
33.0
1.00
1.0
1.0
6.0
12.0
18.0
250
1.00
3.0
1.0
6.0
10.0
16.0
3.0
250
1.00
1.5
1.0
6.0
10.0
16.0
3.0
250
1.00
2.5
1.0
3.0
6.0
14.0
60
3.0
250
1.0
2.5
1.0
3.5
6.5
12.0
0.54
60
3.0
250
3.0
1.5
1.8
1.0
2.2
4.0
0.54
60
3.0
250
3.0
1.5
1.8
1.0
2.2
4.0
0.6
60
3.0
250
3.0
5.0
1.8
1.7
3.5
6.30
240
TRF030
0.300
0.60
60
3.0
250
3.0
6.0
1.8
1.0
2.2
3.50
TRF040
0.400
0.800
60
5.5
250
3.0
8
1.8
0.80
1.60
3.20
TRF050
0.500
1.00
60
6.0
250
3.0
10
3.0
0.56
1.40
2.52
TRF060
0.600
1.20
60
7.0
250
3.0
12
3.2
0.40
1.10
2.16
TRF080
0.800
1.60
60
8.0
250
4.0
18
3.6
0.32
0.80
1.44
TRF100
1.000
2.00
60
10.0
250
5.0
21
2.9
0.22
0.50
1.45
TRF150
1.500
3.00
60
15.0
250
7.50
25.0
3.5
0.12
0.28
0.68
TRF200
2.000
4.00
60
20.0
250
10.0
28
4.5
0.09 0.192 0.42
产品尺寸 (U nit: mm) :
Max. working voltage:
A=16V
B=30V
C=60/72V
E=90/120V
F=250V
G=600V
M=265V
X
012
Manufacturer's Trademark
Packaging Options:
“ - ” Bulk package
“ -T ” Tape & Reel
XX
Lot No
Style1
Style2
Style3
TEL: 86-0769-3892 0554
FAX: 86-0769-8793 2077
E-mail:sales@tlcet.com.cn
Address:No.18,5th GaoLi Road,TangXia Town,DongGuan,GuangDong,P.R China 523710
Holding current:0.12A
Revision: A
No.: 1 OF 2
PPTC RESETTALBE
电路保护元器件专业制造商
FUSES
TRE(90/120V) Series
A
B
C
D
E
物理特性
P/N
LeadΦ(mm) Material(材料)
Max.(最大)
Max.(最大)
Typ.(标准)
Min.(最小)
Max.(最大)
Style(样式)
TRF002
7.4
12.7
5.1
7.6
4.5
1
0.50
CP
TRF004
5.8
9.9
5.1
7.6
4.5
1
0.50
CP
TRF006
5.8
9.9
5.1
7.6
4.5
1
0.60
CP
TRF008
7.4
12.7
5.1
7.6
4.5
1
0.60
CP
TRF009
7.4
12.7
5.1
7.6
4.5
1
0.60
CP
TRF011
6.5
11.0
5.1
5.0
4.5
2
0.60
CP
TRF012
6.8
12.0
5.1
7.6
4.5
2
0.60
CP
TRF012U
6.8
12.0
5.1
7.6
4.5
2
0.60
CP
TRF014
6.5
11.0
5.1
5.0
4.5
2
0.60
CP
CP
CP
TRF014U
6.0
10.0
5.1
4.7
4.5
2
0.60
TRF018
10.2
14.5
5.1
7.6
4.5
1
0.60
TRF018U
10.2
14.5
5.1
7.6
4.5
1
0.60
CP
TRF020
10.5
17.0
5.1
7.6
4.5
1
0.60
CU
TRF030
11.0
16.8
5.1
7.6
4.5
1
0.60
CU
TRF040
11.7
17.0
5.1
7.6
3.8
1
0.60
CU
TRF050
13.0
18.0
5.1
7.6
3.8
2
0.60
CU
TRF060
14.0
19.5
5.1
7.6
3.8
2
0.60
CU
TRF080
16.3
21.3
5.1
7.6
3.8
3
0.80
CU
TRF100
17.8
22.9
5.1
7.6
3.8
3
0.80
CU
TRF150
20.8
29.8
10.2
7.6
3.8
3
0.80
CU
TRF200
28.4
33.5
10.2
7.6
3.8
3
0.80
CU
环境温度与工作电流关系特性曲线 :
工作环境温度
P/N
-40℃
-20℃
0℃
25℃
40℃
50℃
60℃
70℃
85℃
TRF002
0.031
0.028
0.023
0.020
0.017
0.015
0.013
0.011
0.008
TRF004
0.062
0.055
0.048
0.040
0.033
0.029
0.026
0.022
0.017
TRF006
0.093
0.075
0.071
0.060
0.050
0.044
0.038
0.033
0.025
TRF008
0.124
0.110
0.095
0.080
0.066
0.059
0.051
0.044
0.033
TRF009
0.140
0.124
0.110
0.090
0.075
0.068
0.058
0.050
0.038
TRF011
0.171
0.151
0.131
0.110
0.091
0.081
0.071
0.061
0.046
TRF012(U)
0.186
0.165
0.143
0.120
0.099
0.088
0.077
0.066
0.050
TRF014(U)
0.225
0.199
0.172
0.145
0.119
0.106
0.093
0.080
0.060
TRF018(U)
0.269
0.240
0.211
0.180
0.153
0.138
0.123
0.109
0.087
TRF020
0.310
0.275
0.237
0.200
0.165
0.147
0.128
0.110
0.082
TRF030
0.465
0.413
0.356
0.300
0.248
0.221
0.192
0.165
0.123
TRF040
0.620
0.550
0.475
0.400
0.330
0.295
0.255
0.220
0.165
TRF050
0.775
0.688
0.594
0.500
0.412
0.366
0.319
0.275
0.206
TRF060
0.930
0.825
0.710
0.600
0.495
0.443
0.393
0.330
0.246
TRF080
1.240
1.100
0.950
0.800
0.660
0.590
0.510
0.440
0.330
TRF100
1.550
1.38
1.19
1.00
0.83
0.74
0.64
0.55
0.41
TRF150
2.400
2.00
1.80
1.50
1.20
1.10
0.90
0.80
0.60
TRF200
3.100
2.75
2.38
2.00
1.65
1.48
1.28
1.10
0.83
Revision: A
No.: 1 OF 3
PPTC RESETTALBE
FUSES
电路保护元器件专业制造商
TRE(90/120V) Series
动作电流时间曲线表 :
The Time to Trip curves represent typical performance
of a device in a simulated application environment.
Actual performance in specific customer applications
may differ from these values due to the influence of
other variables.
标准包装数量 :
Model
Q’t y/bag
TRF002-TRF040
1000pcs
TRF050-TRF100
500pcs
TRF200
200pcs
Tape and Reel Specifications
Devices taped using EIA468–B/IEC286-2 standards.
6、Agency Recognition:
Caution:Operation beyond the rated voltage or current may result in rupture electrical arcing or flame.Specifications are
subject to change without notice.
很抱歉,暂时无法提供与“TRF050”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.95105
- 10+0.76443
- 30+0.67112
- 100+0.60113
- 500+0.54519
- 1000+0.51711
- 国内价格
- 1+0.86299
- 10+0.69364
- 30+0.60897
- 100+0.54547
