Revision: A
Date: 2018-04-24 Page
No.: 1 OF 1
PPTC RESETTALBE
电路保护元器件专业制造商
FUSES
TRA(16V) Series
Features
◆ Radial Leaded Devices
◆ Cured, flame retardant epoxy polymer insulating material meets UL 94V-0 requirements
◆ Bulk Package, or tape and reel available on most models
◆ UL(Pending), C-UL(Pending), TUV(R50322003)
◆ RoHS, Reach, HF compliance
Applications
Almost anywhere there is a low voltage power supply,
up to 16V and a load to be protected, including:
◆ Personal computer
◆ Toys
◆ Medical electronics
◆ Personal care product
电气特性 :
保持电流
跳脱电流
最大电压
最大电流
最大动作时间
IH, (A)
IT, (A)
V max, (V)
I max, (A)
(A)
(Sec.)
Pd typ, (W)
消耗功率
R min,
电阻范围(Ω)
R max,
R1max,
TRA005
0.05
0.10
16
40
0.25
5.0
0.26
8.00
11.50
17.00
TRA010
0.10
0.20
16
40
0.50
4.0
0.35
2.00
4.50
6.70
TRA017
0.17
0.34
16
40
0.85
3.0
0.36
0.980
1.800
2.700
TRA020
0.20
0.40
16
40
1.00
3.0
0.36
0.780
1.600
2.200
TRA025
0.25
0.50
16
40
1.25
3.0
0.36
0.500
1.100
1.650
P/N
TRA030
0.30
0.60
16
40
1.50
3.0
0.36
0.350
0.700
1.050
TRA040
0.40
0.80
16
40
2.00
3.0
0.40
0.230
0.650
0.970
TRA050
0.50
1.00
16
40
2.50
3.0
0.45
0.170
0.400
0.810
TRA065
0.65
1.30
16
40
3.25
3.0
0.45
0.110
0.300
0.450
0.260
TRA075
0.75
1.50
16
40
3.75
3.0
0.54
0.080
0.230
TRA090
0.90
1.80
16
40
4.50
3.2
0.54
0.070
0.180
0.210
TRA110
1.10
2.20
16
40
5.50
4.0
0.54
0.045
0.140
0.170
TRA120
1.20
2.40
16
40
6.00
4.0
0.54
0.040
0.120
0.160
TRA135
1.35
2.70
16
40
6.75
4.0
0.54
0.035
0.100
0.140
TRA160
1.60
3.20
16
40
8.00
4.5
0.54
0.030
0.100
0.110
TRA185
1.85
3.70
16
40
9.25
4.5
0.54
0.030
0.080
0.100
TRA200
2.00
4.00
16
40
10.0
5.0
0.90
0.020
0.065
0.090
TRA250
2.50
5.00
16
40
12.5
5.0
0.90
0.015
0.050
0.070
TRA300
3.00
6.00
16
40
15.0
4.0
0.90
0.010
0.040
0.055
TRA400
4.00
8.00
16
40
20.0
3.0
1.35
0.010
0.030
0.045
TRA500
5.0
10.0
16
100
25.0
5.0
2.6
0.009
0.027
0.033
TRA600
6.0
12.0
16
100
30.0
7.0
2.8
0.007
0.021
0.031
TRA700
7.0
14.0
16
100
35.0
8.0
3.0
0.006
0.015
0.020
TRA800
8.0
16.0
16
100
40.0
9.0
3.0
0.004
0.013
0.018
TRA900
9.0
18.0
16
100
45.0
12.0
3.3
0.003
0.012
0.016
TRA1000
10.0
20.0
16
100
50.0
12.5
3.7
0.002
0.011
0.015
TRA1100
11.0
22.0
16
100
55.0
13.5
3.7
0.002
0.010
0.013
TRA1200
12.0
24.0
16
100
60.0
15.0
4.2
0.002
0.009
0.012
TRA1300
13.0
26.0
16
100
65.0
18.0
4.2
0.002
0.008
0.011
TRA1400
14.0
28.0
16
100
70.0
20.0
4.2
0.002
0.008
0.011
TEL: 86-0769-3892 0554
FAX: 86-0769-8793 2077
E-mail:sales@tlcet.com.cn
Address:No.18,5th GaoLi Road,TangXia Town,DongGuan,GuangDong,P.R China 523710
Revision: A
No.: 1 OF 2
PPTC RESETTALBE
电路保护元器件专业制造商
FUSES
TRA(16V) Series
产品尺寸 (Unit: mm) :
Manufacturer's Trademark
A500
XX
A 090
XX
Max. working voltage:
A=16V
B=30V
C=60/72V
E=90/120V
F=250V
G=600V
M=265V
X
090
Packaging Options:
“ - ” Bulk package
“ -T ” Tape & Reel
XX
Lot No
Style1
Holding current:0.90A
Style2
A
B
C
D
E
物理特性
P/N
LeadΦ(mm) Material(标准)
Max.(最大)
Max.(最大)
Typ.(标准)
Min.(最小)
Max.(最大)
Style(样式)
TRA005
5.7
10.5
5.1
7.6
3.1
1
0.50
CP
TRA010
5.7
10.5
5.1
7.6
3.1
1
0.50
CP
TRA017
5.7
10.5
5.1
7.6
3.1
1
0.50
CP
TRA020
5.7
10.5
5.1
7.6
3.1
1
0.50
CP
TRA025
5.7
10.5
5.1
7.6
3.1
1
0.50
CP
TRA030
5.7
10.5
5.1
7.6
3.1
1
0.50
CP
TRA040
5.7
10.5
5.1
7.6
3.1
1
0.50
CP
TRA050
5.7
10.5
5.1
7.6
3.1
1
0.50
CP
TRA065
6.5
13.2
5.1
7.6
3.1
1
0.50
CP
TRA075
6.5
13.2
5.1
7.6
3.1
1
0.50
CP
TRA090
7.4
13.0
5.1
7.6
3.1
1
0.50
CP
TRA110
7.4
13.0
5.1
7.6
3.1
1
0.50
CP
TRA120
7.4
13.0
5.1
7.6
3.1
1
0.50
CP
TRA135
9.4
14.5
5.1
7.6
3.1
1
0.50
CP
TRA160
9.4
14.5
5.1
7.6
3.1
1
0.50
CP
TRA185
9.4
14.5
5.1
7.6
3.1
1
0.50
CP
TRA200
10.7
16.7
5.1
7.6
3.1
1
0.60
Cu
Cu
TRA250
10.7
16.7
5.1
7.6
3.1
1
0.60
16.7
5.1
7.6
3.1
1
0.60
Cu
Cu
TRA300
10.7
TRA400
11.5
17.9
5.1
7.6
3.1
1
0.60
TRA500
13.0
18.3
5.1
7.6
3.1
2
0.80
Cu
TRA600
13.0
18.3
5.1
7.6
3.1
2
0.80
Cu
5.1
7.6
3.1
2
0.80
Cu
Cu
TRA700
16.3
21.3
TRA800
17.8
22.9
5.1
7.6
3.1
2
0.80
7.6
3.1
2
0.80
Cu
Cu
TRA900
21.3
26.4
5.1
TRA1000
21.3
26.4
5.1
7.6
3.1
2
0.80
TRA1100
20.8
29.8
10.2
7.6
3.1
2
0.80
Cu
TRA1200
20.8
29.8
10.2
7.6
3.1
2
0.80
Cu
TRA1300
24.2
32.9
10.2
7.6
3.1
2
0.80
Cu
TRA1400
24.2
32.9
10.2
7.6
2
0.80
Cu
3.1
PPTC RESETTALBE
电路保护元器件专业制造商
FUSES
Revision: A
No.: 1 OF 3
TRA(16V) Series
环境温度与工作电流关系特性曲线 :
工作环境温度
P/N
85℃
-40℃
-20℃
0℃
25℃
40℃
50℃
60℃
70℃
TRA005
0.08
0.07
0.06
0.05
0.04
0.04
0.03
0.03
0.02
TRA010
0.17
0.15
0.13
0.10
0.07
0.06
0.05
0.04
0.03
TRA017
0.27
0.24
0.21
0.17
0.14
0.12
0.09
0.07
0.05
TRA020
0.32
0.28
0.25
0.20
0.16
0.14
0.12
0.10
0.07
TRA025
0.40
0.34
0.29
0.25
0.20
0.17
0.15
0.13
0.09
TRA030
0.47
0.41
0.36
0.30
0.24
0.21
0.18
0.14
0.10
TRA040
0.62
0.53
0.46
0.40
0.31
0.28
0.23
0.20
0.16
0.19
TRA050
0.77
0.67
0.58
0.50
0.40
0.34
0.30
0.25
TRA065
1.00
0.87
0.75
0.65
0.51
0.45
0.40
0.34
0.22
TRA075
1.04
0.94
0.83
0.75
0.61
0.54
0.46
0.41
0.29
TRA090
1.39
1.22
1.07
0.90
0.72
0.63
0.53
0.45
0.33
TRA110
1.61
1.43
1.24
1.10
0.89
0.83
0.74
0.66
0.56
TRA120
1.76
1.56
1.35
1.20
0.97
0.91
0.81
0.72
0.61
TRA135
1.98
1.75
1.54
1.35
1.08
1.01
0.89
0.78
0.67
TRA160
2.30
2.06
1.82
1.60
1.33
1.20
1.05
0.96
0.78
TRA185
2.68
2.41
2.13
1.85
1.53
1.40
1.23
1.13
0.93
TRA200
3.14
2.70
2.28
2.00
1.80
1.72
1.34
1.23
1.03
TRA250
3.63
3.25
2.88
2.50
2.08
1.93
1.70
1.53
1.30
TRA300
4.34
3.87
3.42
3.00
2.49
2.28
2.02
1.82
1.52
TRA400
5.78
5.15
4.58
4.00
3.28
3.04
2.68
2.42
2.07
TRA500
7.23
6.44
5.73
5.00
4.10
3.80
3.35
3.03
2.59
TRA600
10.12
9.01
8.02
7.00
5.74
5.32
5.25
4.24
3.62
TRA700
10.12
9.01
8.02
7.00
5.74
5.32
5.25
4.24
3.62
TRA800
11.56
10.30
9.16
8.00
6.56
6.08
5.36
4.84
4.14
TRA900
13.00
11.58
10.30
9.00
7.38
6.84
5.36
4.84
4.14
TRA1000
14.45
12.88
11.45
10.00
8.20
7.60
6.70
6.05
5.18
TRA1100
15.89
14.16
12.60
11.0
9.02
8.36
7.37
6.66
5.69
TRA1200
17.34
15.45
13.74
12.00
9.84
9.12
8.04
7.26
6.21
TRA1300
18.79
16.74
14.89
13.00
12.66
9.88
8.71
7.87
6.73
TRA1400
20.23
18.03
16.03
14.00
15.31
10.64
9.38
8.47
7.25
动作电流时间曲线表 :
PPTC RESETTALBE
FUSES TLS/
电路保护元器件专业制造商
Revision: A
No.: 1 OF 4
TRA(16V) Series
标准包装数量 :
Model
Q’t y/bag
TRA005-TRA500
1000pcs
TRA600-TRA800
500pcs
TRA900-TRA1400
200pcs
Tape and Reel Specifications
Devices taped using EIA468–B/IEC286-2 standards.
6、Agency Recognition:
Caution:Operation beyond the rated voltage or current may result in rupture electrical arcing or flame.Specifications are
subject to change without notice.
很抱歉,暂时无法提供与“TRA250”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.54616
- 50+0.43416
- 150+0.37822
- 1000+0.32454
- 2000+0.29096
- 5000+0.27411
