MBR3020CT THRU MBR30100CT
Reverse Voltage - 20 to 100 Volts
Forward Current - 30.0 Ampere
SCHOTTKY BARRIER RECTIFIER
Features
TO-220AB
The plastic package carries Underwriters
Laboratory Flammability Classification 94V-0
Construction utilizes void-free
molded plastic technique
Low reverse leakage
High forward surge current capability
High temperature soldering guaranteed:
250°C,0.25”(6.35mm) from case for 10 seconds
0.185(4.70)
0.175(4.44)
0.154(3.91)
DIA
0.148(3.74)
0.415(10.54)
MAX
0.057(1.45)
0.051(1.30)
0.113(2.87)
0.103(2.62)
0.145(3.68)
0.135(3.43)
0.410(10.41)
0.390(9.91)
PIN
1
0.560(14.2)
0.530(13.4)
0.350(8.89)
0.330(8.38)
0.635(16.13)
0.625(15.87)
1.148(29.16)
1.118(28.40)
0.160 (4.05)
0.140 (3.55)
0.110(2.79)
0.100(2.54)
0.590(14.22)
0.530(13.46)
Mechanical Data
0.037(0.94)
0.027(0.68)
0.105 (2.67)
0.095 (2.41)
0.105 (2.67)
0.095 (2.41)
Case : JEDEC TO-220AB Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.080 ounce, 2.24 grams
0.205 (5.20)
0.195 (4.95)
0.022(0.58)
0.014(0.35)
PIN 1
PIN 2
PIN 3
CASE
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25°C ambient temperature unlss otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
MBR
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward
rectified current (see fig.1)
Peak forward surge
current 8.3ms single half
sine-wave
MBR
MBR
MDD
MBR
MDD
MBR
UNITS
3020CT 3030CT 3040CT 3045CT 3050CT 3060CT 3070CT 3080CT 3090CT 30100CT
V RMM
V RMS
V DC
21
30
40
28
40
45
32
45
50
35
50
60
42
60
70
49
70
80
56
80
90
63
90
100
70
100
V
V
V
I(AV)
30.0
A
IFSM
250
A
Maximum instantaneous forward voltage at 15.0A
Maximum DC reverse current
TA=25℃
at rated DC blocking voltage
TA=100℃
VF
0.55
IR
Typical junction capacitance (NOTE 1)
Typical thermal resistance (NOTE 2)
CJ
15.0
750
R θJC
Operating junction temperature range
TJ
storage temperature range
MBR
MDD MDD MDD MDD MDD MDD MDD MDD
MBR MBR MBR MBR MBR MBR MBR MBR
Marking Code
Maximum repetitive peak reverse voltage
SYMBOLS 3020CT 3030CT 3040CT 3045CT 3050CT 3060CT 3070CT 3080CT 3090CT 30100CT
T STG
0.75
1.0
0.85
50.0
500
2.0
-65 to +125
V
mA
pF
℃/W
-65 to +150
-65 to +150
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.Thermal resistance from junction to case.
DN:T19826A0
https://www.microdiode.com
Rev:2019A0
Page :1
FIG. 1- FORWARD CURRENT DERATING CURVE
30
24
18
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
12
6
MBR3020CT-MBR3045CT
MBR3050CT-MBR30100CT
50
75
100
125
150
PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
Ratings And Characteristic Curves
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
300
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
250
200
150
100
175
50
1
10
AMBIENT TEMPERATURE, C
INSTANTANEOUS FORWARD
CURRENT,AMPERES
250
50
TJ=25 C
PULSE WIDTH=300 µs
1%DUTY CYCLE
0.5
MBR3020CT-MBR3045CT
MBR3050CT-MBR3060CT
MBR3070CT-MBR30100CT
0.05
0.2
0.4
0.6
0.8
1.0
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
INSTANTANEOUS REVERSE CURRENT,
MILLIAMPERES
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
5
1.1
100
10
TJ=100 C
1
TJ=75 C
0.1
0.01
60
80
100
2000
TJ=25 C
100
MBR3020CT-MBR3045CT
TRANSIENT THERMAL IMPEDANCE,
C/W
PERCENT OF PEAK REVERSE VOLTAGE,%
FIG. 5-TYPICAL JUNCTION CAPACITANCE
JUNCTION CAPACITANCE, pF
TJ=25 C
0.001
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
1000
100
NUMBER OF CYCLES AT 60 Hz
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
100
10
1
0.1
0.01
0.1
1
10
100
10
0.1
1.0
10
REVERSE VOLTAGE,VOLTS
100
t,PULSE DURATION,sec.
The curve above is for reference only.
Rev:2019A0
Page :2
很抱歉,暂时无法提供与“MBR3045CT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+1.12491
- 1000+1.10006
