1SMAF4733A
1SMAF4733A
    MDD(辰达半导体)
    SMAF
    PD=1.0W,VF=1.5V,VZ=5.1V 消费电子、PC、工控、通讯、汽车、智能控制
1SMAF4733A 数据手册
1SMAF4728A THRU 1SMAF4777A Zener Voltage - 3.3 to 330 Volts Peak Pulse Power - 1.0 W SURFACE MOUNT ZENER DIODE Features SMAF  Small plastic package suitable for surface mounted design. 0.106(2.70) 0.094(2.40) 0.063 (1.60) 0.051 (1.30) Mechanical Data 0.146(3.70) 0.130(3.30) Case : JEDEC SMAF Molded plastic body Terminals : Solder plated, solderable per MIL-STD-750,Method 2026 Polarity : Polarity symbol marking on body Mounting Position : Any Weight : 0.002ounce, 0.07grams 0.047(1.20) 0.035(0.90) 0.008(0.20) 0.005(0.12) 0.047(1.20) 0.031(0.80) 0.193(4.90) 0.173(4.40) Maximum Ratings And Electrical Characteristics Dimensions in inches and (millimeters) Ratings at 25 C ambient temperature unless otherwise specified. SYMBOLS VALUE UNITS Power Dissipation at T L =75 C, PD 1.0 W Forward Voltage at I F =200mA VF 1.2 V Junction Temperature Range TJ -55 to + 150 O C -55 to + 150 O C MDD Catalog Number O Storage Temperature Range TS Fig.1 Maximum Continuous Power Derating 1.2 Power Dissipation ( W ) 1.0 0.8 0.6 0.4 0.2 P.C.B. mounted on 0.2 X 0.2" (5 X 5 mm) copper areas pads. 0.0 25 50 75 100 125 150 175 T L ,Lead Temperature (°C) The cruve graph is for reference only http://www.microdiode.com Rev:2024A1 Page :1 1SMAF4728A THRU 1SMAF4777A Zener Voltage - 3.3 to 330 Volts Peak Pulse Power - 1.0 W Ratings And Characteristic Curves Characteristics at Ta = 25°C Zener Voltage Range Type Marking Min(V) Nom(V) 1SMAF4728A 728A 3.10 3.3 1SMAF4729A 729A 3.40 1SMAF4730A 730A 1SMAF4731A Dynamic Impedance (1) V ZT(at I ZT) Reverse Current Admissible Zener Current I ZT Z ZT(at I ZT) IR at V R Max(V) (mA) Max (Ω) Max(μA) (V) I ZM (mA) 3.50 75 10 100 1 285 3.6 3.80 69 10 100 1 263 3.70 3.9 4.10 64 9.0 50 1 243 731A 4.06 4.3 4.56 58 9.0 25 1 219 1SMAF4732A 732A 4.50 4.7 4.93 53 8.0 10 1 203 1SMAF4733A 733A 4.84 5.1 5.36 49 7.0 10 1 186 1SMAF4734A 734A 5.32 5.6 5.92 45 5.0 10 2 170 1SMAF4735A 735A 5.86 6.2 6.51 41 2.0 10 3 154 1SMAF4736A 736A 6.46 6.8 7.18 37 3.5 10 4 140 1SMAF4737A 737A 7.12 7.5 7.88 34 4.0 10 5 127 1SMAF4738A 738A 7.79 8.2 8.67 31 4.5 10 6 116 1SMAF4739A 739A 8.60 9.1 9.59 28 5.0 10 7 104 95 1SMAF4740A 740A 9.50 10 10.5 25 7.0 10 7 1SMAF4741A 741A 10.4 11 11.6 23 8.0 5 8 86 1SMAF4742A 742A 11.4 12 12.6 21 9.0 5 9 79 1SMAF4743A 743A 12.4 13 14.1 19 10 5 10 71 1SMAF4744A 744A 13.8 15 15.8 17 14 5 11 63 58 1SMAF4745A 745A 15.2 16 17.1 16 16 5 12 1SMAF4746A 746A 16.8 18 19.2 14 20 5 13 52 1SMAF4747A 747A 19.0 20 21.2 13 22 5 15 47 1SMAF4748A 748A 20.8 22 23.3 12 23 5 17 43 1SMAF4749A 749A 22.8 24 26.0 11 25 5 18 38 35 1SMAF4750A 750A 25.3 27 28.9 9.5 35 5 21 1SMAF4751A 751A 28.2 30 32.0 8.5 40 5 23 31 1SMAF4752A 752A 31.3 33 34.9 7.5 45 5 25 28 1SMAF4753A 753A 34.2 36 37.9 7.0 50 5 27 26 1SMAF4754A 754A 37.2 39 41.5 6.5 60 5 30 24 1SMAF4755A 755A 40.9 43 45.6 6.0 70 1 32 22 1SMAF4756A 756A 44.9 47 49.8 5.5 80 1 35 20 18 1SMAF4757A 757A 48.6 51 54.0 5.0 95 1 38 1SMAF4758A 758A 53.6 56 58.8 4.5 110 1 42 17 1SMAF4759A 759A 58.9 62 65.6 4.0 125 1 47 15 1SMAF4760A 760A 64.6 68 71.7 3.7 150 1 52 14 1SMAF4761A 761A 71.2 75 78.8 3.3 175 1 56 12 1SMAF4762A 762A 77.9 82 87.0 3.0 200 1 62 11 1SMAF4763A 763A 86.0 91 96.0 2.8 250 1 69 10 9.5 1SMAF4764A 764A 95.0 100 105 2.5 350 1 76 1SMAF4765A 765A 104 110 116 2.3 450 1 84 8.6 1SMAF4766A 766A 114 120 127 2.0 550 1 91 7.8 1SMAF4767A 767A 125 135 142 1.9 700 1 100 7.0 1SMAF4768A 768A 140 150 157 1.7 900 1 110 6.3 1SMAF4769A 769A 155 165 172 1.6 1100 1 120 5.8 1SMAF4770A 770A 170 180 191 1.4 1200 1 135 5.2 4.7 1SMAF4771A 771A 189 200 211 1.2 1400 1 150 1SMAF4772A 772A 209 220 231 1.0 1600 1 165 4.3 1SMAF4773A 773A 229 240 251 1.0 1800 1 180 3.9 1SMAF4774A 774A 249 260 271 1.0 2000 1 190 3.7 775A 269 280 291 1.0 2100 1 205 3.4 776A 289 300 315 1.0 2300 1 230 3.1 777A 313 330 346 1.0 2500 1 250 2.8 1SMAF4775A 1SMAF4776A 1SMAF4777A (1) V ZT is tested with pulses (20 ms) http://www.microdiode.com Rev:2024A1 Page :2 1SMAF4728A THRU 1SMAF4777A Zener Voltage - 3.3 to 330 Volts Peak Pulse Power - 1.0 W Packing information P0 unit:mm P1 d E Item F B A Symbol Tolerance A B C d D D1 D2 E F P P0 P1 T W W1 0.1 0.1 0.1 0.05 2.0 min 0.5 0.1 0.1 0.1 0.1 0.1 0.1 0.3 1.0 SMAF W Carrier width Carrier length Carrier depth Sprocket hole 7" Reel outside diameter 7" Reel inner diameter Feed hole diameter Sprocket hole position Punch hole position Punch hole pitch Sprocket hole pitch Embossment center Overall tape thickness Tape width Reel width P D2 T D1 C W1 D 2.80 4.75 1.42 1.50 178.00 54.40 13.00 1.75 5.05 4.00 4.00 2.00 0.30 8.00 12.30 Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above. Reel packing PACKAGE SMAF REEL SIZE 7" REEL (pcs) COMPONENT SPACING (m/m) BOX (pcs) INNER BOX (m/m) REEL DIA, (m/m) CARTON SIZE (m/m) CARTON (pcs) APPROX. GROSS WEIGHT (kg) 3,000 4.0 6,000 210*208*203 178 400*265*400 120,000 10.0 Suggested Pad Layout Symbol Unit (mm) Unit (inch) A 1.8 0.071 B 1.6 3.8 0.150 D 2.2 0.087 E 5.4 0.213 C http://www.microdiode.com 0.063 Rev:2024A1 Page :5
1SMAF4733A 价格&库存
很抱歉,暂时无法提供与“1SMAF4733A”相匹配的价格&库存,您可以联系我们找货
1SMAF4733A
  • 10+0.25937
  • 100+0.21403
  • 600+0.19200
  • 1200+0.18912
  • 3000+0.14438
库存:2885
1SMAF4733A
  • 10+0.31125
  • 100+0.25402
  • 300+0.22540
  • 3000+0.16589
  • 6000+0.14878
  • 9000+0.14018
库存:4035
1SMAF4733A
  • 20+0.55440
  • 100+0.33070
  • 800+0.23150
  • 3000+0.16540
  • 6000+0.15710
  • 30000+0.14550
